主题中讨论的其他器件:UNIFLASH
您好
我可以问问是否有 AM64 USB DFU?
我的客户在刷写过程中遇到问题、请参阅本手册。
我写在日志下面
(在 cfg 中使用 hs_fs 图像)
c:\ti\mcu_plus_sdk_am64x_08_06_00_43\tools\boot>python usb_dfu_uniflash.py --cfg=sbl_prebuilt/am64x-evm/default_dfu_ospi_hsfs.cfg Parsing config file ... Parsing config file ... SUCCESS. Found 4 command(s) !!! Executing command 1 of 4 ... Found flash writer ... sending sbl_prebuilt/am64x-evm/sbl_dfu_uniflash.release.hs_fs.tiimage ---------------------------------------------------------------------------- Executing DFU command with alt_setting=0 interface=0 transfer_size=512 ---------------------------------------------------------------------------- dfu-util 0.8 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2014 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to dfu-util@lists.gnumonks.org Invalid DFU suffix signature A valid DFU suffix will be required in a future dfu-util release!!! Opening DFU capable USB device... ID 0451:6165 Run-time device DFU version 0110 Claiming USB DFU Interface... Setting Alternate Setting #0 ... Determining device status: state = dfuIDLE, status = 0 dfuIDLE, continuing DFU mode device DFU version 0110 Copying data from PC to DFU device Download [=========================] 100% 323317 bytes Download done. state(6) = dfuMANIFEST-SYNC, status(0) = No error condition is present state(2) = dfuIDLE, status(0) = No error condition is present Done! Sent flashwriter sbl_prebuilt/am64x-evm/sbl_dfu_uniflash.release.hs_fs.tiimage of size 323317 bytes in 1.57s. Bandwidth = 201.11kbps Executing command 2 of 4 ... Command arguments : --operation=flash-phy-tuning-data ------------------------------------------------------ Waiting for DFU device to be enumerated .... ------------------------------------------------------ ------------------------------------------------------ Waiting for DFU device to be enumerated .... ------------------------------------------------------ ------------------------------------------------------ Waiting for DFU device to be enumerated .... ------------------------------------------------------ ------------------------------------------------------ Waiting for DFU device to be enumerated .... ------------------------------------------------------ ------------------------------------------------------ Waiting for DFU device to be enumerated .... ------------------------------------------------------ ------------------------------------------------------ Waiting for DFU device to be enumerated .... ------------------------------------------------------ ------------------------------------------------------ Waiting for DFU device to be enumerated .... ------------------------------------------------------
在下面, 等待 DFU 设备被枚举... 继续宣传。
我们可以如何进行下一步?
您能告诉我您的意见和建议吗?
dfu-util -i 就是这、
c:\ti\mcu_plus_sdk_am64x_08_06_00_43\tools\boot\sbl_prebuilt\am64x-evm>dfu-util -l dfu-util 0.8 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2014 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to dfu-util@lists.gnumonks.org Found DFU: [0451:6165] ver=0200, devnum=35, cfg=1, intf=0, alt=1, name="SocId", serial="01.00.00.00" Found DFU: [0451:6165] ver=0200, devnum=35, cfg=1, intf=0, alt=0, name="bootloader", serial="01.00.00.00"
GR
