[参考译文] SK-AM62:无法从用户空间导出和配置 GPIO
Guru**** 2551750 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1251645/sk-am62-unable-to-export-and-configure-gpio-from-userspace
器件型号:SK-AM62
主题中讨论的其他器件:AM625
我们正在使用基于 am62xx-SK 的定制电路板。
我们需要为特定应用从用户空间导出和控制多个 GPIO。
我更改了 DTS 、并将可用 GPIO 的引脚添加到 MAIN_GPIO0、MAIN_GPIO1节点。   我无法从用户空间导出空闲 GPIO 引脚(40引脚)。
当我尝试导出 GPIO 时出现以下错误。
回声35 >/sys/class/gpio/export
export_store:无效的 GPIO 35。
请找到我的 DTS 更改可作为源代码使用。
k3_am625_aurel.dtsi
// SPDX-License-Identifier: GPL-2.0
 * Common dtsi for AM62x SK and derivatives
 * Copyright (C) 2021-2022 Texas Instruments Incorporated - https://www.ti.com/
	aliases {
		serial2 = &main_uart0;
		mmc0 = &sdhci0;
		usb0 = &usb0;
		usb1 = &usb1;
		ethernet0 = &cpsw_port1;
		ethernet1 = &cpsw_port2;
	chosen {
		stdout-path = "serial2:115200n8";
		bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
	opp-table {
		/* Add 1.4GHz OPP for am625-sk board. Requires VDD_CORE to be at 0.85V */
		opp-1400000000 {
			opp-hz = /bits/ 64 <1400000000>;
			opp-supported-hw = <0x01 0x0004>;
			clock-latency-ns = <6000000>;
	memory@80000000 {
		device_type = "memory";
		/* 512MB RAM for aurel board */
		reg = <0x00000000 0x80000000 0x00000000 0x20000000>;
	reserved-memory {
		#address-cells = <2>;
		#size-cells = <2>;
		ranges;
		rtos_ipc_memory_region: ipc-memories@9c800000 {
			compatible = "shared-dma-pool";
			reg = <0x00 0x9c800000 0x00 0x00300000>;
			no-map;
		mcu_m4fss_dma_memory_region: m4f-dma-memory@9cb00000 {
			reg = <0x00 0x9cb00000 0x00 0x100000>;
			no-map;
		mcu_m4fss_memory_region: m4f-memory@9cc00000 {
			reg = <0x00 0x9cc00000 0x00 0xe00000>;
			no-map;
		wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9da00000 {
			reg = <0x00 0x9da00000 0x00 0x00100000>;
			no-map;
		wkup_r5fss0_core0_memory_region: r5f-memory@9db00000 {
			reg = <0x00 0x9db00000 0x00 0x00c00000>;
			no-map;
		lpm_ctx_ddr: lpm-memory@9e700000 {
			reg = <0x00 0x9e700000 0x00 0x80000>;
			alignment = <0x1000>;
		secure_tfa_ddr: tfa@9e780000 {
			reg = <0x00 0x9e780000 0x00 0x80000>;
			no-map;
		secure_ddr: optee@9e800000 {
			reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */
			no-map;
	vmain_pd: regulator-0 {
		/* TPS65988 PD CONTROLLER OUTPUT */
		compatible = "regulator-fixed";
		regulator-name = "vmain_pd";
		regulator-min-microvolt = <5000000>;
		regulator-max-microvolt = <5000000>;
		regulator-always-on;
		regulator-boot-on;
	vcc_5v0: regulator-1 {
		/* Output of TPS630702 */
		regulator-name = "vcc_5v0";
		vin-supply = <&vmain_pd>;
		regulator-boot-on;
	vcc_3v3_sys: regulator-2 {
		/* output of LM61460-Q1 */
		regulator-name = "vcc_3v3_sys";
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
		regulator-boot-on;
	vdd_mmc1: regulator-3 {
		/* TPS22918DBVR */
/*		compatible = "regulator-fixed";
		regulator-name = "vdd_mmc1";
		regulator-boot-on;
		enable-active-high;
		vin-supply = <&vcc_3v3_sys>;
		gpio = <&exp1 3 GPIO_ACTIVE_HIGH>;
	vcc_1v8: regulator-7 {
		/* output of TPS6282518DMQ */
		regulator-name = "vcc_1v8";
		regulator-min-microvolt = <1800000>;
		regulator-max-microvolt = <1800000>;
		regulator-boot-on;
	tlv320_mclk: clk-0 {
		#clock-cells = <0>;
		compatible = "fixed-clock";
		clock-frequency = <12288000>;
//	main_pwm7: dmtimer-main-pwm-7 {
//		pinctrl-0 = <&usr_led_pins_default>;
//		pinctrl-names = "default";
//		compatible = "ti,omap-dmtimer-pwm";
//		#pwm-cells = <3>;
//		ti,timers = <&main_timer7>;
&main_pmx0 {
    main_gpio0_pins_default: main_gpio0_pins_default {
		pinctrl-single,pins = <
            		AM62X_IOPAD(0x0000, PIN_OUTPUT, 7)   /* (H24)  OSPI0_CLK.GPIO0_0       */ /* MPU_RS485_SUPPLY2_EN */
            		AM62X_IOPAD(0x0004, PIN_OUTPUT, 7)   /* (G25)  OSPI0_LBCLKO.GPIO0_1    */ /* MPU_NAC_1_ENABLE */
            		AM62X_IOPAD(0x0008, PIN_OUTPUT, 7)   /* (J24)  OSPI0_DQS.GPIO0_2       */ /* MPU_NORMAL_RELAY2_EN */
			AM62X_IOPAD(0x000c, PIN_OUTPUT, 7)   /* (E25)  OSPI0_D0.GPIO0_3        */ /* RS485_1_MPU_OPWR_STS */
			AM62X_IOPAD(0x0010, PIN_OUTPUT, 7)   /* (G24)  OSPI0_D1.GPIO0_4        */
			AM62X_IOPAD(0x0014, PIN_OUTPUT, 7)   /* (F25)  OSPI0_D2.GPIO0_5        */
			AM62X_IOPAD(0x0018, PIN_OUTPUT, 7)   /* (F24)  OSPI0_D3.GPIO0_6        */ /*  MPU_FS_ALARM_SIG */
			AM62X_IOPAD(0x001c, PIN_OUTPUT, 7)   /* (J23)  OSPI0_D4.GPIO0_7        */ /* MPU_RS485_DEn1 */
			AM62X_IOPAD(0x0020, PIN_OUTPUT, 7)   /* (J25)  OSPI0_D5.GPIO0_8        */ /* RS485_2_OPWR_STATUS */
			AM62X_IOPAD(0x0024, PIN_OUTPUT, 7)   /* (H25)  OSPI0_D6.GPIO0_9        */ /*  MPU_CAN0_MODE_SEL */
			AM62X_IOPAD(0x0028, PIN_OUTPUT, 7)   /* (J22)  OSPI0_D7.GPIO0_10       */
	                AM62X_IOPAD(0x002c, PIN_OUTPUT, 7)   /* (F23)  OSPI0_CSn0.GPIO0_11     */ /* MPU_NAC_1_ FET_DRIVE */
		        AM62X_IOPAD(0x0030, PIN_OUTPUT, 7)   /* (G21)  OSPI0_CSn1.GPIO0_12    */ /* MPU_NAC_2_PF_ENABLE */
		        AM62X_IOPAD(0x0034, PIN_OUTPUT, 7)   /* (H21)  OSPI0_CSn2.GPIO0_13    */ /* MPU_NAC_2_FET_DRIVE */
			AM62X_IOPAD(0x0038, PIN_OUTPUT, 7)   /* (E24)  OSPI0_CSn3.GPIO0_14     *//* MPU_AUX_ENABLE */
		          AM62X_IOPAD(0x110,  PIN_INPUT,  7)   /* (C25)  RS485_2_MPU_2_OPWR_STS */ /* MPU_NAC_2_ENABLE    */
			AM62X_IOPAD(0x0174, PIN_OUTPUT, 7)   /* (AD21) RGMII2_TD2.GPIO0_91     */
            		AM62X_IOPAD(0x124,  PIN_OUTPUT, 7)   /* (A23)  MMC2_SDCD.GPIO0_71      */ /*  MPU_LCD_RST */
		          AM62X_IOPAD(0x0154, PIN_OUTPUT, 7)   /* (AB16) RGMII1_RD2.GPIO0_83     */ /* MPU_AUX_1_EN */
		          AM62X_IOPAD(0x114,  PIN_OUTPUT, 7)   /* (B24)  EXT_NW_MPU_GPIO1       */ /* MPU_AUX_2_EN        */
            		AM62X_IOPAD(0x128,  PIN_INPUT,  7)   /* (B23)  MMC2_SDWP.GPIO0_72      */ /*  GENERIC_DI2_MPU_STS */
			AM62X_IOPAD(0x003c, PIN_OUTPUT, 7)   /* (M25) GPMC0_AD0.GPIO0_15          */ /* BOOT_MODE_0-15 */
			AM62X_IOPAD(0x0040, PIN_OUTPUT, 7)   /* (N23) GPMC0_AD1.GPIO0_16          */
			AM62X_IOPAD(0x0044, PIN_OUTPUT, 7)   /* (N24) GPMC0_AD2.GPIO0_17          */
			AM62X_IOPAD(0x0048, PIN_OUTPUT, 7)   /* (N25) GPMC0_AD3.GPIO0_18          */
			AM62X_IOPAD(0x004c, PIN_OUTPUT, 7)   /* (P24) GPMC0_AD4.GPIO0_19          */
			AM62X_IOPAD(0x0050, PIN_OUTPUT, 7)   /* (P22) GPMC0_AD5.GPIO0_20          */
			AM62X_IOPAD(0x0054, PIN_OUTPUT, 7)   /* (P21) GPMC0_AD6.GPIO0_21          */
			AM62X_IOPAD(0x0058, PIN_OUTPUT, 7)   /* (R23) GPMC0_AD7.GPIO0_22          */
//			AM62X_IOPAD(0x005c, PIN_OUTPUT, 7)   /* (R24) GPMC0_AD8.GPIO0_23          */
//			AM62X_IOPAD(0x0060, PIN_OUTPUT, 7)   /* (R25) GPMC0_AD9.GPIO0_24          */
//			AM62X_IOPAD(0x0068, PIN_OUTPUT, 7)   /* (R21) GPMC0_AD11.GPIO0_26         */
//			AM62X_IOPAD(0x006c, PIN_OUTPUT, 7)   /* (T22) GPMC0_AD12.GPIO0_27         */
//			AM62X_IOPAD(0x0070, PIN_OUTPUT, 7)   /* (T24) GPMC0_AD13.GPIO0_28         */
//			AM62X_IOPAD(0x0074, PIN_OUTPUT, 7)   /* (U25) GPMC0_AD14.GPIO0_29         */
//			AM62X_IOPAD(0x0078, PIN_OUTPUT, 7)   /* (U24) GPMC0_AD15.GPIO0_30         */
            		AM62X_IOPAD(0x007c, PIN_OUTPUT, 7)   /* (P25)  GPMC0_CLK.GPIO0_31      */ /* MPU_SYS_GF_EN */
	        	AM62X_IOPAD(0x0084, PIN_OUTPUT, 7)   /* (L23)  GPMC0_ADVn_ALE.GPIO0_32 */ /* MPU_NAC_1_PF_ENABLE*/
			AM62X_IOPAD(0x0088, PIN_OUTPUT, 7)   /* (L24)  GPMC0_OEn_REn.GPIO0_33  */
			AM62X_IOPAD(0x008c, PIN_OUTPUT, 7)   /* (L25)  GPMC0_WEn.GPIO0_34      */
			AM62X_IOPAD(0x0090, PIN_OUTPUT, 7)   /* (M24)  GPMC0_BE0n_CLE.GPIO0_35 */ /* MPU_ETH1_GFD_EN */
            		AM62X_IOPAD(0x0094, PIN_OUTPUT, 7)   /* (N20) GPMC0_BE1n.GPIO0_36         */ /* MPU_ETH2_GFD_EN */
            		AM62X_IOPAD(0x0098, PIN_OUTPUT, 7)   /* (U23)  GPMC0_WAIT0.GPIO0_37    */ /* MPU_TRBL_RLY_EN_n */
			AM62X_IOPAD(0x009c, PIN_INPUT,  7)   /* (V25)  GPMC0_WAIT1.GPIO0_38    */ /* MPU_RS485_DEn2/MCASP1_FSX - Pulled Down on HW Base Board*/
            		AM62X_IOPAD(0x00a0, PIN_OUTPUT, 7)   /* (K25)  GPMC0_WPn.GPIO0_39         */ /*MPU_GENERIC_1_INPUT_CTRL*/
            		AM62X_IOPAD(0x00a4, PIN_INPUT,  7)   /* (M22)  GPMC0_DIR.GPIO0_40      */ /* AUX_MPU_OC_FAULT_n */
            		AM62X_IOPAD(0x00a8, PIN_OUTPUT, 7)   /* (M21)  GPMC0_CSn0.GPIO0_41     */ /* MPU_RS485_SUPPLY1_ENABLE */
			AM62X_IOPAD(0x00ac, PIN_OUTPUT, 7)   /* (L21)  GPMC0_CSn1.GPIO0_42     */ /* MPU_FS_TRBL_SIG */
			AM62X_IOPAD(0x00b8, PIN_OUTPUT, 7)   /* (U22)  VOUT0_DATA0.GPIO0_45       *//*MPU_VPP_ENABLE*/
			AM62X_IOPAD(0x00bc, PIN_OUTPUT, 7)   /* (V24)  VOUT0_DATA1.GPIO0_46       *//*MPU_PMIC_VSEL_SD*/
			AM62X_IOPAD(0x00c0, PIN_OUTPUT, 7)   /* (W25)  VOUT0_DATA2.GPIO0_47       */ /* MPU_WC */
			AM62X_IOPAD(0x00c4, PIN_OUTPUT, 7)   /* (W24)  VOUT0_DATA3.GPIO0_48       */ /* MPU_WDT_ENABLE */
			AM62X_IOPAD(0x00d0, PIN_OUTPUT, 7)   /* (Y23)  VOUT0_DATA6.GPIO0_51       */
			AM62X_IOPAD(0x00d4, PIN_OUTPUT, 7)   /* (AA25) VOUT0_DATA7.GPIO0_52       */
			AM62X_IOPAD(0x00d8, PIN_OUTPUT, 7)   /* (V21)  VOUT0_DATA8.GPIO0_53       *//*MPU_PMIC_EN*/
			AM62X_IOPAD(0x00dc, PIN_OUTPUT, 7)   /* (W21)  VOUT0_DATA9.GPIO0_54       *//*MPU_LCD_RST*/
			AM62X_IOPAD(0x013c, PIN_OUTPUT, 7)   /* (AE18) RGMII1_TD2.GPIO0_77        */
			AM62X_IOPAD(0x0140, PIN_OUTPUT, 7)   /* (AD18) RGMII1_TD3.GPIO0_78        */
			AM62X_IOPAD(0x0158, PIN_OUTPUT, 7)   /* (AA15) RGMII1_RD3.GPIO0_84        */
            		AM62X_IOPAD(0x0120, PIN_OUTPUT, 7)   /* (C24)  GPIO0_70 MPU_FS_ALARM_SIG  */
            		AM62X_IOPAD(0x118,  PIN_INPUT,  7)   /* (D25)  USB1_MPU_OVR_CUR_STSn   */ /*  This should be input it is connected to OC of TPS2051 - GPIO0_69*/
	main_gpio1_pins_default: main_gpio1_pins_default {
			AM62X_IOPAD(0x0178, PIN_INPUT,  7)   /* (AC20) RGMII2_TD3.GPIO1_0    */ /* MPU_LCD_INTR */
			AM62X_IOPAD(0x018c, PIN_INPUT, 7)    /* (AC21) RGMII2_RD2.GPIO1_5    */ /* MCU_eMMC_RST_N */
            		AM62X_IOPAD(0x0190, PIN_INPUT,  7)   /* (AE22) RGMII2_RD3.GPIO1_6    */ /* MPU_CLK_BUFFER_EN */
            		AM62X_IOPAD(0x019c, PIN_OUTPUT, 7)   /* (B18)  MCASP0_AXR1.GPIO1_9   */ /* MPU_NORMAL_RELAY1_EN */
            		AM62X_IOPAD(0x01a0, PIN_OUTPUT, 7)   /* (E18) MCASP0_AXR0.GPIO1_10   */ /* MPU_GENERIC_2_INPUT_CTRL */
			AM62X_IOPAD(0x01a4, PIN_OUTPUT, 7)   /* (B20)  MCASP0_ACLKX.GPIO1_11 */
			AM62X_IOPAD(0x01a8, PIN_OUTPUT, 7)   /* (D20)  MCASP0_AFSX.GPIO1_12  */	/* MPU_ALARM_RELAY_EN */
            		AM62X_IOPAD(0x01b8, PIN_OUTPUT, 7)   /* (C13)  SPI0_CS1.GPIO1_16     */ /* MPU_RS485_REn    */
            		AM62X_IOPAD(0x01c4, PIN_OUTPUT, 7)   /* (B14) SPI0_D1.GPIO1_19       */ /* MPU_CAN1_MODE_SEL*/
	main_uart0_pins_default: main-uart0-pins-default {
			AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14) UART0_RXD */
			AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */
  	main_uart2_pins_default: main_uart2-pins_default {
			AM62X_IOPAD(0x0224, PIN_INPUT,  3)   /* (D22) MMC1_DAT3.UART2_RXD    */ /* RS485_MPU_RXD */
			AM62X_IOPAD(0x0228, PIN_OUTPUT, 3)   /* (C21) MMC1_DAT2.UART2_TXD    */ /* MPU_RS485_TXD */
			AM62X_IOPAD(0x0104, PIN_INPUT,  4)   /* (AC24) VOUT0_PCLK.UART2_CTSn */ /* RS485_MPU_CTS */
			AM62X_IOPAD(0x0100, PIN_OUTPUT, 4)   /* (AC25) VOUT0_VSYNC.UART2_RTSn*/ /* MPU_RS485_RTS */
	main_i2c0_pins_default: main-i2c0-pins-default {
			AM62X_IOPAD(0x1e0, PIN_INPUT_PULLUP, 0) /* (B16) I2C0_SCL */
			AM62X_IOPAD(0x1e4, PIN_INPUT_PULLUP, 0) /* (A16) I2C0_SDA */
	main_i2c1_pins_default: main-i2c1-pins-default {
			AM62X_IOPAD(0x1e8, PIN_INPUT_PULLUP, 0) /* (B17) I2C1_SCL */
			AM62X_IOPAD(0x1ec, PIN_INPUT_PULLUP, 0) /* (A17) I2C1_SDA */
	main_i2c2_pins_default: main-i2c2-pins-default {
			AM62X_IOPAD(0x0b0, PIN_INPUT_PULLUP, 1) /* (K22) GPMC0_CSn2.I2C2_SCL */
			AM62X_IOPAD(0x0b4, PIN_INPUT_PULLUP, 1) /* (K24) GPMC0_CSn3.I2C2_SDA */
	main_mmc0_pins_default: main-mmc0-pins-default {
			AM62X_IOPAD(0x220, PIN_INPUT, 0) /* (Y3) MMC0_CMD */
			AM62X_IOPAD(0x218, PIN_INPUT, 0) /* (AB1) MMC0_CLK */
			AM62X_IOPAD(0x214, PIN_INPUT, 0) /* (AA2) MMC0_DAT0 */
			AM62X_IOPAD(0x210, PIN_INPUT, 0) /* (AA1) MMC0_DAT1 */
			AM62X_IOPAD(0x20c, PIN_INPUT, 0) /* (AA3) MMC0_DAT2 */
			AM62X_IOPAD(0x208, PIN_INPUT, 0) /* (Y4) MMC0_DAT3 */
			AM62X_IOPAD(0x204, PIN_INPUT, 0) /* (AB2) MMC0_DAT4 */
			AM62X_IOPAD(0x200, PIN_INPUT, 0) /* (AC1) MMC0_DAT5 */
			AM62X_IOPAD(0x1fc, PIN_INPUT, 0) /* (AD2) MMC0_DAT6 */
			AM62X_IOPAD(0x1f8, PIN_INPUT, 0) /* (AC2) MMC0_DAT7 */
	main_mdio1_pins_default: main-mdio1-pins-default {
			AM62X_IOPAD(0x160, PIN_OUTPUT, 0) /* (AD24) MDIO0_MDC */
			AM62X_IOPAD(0x15c, PIN_INPUT, 0) /* (AB22) MDIO0_MDIO */
//myrmii1_pins_default: myrmii1-pins-default {
	main_rmii1_pins_default: main-rmii1-pins-default{
		AM62X_IOPAD(0x0130, PIN_INPUT, 1) /* (AE19) RGMII1_TXC.RMII1_CRS_DV */
		AM62X_IOPAD(0x0148, PIN_INPUT, 1) /* (AD17) RGMII1_RXC.RMII1_REF_CLK */
		AM62X_IOPAD(0x014c, PIN_INPUT, 1) /* (AB17) RGMII1_RD0.RMII1_RXD0 */
		AM62X_IOPAD(0x0150, PIN_INPUT, 1) /* (AC17) RGMII1_RD1.RMII1_RXD1 */
		AM62X_IOPAD(0x0144, PIN_INPUT, 1) /* (AE17) RGMII1_RX_CTL.RMII1_RX_ER */
		AM62X_IOPAD(0x0134, PIN_OUTPUT, 1) /* (AE20) RGMII1_TD0.RMII1_TXD0 */
		AM62X_IOPAD(0x0138, PIN_OUTPUT, 1) /* (AD20) RGMII1_TD1.RMII1_TXD1 */
		AM62X_IOPAD(0x012c, PIN_OUTPUT, 1) /* (AD19) RGMII1_TX_CTL.RMII1_TX_EN */
	//myrmii2_pins_default: myrmii2-pins-default {
          main_rmii2_pins_default: main-rmii2-pins-default{
		AM62X_IOPAD(0x0168, PIN_INPUT, 1) /* (AE21) RGMII2_TXC.RMII2_CRS_DV */
		AM62X_IOPAD(0x0180, PIN_INPUT, 1) /* (AD23) RGMII2_RXC.RMII2_REF_CLK */
		AM62X_IOPAD(0x0184, PIN_INPUT, 1) /* (AE23) RGMII2_RD0.RMII2_RXD0 */
		AM62X_IOPAD(0x0188, PIN_INPUT, 1) /* (AB20) RGMII2_RD1.RMII2_RXD1 */
		AM62X_IOPAD(0x017c, PIN_INPUT, 1) /* (AD22) RGMII2_RX_CTL.RMII2_RX_ER */
		AM62X_IOPAD(0x016c, PIN_OUTPUT, 1) /* (Y18) RGMII2_TD0.RMII2_TXD0 */
		AM62X_IOPAD(0x0170, PIN_OUTPUT, 1) /* (AA18) RGMII2_TD1.RMII2_TXD1 */
		AM62X_IOPAD(0x0164, PIN_OUTPUT, 1) /* (AA19) RGMII2_TX_CTL.RMII2_TX_EN */
//ain_dss0_pins_default: main-dss0-pins-default {
//pinctrl-single,pins = <
//	AM62X_IOPAD(0x0100, PIN_OUTPUT, 0) /* (AC25) VOUT0_VSYNC */
//	AM62X_IOPAD(0x00f8, PIN_OUTPUT, 0) /* (AB24) VOUT0_HSYNC */
//	AM62X_IOPAD(0x0104, PIN_OUTPUT, 0) /* (AC24) VOUT0_PCLK */
//	AM62X_IOPAD(0x00fc, PIN_OUTPUT, 0) /* (Y20) VOUT0_DE */
//	AM62X_IOPAD(0x00b8, PIN_OUTPUT, 0) /* (U22) VOUT0_DATA0 */
//	AM62X_IOPAD(0x00bc, PIN_OUTPUT, 0) /* (V24) VOUT0_DATA1 */
//	AM62X_IOPAD(0x00c0, PIN_OUTPUT, 0) /* (W25) VOUT0_DATA2 */
//	AM62X_IOPAD(0x00c4, PIN_OUTPUT, 0) /* (W24) VOUT0_DATA3 */
//	AM62X_IOPAD(0x00c8, PIN_OUTPUT, 0) /* (Y25) VOUT0_DATA4 */
//	AM62X_IOPAD(0x00cc, PIN_OUTPUT, 0) /* (Y24) VOUT0_DATA5 */
//	AM62X_IOPAD(0x00d0, PIN_OUTPUT, 0) /* (Y23) VOUT0_DATA6 */
//	AM62X_IOPAD(0x00d4, PIN_OUTPUT, 0) /* (AA25) VOUT0_DATA7 */
//	AM62X_IOPAD(0x00d8, PIN_OUTPUT, 0) /* (V21) VOUT0_DATA8 */
//	AM62X_IOPAD(0x00dc, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA9 */
//	AM62X_IOPAD(0x00e0, PIN_OUTPUT, 0) /* (V20) VOUT0_DATA10 */
//	AM62X_IOPAD(0x00e4, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA11 */
//	AM62X_IOPAD(0x00e8, PIN_OUTPUT, 0) /* (AB25) VOUT0_DATA12 */
//	AM62X_IOPAD(0x00ec, PIN_OUTPUT, 0) /* (AA24) VOUT0_DATA13 */
//	AM62X_IOPAD(0x00f0, PIN_OUTPUT, 0) /* (Y22) VOUT0_DATA14 */
//	AM62X_IOPAD(0x00f4, PIN_OUTPUT, 0) /* (AA21) VOUT0_DATA15 */
//	AM62X_IOPAD(0x005c, PIN_OUTPUT, 1) /* (R24) GPMC0_AD8.VOUT0_DATA16 */
//	AM62X_IOPAD(0x0060, PIN_OUTPUT, 1) /* (R25) GPMC0_AD9.VOUT0_DATA17 */
//	AM62X_IOPAD(0x0064, PIN_OUTPUT, 1) /* (T25) GPMC0_AD10.VOUT0_DATA18 */
//	AM62X_IOPAD(0x0068, PIN_OUTPUT, 1) /* (R21) GPMC0_AD11.VOUT0_DATA19 */
//	AM62X_IOPAD(0x006c, PIN_OUTPUT, 1) /* (T22) GPMC0_AD12.VOUT0_DATA20 */
//	AM62X_IOPAD(0x0070, PIN_OUTPUT, 1) /* (T24) GPMC0_AD13.VOUT0_DATA21 */
//	AM62X_IOPAD(0x0074, PIN_OUTPUT, 1) /* (U25) GPMC0_AD14.VOUT0_DATA22 */
//	AM62X_IOPAD(0x0078, PIN_OUTPUT, 1) /* (U24) GPMC0_AD15.VOUT0_DATA23 */
//	vdd_sd_dv_pins_default: vdd-sd-dv-pins-default {
//		pinctrl-single,pins = <
//			AM62X_IOPAD(0x07c, PIN_OUTPUT, 7) /* (P25) GPMC0_CLK.GPIO0_31 */
	main_usb1_pins_default: main-usb1-pins-default {
			AM62X_IOPAD(0x0258, PIN_OUTPUT, 0) /* (F18) USB1_DRVVBUS */
&wkup_uart0 {
	/* WKUP UART0 is used by DM firmware */
	status = "reserved";
&mcu_uart0 {
	status = "disabled";
&main_uart0 {
	pinctrl-0 = <&main_uart0_pins_default>;
&main_uart1 {
	/* Main UART1 is used by TIFS firmware */
&main_uart2 {
    pinctrl-0 = <&main_uart2_pins_default>;
    compatible = "ti,omap2-uart";
    rs485-rts-delay = <2 2>;
    rs485-rts-active-high;
    linux,rs485-enabled-at-boot-time;
    status = "enabled";
&main_uart3 {
&main_uart4 {
&main_uart5 {
&main_uart6 {
&mcu_i2c0 {
&wkup_i2c0 {
&main_i2c0 {
	pinctrl-0 = <&main_i2c0_pins_default>;
	clock-frequency = <400000>;
	typec_pd: usb-pd@3f {
		compatible = "ti,tps6598x";
		reg = <0x3f>;
		connector {
			ports {
				#address-cells = <1>;
				#size-cells = <0>;
				port@1 {
					reg = <1>;
					usb_con_hs: endpoint {
						remote-endpoint = <&typec_hs>;
&main_i2c1 {
	pinctrl-0 = <&main_i2c1_pins_default>;
	clock-frequency = <100000>;
&main_i2c2 {
&main_i2c3 {
&main_gpio0 {
	pinctrl-0 = <&main_gpio0_pins_default>;
	status = "okay";
&main_gpio1 {
	pinctrl-0 = <&main_gpio1_pins_default>;
	status = "okay";
&sdhci0 {
	pinctrl-0 = <&main_mmc0_pins_default>;
	ti,driver-strength-ohm = <50>;
	disable-wp;
&usbss0 {
	ti,vbus-divider;
&usb0 {
	#size-cells = <0>;
	usb-role-switch;
	port@1 {
		reg = <1>;
		typec_hs: endpoint {
			remote-endpoint = <&usb_con_hs>;
&usb1 {
	dr_mode = "host";
	pinctrl-0 = <&main_usb1_pins_default>;
&cpsw3g {
	pinctrl-0 = <&main_mdio1_pins_default
		     &main_rmii1_pins_default
		     &main_rmii2_pins_default>;
&cpsw_port1 {
	phy-mode = "rmii";
	phy-handle = <&cpsw3g_phy0>;
&cpsw_port2 {
	phy-mode = "rmii";
	phy-handle = <&cpsw3g_phy1>;
&cpsw3g_mdio {
	cpsw3g_phy0: ethernet-phy@3 {
		reg = <0x03>;
//ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
//ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
		ti,min-output-impedance;
	cpsw3g_phy1: ethernet-phy@1 {
	reg = <0x05>;
//&dss {
//	pinctrl-0 = <&main_dss0_pins_default>;
&mcasp0 {
&mcasp1 {
&mcasp2 {
&mailbox0_cluster0 {
	mbox_m4_0: mbox-m4-0 {
		ti,mbox-rx = <0 0 0>;
		ti,mbox-tx = <1 0 0>;
	mbox_r5_0: mbox-r5-0 {
		ti,mbox-rx = <2 0 0>;
		ti,mbox-tx = <3 0 0>;
&ospi0 {
	pinctrl-0 = <&ospi0_pins_default>;
&mcu_m4fss {
	mboxes = <&mailbox0_cluster0 &mbox_m4_0>;
	memory-region = <&mcu_m4fss_dma_memory_region>,
			<&mcu_m4fss_memory_region>;
&wkup_r5fss0_core0 {
	mboxes = <&mailbox0_cluster0 &mbox_r5_0>;
	memory-region = <&wkup_r5fss0_core0_dma_memory_region>,
			<&wkup_r5fss0_core0_memory_region>;
&mcu_rti0 {
	/* MCU RTI0 is used by M4F firmware */
&wkup_rti0 {
	/* WKUP RTI0 is used by DM firmware */
&epwm0 {
&epwm1 {
&epwm2 {
&ecap0_pwm {
&ecap1_pwm {
&ecap2_pwm {
am62xx-fsp.dts
 * AM625 SK: www.ti.com/.../sprr448
/dts-v1/;
#include <dt-bindings/pinctrl/k3.h>
#include <dt-bindings/leds/common.h>
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/net/ti-dp83867.h>
#include "ti/k3-am625.dtsi"
#include "k3_am625_aurel.dtsi"
//#include "ti/k3-am62x-sk-common.dtsi"
	compatible =  "ti,am625-aurel-v0.7", "ti,am625"; //03-Nov-2022
	model = "Aurel-v0.7180723-04"; //platform-mmddyy-revision
	/delete-node/cpu@2; //Disabling 2 CPU cores
	/delete-node/cpu@3;
	transceiver1: can-phy0 {
		compatible = "ti,tcan1042";
		#phy-cells = <0>;
		max-bitrate = <5000000>;
	display {
                                compatible = "microtips,13-101hieb0hf0-s";
                                * Note that the OLDI TX 0 transmits the odd set of pixels
                                * while the OLDI TX 1 transmits the even set. This is a
                                * fixed configuration in the IP integration and is not
                                * changeable. The properties, "dual-lvds-odd-pixels" and
                                * "dual-lvds-even-pixels" have been used to merely
                                * identify if a Dual Link configuration is required.
                                * Swapping them will not make any difference.
                                port@0 {
                                        dual-lvds-odd-pixels;
                                        lcd_in0: endpoint {
                                                remote-endpoint = <&oldi_out0>;
                                port@1 {
                                        dual-lvds-even-pixels;
                                        lcd_in1: endpoint {
                                                remote-endpoint = <&oldi_out1>;
//		watchdog: watchdog {
//	        /* TPS3431 */
//	        compatible = "linux,wdt-gpio";
//	        gpios = <&main_gpio1 45 GPIO_ACTIVE_LOW>;
//	        hw_algo = "toggle";
	        /* mGaik -> Keep this only if watchdog timer cannot be disabled and you want driver to keep toggling the signal without a APP. */
//        	always-running;
	        /* mGaik -> CAP at CWD input of TPS3431 is at 470nF making Reset timeout at 36.433 Sec */
	        /* Ideal 36433, but we pet at 36000 mSec rate bit faster than time out, this ensure if we cross 36000 then we do see WDT trigger in */
//	        hw_margin_ms = <36000>; //36-Sec
//	        status = "okay";
&mcu_pmx0 {
	mcu_i2c0_pins_default: mcu-i2c0-pins-default {
			AM62X_MCU_IOPAD(0x044, PIN_INPUT_PULLUP, 0) 	/* (A8) MCU_I2C0_SCL */
			AM62X_MCU_IOPAD(0x048, PIN_INPUT_PULLUP, 0) 	/* (D10) MCU_I2C0_SDA */
	mcu_mcan1_pins_default: mcu_mcan0_pins_default {
			AM62X_MCU_IOPAD(0x0038, PIN_INPUT, 0)  /* (B3) MCU_MCAN0_RX */
			AM62X_MCU_IOPAD(0x0034, PIN_OUTPUT, 0) /* (D6) MCU_MCAN0_TX */
&main_pmx0 {
	wlan_en_pins_default: wlan-en-pins-default {
	main_mmc2_pins_default: main-mmc2-pins-default {
			AM62X_IOPAD(0x120, PIN_INPUT, 0) /* (C24) MMC2_CMD */
			AM62X_IOPAD(0x118, PIN_INPUT, 0) /* (D25) MMC2_CLK */
			AM62X_IOPAD(0x114, PIN_INPUT, 0) /* (B24) MMC2_DAT0 */
			AM62X_IOPAD(0x110, PIN_INPUT, 0) /* (C25) MMC2_DAT1 */
			AM62X_IOPAD(0x10c, PIN_INPUT, 0) /* (E23) MMC2_DAT2 */
			AM62X_IOPAD(0x108, PIN_INPUT, 0) /* (D24) MMC2_DAT3 */
			AM62X_IOPAD(0x11c, PIN_INPUT, 0) /* (#N/A) MMC2_CLKB */
	main_wlirq_pins_default: main-wlirq-pins-default {
	main_mcan0_pins_default: main-mcan0-pins-default {
                        AM62X_IOPAD(0x1dc, PIN_INPUT, 0) /* (E15) MCAN0_RX */
                        AM62X_IOPAD(0x1d8, PIN_OUTPUT, 0) /* (C15) MCAN0_TX */
	main_spi2_pins_default: main-spi2-pins-default {
          		AM62X_IOPAD(0x1B0, PIN_OUTPUT, 1)   /* (A20) SPI2_CLK pins  on expansion Header*/
            		AM62X_IOPAD(0x1AC, PIN_OUTPUT, 1)  /* (E19) SPI2_CS0 pins on expansion Header */
            		AM62X_IOPAD(0x194, PIN_OUTPUT, 1)   /* (B19) SPI2_D0 pins on expansion Header */
            		AM62X_IOPAD(0x198, PIN_INPUT, 1)   /* (A19) SPI2_D1 pins on expansion Header */
       main_oldi0_pins_default: main-oldi0-pins-default {
                        AM62X_IOPAD(0x0260, PIN_OUTPUT, 0) /* (AA5) OLDI0_A0N */
                        AM62X_IOPAD(0x025c, PIN_OUTPUT, 0) /* (Y6) OLDI0_A0P */
                        AM62X_IOPAD(0x0268, PIN_OUTPUT, 0) /* (AD3) OLDI0_A1N */
                        AM62X_IOPAD(0x0264, PIN_OUTPUT, 0) /* (AB4) OLDI0_A1P */
                        AM62X_IOPAD(0x0270, PIN_OUTPUT, 0) /* (Y8) OLDI0_A2N */
                        AM62X_IOPAD(0x026c, PIN_OUTPUT, 0) /* (AA8) OLDI0_A2P */
                        AM62X_IOPAD(0x0278, PIN_OUTPUT, 0) /* (AB6) OLDI0_A3N */
                        AM62X_IOPAD(0x0274, PIN_OUTPUT, 0) /* (AA7) OLDI0_A3P */
                        AM62X_IOPAD(0x0280, PIN_OUTPUT, 0) /* (AC6) OLDI0_A4N */
                        AM62X_IOPAD(0x027c, PIN_OUTPUT, 0) /* (AC5) OLDI0_A4P */
                        AM62X_IOPAD(0x0288, PIN_OUTPUT, 0) /* (AE5) OLDI0_A5N */
                        AM62X_IOPAD(0x0284, PIN_OUTPUT, 0) /* (AD6) OLDI0_A5P */
                        AM62X_IOPAD(0x0290, PIN_OUTPUT, 0) /* (AE6) OLDI0_A6N */
                        AM62X_IOPAD(0x028c, PIN_OUTPUT, 0) /* (AD7) OLDI0_A6P */
                        AM62X_IOPAD(0x0298, PIN_OUTPUT, 0) /* (AD8) OLDI0_A7N */
                        AM62X_IOPAD(0x0294, PIN_OUTPUT, 0) /* (AE7) OLDI0_A7P */
                        AM62X_IOPAD(0x02a0, PIN_OUTPUT, 0) /* (AD4) OLDI0_CLK0N */
                        AM62X_IOPAD(0x029c, PIN_OUTPUT, 0) /* (AE3) OLDI0_CLK0P */
                        AM62X_IOPAD(0x02a8, PIN_OUTPUT, 0) /* (AE4) OLDI0_CLK1N */
                        AM62X_IOPAD(0x02a4, PIN_OUTPUT, 0) /* (AD5) OLDI0_CLK1P */
&main_mcan0 {
        status = "okay";
        pinctrl-0 = <&main_mcan0_pins_default>;
        phys = <&transceiver1>;
&mcu_i2c0 {
	status = "okay";
	pinctrl-0 = <&mcu_i2c0_pins_default>;
	bq32000: rtc@68 {
               compatible = "ti,bq32000";
               trickle-resistor-ohms = <1120>;
               reg = <0x68>;
&main_i2c1 {
	status = "okay";
	gt928@5d {
        	compatible = "goodix,gt928";
        	reg = <0x5d>;
        	interrupt-parent = <&main_gpio1>;
                interrupts = <0 IRQ_TYPE_EDGE_FALLING>;
        	reset-gpios = <&main_gpio0 54 GPIO_ACTIVE_LOW>;
&main_spi2{
    pinctrl-0 = <&main_spi2_pins_default>;
    status = "okay";
    //pindir-d0-out-d1-in=1;
    adc@0 {
            compatible = "ti,adc128s052";
            reg = <0>;
            vref-supply = <&vcc_3v3_sys>;
            spi-max-frequency = <1000000>;
            #io-channel-cells = <1>;
&dss {
        pinctrl-0 = <&main_oldi0_pins_default>;
    	status = "enabled";
&dss_ports {
        #size-cells = <0>;
        /* VP1: LVDS Output (OLDI TX 0) */
        port@0 {
                reg = <0>;
                oldi_out0: endpoint {
                        remote-endpoint = <&lcd_in0>;
        /* VP1: LVDS Output (OLDI TX 1) */
        port@2 {
                reg = <2>;
                oldi_out1: endpoint {
                        remote-endpoint = <&lcd_in1>;
    尊敬的 Siva:
    Unknown 说:
    echo 35 >/sys/class/gpio/export
    请说明"35"的来源?
    我添加了 DTS 文件作为源代码。  我能够导出任何 GPIO。
    请说明"35"的来源?
    它是 GPIO1_35、填充在映射到 MCU_RESET 引脚的节点 MAIN_GPIO1下。
    尊敬的 Siva:
    [报价用户识别=""]
    请说明"35"的来源?
    它是 GPIO1_35、填充在节点 MAIN_GPIO1下
    [/报价]
    "35"是 GPIO1_35的错误索引。 该索引应基于 MAIN_GPIO1的 gpiochip 的基本索引。
    请参阅以下文档作为示例、以了解如何查找 GPIO1_35的索引。
    https://dev.ti.com/tirex/explore/node?node=A__ANR3bSoQUtte3JSAV7ex0g__linux_academy_am62x__XaWts8R__LATEST
