[参考译文] CCStudio:文件加载程序:AM64x Cortex-M4内核上的验证失败错误
Guru**** 2540720 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1250137/ccstudio-file-loader-verification-failed-error-on-the-am64x-cortex-m4-core
器件型号:CCStudio
我正在尝试在 AM64x Cortex M4F_0内核上加载和运行一个应用程序。 但是、CCS 无法加载和运行应用程序、并显示以下错误
BLAZAR_Cortex_M4F_0: File Loader: Verification failed: Values at address 0x00013E98 do not match Please verify target memory and memory map.
BLAZAR_Cortex_M4F_0: GEL: File: C:\ti\mcu_plus_sdk\am64x\examples\hello_world_cpp\am64x-evm\m4fss0-0_nortos\ti-arm-clang\hello_world_cpp.debug.out: a data verification error occurred, file load failed.
下面随附了我的应用的链接器映射文件
            TI ARM Clang Linker PC v2.1.2
>> Linked Wed Jul 19 13:20:45 2023
OUTPUT FILE NAME:   <hello_world_cpp.debug.out>
ENTRY POINT SYMBOL: "_c_int00"  address: 0000e8a9
MEMORY CONFIGURATION
         name            origin    length      used     unused   attr    fill
  M4F_VECS              00000000   00000200  00000140  000000c0  RWIX
  M4F_IRAM              00000200   0002fe00  00013ca0  0001c160  RWIX
  M4F_DRAM              00030000   00010000  000010b0  0000ef50  RWIX
  USER_SHM_MEM          701d0000   00000080  00000000  00000080  RWIX
  LOG_SHM_MEM           701d0080   00003f80  00000000  00003f80  RWIX
  IPC_VRING_MEM         701d4000   0000c000  00000000  0000c000  RWIX
SEGMENT ALLOCATION MAP
run origin  load origin   length   init length attrs members
00000000    00000000    00000140   00000140    rw-
  00000000    00000000    00000140   00000140    rw- .vectors
00000200    00000200    00008000   00000000    rw-
  00000200    00000200    00008000   00000000    rw- .sysmem
00008200    00008200    00007c98   00007c98    r-x
  00008200    00008200    00007c98   00007c98    r-x .text
0000fe98    0000fe98    00004000   00000000    rw-
  0000fe98    0000fe98    00004000   00000000    rw- .stack
00013e98    00013e98    00000008   00000008    r--
  00013e98    00013e98    00000008   00000008    r-- .ARM.exidx
00030000    00030000    00000708   00000000    rw-
  00030000    00030000    00000708   00000000    rw- .bss
00030708    00030708    000005e8   000005e8    r--
  00030708    00030708    000005e8   000005e8    r-- .rodata
00030cf0    00030cf0    000003c0   000003c0    rw-
  00030cf0    00030cf0    000003c0   000003c0    rw- .data
SECTION ALLOCATION MAP
 output                                  attributes/
section   page    origin      length       input sections
.vectors   0    00000000    00000140
                  00000000    00000140     nortos.am64x.m4f.ti-arm-clang.debug.lib : HwiP_armv7m_handlers_nortos.obj (.vectors)
.sysmem    0    00000200    00008000     UNINITIALIZED
                  00000200    00000010     libc.a : memory.c.obj (.sysmem)
                  00000210    00007ff0     --HOLE--
.text      0    00008200    00007c98
                  00008200    00000a30     nortos.am64x.m4f.ti-arm-clang.debug.lib : printf.obj (.text._vsnprintf)
                  00008c30    00000640                                             : printf.obj (.text._etoa)
                  00009270    00000580                                             : printf.obj (.text._ftoa)
                  000097f0    000004a8                                             : HwiP_armv7m.obj (.text.hwi)
                  00009c98    000002da     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient.obj (.text.Sciclient_service)
                  00009f72    00000276                                              : uart_v0.obj (.text.UART_open)
                  0000a1e8    00000242                                              : uart_v0.obj (.text.UART_fifoConfig)
                  0000a42a    00000240                                              : uart_v0.obj (.text.UART_controllerIsr)
                  0000a66a    0000023c     nortos.am64x.m4f.ti-arm-clang.debug.lib : printf.obj (.text._ntoa_format)
                  0000a8a6    0000023a                                             : MpuP_armv7m.obj (.text.mpu)
                  0000aae0    000001e0     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_write)
                  0000acc0    000001b6     libclang_rt.builtins.a : adddf3.S.obj (.text)
                  0000ae76    000001b2     drivers.am64x.m4f.ti-arm-clang.debug.lib : soc.obj (.text.SOC_moduleSetClockFrequency)
                  0000b028    00000190                                              : uart_v0.obj (.text.UART_close)
                  0000b1b8    0000016a     nortos.am64x.m4f.ti-arm-clang.debug.lib : SysTickTimerP.obj (.text.SysTickTimerP_setup)
                  0000b322    0000016a     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_configInstance)
                  0000b48c    00000150                                              : uart_v0.obj (.text.UART_procLineStatusErr)
                  0000b5dc    00000142                                              : sciclient.obj (.text.Sciclient_sendMessage)
                  0000b71e    00000138     nortos.am64x.m4f.ti-arm-clang.debug.lib : printf.obj (.text._ntoa_long_long)
                  0000b856    00000002     ti_board_config.obj (.text.Board_deinit)
                  0000b858    00000136     libclang_rt.builtins.a : divdf3.S.obj (.text)
                  0000b98e    0000012e     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient.obj (.text.Sciclient_recvMessage)
                  0000babc    00000126                                              : sciclient_pm.obj (.text.Sciclient_pmQueryModuleClkFreq)
                  0000bbe2    00000002     ti_board_open_close.obj (.text.Board_driversClose)
                  0000bbe4    00000120     libc.a : memory.c.obj (.text.aligned_alloc)
                  0000bd04    0000011c     nortos.am64x.m4f.ti-arm-clang.debug.lib : ClockP_nortos_m4.obj (.text.ClockP_init)
                  0000be20    00000116     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_divisorLatchWrite)
                  0000bf36    00000114     nortos.am64x.m4f.ti-arm-clang.debug.lib : printf.obj (.text._ntoa_long)
                  0000c04a    0000010c     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient_pm.obj (.text.Sciclient_pmSetModuleClkFreq)
                  0000c156    0000010a     nortos.am64x.m4f.ti-arm-clang.debug.lib : HwiP_armv7m_handlers_nortos.obj (.text.hwi)
                  0000c260    000000fc     libclang_rt.builtins.a : muldf3.S.obj (.text)
                  0000c35c    000000f8     libc.a : memory.c.obj (.text.free)
                  0000c454    000000f6     nortos.am64x.m4f.ti-arm-clang.debug.lib : SemaphoreP_nortos.obj (.text.SemaphoreP_pend)
                  0000c54a    000000e8                                             : AddrTranslateP.obj (.text.AddrTranslateP_getLocalAddr)
                  0000c632    000000de     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient.obj (.text.Sciclient_waitForMessage)
                  0000c710    000000de                                              : uart_v0.obj (.text.UART_intrEnable)
                  0000c7ee    000000da                                              : uart_v0.obj (.text.UART_intrDisable)
                  0000c8c8    000000d8     libc.a : setvbuf.c.obj (.text.setvbuf)
                  0000c9a0    000000d4     drivers.am64x.m4f.ti-arm-clang.debug.lib : pinmux.obj (.text.Pinmux_unlockMMR)
                  0000ca74    000000c4                                              : uart_v0.obj (.text.UART_flushTxFifo)
                  0000cb38    000000c2                                              : uart_v0.obj (.text.UART_writePolling)
                  0000cbfa    000000c0     nortos.am64x.m4f.ti-arm-clang.debug.lib : printf.obj (.text._out_rev)
                  0000ccba    000000be                                             : ClockP_nortos.obj (.text.ClockP_timerTickIsr)
                  0000cd78    000000ba                                             : ClockP_nortos.obj (.text.ClockP_stop)
                  0000ce32    000000b8                                             : AddrTranslateP.obj (.text.AddrTranslateP_init)
                  0000ceea    000000b4                                             : AddrTranslateP.obj (.text.AddrTranslateP_setRegion)
                  0000cf9e    000000b2     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient.obj (.text.Sciclient_getCurrentContext)
                  0000d050    000000b0                                              : uart_v0.obj (.text.UART_init)
                  0000d100    000000b0     libclang_rt.builtins.a : udivmoddi4.S.obj (.text)
                  0000d1b0    000000aa     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_fifoWrite)
                  0000d25a    000000a8     nortos.am64x.m4f.ti-arm-clang.debug.lib : ClockP_nortos.obj (.text.ClockP_addToList)
                  0000d302    000000a8                                             : ClockP_nortos.obj (.text.ClockP_destruct)
                  0000d3aa    000000a8     ti_drivers_open_close.obj (.text.Drivers_uartOpen)
                  0000d452    000000a6     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient_pm.obj (.text.Sciclient_pmGetModuleClkNumParent)
                  0000d4f8    0000009e                                              : sciclient_soc_priv.obj (.text.Sciclient_getContext)
                  0000d596    0000009c                                              : pinmux.obj (.text.Pinmux_config)
                  0000d632    0000009a                                              : sciclient_pm.obj (.text.Sciclient_pmGetModuleClkParent)
                  0000d6cc    0000009a                                              : sciclient_pm.obj (.text.Sciclient_pmSetModuleClkParent)
                  0000d766    00000098                                              : sciclient_pm.obj (.text.Sciclient_pmModuleGetClkStatus)
                  0000d7fe    00000096                                              : sciclient.obj (.text.Sciclient_init)
                  0000d894    00000096                                              : uart_v0.obj (.text.UART_subConfigTCRTLRModeEn)
                  0000d92a    00000092                                              : soc.obj (.text.SOC_moduleClockEnable)
                  0000d9bc    00000092                                              : uart_v0.obj (.text.UART_writeCancelNoCB)
                  0000da4e    0000008c                                              : sciclient_pm.obj (.text.Sciclient_pmGetModuleState)
                  0000dada    0000008c                                              : sciclient_pm.obj (.text.Sciclient_pmModuleClkRequest)
                  0000db66    0000008c                                              : sciclient_pm.obj (.text.Sciclient_pmSetModuleState)
                  0000dbf2    00000002     ti_board_config.obj (.text.Board_init)
                  0000dbf4    00000088     libc.a : fputc.c.obj (.text.fputc)
                  0000dc7c    00000086     nortos.am64x.m4f.ti-arm-clang.debug.lib : ClockP_nortos.obj (.text.ClockP_getTimeUsec)
                  0000dd02    00000086     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_tcrTlrBitValRestore)
                  0000dd88    00000080                                              : uart_dma.obj (.text.UART_dmaDisableChannel)
                  0000de08    00000080                                              : uart_v0.obj (.text.UART_readData)
                  0000de88    0000007c                                              : uart_dma.obj (.text.UART_dmaClose)
                  0000df04    0000007c     nortos.am64x.m4f.ti-arm-clang.debug.lib : DebugP_log.obj (.text._DebugP_assert)
                  0000df80    0000007a     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_Params_init)
                  0000dffa    00000002     ti_dpl_config.obj (.text.Dpl_deinit)
                  0000dffc    00000074     libc.a : fclose.c.obj (.text.__TI_closefile)
                  0000e070    00000070     nortos.am64x.m4f.ti-arm-clang.debug.lib : ClockP_nortos.obj (.text.ClockP_construct)
                  0000e0e0    00000070     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_dma.obj (.text.UART_dmaOpen)
                  0000e150    0000006e     libclang_rt.builtins.a : comparedf2.c.obj (.text.__gedf2)
                  0000e1be    00000002     nortos.am64x.m4f.ti-arm-clang.debug.lib : TaskP_nortos.obj (.text.TaskP_yield)
                  0000e1c0    0000006e     libclang_rt.builtins.a : comparedf2.c.obj (.text.__ledf2)
                  0000e22e    00000002                            : aeabi_div0.c.obj (.text.__aeabi_ldiv0)
                  0000e230    0000006c     libc.a : memory.c.obj (.text.split)
                  0000e29c    0000006a     drivers.am64x.m4f.ti-arm-clang.debug.lib : pinmux.obj (.text.Pinmux_lockMMR)
                  0000e306    00000002     libc.a : _lock.c.obj (.text._nop)
                  0000e308    00000068     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_divisorValCompute)
                  0000e370    00000068     libc.a : fseek.c.obj (.text.fseeko)
                  0000e3d8    00000068            : getdevice.c.obj (.text.getdevice)
                  0000e440    00000064     libsysbm.a : hostrename.c.obj (.text.HOSTrename)
                  0000e4a4    00000062     libclang_rt.builtins.a : aeabi_dcmp.S.obj (.text)
                  0000e506    00000060     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_getChar)
                  0000e566    00000060     libc.a : _io_perm.c.obj (.text.__TI_wrt_ok)
                  0000e5c6    00000002     --HOLE-- [fill = 0]
                  0000e5c8    00000060     libsysbm.a : close.c.obj (.text.close)
                  0000e628    0000005e     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient_pm.obj (.text.Sciclient_pmSetModuleRst)
                  0000e686    0000005e     nortos.am64x.m4f.ti-arm-clang.debug.lib : SemaphoreP_nortos.obj (.text.SemaphoreP_post)
                  0000e6e4    0000005e     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_writeData)
                  0000e742    0000005c     ti_power_clock_config.obj (.text.Module_clockSetFrequency)
                  0000e79e    0000005a     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_regConfigModeEnable)
                  0000e7f8    00000058     libsysbm.a : hostlseek.c.obj (.text.HOSTlseek)
                  0000e850    00000058                : hostopen.c.obj (.text.HOSTopen)
                  0000e8a8    00000056     nortos.am64x.m4f.ti-arm-clang.debug.lib : boot_armv7m.obj (.text:_c_int00)
                  0000e8fe    00000002     --HOLE-- [fill = 0]
                  0000e900    00000054     libsysbm.a : hostread.c.obj (.text.HOSTread)
                  0000e954    00000054                : hostwrite.c.obj (.text.HOSTwrite)
                  0000e9a8    00000054     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_dma.obj (.text.UART_writeInterruptDma)
                  0000e9fc    00000054     libc++.a : string.cpp.obj (.text._ZNSt3__112basic_stringIcNS_11char_traitsIcEENS_9allocatorIcEEE6__initEPKcj)
                  0000ea50    00000052     nortos.am64x.m4f.ti-arm-clang.debug.lib : SemaphoreP_nortos.obj (.text.SemaphoreP_construct)
                  0000eaa2    00000050     ti_drivers_open_close.obj (.text.Drivers_uartClose)
                  0000eaf2    00000050     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_checkCharsAvailInFifo)
                  0000eb42    0000004e                                              : uart_v0.obj (.text.UART_getHandle)
                  0000eb90    0000004e     libc.a : fflush.c.obj (.text.__TI_doflush)
                  0000ebde    0000004c     ti_dpl_config.obj (.text.Dpl_init)
                  0000ec2a    0000004c     ti_power_clock_config.obj (.text.Module_clockDisable)
                  0000ec76    0000004c     ti_power_clock_config.obj (.text.Module_clockEnable)
                  0000ecc2    0000004c     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_fifoRegisterWrite)
                  0000ed0e    00000002     --HOLE-- [fill = 0]
                  0000ed10    0000004a                                              : sciclient_soc_priv.obj (.text.Sciclient_getDevId)
                  0000ed5a    0000004a                                              : uart_v0.obj (.text.UART_getIntrIdentityStatus)
                  0000eda4    0000004a                                              : uart_v0.obj (.text.UART_lineCharConfig)
                  0000edee    00000002     --HOLE-- [fill = 0]
                  0000edf0    00000048     libclang_rt.builtins.a : fixdfsi.S.obj (.text)
                  0000ee38    00000046     nortos.am64x.m4f.ti-arm-clang.debug.lib : DebugP_uartLogWriter.obj (.text.DebugP_uartLogWriterPutChar)
                  0000ee7e    00000046     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_i2310WA)
                  0000eec4    00000046                                              : uart_v0.obj (.text.UART_readLineStatus)
                  0000ef0a    00000002     --HOLE-- [fill = 0]
                  0000ef0c    00000044     libsysbm.a : hostunlink.c.obj (.text.HOSTunlink)
                  0000ef50    00000044     nortos.am64x.m4f.ti-arm-clang.debug.lib : DebugP_nortos.obj (.text._DebugP_logZone)
                  0000ef94    00000044                                             : printf.obj (.text._strnlen_s)
                  0000efd8    00000044     libclang_rt.builtins.a : fixunsdfsi.S.obj (.text)
                  0000f01c    00000042     nortos.am64x.m4f.ti-arm-clang.debug.lib : ClockP_nortos.obj (.text.ClockP_start)
                  0000f05e    00000042     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_checkOpenParams)
                  0000f0a0    0000003e                                              : sciclient.obj (.text.Sciclient_secProxyWaitThread)
                  0000f0de    0000003e                                              : uart_v0.obj (.text.UART_spaceAvail)
                  0000f11c    0000003e     hello_world.obj (.text._Z16hello_world_mainPv)
                  0000f15a    00000002     --HOLE-- [fill = 0]
                  0000f15c    0000003c     libsysbm.a : hostclose.c.obj (.text.HOSTclose)
                  0000f198    0000003c     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_enhanFuncEnable)
                  0000f1d4    0000003c                                              : uart_v0.obj (.text.UART_resetModule)
                  0000f210    0000003c                                              : uart_v0.obj (.text.UART_writeDataPolling)
                  0000f24c    0000003a     nortos.am64x.m4f.ti-arm-clang.debug.lib : printf.obj (.text._atoi)
                  0000f286    00000038     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient.obj (.text.Sciclient_secProxyFlush)
                  0000f2be    00000002     --HOLE-- [fill = 0]
                  0000f2c0    00000038     libc.a : autoinit.c.obj (.text:__TI_auto_init_nobinit_nopinit)
                  0000f2f8    00000036     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_checkTransaction)
                  0000f32e    00000002     --HOLE-- [fill = 0]
                  0000f330    00000034     libc.a : fopen.c.obj (.text.__TI_cleanup)
                  0000f364    00000034     libsysbm.a : trgmsg.c.obj (.text.__TI_writemsg)
                  0000f398    00000034     libc.a : getdevice.c.obj (.text.finddevice)
                  0000f3cc    00000032     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.HW_WR_FIELD32_RAW)
                  0000f3fe    00000032                                              : uart_v0.obj (.text.UART_hardwareFlowCtrlOptSet)
                  0000f430    00000032     hello_world.obj (.text._ZNSt3__112basic_stringIcNS_11char_traitsIcEENS_9allocatorIcEEEC2IDnEEPKc)
                  0000f462    00000030     nortos.am64x.m4f.ti-arm-clang.debug.lib : SysTickTimerP.obj (.text.SysTickTimerP_Params_init)
                  0000f492    00000030     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_enhanFuncBitValRestore)
                  0000f4c2    00000030                                              : uart_v0.obj (.text.UART_flowCtrlTrigLvlConfig)
                  0000f4f2    00000002     --HOLE-- [fill = 0]
                  0000f4f4    00000030     libsysbm.a : trgmsg.c.obj (.text.__TI_readmsg)
                  0000f524    00000030     libclang_rt.builtins.a : comparedf2.c.obj (.text.__unorddf2)
                  0000f554    00000030     libc.a : exit.c.obj (.text.exit)
                  0000f584    0000002e     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient.obj (.text.CSL_secProxyGetMaxMsgSize)
                  0000f5b2    0000002e                                              : sciclient.obj (.text.Sciclient_secProxyReadThread32)
                  0000f5e0    0000002e     ti_drivers_config.obj (.text.System_init)
                  0000f60e    0000002e     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_deinit)
                  0000f63c    0000002e     nortos.am64x.m4f.ti-arm-clang.debug.lib : printf.obj (.text._is_digit)
                  0000f66a    00000002     --HOLE-- [fill = 0]
                  0000f66c    0000002e     libclang_rt.builtins.a : floatsidf.S.obj (.text)
                  0000f69a    0000002c     nortos.am64x.m4f.ti-arm-clang.debug.lib : DebugP_log.obj (.text.DebugP_logZoneEnable)
                  0000f6c6    0000002c                                             : SemaphoreP_nortos.obj (.text.SemaphoreP_constructBinary)
                  0000f6f2    0000002c     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_moduleReset)
                  0000f71e    0000002c     hello_world.obj (.text._ZNSt3__117__compressed_pairINS_12basic_stringIcNS_11char_traitsIcEENS_9allocatorIcEEE5__repES5_EC2INS_18__default_init_tagESA_EEOT_OT0_)
                  0000f74a    00000002     --HOLE-- [fill = 0]
                  0000f74c    0000002c     libsysbm.a : lseek.c.obj (.text.lseek)
                  0000f778    0000002c                : unlink.c.obj (.text.unlink)
                  0000f7a4    0000002c                : write.c.obj (.text.write)
                  0000f7d0    0000002a     ti_drivers_config.obj (.text.System_deinit)
                  0000f7fa    0000002a     nortos.am64x.m4f.ti-arm-clang.debug.lib : DebugP_uartLogWriter.obj (.text.UART_Transaction_init)
                  0000f824    0000002a     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_intr2Disable)
                  0000f84e    0000002a                                              : uart_v0.obj (.text.UART_operatingModeSelect)
                  0000f878    00000028                                              : sciclient.obj (.text.Sciclient_secProxyVerifyThread)
                  0000f8a0    00000028     libc.a : memory.c.obj (.text.free_list_insert)
                  0000f8c8    00000028     nortos.am64x.m4f.ti-arm-clang.debug.lib : printf.obj (.text.vprintf_)
                  0000f8f0    00000026     main.obj (.text.main)
                  0000f916    00000024     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient.obj (.text.CSL_REG32_FEXT_RAW)
                  0000f93a    00000024     nortos.am64x.m4f.ti-arm-clang.debug.lib : HwiP_armv7m.obj (.text.HwiP_inISR)
                  0000f95e    00000024                                             : SemaphoreP_nortos.obj (.text.SemaphoreP_constructMutex)
                  0000f982    00000024                                             : DebugP_log.obj (.text._DebugP_assertNoLog)
                  0000f9a6    00000002     --HOLE-- [fill = 0]
                  0000f9a8    00000024     libc++abi.a : stdlib_new_delete.cpp.obj (.text._Znwj)
                  0000f9cc    00000024     nortos.am64x.m4f.ti-arm-clang.debug.lib : printf.obj (.text._out_char)
                  0000f9f0    00000024                                             : boot_armv7m.obj (.text._system_pre_init)
                  0000fa14    00000022     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_writeInterrupt)
                  0000fa36    00000020     nortos.am64x.m4f.ti-arm-clang.debug.lib : ClockP_nortos.obj (.text.ClockP_isActive)
                  0000fa56    00000020     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.HW_RD_FIELD32_RAW)
                  0000fa76    00000020     ti_pinmux_config.obj (.text.Pinmux_init)
                  0000fa96    00000002     --HOLE-- [fill = 0]
                  0000fa98    00000020     libclang_rt.builtins.a : floatunsidf.S.obj (.text)
                  0000fab8    0000001e     nortos.am64x.m4f.ti-arm-clang.debug.lib : ClockP_nortos.obj (.text.ClockP_Params_init)
                  0000fad6    0000001c     drivers.am64x.m4f.ti-arm-clang.debug.lib : csl_sec_proxy.obj (.text.CSL_secProxyGetDataAddr)
                  0000faf2    0000001c                                              : uart_v0.obj (.text.UART_breakCtl)
                  0000fb0e    00000002     --HOLE-- [fill = 0]
                  0000fb10    0000001c     libc.a : memory.c.obj (.text.free_list_remove)
                  0000fb2c    0000001c     ti_dpl_config.obj (.text.putchar_)
                  0000fb48    0000001a     nortos.am64x.m4f.ti-arm-clang.debug.lib : SysTickTimerP.obj (.text.SysTickTimerP_start)
                  0000fb62    0000001a                                             : SysTickTimerP.obj (.text.SysTickTimerP_stop)
                  0000fb7c    0000001a     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_fifoCharGet)
                  0000fb96    00000018                                              : sciclient.obj (.text.Sciclient_secProxyThreadStatusReg)
                  0000fbae    00000018     nortos.am64x.m4f.ti-arm-clang.debug.lib : SemaphoreP_nortos.obj (.text.SemaphoreP_Params_init)
                  0000fbc6    00000018     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.text.UART_divisorLatchDisable)
                  0000fbde    00000018                                              : uart_v0.obj (.text.UART_modemControlReset)
                  0000fbf6    00000018                                              : uart_v0.obj (.text.UART_putChar)
                  0000fc0e    00000016     nortos.am64x.m4f.ti-arm-clang.debug.lib : AddrTranslateP.obj (.text.AddrTranslateP_Params_init)
                  0000fc24    00000016     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient.obj (.text.Sciclient_secProxyReadThreadCount)
                  0000fc3a    00000016                                              : uart_v0.obj (.text.UART_divideRoundCloset)
                  0000fc50    00000016                                              : uart_v0.obj (.text.UART_regConfModeRestore)
                  0000fc66    00000014     nortos.am64x.m4f.ti-arm-clang.debug.lib : DebugP_uartLogWriter.obj (.text.DebugP_uartSetDrvIndex)
                  0000fc7a    00000014     libc++.a : string.cpp.obj (.text._ZNSt3__112basic_stringIcNS_11char_traitsIcEENS_9allocatorIcEEED2Ev)
                  0000fc8e    00000014     hello_world.obj (.text._ZNSt3__122__compressed_pair_elemINS_9allocatorIcEELi1ELb1EEC2ENS_18__default_init_tagE)
                  0000fca2    00000014     hello_world.obj (.text._ZNSt3__19allocatorIcEC2Ev)
                  0000fcb6    00000002     --HOLE-- [fill = 0]
                  0000fcb8    00000014     libclang_rt.builtins.a : aeabi_memset.S.obj (.text)
                  0000fccc    00000014                            : aeabi_uldivmod.S.obj (.text)
                  0000fce0    00000012     nortos.am64x.m4f.ti-arm-clang.debug.lib : SysTickTimerP.obj (.text.SysTickTimerP_getCount)
                  0000fcf2    00000012                                             : SysTickTimerP.obj (.text.SysTickTimerP_getReloadCount)
                  0000fd04    00000012     libc.a : memcpy_t2.S.obj (.text:TI_memcpy_small)
                  0000fd16    00000010     drivers.am64x.m4f.ti-arm-clang.debug.lib : pinmux.obj (.text.CSL_REG32_WR_RAW)
                  0000fd26    00000010                                              : sciclient.obj (.text.CSL_REG32_WR_RAW)
                  0000fd36    00000010                                              : uart_v0.obj (.text.HW_RD_REG32_RAW)
                  0000fd46    00000010                                              : uart_v0.obj (.text.HW_WR_REG32_RAW)
                  0000fd56    00000010     hello_world.obj (.text._ZNSt3__111char_traitsIcE6lengthEPKc)
                  0000fd66    00000010     nortos.am64x.m4f.ti-arm-clang.debug.lib : printf.obj (.text._out_null)
                  0000fd76    0000000e                                             : ClockP_nortos_m4.obj (.text.ClockP_getTimerCount)
                  0000fd84    0000000e     libsysbm.a : hostrename.c.obj (.text.strcpy)
                  0000fd92    0000000e     libc.a : strlen.c.obj (.text.strlen)
                  0000fda0    0000000e     libsysbm.a : hostrename.c.obj (.text.strlen)
                  0000fdae    0000000e     libc.a : memset_t2.S.obj (.text:TI_memset_small)
                  0000fdbc    0000000c     ti_board_open_close.obj (.text.Board_driversOpen)
                  0000fdc8    0000000c     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient.obj (.text.CSL_REG32_RD_RAW)
                  0000fdd4    0000000c     nortos.am64x.m4f.ti-arm-clang.debug.lib : SysTickTimerP.obj (.text.CSL_REG32_RD_RAW)
                  0000fde0    0000000c                                             : ClockP_nortos.obj (.text.ClockP_getTicks)
                  0000fdec    0000000c     ti_power_clock_config.obj (.text.PowerClock_init)
                  0000fdf8    0000000c     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient.obj (.text.Sciclient_deinit)
                  0000fe04    0000000c     libc++abi.a : cxa_handlers.cpp.obj (.text._ZSt15get_new_handlerv)
                  0000fe10    0000000c     libc.a : fputc.c.obj (.text.putchar)
                  0000fe1c    0000000a     hello_world.obj (.text._ZNSt3__116__non_trivial_ifILb1ENS_9allocatorIcEEEC2Ev)
                  0000fe26    0000000a     hello_world.obj (.text._ZNSt3__122__compressed_pair_elemINS_12basic_stringIcNS_11char_traitsIcEENS_9allocatorIcEEE5__repELi0ELb0EEC2ENS_18__default_init_tagE)
                  0000fe30    0000000a     hello_world.obj (.text._ZNSt3__17forwardINS_18__default_init_tagEEEOT_RNS_16remove_referenceIS2_E4typeE)
                  0000fe3a    00000008     nortos.am64x.m4f.ti-arm-clang.debug.lib : ClockP_nortos_m4.obj (.text.ClockP_timerClearOverflowInt)
                  0000fe42    00000008     ti_drivers_open_close.obj (.text.Drivers_close)
                  0000fe4a    00000008     ti_drivers_open_close.obj (.text.Drivers_open)
                  0000fe52    00000008     ti_drivers_config.obj (.text.Drivers_uartInit)
                  0000fe5a    00000008     ti_power_clock_config.obj (.text.PowerClock_deinit)
                  0000fe62    00000008     nortos.am64x.m4f.ti-arm-clang.debug.lib : SemaphoreP_nortos.obj (.text.SemaphoreP_destruct)
                  0000fe6a    00000008     hello_world.obj (.text._ZNSt3__119__debug_db_insert_cINS_12basic_stringIcNS_11char_traitsIcEENS_9allocatorIcEEEEEEvPT_)
                  0000fe72    00000008     ti_dpl_config.obj (.text.boot)
                  0000fe7a    00000008     libc.a : memory.c.obj (.text.malloc)
                  0000fe82    00000004     libc++abi.a : stdlib_new_delete.cpp.obj (.text._ZdlPv)
                  0000fe86    00000004     libc.a : fseek.c.obj (.text.fseek)
                  0000fe8a    00000004     libsysbm.a : remove.c.obj (.text.remove)
                  0000fe8e    00000004     libc.a : exit.c.obj (.text:abort)
                  0000fe92    00000002     --HOLE-- [fill = 0]
                  0000fe94    00000004     libclang_rt.builtins.a : aeabi_memcpy.S.obj (.text)
.stack     0    0000fe98    00004000     UNINITIALIZED
                  0000fe98    00000004     nortos.am64x.m4f.ti-arm-clang.debug.lib : boot_armv7m.obj (.stack)
                  0000fe9c    00003ffc     --HOLE--
.bss       0    00030000    00000708     UNINITIALIZED
                  00030000    00000280     ti_drivers_config.obj (.bss.gUartObjects)
                  00030280    00000280     (.common:gHwiCtrl)
                  00030500    00000120     libsysbm.a : trgmsg.c.obj (.bss:_CIOBUF_)
                  00030620    000000a0     (.common:__TI_tmpnams)
                  000306c0    00000038     (.common:gClockCtrl)
                  000306f8    00000008     (.common:parmbuf)
                  00030700    00000004     libc.a : memory.c.obj (.bss.sys_free)
                  00030704    00000004     (.common:gUartHandle)
.rodata    0    00030708    000005e8
                  00030708    00000139     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.rodata.str1.1)
                  00030841    00000003     --HOLE-- [fill = 0]
                  00030844    0000012c                                              : sciclient_fmwSecureProxyMap.obj (.rodata.gSciclientMap)
                  00030970    000000ac     nortos.am64x.m4f.ti-arm-clang.debug.lib : ClockP_nortos_m4.obj (.rodata.str1.1)
                  00030a1c    0000009f                                             : SysTickTimerP.obj (.rodata.str1.1)
                  00030abb    0000006b                                             : SemaphoreP_nortos.obj (.rodata.str1.1)
                  00030b26    0000005a                                             : ClockP_nortos.obj (.rodata.str1.1)
                  00030b80    00000050                                             : printf.obj (.rodata._ftoa.pow10)
                  00030bd0    0000004b     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_dma.obj (.rodata.str1.1)
                  00030c1b    00000046     ti_drivers_open_close.obj (.rodata.str1.1)
                  00030c61    0000002d     nortos.am64x.m4f.ti-arm-clang.debug.lib : DebugP_log.obj (.rodata.str1.1)
                  00030c8e    00000002     --HOLE-- [fill = 0]
                  00030c90    0000002c     ti_dpl_config.obj (.rodata.cfg)
                  00030cbc    0000001c     hello_world.obj (.rodata.str1.1)
                  00030cd8    00000012     nortos.am64x.m4f.ti-arm-clang.debug.lib : printf.obj (.rodata.str1.1)
                  00030cea    00000006     --HOLE-- [fill = 0]
.data      0    00030cf0    000003c0
                  00030cf0    000000f0     libc.a : defs.c.obj (.data._ftable)
                  00030de0    0000009c     drivers.am64x.m4f.ti-arm-clang.debug.lib : uart_v0.obj (.data.gUartDrvObj)
                  00030e7c    00000078     libsysbm.a : host_device.c.obj (.data._device)
                  00030ef4    00000054     ti_drivers_open_close.obj (.data.gUartParams)
                  00030f48    00000050     libsysbm.a : host_device.c.obj (.data._stream)
                  00030f98    00000040     ti_dpl_config.obj (.data.gAddrTranslateRegionConfig)
                  00030fd8    00000020     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient_soc_priv.obj (.data.gSciclientSecProxyCfg)
                  00030ff8    00000018     ti_pinmux_config.obj (.data.gPinMuxMcuDomainCfg)
                  00031010    00000018     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient.obj (.data.gSciclientHandle)
                  00031028    00000018     ti_power_clock_config.obj (.data.gSocModulesClockFrequency)
                  00031040    00000014     ti_dpl_config.obj (.data.gClockConfig)
                  00031054    0000000c     nortos.am64x.m4f.ti-arm-clang.debug.lib : AddrTranslateP.obj (.data.gAddrTranslateConfig)
                  00031060    00000008     libc.a : exit.c.obj (.data..L_MergedGlobals)
                  00031068    00000008     ti_pinmux_config.obj (.data.gPinMuxMainDomainCfg)
                  00031070    00000008     ti_power_clock_config.obj (.data.gSocModules)
                  00031078    00000008     ti_drivers_config.obj (.data.gUartAttrs)
                  00031080    00000008     ti_drivers_config.obj (.data.gUartConfig)
                  00031088    00000004     libc.a : defs.c.obj (.data.__TI_ft_end)
                  0003108c    00000004     libc++abi.a : cxa_default_handlers.cpp.obj (.data.__cxa_new_handler)
                  00031090    00000004     libc.a : _lock.c.obj (.data._lock)
                  00031094    00000004            : _lock.c.obj (.data._unlock)
                  00031098    00000004     nortos.am64x.m4f.ti-arm-clang.debug.lib : DebugP_log.obj (.data.gDebugLogZone)
                  0003109c    00000004                                             : DebugP_uartLogWriter.obj (.data.gDebugP_uartDrvIndex)
                  000310a0    00000004     ti_drivers_config.obj (.data.gUartConfigNum)
                  000310a4    00000004     ti_drivers_config.obj (.data.gUartDmaConfigNum)
                  000310a8    00000001     drivers.am64x.m4f.ti-arm-clang.debug.lib : sciclient.obj (.data.gSecHeaderSizeWords)
                  000310a9    00000003     --HOLE-- [fill = 0]
                  000310ac    00000001     libc.a : memory.c.obj (.data.memory_is_initialized)
                  000310ad    00000003     --HOLE-- [fill = 0]
.init_array
*          0    00000200    00000000     UNINITIALIZED
__llvm_prf_cnts
*          0    00030000    00000000     UNINITIALIZED
__llvm_prf_bits
.ARM.exidx
*          0    00013e98    00000008
                  00013e98    00000008     (.ARM.exidx.text._vsnprintf:nortos.am64x.m4f.ti-arm-clang.debug.lib<printf.obj>)
MODULE SUMMARY
       Module                            code    ro data   rw data
    obj\debug\
       ti_drivers_config.obj             96      0         664
       ti_drivers_open_close.obj         264     70        88
       ti_power_clock_config.obj         264     0         32
       hello_world.obj                   250     28        0
       ti_dpl_config.obj                 114     44        84
       ti_pinmux_config.obj              32      0         32
       main.obj                          38      0         0
       ti_board_open_close.obj           14      0         0
       ti_board_config.obj               4       0         0
       Total:                            1076    142       900
    C:/ti/mcu_plus_sdk/am64x/source/drivers/lib/drivers.am64x.m4f.ti-arm-clang.debug.lib
       uart_v0.obj                       7402    313       156
       sciclient.obj                     2276    0         25
       sciclient_pm.obj                  1702    0         0
       soc.obj                           580     0         0
       uart_dma.obj                      448     75        0
       pinmux.obj                        490     0         0
       sciclient_fmwSecureProxyMap.obj   0       300       0
       sciclient_soc_priv.obj            232     0         32
       csl_sec_proxy.obj                 28      0         0
       Total:                            13158   688       213
    C:/ti/mcu_plus_sdk/am64x/source/kernel/nortos/lib/nortos.am64x.m4f.ti-arm-clang.debug.lib
       printf.obj                        7232    98        0
       HwiP_armv7m.obj                   1228    0         640
       ClockP_nortos.obj                 1098    90        56
       SysTickTimerP.obj                 510     159       0
       SemaphoreP_nortos.obj             534     107       0
       AddrTranslateP.obj                618     0         12
       HwiP_armv7m_handlers_nortos.obj   266     0         320
       MpuP_armv7m.obj                   570     0         0
       ClockP_nortos_m4.obj              306     172       0
       DebugP_log.obj                    204     45        4
       DebugP_uartLogWriter.obj          132     0         4
       boot_armv7m.obj                   122     0         0
       DebugP_nortos.obj                 68      0         0
       TaskP_nortos.obj                  2       0         0
       Total:                            12890   671       1036
    C:\ti\ccs1210\ccs\tools\compiler\ti-cgt-armllvm_2.1.2.LTS\lib\armv7em-ti-none-eabihf/c/libc.a
       memory.c.obj                      720     0         5
       defs.c.obj                        0       0         404
       setvbuf.c.obj                     216     0         0
       getdevice.c.obj                   156     0         0
       fputc.c.obj                       148     0         0
       fclose.c.obj                      116     0         0
       fseek.c.obj                       108     0         0
       _io_perm.c.obj                    96      0         0
       fflush.c.obj                      78      0         0
       exit.c.obj                        52      0         8
       autoinit.c.obj                    56      0         0
       fopen.c.obj                       52      0         0
       memcpy_t2.S.obj                   18      0         0
       memset_t2.S.obj                   14      0         0
       strlen.c.obj                      14      0         0
       _lock.c.obj                       2       0         8
       Total:                            1846    0         425
    C:\ti\ccs1210\ccs\tools\compiler\ti-cgt-armllvm_2.1.2.LTS\lib\armv7em-ti-none-eabihf/c/libsysbm.a
       trgmsg.c.obj                      100     0         288
       host_device.c.obj                 0       0         200
       hostrename.c.obj                  128     0         0
       close.c.obj                       96      0         0
       hostopen.c.obj                    88      0         8
       hostlseek.c.obj                   88      0         0
       hostread.c.obj                    84      0         0
       hostwrite.c.obj                   84      0         0
       hostunlink.c.obj                  68      0         0
       hostclose.c.obj                   60      0         0
       lseek.c.obj                       44      0         0
       unlink.c.obj                      44      0         0
       write.c.obj                       44      0         0
       remove.c.obj                      4       0         0
       Total:                            932     0         496
    C:\ti\ccs1210\ccs\tools\compiler\ti-cgt-armllvm_2.1.2.LTS\lib\armv7em-ti-none-eabihf/libc++.a
       string.cpp.obj                    104     0         0
       Total:                            104     0         0
    C:\ti\ccs1210\ccs\tools\compiler\ti-cgt-armllvm_2.1.2.LTS\lib\armv7em-ti-none-eabihf/libc++abi.a
       stdlib_new_delete.cpp.obj         40      0         0
       cxa_handlers.cpp.obj              12      0         0
       cxa_default_handlers.cpp.obj      0       0         4
       Total:                            52      0         4
    C:\ti\ccs1210\ccs\tools\compiler\ti-cgt-armllvm_2.1.2.LTS\lib\clang/14.0.6/lib/armv7em-ti-none-eabihf/libclang_rt.builtins.a
       adddf3.S.obj                      438     0         0
       divdf3.S.obj                      310     0         0
       comparedf2.c.obj                  268     0         0
       muldf3.S.obj                      252     0         0
       udivmoddi4.S.obj                  176     0         0
       aeabi_dcmp.S.obj                  98      0         0
       fixdfsi.S.obj                     72      0         0
       fixunsdfsi.S.obj                  68      0         0
       floatsidf.S.obj                   46      0         0
       floatunsidf.S.obj                 32      0         0
       aeabi_memset.S.obj                20      0         0
       aeabi_uldivmod.S.obj              20      0         0
       aeabi_memcpy.S.obj                4       0         0
       aeabi_div0.c.obj                  2       0         0
       Total:                            1806    0         0
       Heap:                             0       0         32768
       Stack:                            0       0         16384
       Linker Generated:                 0       8         0
       Grand Total:                      31864   1509      52226
GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
address   name
00013e98  .ARM.exidx$$Base
00013ea0  .ARM.exidx$$Limit
0000fc0f  AddrTranslateP_Params_init
0000c54b  AddrTranslateP_getLocalAddr
0000ce33  AddrTranslateP_init
0000b857  Board_deinit
0000bbe3  Board_driversClose
0000fdbd  Board_driversOpen
0000dbf3  Board_init
0000fe8e  C$$EXIT
0000f38f  C$$IO$$
0000fad7  CSL_secProxyGetDataAddr
0000fab9  ClockP_Params_init
0000e071  ClockP_construct
0000d303  ClockP_destruct
0000fde1  ClockP_getTicks
0000dc7d  ClockP_getTimeUsec
0000fd77  ClockP_getTimerCount
0000bd05  ClockP_init
0000fa37  ClockP_isActive
0000f01d  ClockP_start
0000cd79  ClockP_stop
0000fe3b  ClockP_timerClearOverflowInt
0000ccbb  ClockP_timerTickIsr
0000f69b  DebugP_logZoneEnable
0000ee39  DebugP_uartLogWriterPutChar
0000fc67  DebugP_uartSetDrvIndex
0000dffb  Dpl_deinit
0000ebdf  Dpl_init
0000fe43  Drivers_close
0000fe4b  Drivers_open
0000eaa3  Drivers_uartClose
0000fe53  Drivers_uartInit
0000d3ab  Drivers_uartOpen
0000f15d  HOSTclose
0000e7f9  HOSTlseek
0000e851  HOSTopen
0000e901  HOSTread
0000e441  HOSTrename
0000ef0d  HOSTunlink
0000e955  HOSTwrite
00009ac5  HwiP_Params_init
0000c1e9  HwiP_busFault_handler
000099c9  HwiP_clearInt
00009aed  HwiP_construct
0000c239  HwiP_debugMon_handler
00009b8f  HwiP_destruct
0000985d  HwiP_disable
00009895  HwiP_disableInt
00009bf9  HwiP_enable
000097f1  HwiP_enableInt
0000c1c1  HwiP_hardFault_handler
0000f93b  HwiP_inISR
00009c11  HwiP_init
0000c157  HwiP_interrupt_handler
0000c1d5  HwiP_memFault_handler
0000c1ad  HwiP_nmi_handler
0000c24d  HwiP_pendSV_handler
00009bd5  HwiP_post
0000c211  HwiP_reserved_handler
00009879  HwiP_restore
0000992d  HwiP_restoreInt
00009a07  HwiP_setPri
0000c225  HwiP_svc_handler
0000c1fd  HwiP_usageFault_handler
0000ec2b  Module_clockDisable
0000ec77  Module_clockEnable
0000e743  Module_clockSetFrequency
0000a8a7  MpuP_RegionAttrs_init
0000a9d7  MpuP_disable
0000aa05  MpuP_enable
0000aa63  MpuP_init
0000a9c7  MpuP_isEnable
0000a8d5  MpuP_setRegion
0000d597  Pinmux_config
0000fa77  Pinmux_init
0000fe5b  PowerClock_deinit
0000fded  PowerClock_init
0000d92b  SOC_moduleClockEnable
0000ae77  SOC_moduleSetClockFrequency
0000fdf9  Sciclient_deinit
0000d4f9  Sciclient_getContext
0000cf9f  Sciclient_getCurrentContext
0000ed11  Sciclient_getDevId
0000d7ff  Sciclient_init
0000d453  Sciclient_pmGetModuleClkNumParent
0000d633  Sciclient_pmGetModuleClkParent
0000da4f  Sciclient_pmGetModuleState
0000dadb  Sciclient_pmModuleClkRequest
0000d767  Sciclient_pmModuleGetClkStatus
0000babd  Sciclient_pmQueryModuleClkFreq
0000c04b  Sciclient_pmSetModuleClkFreq
0000d6cd  Sciclient_pmSetModuleClkParent
0000e629  Sciclient_pmSetModuleRst
0000db67  Sciclient_pmSetModuleState
00009c99  Sciclient_service
0000fbaf  SemaphoreP_Params_init
0000ea51  SemaphoreP_construct
0000f6c7  SemaphoreP_constructBinary
0000f95f  SemaphoreP_constructMutex
0000fe63  SemaphoreP_destruct
0000c455  SemaphoreP_pend
0000e687  SemaphoreP_post
0000f463  SysTickTimerP_Params_init
0000fce1  SysTickTimerP_getCount
0000fcf3  SysTickTimerP_getReloadCount
0000b1b9  SysTickTimerP_setup
0000fb49  SysTickTimerP_start
0000fb63  SysTickTimerP_stop
0000f7d1  System_deinit
0000f5e1  System_init
0000fd05  TI_memcpy_small
0000fdaf  TI_memset_small
0000e1bf  TaskP_yield
0000b029  UART_close
0000f60f  UART_deinit
0000de89  UART_dmaClose
0000dd89  UART_dmaDisableChannel
0000e0e1  UART_dmaOpen
0000ca75  UART_flushTxFifo
0000eb43  UART_getHandle
0000d051  UART_init
00009f73  UART_open
0000aae1  UART_write
0000e9a9  UART_writeInterruptDma
00030500  _CIOBUF_
0000df05  _DebugP_assert
0000f983  _DebugP_assertNoLog
0000ef51  _DebugP_logZone
0000f11d  _Z16hello_world_mainPv
0000fd57  _ZNSt3__111char_traitsIcE6lengthEPKc
0000e9fd  _ZNSt3__112basic_stringIcNS_11char_traitsIcEENS_9allocatorIcEEE6__initEPKcj
0000f431  _ZNSt3__112basic_stringIcNS_11char_traitsIcEENS_9allocatorIcEEEC2IDnEEPKc
0000fc7b  _ZNSt3__112basic_stringIcNS_11char_traitsIcEENS_9allocatorIcEEED1Ev
0000fc7b  _ZNSt3__112basic_stringIcNS_11char_traitsIcEENS_9allocatorIcEEED2Ev
0000fe1d  _ZNSt3__116__non_trivial_ifILb1ENS_9allocatorIcEEEC2Ev
0000f71f  _ZNSt3__117__compressed_pairINS_12basic_stringIcNS_11char_traitsIcEENS_9allocatorIcEEE5__repES5_EC2INS_18__default_init_tagESA_EEOT_OT0_
0000fe6b  _ZNSt3__119__debug_db_insert_cINS_12basic_stringIcNS_11char_traitsIcEENS_9allocatorIcEEEEEEvPT_
0000fe27  _ZNSt3__122__compressed_pair_elemINS_12basic_stringIcNS_11char_traitsIcEENS_9allocatorIcEEE5__repELi0ELb0EEC2ENS_18__default_init_tagE
0000fc8f  _ZNSt3__122__compressed_pair_elemINS_9allocatorIcEELi1ELb1EEC2ENS_18__default_init_tagE
0000fe31  _ZNSt3__17forwardINS_18__default_init_tagEEEOT_RNS_16remove_referenceIS2_E4typeE
0000fca3  _ZNSt3__19allocatorIcEC2Ev
0000fe05  _ZSt15get_new_handlerv
0000fe83  _ZdlPv
0000f9a9  _Znwj
00030708  __BSS_END
00030000  __BSS_START
00030500  __CIOBUF_
00013e98  __STACK_END
00004000  __STACK_SIZE
00008000  __SYSMEM_SIZE
UNDEFED   __TI_CINIT_Base
UNDEFED   __TI_CINIT_Limit
UNDEFED   __TI_Handler_Table_Base
UNDEFED   __TI_Handler_Table_Limit
00013ea0  __TI_UNWIND_TABLE_END
00013e98  __TI_UNWIND_TABLE_START
0000f2c1  __TI_auto_init_nobinit_nopinit
0000f331  __TI_cleanup
00031060  __TI_cleanup_ptr
0000dffd  __TI_closefile
0000eb91  __TI_doflush
00031064  __TI_dtors_ptr
00031088  __TI_ft_end
ffffffff  __TI_pprof_out_hndl
ffffffff  __TI_prof_data_size
ffffffff  __TI_prof_data_start
0000f4f5  __TI_readmsg
00000000  __TI_static_base__
00030620  __TI_tmpnams
0000f365  __TI_writemsg
0000e567  __TI_wrt_ok
0000accb  __adddf3
0000edf1  __aeabi_d2iz
0000efd9  __aeabi_d2uiz
0000accb  __aeabi_dadd
0000e4a5  __aeabi_dcmpeq
0000e4e1  __aeabi_dcmpge
0000e4f5  __aeabi_dcmpgt
0000e4cd  __aeabi_dcmple
0000e4b9  __aeabi_dcmplt
0000f525  __aeabi_dcmpun
0000b859  __aeabi_ddiv
0000c261  __aeabi_dmul
0000acc1  __aeabi_dsub
0000f66d  __aeabi_i2d
0000e22f  __aeabi_ldiv0
0000fcc5  __aeabi_memclr
0000fcc5  __aeabi_memclr4
0000fcc5  __aeabi_memclr8
0000fe95  __aeabi_memcpy
0000fe95  __aeabi_memcpy4
0000fe95  __aeabi_memcpy8
0000fcb9  __aeabi_memset
0000fcb9  __aeabi_memset4
0000fcb9  __aeabi_memset8
0000fa99  __aeabi_ui2d
0000fccd  __aeabi_uldivmod
ffffffff  __binit__
0000e1c1  __cmpdf2
0003108c  __cxa_new_handler
0000b859  __divdf3
0000e1c1  __eqdf2
0000edf1  __fixdfsi
0000efd9  __fixunsdfsi
0000f66d  __floatsidf
0000fa99  __floatunsidf
0000e151  __gedf2
0000e151  __gtdf2
0000e1c1  __ledf2
0000e1c1  __ltdf2
0000fe73  __mpu_init
0000c261  __muldf3
0000e1c1  __nedf2
0000fe98  __stack
00030000  __start___llvm_prf_bits
00030000  __start___llvm_prf_cnts
00030000  __stop___llvm_prf_bits
00030000  __stop___llvm_prf_cnts
0000acc1  __subdf3
0000d101  __udivmoddi4
0000f525  __unorddf2
0000e8a9  _c_int00
00030e7c  _device
00030cf0  _ftable
00031090  _lock
0000e307  _nop
00030f48  _stream
00000200  _sys_memory
UNDEFED   _system_post_cinit
0000f9f1  _system_pre_init
00031094  _unlock
0000fe8f  abort
0000bbe5  aligned_alloc
ffffffff  binit
0000e5c9  close
0000f555  exit
0000f399  finddevice
0000dbf5  fputc
0000c35d  free
0000fe87  fseek
0000e371  fseeko
00031054  gAddrTranslateConfig
00030f98  gAddrTranslateRegionConfig
00031040  gClockConfig
000306c0  gClockCtrl
00031098  gDebugLogZone
0003109c  gDebugP_uartDrvIndex
00030280  gHwiCtrl
00000000  gHwiP_vectorTable
00030c90  gMpuConfig
00030c9c  gMpuRegionConfig
00030844  gSciclientMap
00030fd8  gSciclientSecProxyCfg
00031070  gSocModules
00031028  gSocModulesClockFrequency
00031080  gUartConfig
000310a0  gUartConfigNum
00030cf0  gUartDmaConfig
000310a4  gUartDmaConfigNum
00030704  gUartHandle
00030ef4  gUartParams
0000e3d9  getdevice
0000f74d  lseek
0000f8f1  main
0000fe7b  malloc
0000bbe5  memalign
000306f8  parmbuf
0000fe11  putchar
0000fb2d  putchar_
0000fe8b  remove
0000c8c9  setvbuf
0000fd93  strlen
0000f779  unlink
0000f8c9  vprintf_
0000f7a5  write
GLOBAL SYMBOLS: SORTED BY Symbol Address
address   name
00009bd5  HwiP_post
00009c11  HwiP_init
00009f73  UART_open
0000aa63  MpuP_init
0000aae1  UART_write
0000acc1  __subdf3
0000accb  __adddf3
0000b029  UART_close
0000b859  __divdf3
0000bbe5  memalign
0000c261  __muldf3
0000c35d  free
0000c8c9  setvbuf
0000d051  UART_init
0000dbf3  Board_init
0000dbf5  fputc
0000dffb  Dpl_deinit
0000e151  __gedf2
0000e151  __gtdf2
0000e1c1  __cmpdf2
0000e1c1  __eqdf2
0000e1c1  __ledf2
0000e1c1  __ltdf2
0000e1c1  __nedf2
0000e307  _nop
0000e371  fseeko
0000e3d9  getdevice
0000e441  HOSTrename
0000e5c9  close
0000e7f9  HOSTlseek
0000e851  HOSTopen
0000e8a9  _c_int00
0000e901  HOSTread
0000e955  HOSTwrite
0000ebdf  Dpl_init
0000edf1  __fixdfsi
0000ef0d  HOSTunlink
0000f15d  HOSTclose
0000f38f  C$$IO$$
0000f399  finddevice
0000f525  __unorddf2
0000f555  exit
0000f74d  lseek
0000f779  unlink
0000f7a5  write
0000f8c9  vprintf_
0000f8f1  main
0000f93b  HwiP_inISR
0000f9a9  _Znwj
0000fb2d  putchar_
0000fd93  strlen
0000fe11  putchar
0000fe73  __mpu_init
0000fe7b  malloc
0000fe83  _ZdlPv
0000fe87  fseek
0000fe8b  remove
0000fe8e  C$$EXIT
0000fe8f  abort
0000fe98  __stack
00030280  gHwiCtrl
00030500  _CIOBUF_
00030500  __CIOBUF_
000306c0  gClockCtrl
000306f8  parmbuf
00030708  __BSS_END
00030c90  gMpuConfig
00030cf0  _ftable
00030e7c  _device
00030f48  _stream
00031090  _lock
00031094  _unlock
ffffffff  __binit__
ffffffff  binit
[276 symbols]
我们可以看到、地址0x13E98是.arm.exidx 段的基地址。 以下是此部分的原始转储
C:/ti/mcu_plus_sdk/am64x/examples/hello_world_cpp/am64x-evm/m4fss0-0_nortos/ti-arm-clang/hello_world_cpp.debug.out:	file format elf32-littlearm
Contents of section .ARM.exidx:
 13e98 6843ff7f 01000000                    hC......
在0x13E98处的预期值为0x6843ff7f。 在 CCS 报告错误之后0x13E98的实际值也是0x6843ff7f、如下所示
即使预期值和实际值都匹配、CCS 仍会报告验证错误。 您能说明一下 CCS 报告此错误的原因吗?
    此错误很常见、有许多潜在的根本原因。 这在 AM6x 等更复杂的多核器件上最为常见、并且通常是由于目标配置错误。
    有关更多详细信息、请参阅以下文章:
    https://dev.ti.com/tirex/explore/node?node=A__APy2XbLelxyqBB2Yz0WR.w__ccs_devtools__FUz-xrs__LATEST
    Ki 您好、
    感谢您发送编修。
    不过、我不明白的是 CCS 可以将内容写入存储器、因为我们可以看到地址0x13E98处存在该值。 那么、为什么 CCS 在读取该值时遇到问题呢? 如果我们可以让 CCS 转储读取值、它可以让我们深入了解 CCS 读取的内容。
    读取该值时不会出现问题。 不过、它检测到一些不匹配情况、
    也许报告的地址会误导人。 您能否打开完全验证并查看是否出现相同错误?
    Ki、您好!
    完全验证仍然会出现相同的错误
    普拉桑特
    如果我启用 No Verification & Auto Run、然后使用"Run -> Load -> Verify Program..."执行验证操作 加载应用程序后、验证成功
    如果我启用"No Verification & Auto Run"(无验证和自动运行),然后使用"Run -> Load -> Verify Program..."执行验证操作 加载应用程序后,验证成功
    是的、禁用验证将消除错误消息、因为没有勾选。 但问题是、为什么一开始就提出了该错误。 您能否提供该计划? 如果您愿意、可以通过专有 E2E 消息发送。
    这是我尝试加载的 M4F 可执行文件
    e2e.ti.com/.../hello_5F00_world_5F00_cpp.debug.out
    谢谢。 即使启用了验证、我也能够成功地将程序加载到我的 AM64 GP EVM 上:
    您具体使用的 CCS 版本是什么?
    您还可以附加您正在使用的 CCXML 文件吗?
    我已经试过所有 CCS v12、甚至是最新的 CCS v12.4、但是他们都报告同样的错误 下面随附的是 CCS v12.4的屏幕截图
    这是我在用于 AM64x 应用的所有 CCS 中使用的 CCXML
    e2e.ti.com/.../AM64x_5F00_XDS110.ccxml
    AM64x_XDS110.ccxml
    [/报价]
    配置似乎与我正在使用的类似(但我使用的是其他探针除外)。
    系统复位后首次加载时:
    但我得到这个错误:
    BLAZAR_Cortex_M4F_0:无法运行目标 CPU:(错误-1268 @ 0x1090001)器件已锁定在硬故障或 NMI。 复位器件、然后重试此操作。 如果错误仍然存在、请确认配置、对电路板执行下电上电、和/或尝试更可靠的 JTAG 设置(例如、降低 TCLK)。 (仿真软件包9.10.0.00080)
    程序无法正确运行。
    我注意到、当我然后重新载入程序时、0x13E98处的值变为:
    但 main 处没有错误且程序正确。
    如果您禁用了验证、然后再次重新加载程序、会看到相同的行为吗?
    小
    如果您禁用验证后重新加载程序,您是否看到相同的行为?
    是的、我看到同样的行为。 这实际上是在 MCU+ SDK 中 M4F 内核的引导例程(_c_int00)实现中的一个错误。 由于此错误、该值会在__STACK_END 地址处被覆盖。 然而、如果我理解正确的话、CCS 验证必须在内核开始运行之前进行。 这个错误应该不是问题。
    我还有一个有趣的更新:
    我的其他团队成员可以成功地在他的板上加载先前附加的相同 M4F 可执行文件、但在我拥有的板上不能加载。 然后、我使用他的板尝试加载可执行文件。 显然、它可以成功加载和运行。 这让我觉得这是否是电路板问题。 如果是、我想知道发生了什么变化、在我的板上我得到了与加载程序一样简单的任务上的错误。
    最后、这实际上是一个客户问题、幸好我能够使用我的板重新创建。 这是原始客户的主题、
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1230161/tmds64evm-data-verification-error-m4f
    [报价 userid="531297" url="~/support/processors-group/processors/f/processors-forum/1250137/ccstudio-file-loader-verification-failed-error-on-the-am64x-cortex-m4-core/4737029 #4737029"]但是、如果我理解正确、即使在内核上开始运行任何程序之前、也必须进行 CCS 验证。 所以,这个错误应该不是问题。[/报价]
    是的、回答正确。 验证在加载后但运行前发生。
    我的其他团队成员可以在他的电路板上成功加载相同的先前附加的 M4F 可执行文件,但在我拥有的电路板上不能加载。
    他会遇到同样的验证问题?
    然后我用他的板尝试加载可执行文件。 显然、它可以成功加载和运行。 这让我觉得这是否是电路板问题。
    听起来就像这样。 我感到困惑、但这会如何导致验证错误。 是否可以生成调试服务器日志并附加到此线程?
    https://software-dl.ti.com/ccs/esd/documents/ccs_diagnostic-logs.html
    您收到相同的验证问题吗?
    是的、我的板上具有相同的错误。
    您能否生成调试服务器日志并附加到此线程?
    e2e.ti.com/.../debug_5F00_server.log
    谢谢您的参与。 工程人员已查看过、这可能与另一个已知问题有关。 请与我私人进行 E2E 对话、进一步讨论。
    大家好、我想我有一个类似的问题。
    我已在另一个 TT 中解释过它:
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1252488/processor-sdk-am64x-gpmc-clock-can-not-be-set-and-the-read-values-doesn-t-make-sense/4740079#4740079
    您能帮助我如何重置电路板吗?
    博什拉
    [报价 userid="563969" url="~/support/processors-group/processors/f/processors-forum/1250137/ccstudio-file-loader-verification-failed-error-on-the-am64x-cortex-m4-core/4741660 #4741660"]您好,我觉得我有一个类似的问题。  [/报价]
    您的验证错误属于不同类型。 这是一个写入访问错误、而本线程中讨论的错误是假的正不匹配。 问题似乎没有关系。
    但从角度来看、我不能因为完整性错误而让我对应用程序进行编程。
    但在任何情况下、我无法对开发板进行编程、它似乎被锁定了。 您能帮助我如何重置它吗?
    博什拉
    但从角度来看,它不允许我对应用程序进行编程,因为存在完整性错误。  [/报价]
    Prashant 的问题是、在将目标上的值与可执行文件中的内容进行比较时出现错误的正错误消息。 写入内存时没有问题。 事实上、加载成功、但出于某种原因、调试器认为某些值未正确写入。
    您的问题似乎是存储器访问问题。 这些错误大多是由于目标未正确初始化而发生的。
    但是在任何情况下,我都无法对我的主板进行编程,而且它似乎被锁定了。 您能帮助我如何重置它吗?
    这是一个面向器件专家的问题。 我建议为此打开一个全新的主题。
    [/quote]
    好的。 谢谢、我会制作一个新的主题。
