[参考译文] AM62A7:构建 SBL
Guru**** 2538960 points
Other Parts Discussed in Thread: AM62A7
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1322204/am62a7-build-sbl
器件型号:AM62A7
如何在 SDK9.1中构建 am62a7的 SBL 映像?
    请参阅以下通用指南
    https://software-dl.ti.com/mcu-plus-sdk/esd/AM62AX/09_01_00_39/exports/docs/api_guide_am62ax/CCS_PROJECTS_PAGE.html
    https://software-dl.ti.com/mcu-plus-sdk/esd/AM62AX/09_01_00_39/exports/docs/api_guide_am62ax/MAKEFILE_BUILD_PAGE.html
    作为参考、下面是 SBL_NULL 的构建
    ~/ti/mcu_plus_sdk/am62a 09.01.00.39
    ❯ make -s -C examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang all
    Generating SysConfig files ...
    Running script...
    Validating...
    Generating Code (example.syscfg)...
    Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_dpl_config.c...
    Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_dpl_config.h...
    Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_drivers_config.c...
    Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_drivers_config.h...
    Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_drivers_open_close.c...
    Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_drivers_open_close.h...
    Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_pinmux_config.c...
    Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_power_clock_config.c...
    Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_board_config.c...
    Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_board_config.h...
    Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_board_open_close.c...
    Unchanged /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/generated/ti_board_open_close.h...
    Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: ../main.c
    Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: generated/ti_drivers_config.c
    Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: generated/ti_drivers_open_close.c
    Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: generated/ti_board_config.c
    Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: generated/ti_board_open_close.c
    Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: generated/ti_dpl_config.c
    Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: generated/ti_pinmux_config.c
    Compiling: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out: generated/ti_power_clock_config.c
    Linking: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out ...
    Linking: am62ax:r5fss0-0:nortos:ti-arm-clang sbl_null.release.out Done !!!
    Boot image: am62ax:r5fss0-0:nortos:ti-arm-clang /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/sbl_null.release.tiimage ...
    Boot image: am62ax:r5fss0-0:nortos:ti-arm-clang /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/sbl_null.release.tiimage Done !!!
    Boot image: am62ax:r5fss0-0:nortos:ti-arm-clang /home/p-shivhare/ti/mcu_plus_sdk/am62a/examples/drivers/boot/sbl_null/am62ax-sk/r5fss0-0_nortos/ti-arm-clang/sbl_null.release.hs_fs.tiimage Done !!!
    普拉桑特
