[参考译文] AM625:用于 PowerVR 的 libdrm
Guru**** 2546020 points
Other Parts Discussed in Thread: AM625
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1303603/am625-libdrm-for-powervr
器件型号:AM625
您好、TI!
您能为 AM625器件手动编译 libdrm 库吗? 由于此库的原始源代码不包含任何与 PowerVR 图形内核相关的功能、因此手动更新库时的操作方法会令人困惑。
下面是 在 modetest 上返回的新库:
am62xx-evm:~$ modetest
trying to open device 'i915'...failed
trying to open device 'amdgpu'...failed
trying to open device 'radeon'...failed
trying to open device 'nouveau'...failed
trying to open device 'vmwgfx'...failed
trying to open device 'omapdrm'...failed
trying to open device 'exynos'...failed
trying to open device 'tilcdc'...failed
trying to open device 'msm'...failed
trying to open device 'sti'...failed
trying to open device 'tegra'...failed
trying to open device 'imx-drm'...failed
trying to open device 'rockchip'...failed
trying to open device 'atmel-hlcdc'...failed
trying to open device 'fsl-dcu-drm'...failed
trying to open device 'vc4'...failed
trying to open device 'virtio_gpu'...failed
trying to open device 'mediatek'...failed
trying to open device 'meson'...failed
trying to open device 'pl111'...failed
trying to open device 'stm'...failed
trying to open device 'sun4i-drm'...failed
trying to open device 'armada-drm'...failed
trying to open device 'komeda'...failed
trying to open device 'imx-dcss'...failed
trying to open device 'mxsfb-drm'...failed
trying to open device 'simpledrm'...failed
trying to open device 'imx-lcdif'...failed
no device found
阿列克谢
    尊敬的 Alexey:
    命令 it modetest -M tidss。
    克鲁纳尔
