这似乎是一个错误。 gitweb 页面是可加载的,但我不能通过 HTTP 或 git 克隆。
[2024-09-30T14:40:51.822Z] NOTE: recipe libdce-3.00.15.00-r0: task do_fetch: Started
[2024-09-30T14:43:13.248Z] WARNING: libdce-3.00.15.00-r0 do_fetch: Failed to fetch URL git://git.omapzoom.org/repo/libdce.git;protocol=git;branch=master, attempting MIRRORS if available
[2024-09-30T14:45:34.680Z] ERROR: libdce-3.00.15.00-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH="/work/sources/oe-core/scripts:/work/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/libdce/3.00.15.00-r0/recipe-sysroot-native/usr/bin/arm-oe-linux-gnueabi:/work/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/libdce/3.00.15.00-r0/recipe-sysroot/usr/bin/crossscripts:/work/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/libdce/3.00.15.00-r0/recipe-sysroot-native/usr/sbin:/work/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/libdce/3.00.15.00-r0/recipe-sysroot-native/usr/bin:/work/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/libdce/3.00.15.00-r0/recipe-sysroot-native/sbin:/work/build/arago-tmp-default-glibc/work/armv7at2hf-neon-oe-linux-gnueabi/libdce/3.00.15.00-r0/recipe-sysroot-native/bin:/work/sources/bitbake/bin:/work/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/pokyuser"; LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat clone --bare --mirror git://git.omapzoom.org/repo/libdce.git /work/downloads/git2/git.omapzoom.org.repo.libdce.git --progress failed with exit code 128, no output
[2024-09-30T14:45:34.680Z] ERROR: libdce-3.00.15.00-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://git.omapzoom.org/repo/libdce.git;protocol=git;branch=master')
为与原始问题无关的问题打开一个新的主题()。 请在将来执行此操作。
