Thread 中讨论的其他器件:SK-AM62-LP
你(们)好
我使用 SK-AM62-LP EVM 板和 Linux SDK 版本 10_00_07_04。 系统从 SD 卡引导。
我发现 在使用 MTD-utils 时、写入 ospi nand 闪存的数据错误
下面的图片是细节,请帮助检查原因
你(们)好
下面的图片是细节,请帮助检查原因
与您发布的相关主题类似、我刚刚在 SK-AM62A 上进行了该尝试、您的步骤似乎可以正常工作、没有任何问题。 将尝试获取 SK-AM62-LP、以查看我是否能够重新创建您所看到的内容。
root@am62axx-evm:/# dd if=/dev/random of=tmp_write.txt bs=1 count=1M 1048576+0 records in 1048576+0 records out 1048576 bytes (1.0 MB, 1.0 MiB) copied, 4.80675 s, 218 kB/s root@am62axx-evm:/# mtd_debug write /dev/mtd5 0 1048576 tmp_write.txt Copied 1048576 bytes from tmp_write.txt to address 0x00000000 in flash root@am62axx-evm:/# mtd_debug read /dev/mtd5 0 1048576 tmp_read.txt Copied 1048576 bytes from address 0x00000000 in flash to tmp_read.txt root@am62axx-evm:/# ls -al total 2116 drwxr-xr-x 19 root root 4096 Jan 6 00:17 . drwxr-xr-x 19 root root 4096 Jan 6 00:17 .. drwxr-xr-x 3 root root 4096 Jan 1 00:00 .cache lrwxrwxrwx 1 root root 7 Mar 9 2018 bin -> usr/bin drwxr-xr-x 4 root root 4096 Mar 9 2018 boot drwxr-xr-x 18 root root 5140 Jan 5 23:47 dev drwxr-xr-x 54 root root 4096 Jan 1 00:00 etc drwxr-xr-x 3 root root 4096 Mar 9 2018 home lrwxrwxrwx 1 root root 7 Mar 9 2018 lib -> usr/lib drwx------ 2 root root 16384 Apr 5 2011 lost+found drwxr-xr-x 2 root root 4096 Mar 9 2018 media drwxr-xr-x 2 root root 4096 Mar 9 2018 mnt drwxr-xr-x 20 root root 4096 Jan 1 00:00 opt dr-xr-xr-x 178 root root 0 Jan 1 00:00 proc drwx------ 4 root root 4096 Jan 1 00:06 root drwxr-xr-x 22 root root 720 Jan 1 00:00 run lrwxrwxrwx 1 root root 8 Mar 9 2018 sbin -> usr/sbin drwxr-xr-x 2 root root 4096 Mar 9 2018 srv dr-xr-xr-x 12 root root 0 Jan 1 00:00 sys drwxrwxrwt 7 root root 180 Jan 1 00:00 tmp -rw-r--r-- 1 root root 1048576 Jan 6 00:17 tmp_read.txt -rw-r--r-- 1 root root 1048576 Jan 6 00:16 tmp_write.txt drwxr-xr-x 13 root root 4096 Mar 9 2018 usr drwxr-xr-x 9 root root 4096 Jan 1 00:00 var root@am62axx-evm:/# cmp tmp_read.txt tmp_write.txt root@am62axx-evm:/# diff tmp_read.txt tmp_write.txt root@am62axx-evm:/# hexdump -C tmp_write.txt | head 00000000 b0 46 a3 0c a5 ec 13 be c3 ab 33 ce e2 ba 8c 1a |.F........3.....| 00000010 b8 78 d9 7f 92 3c 18 20 15 70 da b3 f1 e9 db 67 |.x...<. .p.....g| 00000020 44 14 e4 1c b9 ab c5 ee 55 03 9c 53 8b 57 5e 50 |D.......U..S.W^P| 00000030 9b db e5 9b 97 f7 06 05 1b c6 7a ac df 53 28 3b |..........z..S(;| 00000040 76 0f b3 2e 09 88 c0 11 ae 72 bf 6d cc ae 25 84 |v........r.m..%.| 00000050 9a cf 1b a2 5b 2d 1f 15 12 de 48 48 62 dc ef db |....[-....HHb...| 00000060 3f 59 5f d1 d1 e9 61 f2 0d cb 96 64 57 7f d6 29 |?Y_...a....dW..)| 00000070 8f b4 97 30 31 a0 77 ad d2 46 36 b4 d2 33 60 6c |...01.w..F6..3`l| 00000080 97 d8 db ce eb 31 73 96 eb 91 ba f7 f0 0b 12 60 |.....1s........`| 00000090 2b 74 39 f5 bc 4e 78 14 52 ed f3 5e 95 1e 1e 61 |+t9..Nx.R..^...a| root@am62axx-evm:/# hexdump -C tmp_read.txt | head 00000000 b0 46 a3 0c a5 ec 13 be c3 ab 33 ce e2 ba 8c 1a |.F........3.....| 00000010 b8 78 d9 7f 92 3c 18 20 15 70 da b3 f1 e9 db 67 |.x...<. .p.....g| 00000020 44 14 e4 1c b9 ab c5 ee 55 03 9c 53 8b 57 5e 50 |D.......U..S.W^P| 00000030 9b db e5 9b 97 f7 06 05 1b c6 7a ac df 53 28 3b |..........z..S(;| 00000040 76 0f b3 2e 09 88 c0 11 ae 72 bf 6d cc ae 25 84 |v........r.m..%.| 00000050 9a cf 1b a2 5b 2d 1f 15 12 de 48 48 62 dc ef db |....[-....HHb...| 00000060 3f 59 5f d1 d1 e9 61 f2 0d cb 96 64 57 7f d6 29 |?Y_...a....dW..)| 00000070 8f b4 97 30 31 a0 77 ad d2 46 36 b4 d2 33 60 6c |...01.w..F6..3`l| 00000080 97 d8 db ce eb 31 73 96 eb 91 ba f7 f0 0b 12 60 |.....1s........`| 00000090 2b 74 39 f5 bc 4e 78 14 52 ed f3 5e 95 1e 1e 61 |+t9..Nx.R..^...a| root@am62axx-evm:/#
此致、Andreas
尊敬的 BERT:
开发人员认为这是一个已知问题、应通过此处提交来解决: https://git.ti.com/cgit/ti-linux-kernel/ti-linux-kernel/commit/?h=ti-linux-6.6.y-cicd&id=7866eaeb3c1ddb52b976c3e4140cdfbba28a74f3
我还没有该板、因此我现在无法自己尝试。 您可以将提交的内容应用于您的内核树 吗、看看这是否能解决您的问题?
此提交内容尚未包含在 SDK v10.0中、但会是我们即将推出的 SDK v10.1版本(即将发布)中的一部分。
此致、Andreas
