尊敬的专家:
我正在尝试在 J722S EVM 上测试 DFU 引导。 但我在 Ubuntu 上找不到 DFU 器件。 我在其他器件上测试的方法相同。
1.启动模式可能不正确,请双确认: SW3[1-8]:1100 1011 SW4[1-8]:0010 0000
2.我们在 EVM 上测试的功能,您可以在您这边尝试一下吗?
Fredy Zhang
尊敬的专家:
Fredy Zhang
您好、Fredy:
请参阅 SDK 文档了解以下内容:
Diwakar
该设置适用于 DFU。 方法。 但 DFU 有一些误差。
`μ A
[SDK-1000-j722s-DRA829]:~/startjacinto/tools/host-tools/k3-bootswitch/bin/j722s-evm> sudo dfu-util -l dfu-util 0.9 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2016 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to sourceforge.net/.../ Found DFU: [0451:6165] ver=0200, devnum=34, cfg=1, intf=0, path="3-4", alt=1, name="SocId", serial="01.00.00.00" Found DFU: [0451:6165] ver=0200, devnum=34, cfg=1, intf=0, path="3-4", alt=0, name="bootloader", serial="01.00.00.00" [SDK-1000-j722s-DRA829]:~/startjacinto/tools/host-tools/k3-bootswitch/bin/j722s-evm> sudo dfu-util -R -a bootloader -D tiboot3.bin dfu-util 0.9 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2016 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to sourceforge.net/.../ dfu-util: Invalid DFU suffix signature dfu-util: A valid DFU suffix will be required in a future dfu-util release!!! Opening DFU capable USB device... ID 0451:6165 Run-time device DFU version 0110 Claiming USB DFU Interface... Setting Alternate Setting #0 ... Determining device status: state = dfuIDLE, status = 0 dfuIDLE, continuing DFU mode device DFU version 0110 Device returned transfer size 512 Copying data from PC to DFU device Download [=========================] 100% 350004 bytes Download done. state(6) = dfuMANIFEST-SYNC, status(0) = No error condition is present dfu-util: unable to read DFU status after completion dfu-util: can't detach Resetting USB to switch back to runtime mode
你(们)好
我最终在10.00 SDK 上进行了测试、它适合我使用。
交换机配置
SW3[1-8]= 11001010
SW4[1-8]= 00000000
目标日志:
U-Boot SPL 2024.04-dirty (Dec 02 2024 - 16:24:07 +0530) SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') SPL initial stack usage: 17048 bytes Trying to boot from DFU ###################################################DOWNLOAD ... OK Ctrl+C to exit ... Authentication passed Authentication passed Authentication passed init_env from device 10 not supported! Authentication passed Authentication passed Starting ATF on ARM64 core... NOTICE: BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty NOTICE: BL31: Built : 16:09:05, Feb 9 2024 U-Boot SPL 2024.04-dirty (Dec 02 2024 - 16:27:12 +0530) SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') Trying to boot from DFU #####DOWNLOAD ... OK Ctrl+C to exit ... Authentication passed Authentication passed U-Boot 2024.04-dirty (Dec 02 2024 - 16:27:12 +0530) SoC: J722S SR1.0 HS-FS Model: Texas Instruments J722S EVM DRAM: 2 GiB (effective 8 GiB) Core: 79 devices, 29 uclasses, devicetree: separate MMC: mmc@fa10000: 0, mmc@fa00000: 1 Loading Environment from nowhere... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Net: eth0: ethernet@8000000port@1 Hit any key to stop autoboot: 0 => => =>
主机日志:
sudo dfu-util -v -R -a bootloader -D tiboot3.bin dfu-util 0.9 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2016 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to sourceforge.net/.../ dfu-util: Invalid DFU suffix signature dfu-util: A valid DFU suffix will be required in a future dfu-util release!!! Opening DFU capable USB device... ID 0451:6165 Run-time device DFU version 0110 Claiming USB DFU Interface... Setting Alternate Setting #0 ... Determining device status: state = dfuIDLE, status = 0 dfuIDLE, continuing DFU mode device DFU version 0110 Device returned transfer size 512 Copying data from PC to DFU device Download [=========================] 100% 349928 bytes Download done. Sent a total of 349928 bytes state(6) = dfuMANIFEST-SYNC, status(0) = No error condition is present dfu-util: unable to read DFU status after completion dfu-util: can't detach Resetting USB to switch back to runtime mode 0.00user 0.00system 0:02.47elapsed 0%CPU (0avgtext+0avgdata 2688maxresident)k 0inputs+0outputs (0major+223minor)pagefaults 0swaps sudo time dfu-util -v -R -a tispl.bin -D tispl.bin dfu-util 0.9 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2016 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to sourceforge.net/.../ dfu-util: Invalid DFU suffix signature dfu-util: A valid DFU suffix will be required in a future dfu-util release!!! Opening DFU capable USB device... ID 0451:6165 Run-time device DFU version 0110 Claiming USB DFU Interface... Setting Alternate Setting #0 ... Determining device status: state = dfuIDLE, status = 0 dfuIDLE, continuing DFU mode device DFU version 0110 Device returned transfer size 4096 Copying data from PC to DFU device Download [=========================] 100% 1026819 bytes Download done. Sent a total of 1026819 bytes state(7) = dfuMANIFEST, status(0) = No error condition is present state(2) = dfuIDLE, status(0) = No error condition is present Done! Resetting USB to switch back to runtime mode 0.00user 0.00system 0:02.40elapsed 0%CPU (0avgtext+0avgdata 3328maxresident)k 0inputs+0outputs (0major+386minor)pagefaults 0swaps sudo time dfu-util -v -R -a u-boot.img -D u-boot.img dfu-util 0.9 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2016 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to sourceforge.net/.../ dfu-util: Invalid DFU suffix signature dfu-util: A valid DFU suffix will be required in a future dfu-util release!!! Opening DFU capable USB device... ID 0451:6165 Run-time device DFU version 0110 Claiming USB DFU Interface... Setting Alternate Setting #1 ... Determining device status: state = dfuIDLE, status = 0 dfuIDLE, continuing DFU mode device DFU version 0110 Device returned transfer size 4096 Copying data from PC to DFU device Download [=========================] 100% 1182619 bytes Download done. Sent a total of 1182619 bytes state(7) = dfuMANIFEST, status(0) = No error condition is present state(2) = dfuIDLE, status(0) = No error condition is present Done! Resetting USB to switch back to runtime mode 0.00user 0.00system 0:02.93elapsed 0%CPU (0avgtext+0avgdata 3584maxresident)k 0inputs+0outputs (0major+426minor)pagefaults 0swaps
图像:
e2e.ti.com/.../tiboot3_2D00_j722s_2D00_hs_2D00_fs_2D00_evm.bin
e2e.ti.com/.../6170.u_2D00_boot.img
Diwakar
