主题中讨论的其他器件:SysConfig
我尝试使用 sys_mcspi.h 将 M4 SPI 配置转换为 PRU
MCSPI_ChConfig gConfigMcspi0ChCfg[CONFIG_MCSPI0_NUM_CH] =
.chNum = MCSPI_CHANNEL_0,
.frameFormat = MCSPI_FF_POL0_PHA0,
.bitRate = 12500000,
.csPolarity = MCSPI_CS_POL_LOW,
.trMode = MCSPI_TR_MODE_TX_RX,
.inputSelect = MCSPI_IS_D0,
.dpe0 = MCSPI_DPE_DISABLE,
.dpe1 = MCSPI_DPE_ENABLE,
.slvCsSelect = MCSPI_SLV_CS_SELECT_0,
.startBitEnable = FALSE,
.startBitPolarity = MCSPI_SB_POL_LOW,
.csIdleTime = MCSPI_TCS0_0_CLK,
.defaultTxData = 0x0U,
.txFifoTrigLvl = 16U,
.rxFifoTrigLvl = 16U,
我就是这样将它转换成 PRU 的:映射正确吗?
MCSPI0_CFG.CH0CONF = 0x0; MCSPI0_CFG.CH0CONF_bit.PHA = 0; //SPICLK phase MCSPI0_CFG.CH0CONF_bit.POL = 0; //SPICLK polarity MCSPI0_CFG.CH0CONF_bit.CLKD = 12500000; //Frequency divider for SPICLK MCSPI0_CFG.CH0CONF_bit.EPOL = 0; //SPIEN polarity MCSPI0_CFG.CH0CONF_bit.TRM = 2; //Transmit/Receive modes MCSPI0_CFG.CH0CONF_bit.IS = 0; //Input Select MCSPI0_CFG.CH0CONF_bit.DPE0 = 0; //Transmission Enable for data line 0 [SPIDATAGZEN[0]] MCSPI0_CFG.CH0CONF_bit.DPE1 = 1; //Transmission Enable for data line 1 [SPIDATAGZEN[1]] MCSPI0_CFG.CH0CONF_bit.SPIENSLV = 0; //Channel 0 only and target mode only MCSPI0_CFG.CH0CONF_bit.SBE = 0; //Start bit enable for SPI transfer
我不确定以下几点:
