[参考译文] bytes-3P-BE-AM6254:更改 CPU 频率失败-错误
Guru**** 2481465 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1455780/bytes-3p-be-am6254-failed-to-change-cpu-frequency---error
器件型号:BYTE-3P-BE-AM6254
您好、TI:
我目前在使用 AM6254ATGFHIAMCRQ1、启动过程完成后、出现下面附加的持续错误、
[   60.616265] cpufreq: __target_index: Failed to change cpu frequency: -34
[   61.010427] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   61.018651] cpufreq: __target_index: Failed to change cpu frequency: -34
[   61.413177] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   61.421551] cpufreq: __target_index: Failed to change cpu frequency: -34
[   91.517427] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   91.525514] cpufreq: __target_index: Failed to change cpu frequency: -34
[   91.540541] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   91.548777] cpufreq: __target_index: Failed to change cpu frequency: -34
[   91.717356] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   91.725589] cpufreq: __target_index: Failed to change cpu frequency: -34
[   91.750272] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   91.758456] cpufreq: __target_index: Failed to change cpu frequency: -34
[   91.965640] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   91.973949] cpufreq: __target_index: Failed to change cpu frequency: -34
[   92.178786] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   92.187026] cpufreq: __target_index: Failed to change cpu frequency: -34
[   92.817851] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   92.826155] cpufreq: __target_index: Failed to change cpu frequency: -34
[   93.239507] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   93.247674] cpufreq: __target_index: Failed to change cpu frequency: -34
[   94.738596] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   94.746863] cpufreq: __target_index: Failed to change cpu frequency: -34
[   95.747298] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   95.755384] cpufreq: __target_index: Failed to change cpu frequency: -34
[   96.658580] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   96.666776] cpufreq: __target_index: Failed to change cpu frequency: -34
[   96.993591] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   97.001652] cpufreq: __target_index: Failed to change cpu frequency: -34
[   97.937477] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   97.945755] cpufreq: __target_index: Failed to change cpu frequency: -34
[   98.247538] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   98.255609] cpufreq: __target_index: Failed to change cpu frequency: -34
[   99.216638] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[   99.224859] cpufreq: __target_index: Failed to change cpu frequency: -34
[  100.072273] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[  100.080494] cpufreq: __target_index: Failed to change cpu frequency: -34
[  100.739521] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
[  100.747674] cpufreq: __target_index: Failed to change cpu frequency: -34
[  100.867933] cpu cpu0: dev_pm_opp_set_rate: failed to find OPP for freq 1404000000 (-34)
就像这样,我遇到了错误,那么什么是实际问题,需要尝试哪些方法?
Sridhar
