主题中讨论的其他器件:SysConfig
你好
我有一个由 Linux 引导的 R5f 代码。 我需要保护 ADC 和 SPI 以便 Linux 不能读取数据。
我认为最好的解决方案是在 SysConfig 中使用防火墙。
当我启用附加的此 SysConfig 时、整个系统将停止工作。 我不知道我做了什么错。 启用 firewal 后、应用程序停止运行。
* These arguments were used when this file was generated. They will be automatically applied on subsequent loads
* via the GUI or CLI. Run CLI with '--help' for additional information on how to override these arguments.
* @cliArgs --device "AM64x" --package "ALV" --part "Default" --context "r5fss0-0" --product "MCU_PLUS_SDK_AM64x@09.00.00"
* @versions {"tool":"1.17.0+3128"}
* Import the modules used in this configuration.
const adc = scripting.addModule("/drivers/adc/adc", {}, false);
const adc1 = adc.addInstance();
const firewall = scripting.addModule("/drivers/firewall/firewall", {}, false);
const firewall1 = firewall.addInstance();
const gpio = scripting.addModule("/drivers/gpio/gpio", {}, false);
const gpio1 = gpio.addInstance();
const gpio2 = gpio.addInstance();
const ipc = scripting.addModule("/drivers/ipc/ipc");
const mcspi = scripting.addModule("/drivers/mcspi/mcspi", {}, false);
const mcspi1 = mcspi.addInstance();
const udma = scripting.addModule("/drivers/udma/udma", {}, false);
const udma1 = udma.addInstance();
const debug_log = scripting.addModule("/kernel/dpl/debug_log");
const mpu_armv7 = scripting.addModule("/kernel/dpl/mpu_armv7", {}, false);
const mpu_armv71 = mpu_armv7.addInstance();
const mpu_armv72 = mpu_armv7.addInstance();
const mpu_armv73 = mpu_armv7.addInstance();
const mpu_armv74 = mpu_armv7.addInstance();
const mpu_armv75 = mpu_armv7.addInstance();
const mpu_armv76 = mpu_armv7.addInstance();
const mpu_armv77 = mpu_armv7.addInstance();
const timer = scripting.addModule("/kernel/dpl/timer", {}, false);
const timer1 = timer.addInstance();
* Write custom configuration values to the imported modules.
adc1.$name = "CONFIG_ADC0";
adc1.ADC.$assign = "ADC0";
adc1.ADC.AIN0.$assign = "ADC0_AIN0";
adc1.ADC.AIN1.$assign = "ADC0_AIN1";
adc1.ADC.AIN2.$assign = "ADC0_AIN2";
adc1.ADC.AIN3.$used = false;
adc1.ADC.AIN4.$used = false;
adc1.ADC.AIN5.$used = false;
adc1.ADC.AIN6.$used = false;
adc1.ADC.AIN7.$used = false;
adc1.ADC.EXT_TRIGGER0.$used = false;
adc1.ADC.EXT_TRIGGER1.$used = false;
firewall1.$name = "CONFIG_FIREWALL0";
firewall1.regCfg.create(2);
firewall1.regCfg[0].$name = "FWL_REG_CFG0";
firewall1.regCfg[0].regIndex = 1;
firewall1.regCfg[0].instName = "ADC0";
firewall1.regCfg[0].interName = "FIFO";
firewall1.regCfg[0].fwlPriv1 = "MAIN_0_R5_0_SECURE";
firewall1.regCfg[1].$name = "FWL_REG_CFG1";
firewall1.regCfg[1].regIndex = 2;
firewall1.regCfg[1].instName = "MCSPI0";
firewall1.regCfg[1].interName = "CFG";
firewall1.regCfg[1].fwlPriv1 = "MAIN_0_R5_0_SECURE";
gpio1.pinDir = "OUTPUT";
gpio1.$name = "DIS_THYR_STM32";
gpio1.GPIO.gpioPin.$assign = "I2C1_SCL";
gpio2.pinDir = "OUTPUT";
gpio2.$name = "SIT_DIS_VCC_STM32";
gpio2.GPIO.gpioPin.$assign = "I2C1_SDA";
ipc.enableLinuxIpc = true;
mcspi1.$name = "CONFIG_MCSPI0";
mcspi1.intrEnable = "DMA";
mcspi1.inputSelect = "0";
mcspi1.dpe0 = "DISABLE";
mcspi1.dpe1 = "ENABLE";
mcspi1.SPI.$assign = "SPI0";
mcspi1.SPI.CLK.$assign = "SPI0_CLK";
mcspi1.SPI.D0.$assign = "SPI0_D0";
mcspi1.SPI.D1.$assign = "SPI0_D1";
mcspi1.mcspiChannel[0].$name = "CONFIG_MCSPI_CH0";
mcspi1.mcspiChannel[0].frameFormat = "POL0_PHA1";
mcspi1.mcspiChannel[0].advanced = true;
mcspi1.mcspiChannel[0].bitRate = 7000000;
mcspi1.mcspiChannel[0].CSn.$assign = "SPI0_CS0";
udma1.$name = "CONFIG_UDMA0";
mcspi1.udmaDriver = udma1;
debug_log.enableLogZoneInfo = true;
debug_log.enableMemLog = true;
mpu_armv71.$name = "CONFIG_MPU_REGION0";
mpu_armv71.size = 31;
mpu_armv71.attributes = "Device";
mpu_armv71.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv71.allowExecute = false;
mpu_armv72.$name = "CONFIG_MPU_REGION1";
mpu_armv72.size = 15;
mpu_armv72.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv73.$name = "CONFIG_MPU_REGION2";
mpu_armv73.baseAddr = 0x41010000;
mpu_armv73.size = 15;
mpu_armv73.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv74.$name = "CONFIG_MPU_REGION3";
mpu_armv74.baseAddr = 0x70000000;
mpu_armv74.size = 21;
mpu_armv74.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv75.$name = "CONFIG_MPU_REGION4";
mpu_armv75.attributes = "NonCached";
mpu_armv75.allowExecute = false;
mpu_armv75.size = 16;
mpu_armv75.baseAddr = 0x8D000000;
mpu_armv76.$name = "CONFIG_MPU_REGION5";
mpu_armv76.baseAddr = 0x80000000;
mpu_armv76.size = 31;
mpu_armv77.$name = "CONFIG_MPU_REGION6";
mpu_armv77.size = 20;
mpu_armv77.baseAddr = 0x8E000000;
mpu_armv77.attributes = "NonCached";
mpu_armv77.allowExecute = false;
timer1.$name = "CONFIG_TIMER0";
timer1.startTimer = true;
timer1.intrPriority = 2;
timer1.timerCallback = "schedulerTimerCallback";
* Pinmux solution for unlocked pins/peripherals. This ensures that minor changes to the automatic solver in a future
* version of the tool will not impact the pinmux you originally saw. These lines can be completely deleted in order to
* re-solve from scratch.
gpio1.GPIO.$suggestSolution = "GPIO1";
gpio2.GPIO.$suggestSolution = "GPIO1";
timer1.TIMER.$suggestSolution = "DMTIMER0";
