[参考译文] AM625:Android 引导加载程序编译错误
Guru**** 2473650 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1464535/am625-android-bootloader-build-error
器件型号:AM625
您好、TI:
您可以指导如何修复 Android 引导加载程序内部版本的错误(09.02.00或10.00.07)
我遵循以下指南:
https://software-dl.ti.com/processor-sdk-android/esd/AM62X/10_00_00/docs/android/Foundational_Components_Bootloaders .html
10_00/ti-bootloader-aosp/ti-u-boot$ swig -版本
SWG 版本4.3.0
使用/opt/rh/devtoolset-2/root/usr/bin/g ++编译[Linux]
已配置选项:+pcr
错误:
10_00/ti-bootloader-AOSP/ti-u-boot$ make ARCH=arm CROSS_COMPILE=$CC32 BINMAN_INDIRS=${LNX_FW_PATH}
scripts/kconfig.conf --syncconfig Kconfig
UPD include/config.h
CFG u-boot.cfg
Gen include/autoconf.mk
Gen include/autoconf.mk.dep.
CFG spl/ u-boot.cfg
Gen spl/include/autoconf.mk
UPD include/config/uboot.release
UPD 包含/生成/ version_autogenerated.h
UPD 包含/生成/ timestamp_autogenerated.h
UPD 包含/生成/ dt.h
ENVC 包含/生成/ env.txt
ENVP 包含/生成/ env.in
ENVT include/generated/ environment.h
cc lib/asm-offsets.s
UPD 包含/生成/ generic-asm-offsets.h
CC arch/arm/lib/asm-offsets.s
UPD 包含/生成/ asm-offsets.h
提供了脚本/dtc/pylibfdt/libfdt.i
PYMOD 重建
脚本‘/dt/pylibfdt/libfdt_wrap.c:在函数"_wrap_FDT_next_node"中:
Scripts/dtc/pylibfdt/libfdt_wrap.c:5581:17:错误:函数‘Swig_5274 Python_Append’的参数太少
5581 | resultobj = swig_intabj Python_Append (resultobj、val);
Scripts/dtc/pylibfdt/libfdt_wrap.c:1262:1:注:在此处声明
1262 | swig_PyObject(PyObject* Python_Append Result, PyObject* obj, int is_void){
脚本‘/故障诊断码(DTC)/ pylibfdt/libfdt_wow.c:在函数"my_wrap_FDT_get_mem_rsV"中:
scripts/dtc/pylibfdt/libfdt_wrap.c:6388:19:错误:函数‘Swig_4597'中 Python_Append 的参数太少
6388 | resultobj = swig_intabj Python_Append (resultobj、val);
scripts/dtc/pylibfdt/libfdt_wrap.c:6397:19:错误:函数‘SPython_Append’的参数太少
6397 | resultobj = swig_intabj Python_Append (resultobj、val);
脚本‘/故障诊断码(DTC)/ pylibfdt/libfdt_wow.c:在函数"_wrap_FDT_get_property_by_offset"中:
scripts/dtc/pylibfdt/libfdt_wrap.c:6639:19:错误:函数‘Swig_4597'中 Python_Append 的参数太少
6639 | resultobj = swig_intabj Python_Append (resultobj、buff);
