[参考译文] TDA4VM: TDA4VM: Edge AI :具有45个输出节点的模型未编译
Guru**** 2538960 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1464016/tda4vm-tda4vm-edge-ai-model-with-45-output-nodes-is-not-compiling
器件型号:TDA4VM
你好、Champs
我正在尝试运行一个自定义模型,有45个输出节点,当我尝试运行编译模型,它给出了错误,并在下面的共享日志文件中提到,
设置:
Edgeai : 9.27/10.07.
Docker
请告诉我如何解决此 e2e.ti.com/.../log_5F00_dd3d_5F00_fnc_5F00_4cam_5F00_vtow_5F00_reclass_5F00_cones_5F00_ped_5F00_finetuned_5F00_on_5F00_vtow_5F00_cones_5F00_ped.txt 问题
