[参考译文] IWR6843ISK-ODS:C674目标不支持 IWR68XX 器件[构建错误]
Guru**** 2558250 points
Other Parts Discussed in Thread: IWR6843ISK-ODS, IWR6843, IWR6843ISK, AWR1642, AWR1642BOOST-ODS
https://e2e.ti.com/support/sensors-group/sensors/f/sensors-forum/1114285/iwr6843isk-ods-iwr68xx-device-is-not-supported-for-the-c674-target-build-error
器件型号:IWR6843ISK-ODS
主题中讨论的其他器件: IWR6843AWR1642AWR1642BOOST-ODS
我正在尝试为毫米波传感器 IWR6843ISK-ODS 版本配置的毫米波物体检测实验室重建 DSS 和 MSS 源文件。 我使用的是毫米波 SDK 3.6版。
我在 这里看到过类似的论坛主题、但似乎已经过时了。
我已将项目器件设置为 IWR6843、并将 XDC 工具设置平台字段设置为使用"IWR68XX"。 这是不正确的吗?
当我重建时、我收到以下错误消息:
**** Clean-only build of configuration Debug for project odsdemo_16xx_dss ****
/home/jc34500/ti/ccs1120/ccs/utils/bin/gmake -k -j 16 clean -O
rm -rf  "odsdemo_16xx_dss.hex"  "configPkg/linker.cmd" "configPkg/compiler.opt"  "odsdemo_16xx_dss.xe674"
rm -rf "dss_config_edma_util.oe674" "dss_data_path.oe674" "dss_main.oe674" "odsdemo_aoaEstBF2D.oe674" "odsdemo_cfar.oe674" "odsdemo_clusteringDBscan3D.oe674" "odsdemo_clusteringDBscan3D_priv.oe674" "odsdemo_doppler.oe674" "odsdemo_dopplerProc_priv.oe674" "odsdemo_heatmap.oe674" "xwr16xx_cache.oe674"
rm -rf "dss_config_edma_util.d" "dss_data_path.d" "dss_main.d" "odsdemo_aoaEstBF2D.d" "odsdemo_cfar.d" "odsdemo_clusteringDBscan3D.d" "odsdemo_clusteringDBscan3D_priv.d" "odsdemo_doppler.d" "odsdemo_dopplerProc_priv.d" "odsdemo_heatmap.d" "xwr16xx_cache.d"
rm -rf  "configPkg/"
Finished clean
**** Build Finished ****
**** Build of configuration Debug for project odsdemo_16xx_dss ****
/home/jc34500/ti/ccs1120/ccs/utils/bin/gmake -k -j 16 all -O
rm -f /home/jc34500/mmWave/odsdemo_16xx_dss/odsdemo_16xx_dss.bin
Building file: "../dss_mmw.cfg"
Invoking: XDCtools
"/home/jc34500/ti/ccs1120/xdctools_3_62_01_16_core/xs" --xdcpath="/home/jc34500/ti/bios_6_53_02_00/packages;/home/jc34500/ti/mathlib_c674x_3_1_2_1;/home/jc34500/ti/dsplib_c674x_3_4_0_0;/home/jc34500/ti/dsplib_c64Px_3_4_0_0;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C674 -p ti.platforms.c6x:IWR68XX:false:600 -r debug -c "/home/jc34500/ti/ti-cgt-c6000_8.3.3" "../dss_mmw.cfg"
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
configuring dss_mmw.xe674 from package/cfg/dss_mmw_pe674.cfg ...
The IWR68XX device is not currently supported.
The following devices are supported for the C674 target:
	TMS320C6670
	TMS320DA830
	DM37XX
	TMS320TI816X
	DRA7XX
	AWR16XX
	Kepler
	TMS320TCI6634
	TMS320TCI6636
	TMS320TCI6638
	TMS320TCI6608
	TMS320TCI6614
	TMS320TCI6616
	TMS320TCI6618
	TMS320TCI6630K2L
	TMS320C66AK2H06
	TMS320C66AK2H12
	TMS320C66AK2E02
	TMS320C66AK2E05
	TCI66AK2G02
	TMS320C6654
	TMS320C6655
	TMS320C6657
	TMS320C6671
	TMS320C6672
	TMS320C6674
	TMS320C6678
	TMS320CDM740
	TMS320C6A8149
	TMS320C6A8168
	TMS320TI811X
	TMS320TI814X
	TMS320DM8148
	TMS320DM8168
	Arctic
	TMS320DA802
	TMS320DA803
	TMS320DA804
	TMS320DA805
	TMS320DA807
	TMS320DA808
	TMS320DA810
	TMS320DA828
	TMS320C6747
	TMS320C6745
	TMS320C6743
	OMAPL137
	OMAPL108
	OMAPL118
	OMAPL138
	TMS320DA840
	TMS320DA850
	TMS320C6742
	TMS320C6746
	TMS320C6748
	Vayu
	TDA3XX
	IWR16XX
subdir_rules.mk:17: recipe for target 'build-188486193-inproc' failed
js: "/home/jc34500/ti/bios_6_53_02_00/packages/ti/sysbios/family/c64p/Settings.xs", line 194: Error: Unsupported device!
    "/home/jc34500/ti/bios_6_53_02_00/packages/ti/sysbios/family/c64p/Settings.xs", line 220
    "/home/jc34500/ti/bios_6_53_02_00/packages/ti/sysbios/family/Settings.xs", line 170
    "/home/jc34500/ti/bios_6_53_02_00/packages/ti/sysbios/family/Settings.xs", line 123
    "/home/jc34500/mmWave/odsdemo_16xx_dss/dss_mmw.cfg", line 15
    "./package/cfg/dss_mmw_pe674.cfg", line 192
gmake: *** [package.mak:203: package/cfg/dss_mmw_pe674.xdl] Error 1
Warning: directory "/home/jc34500/ti/mathlib_c674x_3_1_2_1" on package path has a "packages" subdirectory - did you mean this instead?
Warning: directory "/home/jc34500/ti/dsplib_c674x_3_4_0_0" on package path has a "packages" subdirectory - did you mean this instead?
Warning: directory "/home/jc34500/ti/dsplib_c64Px_3_4_0_0" on package path has a "packages" subdirectory - did you mean this instead?
js: "/home/jc34500/ti/ccs1120/xdctools_3_62_01_16_core/packages/xdc/tools/Cmdr.xs", line 52: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
gmake[2]: *** [build-188486193-inproc] Error 1
gmake[1]: *** [build-188486193] Error 2
gmake[1]: Target 'main-build' not remade because of errors.
gmake: *** [all] Error 2
subdir_rules.mk:14: recipe for target 'build-188486193' failed
makefile:159: recipe for target 'all' failed
我是否使用了正确的目标? 如何使用 DSP C674正确编译这些文件?
    约书亚、您好!
    请使用 SDK 3.5。 对象检测实验室 目前还不支持 SDK 3.6。 此外、如果这不起作用、 请确保在下载 CCS 时包含以下软件包。
    如果仅切换到3.5不起作用、请确保已选中上述软件包、然后重试。
    最棒的
    不需要
    你好、Nate、
    感谢您的建议! 我按照您的说明操作、似乎不是 SDK 或封装问题。 当我重建时、仍然会得到以下控制台输出:
    rm -rf  "configPkg/"
    Finished clean
    rm -f /home/jc34500/Desktop/odsdemo/odsdemo_16xx_dss/odsdemo_16xx_dss.bin
    Invoking: XDCtools
    "/home/jc34500/ti/ccs1120/xdctools_3_62_01_16_core/xs" --xdcpath="/home/jc34500/ti/bios_6_53_02_00/packages;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C674 -p ti.platforms.c6x:IWR68XX:false:600 -r debug -c "/home/jc34500/ti/ti-cgt-c6000_8.3.3" "../dss_mmw.cfg"
    	TMS320C6670
    	TMS320DA830
    	DM37XX
    	TMS320TI816X
    	DRA7XX
    	AWR16XX
    	Kepler
    	TMS320TCI6634
    	TMS320TCI6636
    	TMS320TCI6638
    	TMS320TCI6608
    	TMS320TCI6614
    	TMS320TCI6616
    	TMS320TCI6618
    	TMS320TCI6630K2L
    	TMS320C66AK2H06
    	TMS320C66AK2H12
    	TMS320C66AK2E02
    	TMS320C66AK2E05
    	TCI66AK2G02
    	TMS320C6654
    	TMS320C6655
    	TMS320C6657
    	TMS320C6671
    	TMS320C6672
    	TMS320C6674
    	TMS320C6678
    	TMS320CDM740
    	TMS320C6A8149
    	TMS320C6A8168
    	TMS320TI811X
    	TMS320TI814X
    	TMS320DM8148
    	TMS320DM8168
    	Arctic
    	TMS320DA802
    	TMS320DA803
    	TMS320DA804
    	TMS320DA805
    	TMS320DA807
    	TMS320DA808
    	TMS320DA810
    	TMS320DA828
    	TMS320C6747
    	TMS320C6745
    	TMS320C6743
    	OMAPL137
    	OMAPL108
    	OMAPL118
    	OMAPL138
    	TMS320DA840
    	TMS320DA850
    	TMS320C6742
    	TMS320C6746
    	TMS320C6748
    	Vayu
    	TDA3XX
    	IWR16XX
        "/home/jc34500/Desktop/odsdemo/odsdemo_16xx_dss/dss_mmw.cfg", line 15
    它是否特别与 C674库有关?
    此外、我不知道这是否有用、但我收到了以下警告和错误:
    你有其他想法吗?
    约书亚
    约书亚、您好!
    您可以尝试使用 CCS 11.1吗? 我也会将其重新路由至 CCS 团队进行评论。
    最棒的
    不需要
    约书亚、您好!
    您使用的是哪个工具箱版本和 Linux 发行版+版本?
    Ki
    您好、ki:
    我使用  的是毫米波汽车工具箱(v3.6)和 Ubuntu 18.04 LTS。
    但是、 由于这个线程、我现在正在考虑使用毫米波工业工具箱、因为我的特定传感器是 IWR6843ISK-ODS。 汽车工具箱中的实验室是否也可用于 IWR6843ISK-ODS 传感器? 如果没有、您是否知道 如何从工业工具箱正确构建固件
    约书亚
    你好、Nate、
    尝试使用 CCS 11.1似乎不会更改输出。
    约书亚
    [引用 userid="526098" url="~/support/sensor-group/sensors/f/sensor-forums/1114285/iwr6843isk -ods-iwr68xx-device-is not supported-for-the -c674-target-build-error/4135414#4135414"]我正在使用   mmWave 工具箱和 Ubuntu v3.6[引用]
    谢谢。 我将尝试在本地设置此环境、并让您了解它的运行情况。
    ~引用 userid="526098" URL"/support/sensors-group/sensors/f/sensor-forums/1114285/iwr6843ISK-ODS-iwr68xx-device-isor-isor-low-supported for the -c674-target-build-error/4135414#4135414"]但是、 由于此线程现在使用的是特定的毫米波工具箱、因此我现在考虑了 IWR6843ISK 工业传感器。 汽车工具箱中的实验室是否也可用于 IWR6843ISK-ODS 传感器? 如果没有、您是否知道 如何从工业工具箱正确构建固件
    在这个问题上,我会有很大帮助。
    Nate、您能看一下吗?
    Ki
    [~ userid="526098" url="/support/sensors-group/sensors/f/sensors-forumer/1114285/iwr6843isk -ods-iwr68xx-device-is not supported for the -c674-target-build-error"]我已将项目器件设置为 IWR6843、并将 XDC 工具设置为使用"IWR68XX"字段设置。 这是否不正确?
    我得到相同的误差。 IWR68XX 似乎不是受支持的平台、至少对于此 XDCtools 版本而言是如此。
    那么、您是否会说这是 XDCtools 3.62.1.16_core 的问题? 这会使我失望、因为我能够从工业工具箱(位于~/ti/mmwave_industrial_toolbox_4_11_0/labs/out_for_box_Demo/src/src/xwr6843ISK)中获取源文件以成功构建、并且它还使用相同版本的 XDCtools 和相同的设置(目标、平台):
    唯一不同的是构建配置文件设置、但将其更改为匹配并不会产生影响:
    Invoking: XDCtools
    "/home/jc34500/ti/ccs1120/xdctools_3_62_01_16_core/xs" --xdcpath="/home/jc34500/ti/bios_6_53_02_00/packages;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C674 -p ti.platforms.c6x:IWR68XX:false:600 -r release -c "/home/jc34500/ti/ti-cgt-c6000_8.3.3" "../dss_mmw.cfg"
    下面是工业工具箱项目的构建输出、供参考:
    Building file: "../mmw_dss.cfg"
    Invoking: XDCtools
    "/home/jc34500/ti/ccs1120/xdctools_3_62_01_16_core/xs" --xdcpath="/home/jc34500/ti/bios_6_73_01_01/packages;/home/jc34500/ti/mathlib_c674x_3_1_2_1;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C674 -p ti.platforms.c6x:IWR68XX:false:600 -r release -c "/home/jc34500/ti/ti-cgt-c6000_8.3.3" --compileOptions "--enum_type=int " "../mmw_dss.cfg"
    configuring mmw_dss.xe674 from package/cfg/mmw_dss_pe674.cfg ...
    generating custom ti.sysbios library makefile ...
    Starting build of library sources ...
    making /home/jc34500/Desktop/sdkdemo/mmwave_sdk_68xx_dsp_dss/src/sysbios/sysbios.ae674 ...
    Build of libraries done.
    cle674 package/cfg/mmw_dss_pe674.c ...
    Finished building: "../mmw_dss.cfg"
     导致物体检测实验室项目显示"目前不支持 IWR68XX 器件"的原因是什么。 是因为物体检测实验室来自汽车工具箱、而不是工业工具箱? 这让我回到了问题: 汽车工具箱中的实验室是否也可用于 IWR6843ISK-ODS 传感器?
    约书亚
    约书亚、您好!
    [引用 userid="526098" URL"~/support/sensor-group/sensors/f/sensor-forums/1114285/iwr6843isk ODS-iwr68xx-device-isor-isnot supported for the -c674-target-build-error/4136574#4136574"]是否也可以将工具箱中的实验用于引用 IWR6843ISK?]
    我将把这个主题转发给汽车团队、尝试回答这个问题、但是、我肯定会建议使用 AWR1642作为障碍物检测实验室建议的用户指南。
    此外、您是否对障碍物检测实验室进行了任何修改? 您似乎更改了目标。 在未修改的情况下运行时、它是否会生成?
    最棒的
    不需要
    我们建议您为 IWR6843ISK-ODS EVM 使用毫米波 SDK 3.6演示。
    障碍物检测演示仅在 AWR1642BOOST-ODS EVM 上受支持
    labs\lab0004_obstance_detection
    谢谢你
    Cesar
    您好、Cesar、
    感谢您的明确回答!
    最棒的
    约书亚
    你好、Nate、
    感谢您的推荐! 我确实认为这是问题所在。 当我未经修改运行它时、我仍然会遇到一些构建错误:
    rm -rf  "configPkg/"
    Finished clean
    Invoking: XDCtools
    "/home/jc34500/ti/ccs1120/xdctools_3_62_01_16_core/xs" --xdcpath="/home/jc34500/ti/bios_6_53_02_00/packages;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C674 -p ti.platforms.c6x:AWR16XX:false:600 -r release -c "/home/jc34500/ti/ti-cgt-c6000_8.3.3" "../dss_mmw.cfg"
    making /home/jc34500/Desktop/odsdemo/odsdemo_16xx_dss/src/sysbios/sysbios.ae674 ...
    cle674 package/cfg/dss_mmw_pe674.c ...
    Finished building: "../dss_mmw.cfg"
    Building file: "../odsdemo_aoaEstBF2D.c"
    Invoking: C6000 Compiler
    "/home/jc34500/ti/ti-cgt-c6000_8.3.3/bin/cl6x" -mv6740 --abi=eabi -O3 --include_path="/home/jc34500/Desktop/odsdemo/odsdemo_16xx_dss" --include_path="/home/jc34500/ti/mmwave_sdk_03_04_00_03/packages" --include_path="/packages" --include_path="/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="/home/jc34500/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP/c674" --include_path="/home/jc34500/ti/ti-cgt-c6000_8.3.3/include" --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=MMWAVE_L3RAM_SIZE=0xc0000 --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="odsdemo_aoaEstBF2D.d_raw" --cmd_file="configPkg/compiler.opt"  "../odsdemo_aoaEstBF2D.c"
    >> Compilation failure
    subdir_rules.mk:7: recipe for target 'odsdemo_aoaEstBF2D.oe674' failed
    "../odsdemo_aoaEstBF2D.c", line 42: fatal error #1965: cannot open source file "ti/mathlib/mathlib.h"
    1 catastrophic error detected in the compilation of "../odsdemo_aoaEstBF2D.c".
    Compilation terminated.
    gmake[1]: *** [odsdemo_aoaEstBF2D.oe674] Error 1
    "../odsdemo_clusteringDBscan3D_priv.c", line 39: fatal error #1965: cannot open source file "ODSDemo_clusteringDBscan3D_priv.h"
    1 catastrophic error detected in the compilation of "../odsdemo_clusteringDBscan3D_priv.c".
    gmake[1]: *** [odsdemo_clusteringDBscan3D_priv.oe674] Error 1
    "../odsdemo_clusteringDBscan3D.c", line 43: fatal error #1965: cannot open source file "ti/mathlib/mathlib.h"
    1 catastrophic error detected in the compilation of "../odsdemo_clusteringDBscan3D.c".
    gmake[1]: *** [odsdemo_clusteringDBscan3D.oe674] Error 1
    "../odsdemo_cfar.c", line 5: fatal error #1965: cannot open source file "ti/mathlib/mathlib.h"
    1 catastrophic error detected in the compilation of "../odsdemo_cfar.c".
    gmake[1]: *** [odsdemo_cfar.oe674] Error 1
    "../odsdemo_doppler.c", line 5: fatal error #1965: cannot open source file "ti/mathlib/mathlib.h"
    1 catastrophic error detected in the compilation of "../odsdemo_doppler.c".
    gmake[1]: *** [odsdemo_doppler.oe674] Error 1
    "../odsdemo_heatmap.c", line 5: fatal error #1965: cannot open source file "ti/mathlib/mathlib.h"
    1 catastrophic error detected in the compilation of "../odsdemo_heatmap.c".
    gmake[1]: *** [odsdemo_heatmap.oe674] Error 1
    Building file: "../odsdemo_clusteringDBscan3D_priv.c"
    "/home/jc34500/ti/ti-cgt-c6000_8.3.3/bin/cl6x" -mv6740 --abi=eabi -O3 --include_path="/home/jc34500/Desktop/odsdemo/odsdemo_16xx_dss" --include_path="/home/jc34500/ti/mmwave_sdk_03_04_00_03/packages" --include_path="/packages" --include_path="/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="/home/jc34500/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP/c674" --include_path="/home/jc34500/ti/ti-cgt-c6000_8.3.3/include" --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=MMWAVE_L3RAM_SIZE=0xc0000 --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="odsdemo_clusteringDBscan3D_priv.d_raw" --cmd_file="configPkg/compiler.opt"  "../odsdemo_clusteringDBscan3D_priv.c"
    >> Compilation failure
    subdir_rules.mk:7: recipe for target 'odsdemo_clusteringDBscan3D_priv.oe674' failed
    Building file: "../odsdemo_clusteringDBscan3D.c"
    "/home/jc34500/ti/ti-cgt-c6000_8.3.3/bin/cl6x" -mv6740 --abi=eabi -O3 --include_path="/home/jc34500/Desktop/odsdemo/odsdemo_16xx_dss" --include_path="/home/jc34500/ti/mmwave_sdk_03_04_00_03/packages" --include_path="/packages" --include_path="/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="/home/jc34500/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP/c674" --include_path="/home/jc34500/ti/ti-cgt-c6000_8.3.3/include" --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=MMWAVE_L3RAM_SIZE=0xc0000 --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="odsdemo_clusteringDBscan3D.d_raw" --cmd_file="configPkg/compiler.opt"  "../odsdemo_clusteringDBscan3D.c"
    >> Compilation failure
    subdir_rules.mk:7: recipe for target 'odsdemo_clusteringDBscan3D.oe674' failed
    Building file: "../odsdemo_cfar.c"
    "/home/jc34500/ti/ti-cgt-c6000_8.3.3/bin/cl6x" -mv6740 --abi=eabi -O3 --include_path="/home/jc34500/Desktop/odsdemo/odsdemo_16xx_dss" --include_path="/home/jc34500/ti/mmwave_sdk_03_04_00_03/packages" --include_path="/packages" --include_path="/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="/home/jc34500/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP/c674" --include_path="/home/jc34500/ti/ti-cgt-c6000_8.3.3/include" --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=MMWAVE_L3RAM_SIZE=0xc0000 --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="odsdemo_cfar.d_raw" --cmd_file="configPkg/compiler.opt"  "../odsdemo_cfar.c"
    >> Compilation failure
    subdir_rules.mk:7: recipe for target 'odsdemo_cfar.oe674' failed
    "../dss_data_path.c", line 86: fatal error #1965: cannot open source file "DSP_fft32x32.h"
    1 catastrophic error detected in the compilation of "../dss_data_path.c".
    gmake[1]: *** [dss_data_path.oe674] Error 1
    Building file: "../odsdemo_doppler.c"
    "/home/jc34500/ti/ti-cgt-c6000_8.3.3/bin/cl6x" -mv6740 --abi=eabi -O3 --include_path="/home/jc34500/Desktop/odsdemo/odsdemo_16xx_dss" --include_path="/home/jc34500/ti/mmwave_sdk_03_04_00_03/packages" --include_path="/packages" --include_path="/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="/home/jc34500/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP/c674" --include_path="/home/jc34500/ti/ti-cgt-c6000_8.3.3/include" --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=MMWAVE_L3RAM_SIZE=0xc0000 --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="odsdemo_doppler.d_raw" --cmd_file="configPkg/compiler.opt"  "../odsdemo_doppler.c"
    >> Compilation failure
    subdir_rules.mk:7: recipe for target 'odsdemo_doppler.oe674' failed
    Building file: "../odsdemo_heatmap.c"
    "/home/jc34500/ti/ti-cgt-c6000_8.3.3/bin/cl6x" -mv6740 --abi=eabi -O3 --include_path="/home/jc34500/Desktop/odsdemo/odsdemo_16xx_dss" --include_path="/home/jc34500/ti/mmwave_sdk_03_04_00_03/packages" --include_path="/packages" --include_path="/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="/home/jc34500/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP/c674" --include_path="/home/jc34500/ti/ti-cgt-c6000_8.3.3/include" --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=MMWAVE_L3RAM_SIZE=0xc0000 --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="odsdemo_heatmap.d_raw" --cmd_file="configPkg/compiler.opt"  "../odsdemo_heatmap.c"
    >> Compilation failure
    subdir_rules.mk:7: recipe for target 'odsdemo_heatmap.oe674' failed
    Building file: "../dss_data_path.c"
    "/home/jc34500/ti/ti-cgt-c6000_8.3.3/bin/cl6x" -mv6740 --abi=eabi -O3 --include_path="/home/jc34500/Desktop/odsdemo/odsdemo_16xx_dss" --include_path="/home/jc34500/ti/mmwave_sdk_03_04_00_03/packages" --include_path="/packages" --include_path="/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="/home/jc34500/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP/c674" --include_path="/home/jc34500/ti/ti-cgt-c6000_8.3.3/include" --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=MMWAVE_L3RAM_SIZE=0xc0000 --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="dss_data_path.d_raw" --cmd_file="configPkg/compiler.opt"  "../dss_data_path.c"
    >> Compilation failure
    subdir_rules.mk:7: recipe for target 'dss_data_path.oe674' failed
    "/home/jc34500/ti/mmwave_sdk_03_04_00_03/packages/ti/demo/utils/mmwdemo_monitor.h", line 64: error #102: "MmwDemo_AnaMonitorCfg_t" has already been declared in the current scope
    "/home/jc34500/ti/mmwave_sdk_03_04_00_03/packages/ti/demo/utils/mmwdemo_monitor.h", line 71: error #258: invalid redeclaration of type name "MmwDemo_AnaMonitorCfg" (declared at line 365 of "/home/jc34500/Desktop/odsdemo/odsdemo_16xx_dss/./common/mmw_config.h")
    "../dss_main.c", line 98: fatal error #1965: cannot open source file "ti/mathlib/mathlib.h"
    2 errors and 1 catastrophic error detected in the compilation of "../dss_main.c".
    gmake[1]: *** [dss_main.oe674] Error 1
    Building file: "../xwr16xx_cache.c"
    "/home/jc34500/ti/ti-cgt-c6000_8.3.3/bin/cl6x" -mv6740 --abi=eabi -O3 --include_path="/home/jc34500/Desktop/odsdemo/odsdemo_16xx_dss" --include_path="/home/jc34500/ti/mmwave_sdk_03_04_00_03/packages" --include_path="/packages" --include_path="/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="/home/jc34500/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP/c674" --include_path="/home/jc34500/ti/ti-cgt-c6000_8.3.3/include" --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=MMWAVE_L3RAM_SIZE=0xc0000 --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="xwr16xx_cache.d_raw" --cmd_file="configPkg/compiler.opt"  "../xwr16xx_cache.c"
    Finished building: "../xwr16xx_cache.c"
    Building file: "../dss_main.c"
    "/home/jc34500/ti/ti-cgt-c6000_8.3.3/bin/cl6x" -mv6740 --abi=eabi -O3 --include_path="/home/jc34500/Desktop/odsdemo/odsdemo_16xx_dss" --include_path="/home/jc34500/ti/mmwave_sdk_03_04_00_03/packages" --include_path="/packages" --include_path="/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="/home/jc34500/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP/c674" --include_path="/home/jc34500/ti/ti-cgt-c6000_8.3.3/include" --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=MMWAVE_L3RAM_SIZE=0xc0000 --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="dss_main.d_raw" --cmd_file="configPkg/compiler.opt"  "../dss_main.c"
    >> Compilation failure
    subdir_rules.mk:7: recipe for target 'dss_main.oe674' failed
    Building file: "../dss_config_edma_util.c"
    "/home/jc34500/ti/ti-cgt-c6000_8.3.3/bin/cl6x" -mv6740 --abi=eabi -O3 --include_path="/home/jc34500/Desktop/odsdemo/odsdemo_16xx_dss" --include_path="/home/jc34500/ti/mmwave_sdk_03_04_00_03/packages" --include_path="/packages" --include_path="/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="/home/jc34500/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP/c674" --include_path="/home/jc34500/ti/ti-cgt-c6000_8.3.3/include" --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=MMWAVE_L3RAM_SIZE=0xc0000 --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="dss_config_edma_util.d_raw" --cmd_file="configPkg/compiler.opt"  "../dss_config_edma_util.c"
    Finished building: "../dss_config_edma_util.c"
    Building file: "../odsdemo_dopplerProc_priv.c"
    "/home/jc34500/ti/ti-cgt-c6000_8.3.3/bin/cl6x" -mv6740 --abi=eabi -O3 --include_path="/home/jc34500/Desktop/odsdemo/odsdemo_16xx_dss" --include_path="/home/jc34500/ti/mmwave_sdk_03_04_00_03/packages" --include_path="/packages" --include_path="/packages/ti/dsplib/src/DSP_fft16x16/c64P" --include_path="/packages/ti/dsplib/src/DSP_fft32x32/c64P" --include_path="/home/jc34500/ti/dsplib_c674x_3_4_0_0/packages/ti/dsplib/src/DSPF_sp_fftSPxSP/c674" --include_path="/home/jc34500/ti/ti-cgt-c6000_8.3.3/include" --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=MMWAVE_L3RAM_SIZE=0xc0000 --define=DebugP_ASSERT_ENABLED -g --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --preproc_dependency="odsdemo_dopplerProc_priv.d_raw" --cmd_file="configPkg/compiler.opt"  "../odsdemo_dopplerProc_priv.c"
    Finished building: "../odsdemo_dopplerProc_priv.c"
    但没关系、因为我只能使用 IWR6843ISK-ODS 传感器、所以我将停止尝试使用该实验。
    最棒的
    约书亚
    谢谢你
    Cesar
