[参考译文] IWR1443:IWR1443
Guru**** 2555190 points
Other Parts Discussed in Thread: IWR1443
https://e2e.ti.com/support/sensors-group/sensors/f/sensors-forum/1001991/iwr1443-iwr1443
器件型号:IWR1443
尝试从 MMWave_industrial_toolbox_4_3_1编译4K_FFT_lab in、但遇到以下错误
***为项目4K_FFT_LAB 构建配置调试****
"C:\\ti\\ccs1011\\ccs\\utils\\bin\\gmake"-k -j 4 all -O
RM -f C:/business/software/code composer workspace/4K_FFT_lab/xwr14xx_4k_fft_lab_mss.bin
Makefile:199:目标"预编译"的配方失败
Process_begin:CreateProcess (NULL、rm -f C:/business/software/code composer workspace/4K_FFT_lab /xwr14xx_4K_FFT_lab:ms.bin、...) 失败。
gmaking[1]:[预编译]错误2 (忽略)
构建文件:"../sensor_mgmt.c"
调用:ARM 编译器
"c:/ti/ti-cgt-arm_16.9.6.LTS/bin/armcl "-mv7R4 --code_state=16 --float_support=VFPv3D16 -me -O3 --include_path="C:/business/software/code composer workspace/4K_FFT_lab"--include_path="cinclude_path="C /ti/mmwave_sdk_02_01_00_04/packages:/ti/ti-cgt-arm_16.9.6.LTS/include --define=us_subsensors=-exit_rom-code_display_subsensors=-code_exitive_display_rom-code_display_subs=-exitive_display_subs=-rom-code_display_subs=-codest-rom-code_display_subs=-exitive_display_subs=-codest-codest-rom-codest_subs=-codest-ex=-code_subs=-rom-codest_subs=-codest_ex=-rom-codest_subs=-code_display_subs=-rom-codest_ex=-codest-rom-codest_subs=-codest_subs=-code_subs=-code_subs=-
>>编译失败
subdir_rules.mk:9:目标'senser_mgmt.oer4f'的配方失败
"./sensor_mgmt.c"、第405行:警告#169-D:类型"int32_t *"的参数与类型"rlCalibrationData_t *"的参数不兼容
"./sensor_mgmt.c"、第405行:错误#167:函数调用中的参数太少
1在编译"./sensor_mgmt.c"时检测到错误。
gmaking[1]:***[sensor_mgmt.oer4f]错误1.
编译文件:"../main.c"
调用:ARM 编译器
"c:/ti/ti-cgt-arm_16.9.6.LTS/bin/armcl "-mv7R4 --code_state=16 --float_support=VFPv3D16 -me -O3 --include_path="C:/business/software/code composer workspace/4K_FFT_lab"--include_path="ce_path="C /ti/mmwave_sdk_02_01_00_04/packages:/ti/ti-cgt-arm_16.9.6.LTS/include --include_path="cus=excus=trab_subsection=-exit_us=-code_exit_defination=-rom_us-rom_us=-code_display_exit_decomination=-rom-code_subs_defination=-ex-us-us_us_subsepage=-code_display_exit_subs=-code.prine_display_subs=-rom-code_display_subs=-rom-code_display_subs=-us=-us_exit_ex-us=-code_display_subs=-us.us.us_exit_us.us=-code_display_subs=-us.us.trab-code_display_subsection=-us.us.
>>编译失败
subdir_rules.mk:9:目标'main.oer4f'的配方失败
"./main.c"、第708行:错误#20:标识符"mmWave_L3RAM_NUM_Bank"未定义
"./main.c"、第708行:错误#20:标识符"mmWave_SHMEM_BANK_SIZE "未定义
"./main.c"、第1909行:错误#20:标识符"rlRfInitcomplete_t"未定义
"./main.c"、第1909行:错误#20:标识符"ptrRFInitCompleteMessage"未定义
"../main.c"、第1913行:错误#29:需要表达式
"./main.c"、第1913行:错误#66:预期为";"
在"../main.c"的编译中检测到6个错误。
gmaking[1]:***[main.oer4f]错误1.
gmake[1]:不会由于错误而重做目标'main-build'。
gmake:***[全部]错误2.
Makefile:165:目标“全部”的配方失败
****构建完成**** "
还尝试了工业工具箱的早期版本、但遇到了类似的错误。
有什么建议吗?
Henry
    你(们)好、亨利
    您安装了哪个版本的毫米波 SDK? 它是否与实验室用户指南中指示的版本相匹配?
    此外、请记住、此实验已被弃用、可能与最新的 IWR1443器件版本(ES3.0)不兼容。
    AG
    尊敬的 AG:
    我试过 SKD 2.1和3.2。 我将 尝试 使用用户指南中提到的1.2.05。
    Henry
