Thread 中讨论的其他器件:IWR1443、 SYSBIOS
工具/软件:Code Composer Studio
构建日志如下所示
请告诉我如何更正
****为项目 MMW_MSS_14xx 构建配置调试****
"C:\\ti\\ccs740\\ccsv7\\utils\\bin\\gmake"-k -j 2 all -O
rm -f C:/Dev/BASE/IWR1443/mmwave/mmw_mss_14xx/xwr14xx_mmw_mss.bin
Makefile:195:目标"预编译"的配方失败
Process_begin:CreateProcess (NULL、rm -f C:/Dev/BASE/IWR1443/mmwave/mmw_mss_14xx/xwr14xx_mmw_mss.bin、...) 失败。
制造(e=2):
gmaking[1]:[预编译]错误2 (忽略)
'building file:"../MMW.cfg"'(构建文件:"./mmw.cfg")
'调用:XDCtools '
"c:/ti/xdctools_3_50_00_10_core/xs "--xdcpath="C:/ti/bios_6_52_00_12/packages;C:/ti/ccs740/ccsv7/ccs_base;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.R4F -p ti.platforms.cortexR:IWR14XX:false:200 -r release -c "C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS "../Mmw.cfg"
正在制作 package.mak (由于 package.bld)...
正在为软件包 configPkg 生成接口(因为 package/package.xdc.inc 比 package.XDC 旧)...
从 package/cfg/mmw_per4f.cfg 配置 MMW.xer4f ...
正在生成自定义 ti.sysbios 库 makefile ...
正在开始构建库源...
制作 C:/Dev/BASE/IWR1443/mmwave/mmw_mss_14xx/src/sysbios/sysbios.aer4f ...
gmake[1]:输入目录`C:/Dev/BASE/IWR1443/mmwave/mmw_mss_14xx/src/sysbios
cler4f C:/ti/bios_6_52_00_12/packages/ti/sysbios/BIOS.c
asmer4f C:/ti/bios_6_52_00_12/packages/ti/sysbios/family/arm/IntrinsicsSupport_asm.asm
asmer4f C:/ti/bios_6_52_00_12/packages/ti/sysbios/family/arm/TaskSupport_asm.asm
asmer4f C:/ti/bios_6_52_00_12/packages/ti/sysbios/family/arm/v7r/vim/Hwi_asm.sv7R
asmer4f C:/ti/bios_6_52_00_12/packages/ti/sysbios/family/arm/v7r/vim/Hwi_asm_switch.sv7R
asmer4f C:/ti/bios_6_52_00_12/packages/ti/sysbios/family/arm/exc/Exception_asm.asm
asmer4f C:/ti/bios_6_52_00_12/packages/ti/sysbios/family/arm/v7r/tms570/Core_asm.sv7R
asmer4f C:/ti/bios_6_52_00_12/packages/ti/sysbios/family/arm/a15/TimestampProvider_asm.asm
arer4f bios.obj arm_IntrinsicsSupport_asm.obj arm_TaskSupport_asm.obj vim_hwi_asm.obj vim_hwi_asm_switch.obj exc_exception_asm.obj tms570_Core_asm.obj a15_TimestampProvider_as.obj……
gmake[1]:离开目录`C:/Dev/BASE/IWR1443/mmwave/mmw_mss_14xx/src/sysbios
已完成库构建。
clel4f 封装/cfg/mmw_per4f.c……
'完成的建筑:"../MMW.cfg"'
'生成文件:"../config_EDMA_util.c"
'调用:ARM 编译器'
"c:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/bin/armcl -mv7R4 --code_state=16 --float_support=VFPv3D16 -me -O3 --include_path="C:/Dev/BASE/IWR1443/mmwave/mmw_mss_14xx --include_path="C:/ti/mmwave_sdk_01_01_00_02/packages --include_path="C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/include --define= soc_excus_subsection=rus_exit_pruature=pf-nategr_ex-us_excus=-code_memb_exit_exit_pruature=-us_exit_pruag=-rom_ab_us_code.pruat_ex-us=-us_excus_ab_exit_ab_ab_code.mag=-rom_ex-us_code_subs=-us_exit_ab_ab_code_subs=-us_exit_exit_ab_ex-us=-rom_us_us_us=-us_code.pruat_ab_code.pruateg&=-code.pruat_ab_ab_ab_ab_ab_ab_ab_ex
'完成构建:"./config_EDMA_util.c"
'生成文件:"../config_hwa util.c"
'调用:ARM 编译器'
"c:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/bin/armcl -mv7R4 --code_state=16 --float_support=VFPv3D16 -me -O3 --include_path="C:/Dev/BASE/IWR1443/mmwave/mmw_mss_14xx --include_path="C:/ti/mmwave_sdk_01_01_00_02/packages --include_path="C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/include --define=subsc_exit_exion_pruature=pf-nateg_exit_pruature=pf-nategr_ex-us_exit_abus=-code_subs=-code_exit_exit_exit_exit_pruature=page=-us_ab_pruateg&=-us_ab_ex-us_ex-us_exit_ab_ab_ab_ex-us_pruatify_subs=-us=-us_pruatify_rand=-r&=-r&=-us_ab_exit_ab_ab_ab_ab_ab_exit_pruature=page=page=page=pf-nateg&-code.pruateg&=-us_
'已完成构建:"../config_hwa util.c"
'生成文件:"../data_path.c"
'调用:ARM 编译器'
"c:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/bin/armcl -mv7R4 --code_state=16 --float_support=VFPv3D16 -me -O3 --include_path="C:/Dev/BASE/IWR1443/mmwave/mmw_mss_14xx --include_path="C:/ti/mmwave_sdk_01_01_00_02/packages --include_path="C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/include --define_membrate=subtract_subtract=-us_membrand_defination=-rom_subs_defination=-code_display_subs=-rom_decurity=-code_display_subs=-out_subs=-code_date-exit_rom_subs=-rom_decome_display_subs=-code.page=-code_display_subs=-rom_subs=-code_display_subs=-code_display_subs=-rom_subsection=-out_subtrab_subs=-code_display_subs=-out_subs=-out_subs=-out_subs=-code.come_display_subs=-code_display_subs=-code.page=-code_display_
'已完成构建:"./data_path.c"
'生成文件:"./main.c"'
'调用:ARM 编译器'
"c:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/bin/armcl -mv7R4 --code_state=16 --float_support=VFPv3D16 -me -O3 --include_path="C:/Dev/BASE/IWR1443/mmwave/mmw_mss_14xx --include_path="C:/ti/mmwave_sdk_01_01_00_02/packages --include_path="C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/include --define=subtract_support=us_subsection=-exit_rom_us=-code_display_subsection=-rom_subboard_exit_us=-code_display_subsection=-rom_subs=-us_subboard.us_exit_subs=-code_display_subsection=-us=-rom_subs=-code_display_subs=-rom_subs=-code_display_subsection_subs=-us_subs=-rom_subs=-us_exit_exit_us=-code_display_subs=-rom_us.us_us_us_subs=-code_display_subs=-us.us.us=-code_display_subs=-code_display_subsection=-us.
'完工建筑:"../main.c"'
'生成文件:"../post_processing.c"
'调用:ARM 编译器'
"c:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/bin/armcl -mv7R4 --code_state=16 --float_support=VFPv3D16 -me -O3 --include_path="C:/Dev/BASE/IWR1443/mmwave/mmw_mss_14xx --include_path="C:/ti/mmwave_sdk_01_01_00_02/packages --include_path="C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/include --define=subsc_exition_subtration=-from_decures=-out_subscout_subscout_subscout_exit_subection=-code_display_subs=-code_display_subsection=page=-from_subboard_subscout_subscout_subscout_subscout_subscout_subtrage=-out_subscout_subs=-out_subscout_subscout_subs=-out_subscout_subscout_subscout_subs=-out_subscout_subs=-out_subscout_subtrage=-out_subscout_subscout_subtrage=-out_subscout_subscout_subs=-code.coming_decome.come.
'已完成建筑:"../post_processing.c"
'生成文件:"../MMW_CLI.c"
'调用:ARM 编译器'
"c:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/bin/armcl -mv7R4 --code_state=16 --float_support=VFPv3D16 -me -O3 --include_path="C:/Dev/BASE/IWR1443/mmwave/mmw_mss_14xx --include_path="C:/ti/mmwave_sdk_01_01_00_02/packages --include_path="C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/include --define=mcos_exclus_subection=-membr_subtry_subsection=-membr_subsc_subs=cm_off-code_remote_display_subs=-mf-nature=mfrom_subs=-code_display_subsection_subs=-mfrom_subs=-code_display_subsection_subs=-mfrom_subs=-code_display_subs=-rom_subsection_subs=-code_display_subsection_subs=-mf_subs=-rom_subs=-us_subsection_subs=-rom_subboard_subtract_subs=-file_display_subs=-code.com_subs=-code_display_subs=-mf_
'完成的建筑:"../MMW_CLI.c"
'构建文件:"../Rx_ch_bias _measure.c"'
'调用:ARM 编译器'
"c:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/bin/armcl -mv7R4 --code_state=16 --float_support=VFPv3D16 -me -O3 --include_path="C:/Dev/BASE/IWR1443/mmwave/mmw_mss_14xx --include_path="C:/ti/mmwave_sdk_01_01_00_02/packages --include_path="C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/include --define= soc_exit_subsection=-rom_subtract_subs=-exit_exit_rom_us=-code_page=-exit_rom_subtract_subs_decimumination=-rom_subs=-code_display_exit_exit_exit_rom_rom_subs=-us_exit_exit_rom_us=-code_page=-code_page=-code_page=-code_page=-code_subtrab_exit_exit_exit_rom_exit_rom_rom_us_ecimination=-rom_us_us_exit_us_us.trage=-code_display_subs=-code_page=-code_display_subs=-code.
'完成构建:"../Rx_ch_bias 测量.c"'
'生成文件:"../sensor_mgmt.c"
'调用:ARM 编译器'
"c:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/bin/armcl -mv7R4 --code_state=16 --float_support=VFPv3D16 -me -O3 --include_path="C:/Dev/BASE/IWR1443/mmwave/mmw_mss_14xx --include_path="C:/ti/mmwave_sdk_01_01_00_02/packages --include_path="C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/include --define= sor_subtract=s_defination=-membr_subboard_subtract_subsensors=-code_display_subsensor=-rom-code_display_subs=-exitive_display_subs=-rom_subs=-code_display_subsepage=-rom_subs=-code_display_subsection_subs=-rom_subs=-code_display_subs=-us_subsection_subsepage=-rom_subboard_subs=-codest_subtrage=-code.combag_subs=-rom_subtrage=-us_subs=-code_display_subs=-code_display_subs=-rom_subs=-code_display_subs=-code.pr
'完成的建筑:"../sensor_mgmt.c"
'构建目标:"xwr14xx_mmw_MSS.xer4f"
'调用:ARM 链接器'
"c:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/bin/armcl -mv7R4 --code_state=16 --float_support=VFPv3D16 -me -O3 --define=SOC_XWR14XX --define=Subsys_MSS --define=download_from_ccs --define=mmWave_L3RAM_SIZE=0x40000 --define=subs=m_off-map_subsection=0x4m_ench_subs=-sw-display_subs=-m=ench_subs=-sw-sw-dime_display_subs=-subsection=-sw-caps=ench_subs=-caps=-caps=-ive_display_subsection-sw-sw-sw-sw-sw-ation-m=-m=-m=dim_subs=-subs=-subs= stack_size=0x800 -"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/lib -"C:/ti/mmwave_sdk_01_01_00_02/packages/ti/control/mmwave/lib -"C:/ti/mmwave_sdk_01_01_00_02/packages/ti/control/mmwavelink/lib -"C:/ti/mmwave_sdk_01_01_00_02/packages/ti/drivers/adcbuf/lib -"C:/ti/mmwave_sdk_01_01_00_02/packages/ti/drivers/crc/lib -"C:/ti/mmwave_sdk_01_01_00_02/packages/ti/drivers/dma/lib -i"C:/ti/mmwave_sdk_01_01_00_02/packages/ti/drivers/edma/lib -i"C:/ti/mmwave_sdk_01_01_00_02/packages/ti/drivers/hwa/lib /ti/mmwave_sdk_01_01_00_02/packages/ti/drivers/pinmux/lib /ti/mmwave_sdk_01_01_00_02/packages/ti/utils/cli/lib -i"C:/ti/mmwave_sdk_01_01_00_02/packages/ti/drivers/esm/lib /ti/mmwave_sdk_01_01_00_02/packages/ti/drivers/mailbox/lib /ti/mmwave_sdk_01_01_00_02/packages/ti/drivers/soc/lib /ti/ccs740/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS/include -i_exc_di_express -ms/i_exc_ram_isde-example_-i_cn-i_cn_ombi-display_intrack_ines_-i_example_-i_example_ine_-i_example_-i_om-i_example_ine_ine_intrack_example_-i_example_-i_om-ine_-i_example_-i_-ine_ine_ine_inch-/ti/mmwave_sdk_01_01_00_02/packages/ti/drivers/gpio/lib -i_exit_-i_example_intrack_example_ine_ine_ine_ine_-example_inch-/ti/mmwave_sdk_01_01_00_02/packages/ti/drivers/osal/lib -i_example_-i_example_inch-/ti/mmwave_sdk_01_01_00_02/packages/ti/drivers/uart/lib -i_exampl unused_section_elimination=on -o "xwr14xx_mmw_MSS.xer4f"./config_edma_util.oer4f"./config_osc_util.oer4f"./data_path.oer4f"./main.oer4f./librf_linker -swr_l4xx/librf_libor_libr4
'完成的构建目标:"xwr14xx_mmw_MSS.xer4f"
C:/ti/mmwave_sdk_01_01_00_02/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe xwr14xx_MMW_MSS.xer4f xwr14xx_mmw_mss.bin 0x200000
解析输入目标文件 xwr14xx_MMW_MSS.xer4f。
附加零0
添加零101536
附加零1359085568
文件转换完成!
C:/ti/mmwave_sdk_01_01_00_02/packages/scripts/ImageCreator/append_bin_crc/gen_bincrc32.exe xwr14xx_mmw_mss.bin
Makefile:199:目标'post-build'的配方失败
Process_begin:CreateProcess (C:\ti\mmwave_sdk_01_00_02\packages\scripts\ImageCreator\append_bin_crc\gen_bincrc32.exe、C:/ti/mmwave_sdk_01_01_00_02/packages/scripts/ImageCreator/append_bin_crc/gen_bincrc32.exe xwr14xx_mmw_MSS.bin、...) 失败。
make (e=216):错误216 -------------------------------------------------------- 此处将出现一个错误 、二进制文件生成失败
Gmaked[3]:[编译后处理]错误216 (忽略)
****构建完成****
