[参考译文] AWR6843AOPEVM:无法构建任何 AWR6843AOPEVM 示例
Guru**** 2644745 points
Other Parts Discussed in Thread: AWR6843AOP, TMS320C6670, TMS320C6654, TMS320C6655, TMS320C6657, TMS320C6671, TMS320C6672, TMS320C6674, TMS320C6678, TMS320DM8148, TMS320DM8168, TMS320C6747, TMS320C6745, TMS320C6743, TMS320C6742, TMS320C6746, TMS320C6748, SYSBIOS, MATHLIB, AWR6843
https://e2e.ti.com/support/sensors-group/sensors/f/sensors-forum/1194394/awr6843aopevm-unable-to-build-any-of-the-awr6843aopevm-examples
器件型号:AWR6843AOPEVM
主题中讨论的其他器件:MMWAVEICBOOSTAWR6843AOPTMS320C6670TMS320TCI6608TMS320TCI6614TMS320TCI6616TMS320TCI6618TMS320C6654TMS320C6655TMS320C6657TMS320C6671TMS320C6672TMS320C6674TMS320C6678TMS320DM8148TMS320DM8168TMS320C6747TMS320C6745TMS320C6743OMAPL138TMS320C6742TMS320C6746TMS320C6748SYSBIOSMATHLIBAWR6843
  我尝试过通过实验室导入 CCS 项目,具体情况是: MULTI_MOTIE_68xx_AOP。
我已将 AWR6843AOP 连接到毫米波 ICBOOST 载板、并配置为在功能模式下工作。
在导入 DSS 工程后,我收到以下错误:
****为项目 MULTI_TOPLE_68xx_AOP_DSS 构建配置调试****
"C:\\ti\\ccs1210\\ccs\\utils\\bin\\gmake"-k -j 12 all -O
rm -f D:/Vinay/personal/Phd/IIITB/Radar_workspace/multi_gesture_68xx_aop_dss/Debug/multi_gesture_68xx_aop_dss.bin
Makefile:182:目标"预编译"的配方失败
Process_begin:CreateProcess (NULL、rm -f D:/Vinay/personal/Phd/IIITB/Radar_workspace/multi_gesture_68xx_aop_dss/Debug/multi_gesture_68xx_aop_dss.bin、...) 失败。
gmaking[1]:[预编译]错误2 (忽略)
编译文件:"../dss/dss_mmw.cfg
调用:XDCtools
"c:/ti/xdctools_3_50_04_43_core/xs "--xdcpath="C:/ti/bios_6_53_02_00/packages;" xdc.tools.configuro -o configPkg -t ti.targets.elf.c674 -p ti.platforms.c6x:IWR68XX:false:600 -r release -c "C:/ti/ti-cgt-c6000_8.3.3 "--compileOptions "--enum_type=int ""./dss/dss_mmw.cfg
正在制作 package.mak (由于 package.bld)...
正在为软件包 configPkg 生成接口(因为 package/package.xdc.inc 比 package.XDC 旧)...
从 package/cfg/dss_mmw_pe674.cfg 配置 DS_MMw.xe674 ...
目前不支持 IWR68XX 器件。
C674目标支持以下器件:
TMS320C6670
TMS320DA830
DM37XX
TMS320TI816X
DRA7XX
AWR16XX
Kepler
TMS320TCI6634
TMS320TCI6636
TMS320TCI6638
TMS320TCI6608
TMS320TCI6614
TMS320TCI6616
TMS320TCI6618
TMS320TCI6630K2L
TMS320C66AK2H06
TMS320C66AK2H12
TMS320C66AK2E02
TMS320C66AK2E05
TCI66AK2G02
TMS320C6654
TMS320C6655
TMS320C6657
TMS320C6671
TMS320C6672
TMS320C6674
TMS320C6678
TMS320CDM740
TMS320C6A8149
TMS320C6A8168
TMS320TI811X
TMS320TI814X
TMS320DM8148
TMS320DM8168
北极
TMS320DA802
TMS320DA803
TMS320DA804
TMS320DA805
TMS320DA807
TMS320DA808
TMS320DA810
TMS320DA828
TMS320C6747
TMS320C6745
TMS320C6743
OMAPL137
OMAPL108
OMAPL118
OMAPL138
TMS320DA840
TMS320DA850
TMS320C6742
TMS320C6746
TMS320C6748
瓦伊
TDA3XX
IWR16XX
dss/subdir_rules.mk:19:目标'Build-743149201-InProc '的配方失败
JS:"c:/ti/bios_6_53_02_00/packages/ti/sysbios/family/c64p/Settings.xs、第194行:错误:不支持的设备!
"C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/c64p/Settings.xs、第220行
"C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/Settings.xs、第170行
"C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/Settings.xs "、第123行
"D:/Vinay/personal/Phd/IIITB/Radar_workspace/multi_gesture_68xx_aop_dss/dss/dss_mmw.cfg、第15行
"./package/cfg/dss_mmw_pe674.cfg,第187行
gmake.exe:***[package/cfg/DSS_MMW_PE674.xdl]错误1
JS:"c:/ti/xdctools_3_50_04_43_core/packages/xdc/tools/Cmdr.xs、第52行:错误:xdc.tools.configuro:由于先前的错误(状态= 2)、配置失败;已删除'linker.cmd'。
gmak[2]:***[Build-743149201-InProC]错误1.
gmaking[1]:***[Build-743149201]错误2.
gmake[1]:不会由于错误而重做目标'main-build'。
gmake:***[全部]错误2.
dss/subdir_rules.mk:16:目标'build-743149201'的配方失败
Makefile:156:目标“全部”的配方失败
****构建完成****
我在 Windows 10操作系统上使用 CCS 12.1 、并安装了 mmwavesdk 3.06_LTS 和 Radartoolbox 1_00_00_26。
这些实验是从以下位置挑选的: MMWAVE_automotive_toolbox_3_6_0
您能告诉我如何解决这个构建问题吗?
    您有一些问题:
    1. 此构建错误是否仅在尝试构建此特定手势识别实验时发生、还是在尝试构建其他演示时也发生? 例如、您是否能够成功导入和构建开箱即用演示(OOB)?
    2. 编译 MSS 工程时或仅使用 DSS 工程时是否会发生任何错误?
    3. 您能否确认要构建的特定演示/实验? 您似乎正在尝试构建我们的一个旧手势演示、该演示已包含在工业工具箱中、直到版本4.12.1、但已被发布的雷达工具箱弃用。 如果您不知道、可 在此处找到最新的手势演示
    Josh
    感谢您的回复。
    答案:
    1)是的、与 AWR6843AOP 相关的任何其他工程都会出现编译错误。 而我有1642BOOST ODS 项目、这些项目构建和运行顺畅。
    我尝试了如下的开箱即用演示,并得到了相同的错误:
    ****为项目 out_for_box_6843_AOP 构建配置调试****
    rm -f D:/Vinay/personal/Phd/IIITB/Radar_workspace/out_of_box_6843_aop/Debug/out_of_box_6843_aop.bin
    Makefile:195:目标"预编译"的配方失败
    Process_begin:CreateProcess (NULL、rm -f D:/Vinay/personal/Phd/IIITB/Radar_workspace/out_of_box_6843_aop/Debug/out_of_box_6843_aop.bin、...) 失败。
    编译文件:"../MMW.cfg"
    调用:XDCtools
    "c:/ti/xdctools_3_50_04_43_core/xs "--xdcpath="C:/ti/bios_6_53_02_00/packages;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.r4Ft -p ti.platforms.cortexR:IWR68XX:false:200 -r release -c "C:/ti/ti-cgt-arm_16.9.6.LTS "--compileOptions "--enum_type=int ""./mmw.cfg"
    正在从 package/cfg/mmw_per4ft.cfg 配置 mmw.xer4ft ...
    目前不支持 IWR68XX 器件。
    ti.catalog.arm.cortexr5目录支持以下器件:
    RM57D8XX SIMPLEMING SIMMAXWELL
    subdir_rules.mk:19:目标'Build-1188615185-InProc '的配方失败
    JS:"c:/ti/bios_6_53_02_00/packages/ti/sysbios/family/arm/Settings.xs "、第672行:错误:不支持的设备!
    "C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/arm/Settings.xs "、第831行
    "C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/Settings.xs、第242行
    "C:/ti/bios_6_53_02_00/packages/ti/sysbios/family/Settings.xs、第121行
    "D:/Vinay/personal/Phd/IIITB/Radar_workspace/out_of_box_6843_aop/mmw.cfg、第15行
    "./package/cfg/mmw_per4ft.cfg,第196行
    gmake.exe:***[package/cfg/MMW_per4ft.xdl]错误1
    gmak[2]:***[Build-1188615185-InProC]错误1.
    gmaking[1]:***[Build-1188615185]错误2.
    gmake:***[全部]错误2.
    subdir_rules.mk:16:目标'build-1188615185'的配方失败
    Makefile:169:目标'all'的配方失败
    ****构建完成****
    2) 2)运行 MSS 或 DSS 时出现此错误。
    3)我正在使用 RadarToolbox 1.00.26 (我认为是最新版本)。
    我安装了 XDC3.5、它解决了开箱即用演示中出现的构建问题。
    但当我尝试 Incabinsensing 时,我遇到错误,因为似乎缺少少量文件。
    ****项目占用检测_3D_68xx_DSS 的默认配置构建****
    rm -f D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/default/occupancy_detection_3d_68xx_dss.bin
    Makefile:181:目标"预编译"的配方失败
    Process_begin:CreateProcess (NULL、rm -f D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/default/occupancy_detection_3d_68xx_dss.bin、...) 失败。
    编译文件:"../dss/mmwLab_dss.cfg
    调用:XDCtools
    "C:/ti/xdctools_3_50_08_24_core/xs "--xdcpath="C:/ti/bios_6_73_01_01/packages;C:/ti/mathlib_c674x_3_1_2_1/packages;C:/ti/dsplib_c674x_3_4_0_0/packages;" xdc.tools.configuro configPkg -t ti.targets.elf.c674 -p ti.platforms.c6x:IWR68XX:false:600 -r release -c "C:/ti/ti-cgt-c6000_8.3.3 "../dss/mmwLab_dss.cfg
    从 package/cfg/mmwLab_dss_pe674.cfg 配置 mmwLab_dss.xe674 ...
    正在生成自定义 ti.sysbios 库 makefile ...
    正在开始构建库源...
    制作 D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/dss/src/sysbios/sysbios.ae674 ...
    gmake[1]:输入目录`D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/dss/src/sysbios
    CLE674 C:/ti/bios_6_73_01_01/packages/ti/sysbios/BIOS.c……
    asme674 C:/ti/bios_6_73_01_01/packages/ti/sysbios/family/c64p/Exception_asm.s64P……
    asme674 C:/ti/bios_6_73_01_01/packages/ti/sysbios/family/c64p/Hwi_asm.s62……
    asme674 C:/ti/bios_6_73_01_01/packages/ti/sysbios/family/c64p/Hwi_asm_switch.s62……
    asme674 C:/ti/bios_6_73_01_01/packages/ti/sysbios/family/c64p/Hwi_disp_always.s64P……
    asme674 C:/ti/bios_6_73_01_01/packages/ti/sysbios/rts/ti/tls_get_tp.asm……
    asme674 C:/ti/bios_6_73_01_01/packages/ti/sysbios/family/c62/TaskSupport_asm.s62……
    are674 bios.obj c64p_exception_asm.obj c64p_hwi_asm-switch.obj c64p_hwi_disp_always.obj ti_tls_get_tp.obj c62_taskSupport_asc.obj ...
    gmake[1]:离开目录`D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/dss/src/sysbios
    已完成库构建。
    cle674软件包/cfg/mmwLab_dss_pe674.c……
    "C:/ti/xdctools_3_50_08_24_core/packages/xdc/runtime/Text.c、第218行:备注#2142-D:有符号和无符号操作数之间的比较
    "C:/ti/xdctools_3_50_08_24_core/packages/xdc/runtime/Text.c、第237行:备注#2142-D:有符号和无符号操作数之间的比较
    已完成构建:"./dss/mmwLab_dss.cfg
    编译文件:"../common/src/dpu/capon3d_overhead/modules/detection/CFAR/src/RADARDEMO_detectionCFAR.c
    调用:C6000编译器
    "c:/ti/ti-cgt-c6000_8.3.3/bin/cl6x -mv6740 --abi=eabi -O3 --opt_for_speed=3 --include_path="D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss --include_path="D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/common --include_path="D:/ti/dsplib_c674x_3_4_0_0/packages --include_path="D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/dss /ti/radar_toolbox_1_00_00_26/source/ti/labs --include_remote_define =/ti/mmwave_sdk_03_05_00_04/packages -- mmwave_define =/ti/ti-cgt-c6000_8.3.3/include -- mmwave_define =-- mmwave_mem_sband_define_remband_define_mem_sband_define_mem_sband_define-define = 0x100_mem_sband_define_remband_define_remote_mem_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn=mmwe_mem_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_defin <'D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/common/mmwLab_hwres.h'>'-g -gcc --diag_error=10015 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsection=on --obj_extension=.oe674 --preproc_with_compile --precapsc/src/dtran/detections="common/capture/caps/sr_detection/file/captive/captive/caps/sr.tran/caps/sr.tran/capsections/sr.tran/capsections/sr/capsections/sr/capsections/sr/capsections/sr/capsections/sr/capsections/sr/capsections/sr/capsections/sr/capsectionsections/sr /common/src/dpu/capon3d_overhead/modules/detection/CFAR/src/RADARDEMO_detectionCFAR.c
    >>编译失败
    common/src/DPU/capon3d_管理 费用/模块/检测/CFAR/src/subdir_rules.mk:9:目标'common/src="/DPU/capon3d_管理 费用/模块/检测/CFAR/src/RADARDEMO_detectionCFAR.oe674'的配方失败
    "...\common\src\DPU\capon3d_管理 费用\modules\detection\CFAR\src\./api/RADARDEMO_detectionCFAR.h "、第43行:致命错误#1965:无法打开源文件"common/swpform.h"
    1在编译"../common/src/dpu/capon3d_overhead/modules/detection/CFAR/src/RADARDEMO_detectionCFAR.c 时检测到灾难性错误。
    编译已终止。
    gmake[1]:***[common/src/DPU/capon3d_管理 费用/模块/检测/CFAR/src/RADARDEMO_detectionCFAR.oe674]错误1.
    编译文件:"../common/src/dpu/capon3d_overhead/modules/detection/CFAR/src/RADARDEMO_detectionCFAR_priv.c
    调用:C6000编译器
    "c:/ti/ti-cgt-c6000_8.3.3/bin/cl6x -mv6740 --abi=eabi -O3 --opt_for_speed=3 --include_path="D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss --include_path="D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/common --include_path="D:/ti/dsplib_c674x_3_4_0_0/packages --include_path="D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/dss /ti/radar_toolbox_1_00_00_26/source/ti/labs --include_remote_define =/ti/mmwave_sdk_03_05_00_04/packages -- mmwave_define =/ti/ti-cgt-c6000_8.3.3/include -- mmwave_define =-- mmwave_mem_sband_define_remband_define_mem_sband_define_mem_sband_define-define = 0x100_mem_sband_define_remband_define_remote_mem_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn=mmwe_mem_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_defin <'D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/common/mmwLab_hwres.h'>'-g -gcc --diag_error=10015 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsection=on --obj_extension=.oe674 --preproc_with_compile --precapsc/src/dtran/detection="common/capture/caps/sr_detection/file/capture/files/captiv/tran/caps/sr.tran/caps/sr_detection/capsectionsection/capsection/files/dc/tran/capprod/files/captiv/caps/sr.tran/capsections/sr.tran/caps/sr.tran/capsectionsections/spru/caps/sr.tran/d//common/src/dpu/capon3d_overhead/modules/detection/CFAR/src/RADARDEMO_detectionCFAR_priv.c
    >>编译失败
    common/src/DPU/capon3d_管理 费用/模块/检测/CFAR/src/subdir_rules.mk:9:目标'common/src="/DPU/capon3d_管理 费用/模块/检测/CFAR/src/RADARDEMO_detectionCFAR_priv.oe674'的配方失败
    "...\common\src\DPU\capon3d_管理 费用\modules\detection\CFAR\src\RADARDEMO_detectionCFAR_priv.h"、第43行:致命错误#1965:无法打开源文件"common/swpform.h"
    1在编译"../common/src/dpu/capon3d_overhead/modules/detection/CFAR/src/RADARDEMO_detectionCFAR_priv.c 时检测到灾难性错误。
    编译已终止。
    gmake[1]:***[common/src/DPU/capon3d_管理 费用/模块/检测/CFAR/src/RADARDEMO_detectionCFAR_priv.oe674]错误1.
    编译文件:"../dss/dss_main.c
    调用:C6000编译器
    "c:/ti/ti-cgt-c6000_8.3.3/bin/cl6x -mv6740 --abi=eabi -O3 --opt_for_speed=3 --include_path="D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss --include_path="D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/common --include_path="D:/ti/dsplib_c674x_3_4_0_0/packages --include_path="D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/dss /ti/radar_toolbox_1_00_00_26/source/ti/labs --include_remote_define =/ti/mmwave_sdk_03_05_00_04/packages -- mmwave_define =/ti/ti-cgt-c6000_8.3.3/include -- mmwave_define =-- mmwave_mem_sband_define_remband_define_mem_sband_define_mem_sband_define-define = 0x100_mem_sband_define_remband_define_remote_mem_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn=mmwe_mem_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_defin <'D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/common/mmwLab_hwres.h'>'-g -gcc -diag_error=10015 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --precmd_Dependence="dss/dss_main.d_raw"--opt_file.opt_file./dss/dss_main.c。
    >>编译失败
    dss/subdir_rules.mk:9:目标'dss/dss_main.oe674'的配方失败
    "../dss/dss_main.c、第79行:致命错误#1965:无法打开源文件"common/src/DPC/capon3d_管理 费用/objectdetection.h"
    1在编译"../dss/dss_main.c 时检测到灾难性错误。
    编译已终止。
    gmake[1]:***[DSS/DSS_main.oe674]错误1.
    编译文件:"../common/src/dpu/capon3d_overhead/modules/detection/CFAR/src/relativeThrTab.c
    调用:C6000编译器
    "c:/ti/ti-cgt-c6000_8.3.3/bin/cl6x -mv6740 --abi=eabi -O3 --opt_for_speed=3 --include_path="D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss --include_path="D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/common --include_path="D:/ti/dsplib_c674x_3_4_0_0/packages --include_path="D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/dss /ti/radar_toolbox_1_00_00_26/source/ti/labs --include_remote_define =/ti/mmwave_sdk_03_05_00_04/packages -- mmwave_define =/ti/ti-cgt-c6000_8.3.3/include -- mmwave_define =-- mmwave_mem_sband_define_remband_define_mem_sband_define_mem_sband_define-define = 0x100_mem_sband_define_remband_define_remote_mem_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn=mmwe_mem_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_defin <'D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/common/mmwLab_hwres.h'>'-g -gcc --diag_error=10015 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --precapsc/src/dc/thon3files/trab/trab/capsection_modules="common/proc/trab/caps/srand/tran/caps/seconfig/capsection/tran/capsection/tran/capsections/seconfig/capsection/directory/tran/caps/seconfig/tran/tran/caps/secures/securation="/tran/tran/tran/tran/caps/sec /common/src/dpu/capon3d_overhead/modules/detection/CFAR/src/relativeThrTab.c
    已完成构建:"./common/src/dpu/capon3d_overhead/modules/detection/CFAR/src/relativeThrTab.c
    编译文件:"../common/src/dpu/capon3d_overhead/modules/detection/CFAR/src/cfarRatio.c
    调用:C6000编译器
    "c:/ti/ti-cgt-c6000_8.3.3/bin/cl6x -mv6740 --abi=eabi -O3 --opt_for_speed=3 --include_path="D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss --include_path="D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/common --include_path="D:/ti/dsplib_c674x_3_4_0_0/packages --include_path="D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/dss /ti/radar_toolbox_1_00_00_26/source/ti/labs --include_remote_define =/ti/mmwave_sdk_03_05_00_04/packages -- mmwave_define =/ti/ti-cgt-c6000_8.3.3/include -- mmwave_define =-- mmwave_mem_sband_define_remband_define_mem_sband_define_mem_sband_define-define = 0x100_mem_sband_define_remband_define_remote_mem_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn=mmwe_mem_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_define-cn_sband_defin <'D:/Vinay/personal/Phd/IIITB/Radar_workspace/occupancy_detection_3d_68xx_dss/common/mmwLab_hwres.h'>'-g -gcc --diag_error=10015 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --obj_extension=.oe674 --preproc_with_compile --precapate_sup相关性="common/src/src/opt_on3for_detection="/capproc/trasonics/caps\config/capsection/caps/sr/spru/capsection/file/caps/sr/sr/src/capsection/capsection/capprod/file/capsectionsection/capsection/caps/sr/sr/sr/sr/sr/sm/fultran/caps/seconnectionsectionsections="/capsection /common/src/dpu/capon3d_overhead/modules/detection/CFAR/src/cfarRatio.c
    gmake:***[全部]错误2.
    已完成构建:"./common/src/dpu/capon3d_overhead/modules/detection/CFAR/src/cfarRatio.c
    Makefile:155:目标'all'的配方失败
    ****构建完成****
    以下文件似乎缺少。
    当我检查封装时、它会显示
    您能告诉我您将项目导入 CCS 的过程吗? 如果您尝试通过 CCS 从 Resource Explorer 导入工程、可能会出现一些错误。 您可以尝试通过以下过程导入项目吗?
    1.雷达工具箱安装在本地机器上。 (根据您共享的已发现产品的图像、这种情况似乎已经发生了。)
    2.在 CCS 中、在屏幕顶部选择 Project→Import CCS Projects
    3.在打开的窗口中,选择 浏览。
    4.导航至要导入的项目目录。 单击 选择文件夹。 例如 C:/ti/radar_toolbox_1_00_00_26/source/ti/examples/InCabin_Sensing/AWR6843_High_Accuracy_Localization_Demo_with_Classification/src/68xx
    5.然后应显示该目录中已发现的项目。 选择所需的项目、然后选择完成。 (对于利用两个内核的示例、您将需要导入 MSS 和 DSS 项目)
    请告诉我在执行上述步骤时问题是否仍然存在。
    Josh
    Josh、您好!
       按建议执行,但仍会出现以下错误:
    和构建错误:
    调用:XDCtools
    正在开始构建库源...
    已完成库构建。
    调用:C6000编译器
    >>编译失败
    编译已终止。
    调用:C6000编译器
    >>编译失败
    编译已终止。
    调用:C6000编译器
    调用:C6000编译器
    >>编译失败
    编译已终止。
    调用:C6000编译器
    gmake:***[全部]错误2.
    ****构建完成****
    我尝试卸载和安装雷达工具箱、但在安装时它向我提供了此 消息。
    因此、我搜索了 MMWAVESDK-L、发现网站上没有5.00.00版本。 那么、我如何获得它呢?
    如果不存在对它的依赖、因为我使用的是 AWR6843AOP、那么我应该忽略这种依赖关系吗?
    已安装5.01,可用于检查错误是否已关闭。
    但我仍然得到该误差。
    很抱歉耽误你的时间。 通过 CCS 进行安装时、在 Radar Toolbox 安装中似乎存在一些问题。 请卸载机器上安装的雷达工具箱的任何实例、并通过以下过程直接从 Web 安装。
    1.在 dev.ti.com 上的 Resource Explorer 中查找最新的 Radar Toolbox (位于 此链接)。
    2.下载雷达工具箱
    3.解压下载的压缩文件并将其放入 C:/ti/中
    Josh
    Josh、您好!
       我执行了您建议的步骤、但运气不好。
    事实上,我下载了.zip 文件,我看不到 任何与 C:\ti\radar_toolbox_1_00_00_26\source\ti\labs 相关的文件夹...... 因此 ,总的来说,C:\ti\radar_toolbox_1_00_00_26\source\ti\ path 中缺少实验文件夹。 无论是从 TI Resource Explorer 获取还是从安装中获取、我都会遇到相同的错误。
    您能否检查一下、因为这些错误似乎指向应该位于 labs 文件夹中的文件。
    我的 radartoolbox 文件夹如下所示:
    错误是相同的、但只是粘贴以确认缺少的文件都来自 labs 文件夹。
    我再次对延迟的答复表示歉意。
    [引用 userid="514354" URL"~/support/sensors-group/sensors/f/sensors-forum/1194394/awr6843aopevm-unable-to-build-any-of-the-awr6843aopevm-examples/4508710 #4508710"]您能否检查,因为这些错误似乎指向应该位于 labs 文件夹中的文件。
    随着 Radar Toolbox 的发布、labs 文件夹已被删除、之前驻留在 Labs 文件夹中的所有内容现在都位于 examples 文件夹( /source/ti/examples)。 我能够再现您的问题。 问题不是文件丢失、而是.projectspec 文件中的错误、该文件定义了导入 CCS 工程时在何处查找文件。 此错误正在得到解决、并将在下一次 Radar Toolbox 更新中得到解决。
    据我们所知、此示例应该是唯一受影响的示例。 您是否能够从雷达工具箱成功导入和构建其他示例项目?
    Josh
    很抱歉耽误你的回答、Josh。
    非常感谢您确认观察结果。 我什么时候能想到新的雷达工具箱。
    是否可以在此处释放丢失的文件?
    新的 Radar Toolbox 版本将在未来几周内发布。 如果您遇到此问题、可以联系您当地的 TI 现场代表、我们可以离线为您提供此演示的更新版本。
    Josh
