主题: CC1190中讨论的其他部件
工具/软件:WEBENCH设计工具
你好。
我下载了最新版本的cc1310 SDK,并尝试编译示例IAR项目。 版本IAR 8.20 ,我遇到下一个错误
运行"C:\ti\xdctools_3_50_03_33_core/xs"--xdcpath="C:\ti\simplelink_cc13x0_SDK_1_50_00_08\kernel\tirtos\packages;C:\ti\时出错
simplelink_cc13x0_SDK_1_50_00_08\source" IAR.tools.configuro -c "C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0_2\arm"--cc "C:\Program Files"
(x86)\IAR Systems\Embedded Workbench 8.0_2\arm\bin\iccarm.exe"--device "CC1350F128"--compileOptions "dump.c -o C:\ti\"
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHXL\ti154stack\collector\tirtos\IAR\Debug\Obj --debug --endian=little --CPU=Cortex-M3 -IC:\ti\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCCHXL\ti154stack\collector\tirtos\IAR -FC:\ti\simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\
CC1310_LAUNCHXL\ti154stack\collector\tirtos\IAR\..\..\..\..\common\boards\CC13X0_LAUNCHLXL\configPkg\compiler.opt.defs -IC:\ti\
simplelink_cc13x0_SDK_1_50_00_08/source -IC:\ti\simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHXL\ti154stack\collector\tos\irtos\iAR\..\..\..\..\..\..\..\..\..\.\..
收集器-IC:\ti\simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHXL\ti154stack\collector\tilos\iAR\..\..\..\..\..\collector\subg -IC:\ti\
simplelink_cc13x0_SDK_1_50_00_08\kernel\tirtos\packages -ic:\ti\simplelink_cc13x0_SDK_1_50_00_08\source -ic:\ti\xdctools_3_50_03_33_core\packages -ic:\ti\
xdctools_3_50_03_33_core\packages\XDC -IC:\ti\simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCCHXL\ti154stack\collector\tirtos\IAR\..\..\..\..\..\..\..\..\..\..
通用-IC:\ti\simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\common\inc -IC:\ti\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHXL\ti154stack\collector\tirtos\iAR\..\..\..\..\common\boards -IC:\ti\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHXL\ti154stack\collector\tirtos\iAR\..\..\..\..\common\boards\subg -ic:\ti\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\common\boards\CC13X0_LAUNCXL -IC:\ti\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHXL\ti154stack\collector\tirtos\iAR\..\..\..\..\common\boards\CC1310_CC1190 -IC1310 -IC:1190:\ti\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHXL\ti154stack\collector\tirtos\iAR\..\..\..\..\common\api\inc -ic:\ti\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\common\util -IC:\ti\simplelink_cc13x0_SDK_1_50_00_08\
Examples\RTOS\CC1310_LAUNCHXL\ti154stack\collector\tirtos\IAR\..\..\..\..\..\..\堆 栈\src:\ti\simplelink_cc13x0_SDK_1_50_00_08\Examples\RTOS\CC1310_LAUNCXL\
ti154stack\collector\tirtos\iar \..\..\..\stack\tirtos\inc -ic:\ti\simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCCHXL\ti154stack\collector\tos\irtos\IAR\..\..\..\..\.\..\..
stack\tirtos\src -ic:\ti\simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\
-ic:\ti\simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\SOURCE\ti154stack\hal\src\target\_common -IC:\t\ut\ut\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\src\
cc13xx -IC:\ti\simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCCHXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\.\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\sources\..\ti154stack\osit\osl\ostal\ostal\util\\cl\\cl\in\in\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\sources\..\ti154stack\services\src\AES -IC:\t\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\sources\..\ti154stack\services\src\services\\appasrt-IC:\t\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iar\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\sources\..\ti154stack\services\src\services\in\in.\in\in\in\in.\in\in\in\in\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iar\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\sources\..\ti154stack\services\src\src\services\cc26xx -IC\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\sources\..\ti154stack\services\src\t\services\\tdr -IC:\\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\sources\..\ti154stack\services\src\t\til\data\ic:\\scal\t\t\\cal\\cal\in.\in\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\SOURCE\ti154stack\stack\src\stack\tiCall -IC:\\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\SOURCE\ti154stack\FH -IC:\t\.\.\.\.\.\.\.\.\.\.\.\.\.\.
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\SOURCE\ti154stack\high _level -IC:\ti\.\.\.\.\.\.\.\.\.\.\.\.\.\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\sources\iti154stack\inc -IC:\ti\in\in\.\.\.\.\.\.\.\.\.\.\.\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCCHXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\sources\..\ti154stack\inc栈\in\in\in\inc.\cc13xx -IC:\t\in\in\in\in\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\SOURCE\ti154stack\low_level\cc13xx -IC:\t\util\\ct\\ct\in\in.\in\in\in\in\
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\SOURCE\ti154stack\low_level\cc13xx\subg -ic\.\.\.\.\.\.\.\.\.\.\.\.\.
simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHLXL\ti154stack\collector\tirtos\iAR\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\..\sources\..\ti154stack\track\intrack\ic:\til\intracer -IC:\t\.\.\.\.\.\.
simplelink_cc13x0_sdk_1_50_00_08\sources\ities\devices\cc13x0 -ic:\ti\simplelink_cc13x0_sdk_1_50_00_08\sources\ti\devices\cc13x0\inc -ic:\ti\
simplelink_cc13x0_sdk_1_50_00_08\sources\devices\cc13x0\driverlib -Duse_core_SDK -DRF_multi_mode -DTEMP_SENSOR -DAUTO_START
-DxASSERT_LEDs -DNV_RESTORE -DFEATURE_FH_OPT -DxPOWER_MEAS -DMAC_PNM_MAX_NUMBER_of_NODE=50
-DMX_DEVICE_TABLE条目=50 -DBOARD_DISPLAY_USE_UART -DxBOARD_DISPLAY_USE_LCD -DOLE_PAGE_NV -DOLE_PAGE_NV_FULL _HDR
-DDEVICE_family=cc13x0 -DDeviceFamily_CC13X0 -DCC13XX_LAUNCHXL -DCCFG_FORCE_VDDR_HHH=0 -DSET_CCFG_BL_CONFIG_BL_LEVEL=0x00
-DSET_CCFG_BL_CONFIG_BL_ENable=0xC5 -DSET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0D -DSET_CCFG_BL_CONFIG_BOOTLOADER_ENDE=0xC5
-DHEAPMGR_size=0 -Duse_ICALL -DSTacK_library -DICALL_Lite -DRCN_APP_ASSERT -dhal_Assert _spin
-DICALL_HOUNK_ABORT_FUNC=halAssertHandler -Dxdc_runtime Log_disable_all -Dxdc_runtime _assert_disable_all -DxPREAMBLE兼容性
-DxSTATIC_MAC_SECURE_DEFAULTS -Dxdc_TARGET_Types__=IAR/Targets/ARM/std.h -Dxdc_TARGET_NAME__=M3 -DFEATURE_ENTIGE_ACK
-DFEATURE_SYSTEM_STATS -DxFCS_TYPE16 --preinclude=C:\ti\simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCCHXL\ti154stack\collector\
tirtos\iar\..\..\/collector/subg/features.h --debug --silent -e --aeabi --thum--diag_suppress=Pa050 -e --FPU=None --dlib_config \"C:\Program Files (x86)\IAR Systems\
Embedded Workbench 8.0_2\arm\INC\c\DLib_Config_Normal. h\"-Ohz"--linkOptions "-o C:\ti\simplelink_cc13x0_SDK_1_50_00_08\Examples\RTOS\
CC1310_LAUNCHXL\ti154stack\collector\tirtos\IAR\Debug\EXE\collector_cc13x0lp.out --map C:\ti\simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\
CC1310_LAUNCHXL\ti154stack\collector\tirtos\IAR\Debug\List\collector_cc13x0lp.map --config C:\ti\simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\
CC1310_LAUNCHXL\ti154stack\collector\tirtos\IAR/Cc13x0lp.icf -FC:\ti\simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCHTXL\ti154stack\collector\
tirtos\IAR\..\..\common\boards\CC13X0_LAUNCXL\configPkg\linker.cmd C:\ti\
simplelink_cc13x0_sdk_1_50_00_08/source/ti/devices/cc13x0/driverlib/bin/ia/driverlib.lib C:\ti\
simplelink_cc13x0_SDK_1_50_00_08/source/ti/display/lib/display.arm3 C:\ti\simplelink_cc13x0_SDK_1_50_00_08/source/ti/grlib/grlib.arm3 C:\ti\
simplelink_cc13x0_sdk_1_50_00_08/source/ti/mW/lcd/lib/lc.arm3 C:\ti\simplelink_cc13x0_sdk_1_50_00_08/source/ti/drivers/lib/drivers_cc13x0.arm3 C:\ti\
simplelink_cc13x0_sdk_1_50_00_08/source/ti/drivers/RF/lib/RF_multimone_cc13x0.arm3 C:\ti\
simplelink_cc13x0_SDK_1_50_00_08/kernel/tirtos/ti/DPL/lib/DPL_cc13x0.arm3 C:\ti\simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCCHXL\
ti154stack\collector\tirtos\iar\..\..\library\tirtos\iar\bin/maclib_secure.a --silent --CPU=Cortex-M3 --redirect _printf=_scanfSmall --redirect _f=_ScanfSmall
--config_def one_page_NV=1 --config_def one_page_nv_full _hdr=1 --semihosting --entry __IAR_program_start --vFE --text_out locale"--profile release
--projFile "C:\ti\simplelink_cc13x0_SDK_1_50_00_08\examples\RTOS\CC1310_LAUNCCHXL\ti154stack\collector\tirtos\IAR\collector_cc13x0lp.EWP"
在一个有类似错误的论坛上,我没有找到解决方案。
