下午好!
我正在使用CC1310处理定制PCB。 我有一个SD卡连接到以下CC1310引脚,带有100欧姆系列电阻器和10k上拉电阻器:
SD卡MOSI:引脚17 (DIO_11)
SD卡miso:引脚11 (DIO_6)
SD卡CS:引脚10 (DIO_5)
SD卡CLK:引脚18 (DIO_12)
我正在使用SDRAW.C (nortos)示例。 我在代码中没有更改任何内容,但这里只是为了以防:
/* * Copyright (c) 2016-2019, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* * ======== sdraw.c ======== */ #include <stddef.h> #include <stdint.h> #include <stdlib.h> #include <string.h> /* Driver Header files */ #include <ti/drivers/GPIO.h> #include <ti/drivers/SD.h> #include <ti/display/Display.h> /* Example/Board Header files */ #include "Board.h" /* Buffer size used for the file copy process */ #define BUFFSIZE 1024 /* Starting sector to write/read to */ #define STARTINGSECTOR 0 #define BYTESPERKILOBYTE 1024 /* * Set this constant to 1 in order to write to the SD card. * WARNING: Running this example with WRITEENABLE set to 1 will cause * any filesystem present on the SD card to be corrupted! */ #define WRITEENABLE 1 static Display_Handle display; unsigned char textarray[BUFFSIZE]; unsigned char cpy_buff[BUFFSIZE]; /* * ======== mainThread ======== * Task to perform a raw write and read from the SD card. * Note: Running this application will cause any filesystem on the * SD card to become corrupted! */ void *mainThread(void *arg0) { int_fast8_t result; uint_fast32_t cardCapacity; uint_fast32_t totalSectors; uint_fast32_t sectorSize; uint_fast32_t sectors; int i; SD_Handle sdHandle; Display_init(); GPIO_init(); SD_init(); /* Configure the LED pin */ GPIO_setConfig(Board_GPIO_RLED, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW); // GPIO_setConfig(Board_SPI_FLASH_CS, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_HIGH); /* Open the display for output */ display = Display_open(Display_Type_UART, NULL); if (display == NULL) { /* Failed to open display driver */ while (1); } /* Turn on user LED */ GPIO_write(Board_GPIO_RLED, Board_GPIO_LED_ON); Display_printf(display, 0, 0, "Starting the SD example\n"); /* Initialize the array to write to the SD card */ for (i = 0; i < BUFFSIZE; i++) { textarray[i] = i & 0xFF; } /* Mount and register the SD Card */ sdHandle = SD_open(Board_SD0, NULL); if (sdHandle == NULL) { Display_printf(display, 0, 0, "Error starting the SD card\n"); while (1); } result = SD_initialize(sdHandle); if (result != SD_STATUS_SUCCESS) { Display_printf(display, 0, 0, "Error initializing the SD card\n"); while (1); } totalSectors = SD_getNumSectors(sdHandle); sectorSize = SD_getSectorSize(sdHandle); cardCapacity = (totalSectors / BYTESPERKILOBYTE) * sectorSize; Display_printf(display, 0, 0, "There are %u total sectors on the SD card.\n", totalSectors); Display_printf(display, 0, 0, "The Read/Write sector size is %u bytes\n", sectorSize); Display_printf(display, 0, 0, "The total card capacity is %u KB\n", cardCapacity); /* Calculate number of sectors taken up by the array by rounding up */ sectors = (sizeof(textarray) + sectorSize - 1) / sectorSize; #if (WRITEENABLE) Display_printf(display, 0, 0, "Writing the array...\n"); result = SD_write(sdHandle, textarray, STARTINGSECTOR, sectors); if (result != SD_STATUS_SUCCESS) { Display_printf(display, 0, 0, "Error writing to the SD card\n"); while (1); } #endif Display_printf(display, 0, 0, "Reading the array...\n"); result = SD_read(sdHandle, cpy_buff, STARTINGSECTOR, sectors); if (result != SD_STATUS_SUCCESS) { Display_printf(display, 0, 0, "Error reading from the SD card\n"); while (1); } /* Compare data read from the SD card with expected values */ for (i = 0; i < BUFFSIZE; i++) { if (cpy_buff[i] != textarray[i]) { Display_printf(display, 0, 0, "Data read from SD card differed from expected value\n"); Display_printf(display, 0, 0, " Expected value for index %d: %d, got %d\n", i, textarray[i], cpy_buff[i]); Display_printf(display, 0, 0, "Run the example with WRITEENABLE " "= 1 to write expected values to the SD card\n"); break; } } if (i == BUFFSIZE) { Display_printf(display, 0, 0, "Data read from SD card matched expected values\n"); } SD_close(sdHandle); return (NULL); }
我已更改CC1310_LAUNCHXL_SPI0_Miso,CC1310_LAUNCHXL_SPI0_MOSI,CC1310_LAUNCHXL_SPI0_CLK和CC1310_LAUNCHXL_SPI0_CSN 的针脚,使其与我的引脚匹配。 我没有更改此文件中的任何其他内容:
/* SPI */ #define CC1310_LAUNCHXL_SPI_FLASH_CS IOID_5 // WAS IOID_20 #define CC1310_LAUNCHXL_FLASH_CS_ON 0 #define CC1310_LAUNCHXL_FLASH_CS_OFF 1 /* SPI Board */ #define CC1310_LAUNCHXL_SPI0_MISO IOID_11 //WAS IOID_8 /* RF1.20 */ #define CC1310_LAUNCHXL_SPI0_MOSI IOID_6 //WAS IOID_9 /* RF1.18 */ #define CC1310_LAUNCHXL_SPI0_CLK IOID_12 //WAS IOID_10 /* RF1.16 */ #define CC1310_LAUNCHXL_SPI0_CSN IOID_5 // WAS IOID_11 #define CC1310_LAUNCHXL_SPI1_MISO PIN_UNASSIGNED #define CC1310_LAUNCHXL_SPI1_MOSI PIN_UNASSIGNED #define CC1310_LAUNCHXL_SPI1_CLK PIN_UNASSIGNED #define CC1310_LAUNCHXL_SPI1_CSN PIN_UNASSIGNED /* UART Board */ #define CC1310_LAUNCHXL_UART_RX IOID_2 //was 2 /* RXD */ #define CC1310_LAUNCHXL_UART_TX IOID_3 //was 3 /* TXD */ #define CC1310_LAUNCHXL_UART_CTS IOID_19 /* CTS */ #define CC1310_LAUNCHXL_UART_RTS IOID_18 /* RTS */
然而当在我的PCB中插入一个新格式化的SD卡时,它会卡在while循环中,因为SD_OPEN返回NULL。
我做错了什么?
提前感谢。
KR,
Mirte H
