[参考译文] CC1120:无法使用开发套件启动数据包 TX
Guru**** 2782615 points
Other Parts Discussed in Thread: CC1120, SMARTRFTRXEBK
https://e2e.ti.com/support/wireless-connectivity/sub-1-ghz-group/sub-1-ghz/f/sub-1-ghz-forum/1015257/cc1120-unable-to-start-packet-tx-with-dev-kit
器件型号:CC1120
因此、当我按下 Packet TX 选项卡上的开始按钮时、它会设法发送3个数据包、但程序会冻结。 最后、我会看到一个窗口、要求我重新启动设备控制面板。 这是可重复的、并且每次使用这些设置时都会发生:
<?xml version="1.0" encoding="ISO-8859-1"?>
<!DOCTYPE configuration SYSTEM "C:/Program Files (x86)/Texas Instruments/SmartRF Tools/SmartRF Studio 7/config/xml/configdata.dtd"[]>
<dcpanelconfiguration>
    <Devicename>CC1120</Devicename>
    <Description>Saved configuration data</Description>
    <registersettings>
        <Register>
            <Name>AGC_CFG0</Name>
            <Value>0xcf</Value>
        </Register>
        <Register>
            <Name>AGC_CFG1</Name>
            <Value>0x0a</Value>
        </Register>
        <Register>
            <Name>AGC_CS_THR</Name>
            <Value>0x19</Value>
        </Register>
        <Register>
            <Name>AGC_GAIN_ADJUST</Name>
            <Value>0x9a</Value>
        </Register>
        <Register>
            <Name>AGC_REF</Name>
            <Value>0x2e</Value>
        </Register>
        <Register>
            <Name>CHAN_BW</Name>
            <Value>0x02</Value>
        </Register>
        <Register>
            <Name>DCFILT_CFG</Name>
            <Value>0x1c</Value>
        </Register>
        <Register>
            <Name>DEVIATION_M</Name>
            <Value>0x47</Value>
        </Register>
        <Register>
            <Name>FIFO_CFG</Name>
            <Value>0x00</Value>
        </Register>
        <Register>
            <Name>FREQ0</Name>
            <Value>0x33</Value>
        </Register>
        <Register>
            <Name>FREQ1</Name>
            <Value>0xf3</Value>
        </Register>
        <Register>
            <Name>FREQ2</Name>
            <Value>0x6d</Value>
        </Register>
        <Register>
            <Name>FREQOFF0</Name>
            <Value>0xf2</Value>
        </Register>
        <Register>
            <Name>FREQOFF1</Name>
            <Value>0xff</Value>
        </Register>
        <Register>
            <Name>FREQOFF_CFG</Name>
            <Value>0x02</Value>
        </Register>
        <Register>
            <Name>FS_CAL0</Name>
            <Value>0x0e</Value>
        </Register>
        <Register>
            <Name>FS_CAL1</Name>
            <Value>0x40</Value>
        </Register>
        <Register>
            <Name>FS_CFG</Name>
            <Value>0x14</Value>
        </Register>
        <Register>
            <Name>FS_CHP</Name>
            <Value>0x27</Value>
        </Register>
        <Register>
            <Name>FS_DIG0</Name>
            <Value>0x5f</Value>
        </Register>
        <Register>
            <Name>FS_DIG1</Name>
            <Value>0x00</Value>
        </Register>
        <Register>
            <Name>FS_DIVTWO</Name>
            <Value>0x03</Value>
        </Register>
        <Register>
            <Name>FS_DSM0</Name>
            <Value>0x33</Value>
        </Register>
        <Register>
            <Name>FS_DVC0</Name>
            <Value>0x17</Value>
        </Register>
        <Register>
            <Name>FS_PFD</Name>
            <Value>0x50</Value>
        </Register>
        <Register>
            <Name>FS_PRE</Name>
            <Value>0x6e</Value>
        </Register>
        <Register>
            <Name>FS_REG_DIV_CML</Name>
            <Value>0x14</Value>
        </Register>
        <Register>
            <Name>FS_SPARE</Name>
            <Value>0xac</Value>
        </Register>
        <Register>
            <Name>FS_VCO0</Name>
            <Value>0xb4</Value>
        </Register>
        <Register>
            <Name>FS_VCO1</Name>
            <Value>0x9c</Value>
        </Register>
        <Register>
            <Name>FS_VCO2</Name>
            <Value>0x50</Value>
        </Register>
        <Register>
            <Name>FS_VCO4</Name>
            <Value>0x13</Value>
        </Register>
        <Register>
            <Name>IF_MIX_CFG</Name>
            <Value>0x00</Value>
        </Register>
        <Register>
            <Name>IOCFG0</Name>
            <Value>0x30</Value>
        </Register>
        <Register>
            <Name>IOCFG1</Name>
            <Value>0xb0</Value>
        </Register>
        <Register>
            <Name>IOCFG2</Name>
            <Value>0x09</Value>
        </Register>
        <Register>
            <Name>IOCFG3</Name>
            <Value>0x14</Value>
        </Register>
        <Register>
            <Name>IQIC</Name>
            <Value>0x00</Value>
        </Register>
        <Register>
            <Name>MDMCFG0</Name>
            <Value>0x4a</Value>
        </Register>
        <Register>
            <Name>MDMCFG1</Name>
            <Value>0x06</Value>
        </Register>
        <Register>
            <Name>MODCFG_DEV_E</Name>
            <Value>0x06</Value>
        </Register>
        <Register>
            <Name>PA_CFG0</Name>
            <Value>0x7d</Value>
        </Register>
        <Register>
            <Name>PA_CFG1</Name>
            <Value>0x54</Value>
        </Register>
        <Register>
            <Name>PA_CFG2</Name>
            <Value>0x6e</Value>
        </Register>
        <Register>
            <Name>PKT_CFG0</Name>
            <Value>0x20</Value>
        </Register>
        <Register>
            <Name>PKT_CFG1</Name>
            <Value>0x00</Value>
        </Register>
        <Register>
            <Name>PKT_CFG2</Name>
            <Value>0x07</Value>
        </Register>
        <Register>
            <Name>PKT_LEN</Name>
            <Value>0x40</Value>
        </Register>
        <Register>
            <Name>PREAMBLE_CFG1</Name>
            <Value>0x00</Value>
        </Register>
        <Register>
            <Name>SETTLING_CFG</Name>
            <Value>0x03</Value>
        </Register>
        <Register>
            <Name>SYMBOL_RATE2</Name>
            <Value>0x73</Value>
        </Register>
        <Register>
            <Name>SYNC0</Name>
            <Value>0xaa</Value>
        </Register>
        <Register>
            <Name>SYNC1</Name>
            <Value>0xaa</Value>
        </Register>
        <Register>
            <Name>SYNC2</Name>
            <Value>0xaa</Value>
        </Register>
        <Register>
            <Name>SYNC3</Name>
            <Value>0xaa</Value>
        </Register>
        <Register>
            <Name>SYNC_CFG0</Name>
            <Value>0x00</Value>
        </Register>
        <Register>
            <Name>SYNC_CFG1</Name>
            <Value>0x1f</Value>
        </Register>
        <Register>
            <Name>XOSC1</Name>
            <Value>0x03</Value>
        </Register>
        <Register>
            <Name>XOSC5</Name>
            <Value>0x0e</Value>
        </Register>
    </registersettings>
    <dcpanel>
        <Property name="m_chkRegView" role="44">2</Property>
        <Property name="m_chkCmdView" role="44">0</Property>
        <Property name="m_chkRfParameters" role="44">2</Property>
        <Property name="m_cmbUserMode" role="46">1</Property>
        <Property name="m_easyModeSettings" role="33">-1</Property>
        <Property name="m_typicalSettings" role="33">-1</Property>
        <Property name="m_testFuncPanel" role="37">2</Property>
    </dcpanel>
    <rfparameters>
        <Property name="m_cmbFrontends" role="46">0</Property>
        <Property name="m_chkHGMorBYP" role="44">2</Property>
        <Property name="m_cmbEmRevs" role="46">-1</Property>
        <Property name="Xtal Frequency" role="46">32.000000</Property>
    </rfparameters>
    <conttx>
        <Property name="m_rbtModulated" role="45">1</Property>
        <Property name="m_rbtUnmodulated" role="45">0</Property>
        <Property name="m_cmbDataFormat" role="46">1</Property>
        <Property name="m_chkFreqSweep" role="44">0</Property>
        <Property name="m_chkChanSweep" role="44">0</Property>
    </conttx>
    <contrx>
        <Property name="m_chkAutoScroll" role="44">2</Property>
    </contrx>
    <packettx>
        <Property name="m_edtPayloadSize" role="42">30</Property>
        <Property name="m_edtPacketCount" role="42">100</Property>
        <Property name="m_edtPacketCountEsy" role="42">100</Property>
        <Property name="m_edtRandomPacketData" role="42">13 0d 89 0a 1c db ae 32 20 9a 50 ee 40 78 36 fd 12 49 32 f6 9e 7d 49 dc ad 4f 14 f2 </Property>
        <Property name="m_edtPacketData" role="42"></Property>
        <Property name="m_edtAccessAddress" role="42"></Property>
        <Property name="m_edtDeviceAddress" role="42"></Property>
        <Property name="m_chkAddSeqNbr" role="44">2</Property>
        <Property name="m_chkInfinite" role="44">0</Property>
        <Property name="m_chkInfiniteEsy" role="44">0</Property>
        <Property name="m_rbtRandom" role="45">1</Property>
        <Property name="m_rbtText" role="45">0</Property>
        <Property name="m_rbtHex" role="45">0</Property>
        <Property name="m_chkAdvanced" role="44">0</Property>
    </packettx>
    <packetrx>
        <Property name="m_cmbViewFormat" role="46">0</Property>
        <Property name="m_chkSeqNbrIncluded" role="44">2</Property>
        <Property name="m_edtDumpFile" role="42"></Property>
        <Property name="m_chk802154gMode" role="44">0</Property>
    </packetrx>
    <commandpanel>
        <Property name="m_chkInsertLength" role="44">0</Property>
        <Property name="m_edtTxFifo" role="42"></Property>
        <Property name="m_edtRxFifo" role="42"></Property>
        <Property name="m_cmbInstrInput" role="46">-1</Property>
    </commandpanel>
    <packetRxSniffMode>
        <Property name="m_edtPreambleLength" role="42">8</Property>
        <Property name="m_edtCarrierSenseThreshold" role="42">-90</Property>
        <Property name="m_rbtRssi" role="45">1</Property>
        <Property name="m_rbtPreamble" role="45">0</Property>
    </packetRxSniffMode>
</dcpanelconfiguration>
我出了什么问题?
    我已通知一位专家对此进行研究。
    同时、这些是默认值吗?
    如果没有、它是否适用于 SmartRF Studio 中的默认设置?
    Toby
    我假设您使用的是 SmartRF Studio
    您使用的确切硬件是什么?
    如果您尚未将 GPIO2从 CC1120连接到 EM 连接器、也会看到这种情况。
    我正在使用 CC1120开发套件、特别是 Smart RF TX 板。
    该电路板使用默认值。
    @、您是否建议更改 GPIO2_CFG 寄存器? 我应该将其更改为什么?
    您是否将 TRXEB (www.ti.com/.../SMARTRFTRXEBK)与 CC1120 EM (https://www.ti.com/tool/CC1120EMK-868-915)?)结合使用
    是的
    导入.cfg 文件之后。
    按数字并在此处写入06。 如您所见 、这用于其他设置。
    感谢您的建议、
    但这似乎没有解决问题。 我收到相同的错误消息。
     我这里没有 CC1120 EM。 您可以尝试从 SmartRF Studio 中的设置开始、在该设置中、您可以发送3个以上的数据包并逐一更改寄存器值以反映您的设置。 从顶部开始、查看导致事件崩溃的原因。
