Other Parts Discussed in Thread: BOOSTXL-CC1125, CC1125
主题中讨论的其他器件: CC1125
我有 一个 BOOSTXL-CC1125、我使用 SmartRF Studio 将其置于457MHz 的"连续、未调制"传输中:
我已从 SmartRF Studio 导出命令、并让 AVR 将同一组命令发送到同一 BOOSTXL-CC1125板-但 我从未看到任何射频活动。
下面显示了我要发送的内容(左侧)和右侧的 SmartRF Studio 序列、以供比较
STB =选通信号命令;
rg8 = 8位寄存器访问;
rg16 =扩展(16位)寄存器访问。
| 类型 | 访问 | 地址 | 长度 | 数据 | 状态 | SmartRF Studio | ||||
| STB | 30 | 0F | SRES | 复位 | ||||||
| STB | 36. | 0F | 面 | 面 | ||||||
| STB | 3b. | 0F | SFTX | SFTX | ||||||
| rg8. | 00 | 2b. | 0001. | 三 | 0F | PA_CFG2 | PA_CFG2 0x3f 2 W | |||
| RGF | 00 | 2F | 05 | 0001. | 01 | 0F | CFM_DATA_CFG | CFM_DATA_CFG 0x01 2 W | ||
| rg8. | 00 | 一维 | 0001. | cf | 0F | AGC_CFG0 | AGC_CFG0 0xCF 2 W | |||
| rg8. | 00 | 1c. | 0001. | A9 | 0F | AGC_CFG1 | AGC_CFG1 0xa9 2 W | |||
| rg8. | 00 | 18 | 0001. | 19. | 0F | AGC_CS_THR | AGC_CS_THR 0x19 2 W | |||
| rg8. | 00 | 17. | 0001. | 20. | 0F | AGC_REF | AGC_REF 0x20 2 W | |||
| rg8. | 00 | 11. | 0001. | 10. | 0F | CHAN_BW | CHAN_BW 0x10 2 W | |||
| rg8. | 00 | 0°C | 0001. | 1c. | 0F | DCFILT_CFG | DCFILT_CFG 0x1c 2 W | |||
| rg8. | 00 | 0a | 0001. | 答3. | 0F | 偏差_M | 偏差_M 0xa3 2 W | |||
| rg8. | 00 | 1e. | 0001. | 00 | 0F | FIFO_CFG | FIFO_CFG 0x00 2 W | |||
| RGF | 00 | 2F | 0E | 0001. | C6 | 0F | FREQ0 | FREQ0 0xc6 2 W | ||
| RGF | 00 | 2F | 0D | 0001. | BC | 0F | FREQ1 | FREQ1 bbbc 2 W | ||
| RGF | 00 | 2F | 0°C | 0001. | 5B | 0F | FREQ2 | FREQ2 0x5b 2W | ||
| RGF | 00 | 2F | 01 | 0001. | 22. | 0F | FREQOFF_CFG | FREQOFF_CFG 0x22 2 W | ||
| rg8. | 00 | 0f | 0001. | 33. | 0F | FREQ_IF_CFG | FREQ_IF_CFG 0x33 2 W | |||
| RGF | 00 | 2F | 17. | 0001. | 0E | 0F | FS_CAL0 | FS_CAL0 0x0E 2 W | ||
| rg8. | 00 | 21. | 0001. | 14. | 0F | FS_CFG | FS_CFG 0x14 2 W | |||
| RGF | 00 | 2F | 13. | 0001. | 5 f | 0F | FS_DIG0 | FS_DIG0 0x5f 2 W | ||
| RGF | 00 | 2F | 12. | 0001. | 00 | 0F | FS_DIG1 | FS_DIG1 0x00 2 W | ||
| RGF | 00 | 2F | 19. | 0001. | 03 | 0F | FS_DIVTWO | FS_DIVTWO 0x03 2 W | ||
| RGF | 00 | 2F | 1b | 0001. | 33. | 0F | FS_DSM0 | FS_DSM0 0x33 2 W | ||
| RGF | 00 | 2F | 一维 | 0001. | 17. | 0F | FS_DVC0 | FS_DVC0 0x17 2 W | ||
| RGF | 00 | 2F | 1f | 0001. | 50 | 0F | FS_PFD | FS_PFD 0x50 2 W | ||
| RGF | 00 | 2F | 20. | 0001. | 6e | 0F | FS_PRE | FS_PRE 0x6e 2 W | ||
| RGF | 00 | 2F | 21. | 0001. | 14. | 0F | FS_REG_DIV_CML | FS_REG_DIV_CML 0x14 2 W | ||
| RGF | 00 | 2F | 22. | 0001. | 交流 | 0F | FS_SPARE | FS_SPARE 0xac 2 W | ||
| RGF | 00 | 2F | 11. | 0001. | 05 | 0F | IF_ADC0 | IF_ADC0 0x05 2 W | ||
| RGF | 00 | 2F | 00 | 0001. | 00 | 0F | IF_Mix_CFG | IF_Mix_CFG 0x00 2 W | ||
| rg8. | 00 | 03 | 0001. | 09. | 0F | IOCFG0 | IOCFG0 0x09 2 W | |||
| rg8. | 00 | 02 | 0001. | B0 | 0F | IOCFG1 | IOCFG1 0xb2 W | |||
| rg8. | 00 | 01 | 0001. | 08 | 0F | IOCFG2 | IOCFG2 0x08 2 W | |||
| rg8. | 00 | 00 | 0001. | B0 | 0F | IOCFG3 | IOCFG3 0xb2 W | |||
| rg8. | 00 | 10. | 0001. | C6 | 0F | IQIC | IQIC 0xc6 2 W | |||
| rg8. | 00 | 13. | 0001. | 05 | 0F | MDMCFG0 | MDMCFG0 0x05 2 W | |||
| rg8. | 00 | 12. | 0001. | 06 | 0F | MDMCFG1 | MDMCFG1 0x06 2 W | |||
| rg8. | 00 | 0b | 0001. | 0a | 0F | MODCFG_DEV_E | MODCFG_DEV_E 0x0a 2W | |||
| rg8. | 00 | 28. | 0001. | 20. | 0F | Pkt_CFG0 | PKT_CFG0 0x20 2 W | |||
| rg8. | 00 | 27. | 0001. | 00 | 0F | Pkt_CFG1 | PKT_CFG1 0x00 2 W | |||
| rg8. | 00 | 26 | 0001. | 05 | 0F | Pkt_CFG2 | PCT_CFG2 0x05 2 W | |||
| rg8. | 00 | 0D | 0001. | 00 | 0F | 前导码_CFG1 | 前导码_CFG1 0x00 2 W | |||
| RGF | 00 | 2F | 91. | 0001. | 08 | 0F | serial_status | serial_status 0x08 2 W | ||
| rg8. | 00 | 20. | 0001. | 03 | 0F | Setting_CFG | Setting_CFG 0x03 2 W | |||
| rg8. | 00 | 16. | 0001. | 10. | 0F | 符号_RATE0 | SYMBOL_RATE0 0x10 2 W | |||
| rg8. | 00 | 15. | 0001. | 75 | 0F | symbol_rate1 | symbol_rate1 0x75 2 W | |||
| rg8. | 00 | 14. | 0001. | 三 | 0F | 符号2 | Symbol_Rate2 0x3f 2 W | |||
| rg8. | 00 | 08 | 0001. | 08 | 0F | SYNC_CFG1 | SYNC_CFG1 0x08 2 W | |||
| RGF | 00 | 2F | 36. | 0001. | 07 | 0F | XOSC1 | XOSC1 0x07 2 W | ||
| RGF | 00 | 2F | 34 | 0001. | C7 | 0F | XOSC3 | XOSC3 0xc7 2 W | ||
| RGF | 00 | 2F | 32 | 0001. | 0E | 0F | XOSC5 | XOSC5 0x0E 2 W | ||
| RGF | 00 | 2F | 9F | 0001. | 00 | 0F | XOSC_TEST1 | XOSC_TEST1 0x00 2 W | ||
| RGF | 80 | 2F | 8F | 0001. | 58. | :00 | 器件型号 | |||
| RGF | 80 | 2F | 90 | 0001. | 21. | :00 | 方案 | |||
| STB | 3D | 0F | SNOP | |||||||
| STB | 36. | 0F | 面 | |||||||
| STB | 3b. | 0F | SFTX | |||||||
| RGF | 00 | 2F | 25 | 0001. | 00 | 0F | FS_VCO2 | FS_VCO2 0x00 2 W | ||
| RGF | 00 | 2F | 15. | 0001. | 22. | 0F | FS_CAL2 | FS_CAL2 0x22 2 W | ||
| RGF | 00 | 2F | 15. | 0001. | 20. | 0F | FS_CAL2 | FS_CAL2 0x20 2 W | ||
| STB | 35. | 0F | STX | STX | ||||||
| STB | 3D | :2F | SNOP | |||||||
在 STX 命令选通处、电路板开始使用 SmartRF Studio 进行传输、但不使用 AVR。
请注意 、 带 AVR 的 STX 之后的状态表示芯片处于 TX 状态!
此外、在该状态下、使用 AVR 时、GPIO2上确实会出现1.2kHz 信号-与 SmartRF Studio 相同。
那么、AVR 会缺少什么呢? 或者 什么是 SmartRF Studio 跟踪不能告诉我?
