[参考译文] CC1352P:能否在 OAD 片外示例中更改 BIM_VER 宏?
Guru**** 2487425 points
Other Parts Discussed in Thread: CC1352P
https://e2e.ti.com/support/wireless-connectivity/sub-1-ghz-group/sub-1-ghz/f/sub-1-ghz-forum/1179127/cc1352p-can-i-change-bim_ver-macro-at-oad-off-chip-examples
器件型号:CC1352P
在 bim_offchip_CC1352P_4_LAUNCHXL_nortos_ticlang 示例中,在 oad_image_header.h 上,我看到了以下宏和警告:
 * Version of BIM this image is intended to work with
 * \warning This is not intended to be changed
#define BIM_VER                      0x3
是否可以更改 bim 版本? 还是 可能导致 OAD 代码中某处出现意外行为?
