[参考译文] LP-CC1311P3:LP-CC1311P3 SimpleLink Academy 中缺少 Project Zero
Guru**** 2527670 points
Other Parts Discussed in Thread: LP-CC1311P3, CC1311P3
https://e2e.ti.com/support/wireless-connectivity/sub-1-ghz-group/sub-1-ghz/f/sub-1-ghz-forum/1253918/lp-cc1311p3-missing-project-zero-in-lp-cc1311p3-simplelink-academy
器件型号:LP-CC1311P3
主题中讨论的其他器件: CC1311P3
您好、TI。
我曾尝试使用 LP-CC1311P3和 SimpleLink Academy 开始开发 CC1311P3、但在站点上:https://dev.ti.com/tirex/explore/node?a=Zj4YMtc__5.6.1&node=A__AJQ.W4SjOquNWJ4zKRUcCw__cc13xx_devtools__FUz-xrs__LATEST&r=Zj4YMtc__LATEST&r=fc2e6sr__3.30.00.04&r=pTTHBmu__3.20.00.68 当我尝试单击 传感器和收集器- TI 15.4-Stack Project Zero 时、 我收到以下错误消息:
Could not resolve Rex 3 link "Software/SimpleLink CC13xx CC26xx SDK/SimpleLink Academy/TI 15.4-Stack/Sensor and Collector - TI 15.4-Stack Project Zero": Expected foundation node in link
