[参考译文] CC1310:ADC 收集电压引脚是否需要一个支持模拟输入的引脚?
Guru**** 2478765 points
Other Parts Discussed in Thread: CC1310
https://e2e.ti.com/support/wireless-connectivity/sub-1-ghz-group/sub-1-ghz/f/sub-1-ghz-forum/1341662/cc1310-does-the-adc-collect-voltage-pin-require-a-pin-that-supports-analog-inputs
器件型号:CC1310
CC1310 ADC 收集电压引脚的要求是什么、还是所有引脚都可接受?
