[参考译文] CC3135:CC3135 SDK 许可证
Guru**** 2526560 points
Other Parts Discussed in Thread: CC3135
https://e2e.ti.com/support/wireless-connectivity/wi-fi-group/wifi/f/wi-fi-forum/1126596/cc3135-cc3135-sdk-license
器件型号:CC3135
各位专家、您好!
我们的客户希望确认 CC3135 SDK, simplelink_cc32xx_sdk_6_10_00_05。
他们找到了此 SDK 许可证的2个文档。
manifest_simplelink_cc32xx_sdk_6_10_00_05.htm
license_simplelink_cc32xx_sdk_6_10_00_05.txt ( 这在 SDK 安装时序中显示)
这2个文档是否是他们需要参考的所有文档?
是否有任何与许可证相关的文档、但这些文档除外?
A. Fujinaka
    Akihiko、您好!
    CC3135 SDK 实际上不同于 CC32XX、您可以在 此处找到 SDK 插件。
    运行安装程序时,必须接受许可协议。 它位于下方
    Copyright (c) 2017, Texas Instruments Incorporated
    All rights reserved.
    Redistribution and use in source and binary forms, with or without
    modification, are permitted provided that the following conditions
    are met:
    * Redistributions of source code must retain the above copyright
    notice, this list of conditions and the following disclaimer.
    * Redistributions in binary form must reproduce the above copyright
    notice, this list of conditions and the following disclaimer in the
    documentation and/or other materials provided with the distribution.
    * Neither the name of Texas Instruments Incorporated nor the names of
    its contributors may be used to endorse or promote products derived
    from this software without specific prior written permission.
    THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
    AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
    THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
    PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
    CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
    EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
    PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
    OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
    WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
    OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
    EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    这是他们在使用 SDK 时需要参考的许可证。
    以及清单文件
    e2e.ti.com/.../Manifest-File.pdf
    希望这对您有所帮助、
    Rogelio
    Rogelio、您好!
    Thdy 识别 CC32xx 的最新 SDK
    但对于 CC3135,这些是最新版本。
    manifest_simplelink_sdk_wifi_plugin_4_20_00_10.html
    license_simplelink_sdk_wifi_plugin_4_20_00_10.txt
    此处提供的信息表明,CC3135最简约的版本与 CC32xx 相同。
    CC3135:最新 SDK - Wi-Fi 论坛- Wi-Fi - TI E2E 支持论坛
    即使他们将 使用 cc32xx_sdk_6_10_00_05作为最新版本、
    他们需要遵循 CC3135的 ver_4_20_00_10清单和许可证?
    A. Fujinaka
    如果他们要使用 CC32xx SDK、则必须遵循该许可证。 请注意、cc32xx SDK 上的演示不适用于 cc3135、因为主机处理器会有所不同。
    -Rogelio
