[参考译文] CC3220SF:为什么 UART.h 读取回调失败?
Guru**** 2815505 points
Other Parts Discussed in Thread: CC3220SF
https://e2e.ti.com/support/wireless-connectivity/wi-fi-group/wifi/f/wi-fi-forum/1049724/cc3220sf-why-read-callback-fail-with-uart-h
器件型号:CC3220SF
您好、支持团队、
我们的产品使用 CC3220SF SoC。 SimpleLink-SDK 版本:simplelink_cc32xx_sdk_4_30_00_06。
在演示代码"AT_commands"(路径:C:\ti\simplelink_cc32xx_sdk_4_30_00_06\examples\rtos\CC3220SF_LAUNCHXL_demos\at_commands\tirtos\ccs)中,使用 UART.h 而不是 UART2.h
我使用示例代码“uartecho”并修改"uartecho.c"代码,然后在 Launchpad 中运行代码。
我的问题:
  1. 回调函数是 ISR (中断服务例程)?
  2. 第112行、如果没有 UART_READ (UART、INPUT、1)、则回调函数不起作用、为什么?
  3. 我同时通过 Terminal v1.9v 程序发送“$4C$53$31$32$33$34$35$23”,但我从未收到“RightMatch”消息。
  4. 无法在 UART.h 中使用 readcallback 函数? 因为我没有看到任何示例或演示代码将 readcallback 函数与 UART.h 一同使用
 * Copyright (c) 2015-2020, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 * *  Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 *    its contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  ======== uartecho.c ========
#include <stdint.h>
#include <stddef.h>
/* Driver Header files */
#include <ti/drivers/GPIO.h>
#include <ti/drivers/UART.h>
/* Driver configuration */
#include "ti_drivers_config.h"
volatile char g_ucInput = 0;
volatile char g_ucRxDBuf[8] = {0};
volatile char g_ucTestLEDFlag = 0;
UART_Handle uart;
UART_Params uartParams;
void readcallback_LS (UART_Handle handle, void *buf, size_t count)
  char i;
  char i_input;
  UART_read(uart, &i_input, 1);
  g_ucInput = i_input;
  for(i=7; i>=1; i--)
    g_ucRxDBuf[i] = g_ucRxDBuf[i-1];
  g_ucRxDBuf[0]=g_ucInput;
} // End void readcallback_LS (UART_Handle handle, void *buf, size_t count)
 *  ======== mainThread ========
void *mainThread(void *arg0)
    char        input;
    const char  echoPrompt[] = "Echoing characters:\r\n";
    const char  RightMatch[] = "Match J-MEX command\r\n";
    /* Call driver init functions */
    GPIO_init();
    UART_init();
    /* Configure the LED pin */
    GPIO_setConfig(CONFIG_GPIO_LED_0, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
    /* Create a UART with data processing off. */
    UART_Params_init(&uartParams);
    uartParams.readMode = UART_MODE_CALLBACK;
    uartParams.writeMode = UART_MODE_BLOCKING;
    uartParams.readCallback = readcallback_LS;
    uartParams.readReturnMode = UART_RETURN_FULL;
    uartParams.readDataMode = UART_DATA_BINARY;
    uartParams.writeDataMode = UART_DATA_BINARY;
    uartParams.readEcho = UART_ECHO_OFF;
    uartParams.baudRate = 115200;
    uartParams.dataLength = UART_LEN_8;
    uartParams.stopBits = UART_STOP_ONE;
    uartParams.parityType = UART_PAR_NONE;
    uart = UART_open(CONFIG_UART_0, &uartParams);
    if (uart == NULL) {
        /* UART_open() failed */
        while (1);
    /* Turn on user LED to indicate successful initialization */
    GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_ON);
    UART_write(uart, echoPrompt, sizeof(echoPrompt));
    UART_control(uart, UART_CMD_RXENABLE, NULL);
    UART_read(uart, &input, 1);
    /* Loop forever echoing */
    while (1) {
      // Lishen add[S]
      if( (g_ucRxDBuf[7]==0x4C) && (g_ucRxDBuf[6]==0x53) && (g_ucRxDBuf[0]==0x23) )
        UART_write(uart, RightMatch, sizeof(RightMatch));
      else
        GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_OFF);
Lishen
    是的、 上下文是硬件中断
    1. 第112行、如果没有 UART_READ (UART、INPUT、1)、则回调函数不起作用、为什么?
    应通过调用 read()或 write()来触发回调函数。
    读取或写入完成后、UART 驱动 程序应调用用户的回调函数。
    1. 我同时通过 Terminal v1.9v 程序发送“$4C$53$31$32$33$34$35$23”,但我从未收到“RightMatch”消息。
    您得到的结果是什么?
    1. 无法在 UART.h 中使用 readcallback 函数? 因为我没有看到任何示例或演示代码将 readcallback 函数与 UART.h 一同使用
    您说得对、虽然 UART 可以正常工作、但没有示例。
    Shlomi
    尊敬的 Shlomi:
    我参考 uart2callback 示例代码、我修改并测试此代码对我来说很好。 接下来、我将创建一个新线程、以便在(1){...}时为其提供服务 并获取24字节 RX 数据。 感谢你的帮助。
     * are met:
    #include <stdint.h>
    #include <stddef.h>
    /* POSIX Header files */
    #include <semaphore.h>
    //volatile char g_ucRxDBuf[8] = {0};
    volatile char g_ucRxDBuf[24] = {0};
    static sem_t sem_UartRxCallBack;
    #if (0)
      char i;
      char i_input;
      for(i=7; i>=1; i--)
    #endif
      sem_post(&sem_UartRxCallBack);
        unsigned char i;
        char        input;
        const char  RightMatch[] = "Match J-MEX WiFi-Moti command\r\n";
        UART_Handle uart;
        GPIO_init();
        UART_init();
        /* Create semaphore */
        sem_init(&sem_UartRxCallBack, 0, 0);
        if (uart == NULL) {
            while (1);
        UART_control(uart, UART_CMD_RXENABLE, NULL);      //callback function will work. so this is enable RX interrupt.
        //UART_control(uart, UART_CMD_RXDISABLE, NULL);     //callback function will not working. so this is disable RX interrupt.
        while (1)
          /* until read callback executes */
          sem_wait(&sem_UartRxCallBack);
          for(i=23; i>=1; i--)
          g_ucRxDBuf[0]=input;
          if( (g_ucRxDBuf[23]==0x4C) && (g_ucRxDBuf[22]==0x53) && (g_ucRxDBuf[21]==0x14) && (g_ucRxDBuf[0]==0x23) )
            for(i=0; i<=23; i++)
              g_ucRxDBuf[i] = 0;    // reset all UART RxD command Buffer
          else
    Lishen
