[参考译文] LAUNCHXL-CC1352P:问题:路由器在加入网络时崩溃。
Guru**** 3030160 points
https://e2e.ti.com/support/wireless-connectivity/zigbee-thread-group/zigbee-and-thread/f/zigbee-thread-forum/1484720/launchxl-cc1352p-issue-router-crashes-when-join-into-the-network
器件型号:LAUNCHXL-CC1352P
环境中有多个协调人、他们都已关闭许可工作。 如果路由器未能检测到加入网络的可能性、它将崩溃。
没错。 此问题是由函数'bdb_filterNwkDisc'引起的。 它可以像这样进行固定。
void bdb_filterNwkDisc(void)
  networkDesc_t* pNwkDesc;
  uint8_t i = 0;
  uint8_t ResultCount = 0, ResultTotal = 0;
  pBDBListNwk  = nwk_getNwkDescList();
  nwk_desc_list_release();
  pNwkDesc = pBDBListNwk;
  while (pNwkDesc)
    ResultCount++;
    pNwkDesc = pNwkDesc->nextDesc;
  ResultTotal = ResultCount;
  if(pBDBListNwk)
    if(pNwkDesc)
      void *nextDesc = pNwkDesc->nextDesc;
      // "nextDesc" replace "pNwkDesc->nextDesc" because "pNwkDesc->nextDesc" is not corret after freed, fixed by LuoYiming 2025-03-10
      for ( i = 0; i < ResultTotal; i++, pNwkDesc = nextDesc )
        nextDesc = pNwkDesc->nextDesc; // get the "nextDesc" before "pNwkDesc" is freed, fixed by LuoYiming 2025-03-10
        if ( nwk_ExtPANIDValid( ZDO_UseExtendedPANID ) == true )
          // If the extended Pan ID is commissioned to a non zero value
          // Only join the Pan that has match EPID
          if ( osal_ExtAddrEqual( ZDO_UseExtendedPANID, pNwkDesc->extendedPANID) == false )
            //Remove from the list
            bdb_nwkDescFree(pNwkDesc);
            ResultCount--;
            continue;
        else if ( zgConfigPANID != 0xFFFF )
          // PAN Id is preconfigured. check if it matches
          if ( pNwkDesc->panId != zgConfigPANID )
            ResultCount--;
            continue;
        if ( pNwkDesc->chosenRouter != _NIB.nwkCoordAddress || _NIB.nwkCoordAddress == INVALID_NODE_ADDR )
          // check that network is allowing joining
          if ( ZSTACK_ROUTER_BUILD )
            if ( !pNwkDesc->routerCapacity )
              ResultCount--;
              continue;
          else if ( ZSTACK_END_DEVICE_BUILD )
            if ( !pNwkDesc->deviceCapacity )
              ResultCount--;
              continue;
        // check version of zigbee protocol
        if ( pNwkDesc->version != _NIB.nwkProtocolVersion )
          continue;
        // check version of stack profile, only matching profiles are supported
        if ( pNwkDesc->stackProfile != zgStackProfile  )
            ResultCount--;
            continue;
  //Notify the application about the remaining valid networks to join
  if(pfnFilterNwkDesc)
    pfnFilterNwkDesc(pBDBListNwk, ResultCount);
    您好、Aries、
    感谢您发布问题解决方案。
    Alex F
