Thread 中讨论的其他器件:SysConfig、 CC2652R、 Z-stack
网络上有138个器件的 Zigbee2MQTT 用户收到 NwkTableFull 错误(https://github.com/Koenkk/zigbee2mqtt/issues/13180)。 应增加哪一个表来防止这种情况? 固件使用以下选项进行编译:
#define MT_SYS_KEY_MANAGEMENT 1 #define FEATURE_NVEXID 1 // Increase frame retries #define ZMAC_MAX_FRAME_RETRIES 7 #define NWK_MAX_DATA_RETRIES 4 // Increase MAC buffers #undef MAC_CFG_TX_DATA_MAX #define MAC_CFG_TX_DATA_MAX 20 #undef MAC_CFG_TX_MAX #define MAC_CFG_TX_MAX 32 #undef MAC_CFG_RX_MAX #define MAC_CFG_RX_MAX 20 // Save memory #undef NWK_MAX_BINDING_ENTRIES #define NWK_MAX_BINDING_ENTRIES 1 #undef APS_MAX_GROUPS #define APS_MAX_GROUPS 1 // Increase NV pages to 3 to allow for bigger device tables #undef NVOCMP_NVPAGES #define NVOCMP_NVPAGES 3 // Disabling MULTICAST is required in order for proper group support. // If MULTICAST is not disabled, the group adress is not included in the APS header #define MULTICAST_ENABLED FALSE // Increase the max number of boardcasts, the default broadcast delivery time is 3 seconds // with the value below this will allow for 1 broadcast every 0.15 second #define MAX_BCAST 30 /** * Enable MTO routing */ #define CONCENTRATOR_ENABLE TRUE #define CONCENTRATOR_DISCOVERY_TIME 100 #define CONCENTRATOR_ROUTE_CACHE TRUE #define MAX_RTG_SRC_ENTRIES 255 #define SRC_RTG_EXPIRY_TIME 2 /** * Scale other device tables appropriately */ #define NWK_MAX_DEVICE_LIST 50 #define ZDSECMGR_TC_DEVICE_MAX 200 #define MAX_NEIGHBOR_ENTRIES 20 #define MAX_RTG_ENTRIES 255 /** * Reduce the APS ack wait duration from 6000 ms to 1000 ms (value * 2 = value in ms). * This will make requests timeout quicker, in pratice the default timeout of 6000ms is too long. */ #define APSC_ACK_WAIT_DURATION_POLLED 500 // From www.ti.com/.../swra650b.pdf #define LINK_DOWN_TRIGGER 12 #define NWK_ROUTE_AGE_LIMIT 5 #define DEF_NWK_RADIUS 15 #define DEFAULT_ROUTE_REQUEST_RADIUS 8 #define ZDNWKMGR_MIN_TRANSMISSIONS 0 #define ROUTE_DISCOVERY_TIME 13 #define MTO_RREQ_LIMIT_TIME 5000
