Other Parts Discussed in Thread: UNIFLASH, CCSTUDIO
我已经购买了一个具有 CC2562P 的 SonOff ZigBee 3.0软件狗、该软件狗具有 Silicon Labs UART 转 USB 桥接器。
它以前工作正常、闪存时没有任何问题、但从我上次刷写时(使用正确的固件)开始、它不再进入引导加载模式(我已经多次尝试按住那个该死的引导按钮)
我尝试使用闪存编程器2批量擦除软件狗、但似乎无法擦除它、甚至无法连接到它。
不知道该怎么做。
>Initiate access to target: COM3 using 2-pin cJTAG. >No response from device. Device may not be in bootloader mode. Reset device and try again. If problem persists, check connection and baud rate. >Connecting over serial bootloader failed: No response from device. Device may not be in bootloader mode. Reset device and try again. If problem persists, check connection and baud rate. >Failed to create device object.
