Other Parts Discussed in Thread: SYSCONFIG, CC2651R3
Thread 中讨论的其他器件: SysConfig
在 SDK 5.30中 CC2651R3的 SysConfig 文件中、可将 TX 功率设置为7dBm。 是?μ A
我建议设置一个位于数据表范围内的 TX 功率。
对于 CC2651R3、最高 TX 功率为5dBm (数据表)。
Toby
这是 CC2651R3"ti_radio_config.c"的代码、该代码由 SysConfig 1.10基于 SDK5.30生成
// 2400 MHz, 5 dBm
RF_TxPowerTable_Entry txPowerTable_2400_pa5[TXPOWERTABLE_2400_PA5_SIZE] =
{-20, RF_TxPowerTable_DEFAULT_PA_ENTRY(8, 3, 0, 2) },
{-18, RF_TxPowerTable_DEFAULT_PA_ENTRY(10, 3, 0, 3) },
{-15, RF_TxPowerTable_DEFAULT_PA_ENTRY(13, 3, 0, 3) },
{-12, RF_TxPowerTable_DEFAULT_PA_ENTRY(15, 3, 0, 5) },
{-10, RF_TxPowerTable_DEFAULT_PA_ENTRY(17, 3, 0, 5) },
{-9, RF_TxPowerTable_DEFAULT_PA_ENTRY(19, 3, 0, 6) },
{-6, RF_TxPowerTable_DEFAULT_PA_ENTRY(18, 2, 0, 9) },
{-5, RF_TxPowerTable_DEFAULT_PA_ENTRY(19, 2, 0, 11) },
{-3, RF_TxPowerTable_DEFAULT_PA_ENTRY(23, 2, 0, 11) },
{0, RF_TxPowerTable_DEFAULT_PA_ENTRY(25, 1, 0, 19) },
{1, RF_TxPowerTable_DEFAULT_PA_ENTRY(28, 1, 0, 22) },
{2, RF_TxPowerTable_DEFAULT_PA_ENTRY(31, 1, 0, 25) },
{3, RF_TxPowerTable_DEFAULT_PA_ENTRY(36, 1, 0, 29) },
{4, RF_TxPowerTable_DEFAULT_PA_ENTRY(23, 0, 0, 29) },
{5, RF_TxPowerTable_DEFAULT_PA_ENTRY(31, 0, 0, 56) },
{6, RF_TxPowerTable_DEFAULT_PA_ENTRY(43, 0, 0, 61) },
// The original PA value (6.5 dBm) has been rounded to an integer value.
{7, RF_TxPowerTable_DEFAULT_PA_ENTRY(63, 0, 0, 0) },
RF_TxPowerTable_TERMINATION_ENTRY
这是 CC2651R3"ti_radio_config.c"的代码、该代码由基于 SDK5.20的 SysConfig 1.10生成
// 2400 MHz, 5 dBm
{-20, RF_TxPowerTable_DEFAULT_PA_ENTRY(6, 3, 0, 2) },
{-18, RF_TxPowerTable_DEFAULT_PA_ENTRY(8, 3, 0, 3) },
{-15, RF_TxPowerTable_DEFAULT_PA_ENTRY(10, 3, 0, 3) },
{-12, RF_TxPowerTable_DEFAULT_PA_ENTRY(12, 3, 0, 5) },
{-10, RF_TxPowerTable_DEFAULT_PA_ENTRY(15, 3, 0, 5) },
{-9, RF_TxPowerTable_DEFAULT_PA_ENTRY(16, 3, 0, 5) },
{-6, RF_TxPowerTable_DEFAULT_PA_ENTRY(20, 3, 0, 8) },
{-5, RF_TxPowerTable_DEFAULT_PA_ENTRY(22, 3, 0, 9) },
{-3, RF_TxPowerTable_DEFAULT_PA_ENTRY(19, 2, 0, 12) },
{0, RF_TxPowerTable_DEFAULT_PA_ENTRY(19, 1, 0, 20) },
{1, RF_TxPowerTable_DEFAULT_PA_ENTRY(22, 1, 0, 20) },
{2, RF_TxPowerTable_DEFAULT_PA_ENTRY(25, 1, 0, 25) },
{3, RF_TxPowerTable_DEFAULT_PA_ENTRY(29, 1, 0, 28) },
{4, RF_TxPowerTable_DEFAULT_PA_ENTRY(35, 1, 0, 39) },
{5, RF_TxPowerTable_DEFAULT_PA_ENTRY(23, 0, 0, 57) },
