[参考译文] LP-CC2652R7:CC2652R7中的 LOCK-APP 程序会烧写连接器示例、但无法连接到 Raspberry Pi 边界路由。
Guru**** 3032170 points
Other Parts Discussed in Thread: CC2652R7, UNIFLASH
https://e2e.ti.com/support/wireless-connectivity/zigbee-thread-group/zigbee-and-thread/f/zigbee-thread-forum/1244160/lp-cc2652r7-the-lock-app-program-in-the-cc2652r7-burn-connecthomeip-example-cannot-connect-to-the-raspberry-pi-boundary-route
器件型号:LP-CC2652R7
主题中讨论的其他器件:CC2652R7、 UNIFLASH
以下是客户的请求:
我是否可以问、问题是 CC2652R7中的程序未正确烧录?
在 ubuntu 下编译并生成了 Hex 文件、然后通过 uniflash 将它们刻录到 cc2652r7。
项目为  git clone --递归 se-submodules github.com/.../connectedhomeip
CC2652R7板的串行端口打印如下:
#000001 [ 0.039 ] INFO: (led_service.c:191) Registered service, 5 attributes, status 0x00
#000002 [ 0.040 ] INFO: (button_service.c:230) Registered service, 7 attributes
#000003 [ 0.040 ] INFO: (data_service.c:209) Registered service, 6 attributes
#000004 [ 0.041 ] INFO: (project_zero.c:660) Registered OAD Service
#000005 [ 0.041 ] INFO: (project_zero.c:2888) Left button not held under boot, not reverting to factory.
#000006 [ 0.041 ] INFO: (project_zero.c:2890) Right+Left button not held under boot, not erasing external flash.
#000007 [ 0.041 ] INFO: (project_zero.c:678) OAD Image v0001
#000008 [ 0.041 ] INFO: (led_service.c:207) Registered callbacks to application. Struct @200021e4
#000009 [ 0.041 ] INFO: (button_service.c:248) Registered callbacks to application. Struct @200021ec
#000010 [ 0.041 ] INFO: (data_service.c:227) Registered callbacks to application. Struct @200021f4
#000011 [ 0.041 ] INFO: (led_service.c:242) SetParameter : LED0 len: 1
#000012 [ 0.041 ] INFO: (led_service.c:250) SetParameter : LED1 len: 1
#000013 [ 0.041 ] INFO: (button_service.c:289) SetParameter : BUTTON0 len: 1
#000014 [ 0.041 ] INFO: (button_service.c:322) Trying to send noti/ind: connHandle ffff, Noti/ind disabled
#000015 [ 0.041 ] INFO: (button_service.c:300) SetParameter : BUTTON1 len: 1
#000016 [ 0.041 ] INFO: (button_service.c:322) Trying to send noti/ind: connHandle ffff, Noti/ind disabled
#000017 [ 0.041 ] INFO: (data_service.c:265) SetParameter : String len: 40
#000018 [ 0.041 ] INFO: (data_service.c:276) SetParameter : Stream len: 20
#000019 [ 0.041 ] INFO: (data_service.c:298) Trying to send noti/ind: connHandle ffff, Noti/ind disabled
#000020 [ 0.048 ] INFO: (project_zero.c:1161) GAP is started. Our address: D8:B6:73:6C:14:EC
#000021 [ 0.048 ] INFO: (project_zero.c:1179) Name in advertData array: ProjectZero
#000022 [ 0.053 ] INFO: (project_zero.c:1382) Adv Set 0 Enabled
#000023 [ 4.195 ] INFO: (project_zero.c:2628) Button interrupt: Button 1
#000024 [ 4.245 ] INFO: (project_zero.c:1994) Button 1 pressed
#000025 [ 4.245 ] INFO: (button_service.c:300) SetParameter : BUTTON1 len: 1
#000026 [ 4.245 ] INFO: (button_service.c:322) Trying to send noti/ind: connHandle ffff, Noti/ind disabled
#000027 [ 6.896 ] INFO: (project_zero.c:2628) Button interrupt: Button 1
#000028 [ 6.946 ] INFO: (project_zero.c:1994) Button 1 released
#000029 [ 6.946 ] INFO: (button_service.c:300) SetParameter : BUTTON1 len: 1
#000030 [ 6.946 ] INFO: (button_service.c:322) Trying to send noti/ind: connHandle ffff, Noti/ind disabled
#000031 [ 366.585 ] INFO: (project_zero.c:2628) Button interrupt: Button 1
#000032 [ 366.635 ] INFO: (project_zero.c:1994) Button 1 pressed
#000033 [ 366.635 ] INFO: (button_service.c:300) SetParameter : BUTTON1 len: 1
#000034 [ 366.635 ] INFO: (button_service.c:322) Trying to send noti/ind: connHandle ffff, Noti/ind disabled
#000035 [ 369.183 ] INFO: (project_zero.c:2628) Button interrupt: Button 1
#000036 [ 369.233 ] INFO: (project_zero.c:1994) Button 1 released
#000037 [ 369.233 ] INFO: (button_service.c:300) SetParameter : BUTTON1 len: 1
#000038 [ 369.233 ] INFO: (button_service.c:322) Trying to send noti/ind: connHandle ffff, Noti/ind disabled
Raspberry Pi 构建的边界路由验证 RCP 无法通过:
ubuntu@raspberrypi:~$ sudo ot-ctl state
[sudo] password for ubuntu:
connect session failed: No such file or directory
ubuntu@raspberrypi:~$ sudo systemctl status
● raspberrypi
State: running
Jobs: 0 queued
Failed: 0 units
Since: Mon 2023-03-20 22:35:45 CST; 3 months 13 days ago
CGroup: /
├─user.slice
│ └─user-1000.slice
│ ├─user@1000.service …
│ │ ├─user.slice
│ │ │ └─podman-pause-8178418391264919638.scope
│ │ │ └─2852 /usr/bin/podman
│ │ ├─app.slice
│ │ │ └─dbus.service
│ │ │ └─2973 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
│ │ └─init.scope
│ │ ├─2791 /lib/systemd/systemd --user
│ │ └─2792 (sd-pam)
│ └─session-1.scope
│ ├─2787 sshd: ubuntu [priv]
│ ├─2948 sshd: ubuntu@pts/0
│ ├─2949 -bash
│ ├─3668 sudo systemctl status
│ ├─3669 sudo systemctl status
│ ├─3670 systemctl status
│ └─3671 less
├─init.scope
│ └─1 /sbin/init fixrtc splash
└─system.slice
├─irqbalance.service
│ └─715 /usr/sbin/irqbalance --foreground
├─containerd.service …
│ └─974 /usr/bin/containerd
├─systemd-networkd.service
│ └─698 /lib/systemd/systemd-networkd
├─systemd-udevd.service
│ └─444 /lib/systemd/systemd-udevd
├─cron.service
│ └─943 /usr/sbin/cron -f -P
├─system-serial\x2dgetty.slice
│ └─serial-getty@ttyS0.service
│ └─1010 /sbin/agetty -o -p -- \u --keep-baud 115200,57600,38400,9600 ttyS0 vt220
├─otbr-web.service
│ └─1142 /usr/sbin/otbr-web
├─networkd-dispatcher.service
│ └─717 /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers
├─bluetooth.service
│ └─988 /usr/lib/bluetooth/bluetoothd
├─multipathd.service
│ └─430 /sbin/multipathd -d -s
├─systemd-journald.service
│ └─400 /lib/systemd/systemd-journald
├─unattended-upgrades.service
│ └─969 /usr/bin/python3 /usr/share/unattended-upgrades/unattended-upgrade-shutdown --wait-for-signal
├─ssh.service
边框路由提示:
1 raspberrypi otbr-agent: [NOTE]-AGENT---: Backbone interface: eth0
Jul 3 14:41:21 raspberrypi otbr-agent[2419]: [NOTE]-AGENT---: Running 0.3.0-thread-reference-20230119-238-ga611a780d0
Jul 3 14:41:21 raspberrypi otbr-agent[2419]: [NOTE]-AGENT---: Thread version: 1.3.0
Jul 3 14:41:21 raspberrypi otbr-agent[2419]: [NOTE]-AGENT---: Thread interface: wpan0
Jul 3 14:41:21 raspberrypi otbr-agent[2419]: [NOTE]-AGENT---: Radio URL: spinel+hdlc+uart:///dev/ttyACM0
Jul 3 14:41:21 raspberrypi otbr-agent[2419]: [NOTE]-AGENT---: Radio URL: trel://eth0
Jul 3 14:41:21 raspberrypi otbr-agent[2419]: [NOTE]-ILS-----: Infra link selected: eth0
Jul 3 14:41:21 raspberrypi otbr-agent[2419]: [INFO]-NCP-----: OpenThread log level changed to 4
Jul 3 14:41:23 raspberrypi otbr-agent[2419]: 49d.17:33:38.807 [W] Platform------: Wait for response timeout
Jul 3 14:41:23 raspberrypi otbr-agent[2419]: 49d.17:33:38.808 [I] Platform------: Software reset RCP successfully
Jul 3 14:41:25 raspberrypi otbr-agent[2419]: 49d.17:33:40.810 [W] Platform------: Wait for response timeout
Jul 3 14:41:25 raspberrypi otbr-agent[2419]: 49d.17:33:40.810 [C] Platform------: Failed to communicate with RCP - no response from RCP during initialization
Jul 3 14:41:25 raspberrypi otbr-agent[2419]: 49d.17:33:40.810 [C] Platform------: This is not a bug and typically due a config error (wrong URL parameters) or bad RCP image:
Jul 3 14:41:25 raspberrypi otbr-agent[2419]: 49d.17:33:40.810 [C] Platform------: - Make sure RCP is running the correct firmware
Jul 3 14:41:25 raspberrypi otbr-agent[2419]: 49d.17:33:40.810 [C] Platform------: - Double check the config parameters passed as `RadioURL` input
Jul 3 14:41:25 raspberrypi otbr-agent[2419]: 49d.17:33:40.810 [C] Platform------: HandleRcpTimeout() at radio_spinel_impl.hpp:2051: RadioSpinelNoResponse
Jul 3 14:41:25 raspberrypi systemd[1]: otbr-agent.service: Main process exited, code=exited, status=6/NOTCONFIGURED
Jul 3 14:41:25 raspberrypi systemd[1]: otbr-agent.service: Failed with result 'exit-code'.
Jul 3 14:41:30 raspberrypi systemd[1]: otbr-agent.service: Scheduled restart job, restart counter is at 84.
您能检查一下这个案例吗? 谢谢。
谢谢。此致、
尼克
    您好、Nick。
     CC2652R7串行端口指示加载了 BLE5 project_zero (开箱即用 LaunchPad 上的默认程序)、而不是应加载以与 Thread 边界路由器主机(RPi)配合使用的 Thread RCP。  请让客户遵循 Matter 入门指南并参考 TI Matter Github 存储库。  在重新对 RCP 映像进行编程之前、他们应使用 Uniflash 擦除所有程序存储器。
    瑞安
    您好, Ryan M ü,
    感谢您的快速响应。
    客户 下载了 chip-LP_CC2652R7-lock-example-bim.hex 文件、并可以通过串行端口打印出该信息。 打印的信息如下:
    Initialize Server
    Failed to remove advertised services: 3
    Failed to advertise extended commissionable node: 3
    Failed to finalize service update: 3
    Initialize LEDs
    Initialize buttons
    Lock completed
    Unlock initiated
    Unlock completed
    Lock initiated
    Lock completed
    Unlock initiated
    Unlock completed
    Lock initiated
    Lock completed
    Unlock initiated
    Unlock completed
    Lock initiated
    Lock completed
    ÿInitialize Server
    Initialize LEDs
    Initialize buttons
    Lock completed
    客户 通过 USB 电缆将此板连接到 Raspberry Pi USB 端口是否正确、 如下图所示:
    RCP 和 Matter Device 中的程序是否与下图中的相同?
    如果将 LP_CC2652R7连接到 Raspberry Pi 以用作 RCP、为何要在其上运行 CHIP-LP_CC2652R7-LOCK-EXAMPLE-BIM.hex? 你不应该对它运行 RCP 吗?
    尊敬的 YiPai:
    感谢您的提醒。
    您好、Ryan、
    客户发现 [FAQ] CC2652R7:Matter -- Getting Started Guide 中的 URL 无效。 这是他要烧录的 RCP 文件。
    您能检查一下吗? 谢谢。
    谢谢。此致、
    尼克
    您可以从 simplelink_cc13xx_cc26xx_sdk_7_10_00_98\examples\rtos\LP_CC2652R7\thready\rcp 为 CC2652R7导入和编译 RCP
    在所有点上,YK 都是正确的,你可以发现 RCP 图像是附加的。   e2e.ti.com/.../rcp_5F00_CC26X2R1_5F00_LAUNCHXL_5F00_tirtos_5F00_ticlang.out
    瑞安
    您好、Ryan、
    是否有任何指南可供客户安装  CortexM4的 CLANG 编译器?
    投影 RCP 报告错误、如 下图所示。
    以下是下载页面的链接: https://www.ti.com/tool/download/ARM-CGT-CLANG/2.1.2.LTS
    我本来也希望它是 CCS/SDK 安装程序中的一个选项、您可以从"CCS Preferences"->"Code Composer Studio"->"Build"->"Compilers"中检查发现的工具。  例如、我的安装位置是 C:\ti\ccs1220\ccs\tools\compiler\ti-cgt-armllvm_2.1.2.LTS
    瑞安
    您好、Ryan、
    感谢您的友好帮助。
    谢谢。此致、
    尼克
    您好、Ryan、
    以下是客户的进一步回复:
    现在 RCP 已设置、Matter 设备正常工作、他想使用 chiptool 进行配对、但似乎失败了。
    您能检查一下吗? 谢谢。
    谢谢。此致、
    尼克
    哪些 Linux Matter 主机连接到 ZNP、以及他们要尝试连接哪些 Matter 设备? 他们是否确认 OpenThread 边界路由器可正常运行?  请让客户提供芯片工具终端日志和 CC2652R7 Matter 器件 UART 日志(如果可能)。
    瑞安
    您好,Ryan M ü,
    感谢您的快速响应。
    客户已确认 OpenThread 发声器路由器工作 正常。
    在 bounder 路由器上运行 chip-tool 的终端日志:
    ubuntu@raspberrypi:~/matter/out$ ls
    args.gn  build.ninja  build.ninja.d  build.ninja.stamp  chip-tool  chip-tool-utils.a  chip-tool.map  gen  lib  liblogging-stdio.a  obj  python  relative_path_transformations.json  toolchain.ninja
    ubuntu@raspberrypi:~/matter/out$ ./chip-tool
    [1689126501.963905][6142:6142] CHIP:TOO: Missing cluster name
    Usage:
      ./chip-tool cluster_name command_name [param1 param2 ...]
      | Clusters:        |
      | * accesscontrol        |
      | * accountlogin        |
      | * actions        |
      | * administratorcommissioning                                                        |
      | * any        |
      | * applicationbasic        |
      | * applicationlauncher                                                               |
      | * audiooutput        |
      | * ballastconfiguration                                                              |
      | * barriercontrol        |
      | * basicinformation        |
      | * binaryinputbasic        |
      | * binding        |
      | * booleanstate        |
      | * bridgeddevicebasic        |
      | * channel        |
      | * clientmonitoring        |
      | * colorcontrol        |
      | * contentlauncher        |
      | * descriptor        |
      | * diagnosticlogs        |
      | * discover        |
      | * doorlock        |
      | * electricalmeasurement                                                             |
      | * ethernetnetworkdiagnostics                                                        |
      | * fancontrol        |
      | * faultinjection        |
      | * fixedlabel        |
      | * flowmeasurement        |
      | * generalcommissioning                                                              |
      | * generaldiagnostics        |
      | * groupkeymanagement        |
      | * groupsettings        |
      | * groups        |
      | * identify        |
      | * illuminancemeasurement                                                            |
      | * keypadinput        |
      | * levelcontrol        |
      | * localizationconfiguration                                                         |
      | * lowpower        |
      | * mediainput        |
      | * mediaplayback        |
      | * modeselect        |
      | * networkcommissioning                                                              |
      | * occupancysensing        |
      | * onoff        |
      | * onoffswitchconfiguration                                                          |
      | * operationalcredentials                                                            |
      | * otasoftwareupdateprovider                                                         |
      | * otasoftwareupdaterequestor                                                        |
      | * pairing        |
      | * payload        |
      | * powersource        |
      | * powersourceconfiguration                                                          |
      | * pressuremeasurement                                                               |
      | * proxyconfiguration        |
      | * proxydiscovery        |
      | * proxyvalid        |
      | * pulsewidthmodulation                                                              |
      | * pumpconfigurationandcontrol                                                       |
      | * relativehumiditymeasurement                                                       |
      | * scenes        |
      | * softwarediagnostics                                                               |
      | * subscriptions        |
      | * switch        |
      | * targetnavigator        |
      | * temperaturemeasurement                                                            |
      | * tests        |
      | * thermostat        |
      | * thermostatuserinterfaceconfiguration                                              |
      | * threadnetworkdiagnostics                                                          |
      | * timeformatlocalization                                                            |
      | * timesynchronization                                                               |
      | * unitlocalization        |
      | * unittesting        |
      | * userlabel        |
      | * wakeonlan        |
      | * wifinetworkdiagnostics                                                            |
      | * windowcovering        |
      | * interactive        |
      | * storage        |
    [1689126501.965290][6142:6142] CHIP:TOO: Run command failure: ../examples/chip-tool/commands/common/Commands.cpp:78: Error 0x0000002F
    ubuntu@raspberrypi:~/matter/out$ cd ..
    ubuntu@raspberrypi:~/matter$
    ubuntu@raspberrypi:~/matter$ ls
     BUILD.gn             CONTRIBUTING.md   NOTICE      README_MATTER.md   README_WIFI.md     REVIEWERS.md                                           build             config        docs       gn_build.sh    lgtm.yml   scripts   third_party
     CODE_OF_CONDUCT.md   LICENSE           README.md   README_THREAD.md   RELEASE_NOTES.md  'Texas Instruments Matter GitHub_1.0.x_manifest.html'   build_overrides   credentials   examples   integrations   out        src       zzz_generated
    ubuntu@raspberrypi:~/matter$ cd ..
    ubuntu@raspberrypi:~$ ls
    connectedhomeip  matter  ot-br-posix
    ubuntu@raspberrypi:~$ cd matter/
    ubuntu@raspberrypi:~/matter$ cd out
    ubuntu@raspberrypi:~/matter/out$ cd ~
    ubuntu@raspberrypi:~$ sudo ot-ctl dataset active -x
    000300000f35060004001fffe00208dead00beef00cafe0708fde2f55f8122e830051000112233445566778899aabbccddeeff030f4f70656e5468726561642d37386237010212340410104810e2315100afd6bc9215a6bfac530c0402a0f7f80e080000000000010000
    Done
    ubuntu@raspberrypi:~/matter$ cd out/
    ubuntu@raspberrypi:~/matter/out$ ./chip-tool pairing ble-thread 1 000300000f35060004001fffe00208dead00beef00cafe0708fde2f55f8122e830051000112233445566778899aabbccddeeff030f4f70656e5468726561642d37386237010212340410104810e2315100afd6bc9215a6bfac530c0402a0f7f80e080000000000010000 20202021 3840
    [1689139858.904812][10800:10800] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
    [1689139858.905125][10800:10800] CHIP:DL: writing settings to file (/tmp/chip_kvs-XcUmQc)
    [1689139858.905317][10800:10800] CHIP:DL: renamed tmp file to file (/tmp/chip_kvs)
    [1689139858.956389][10800:10800] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
    [1689139858.956876][10800:10800] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-NS429B)
    [1689139858.957131][10800:10800] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
    [1689139858.957291][10800:10800] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
    [1689139858.957464][10800:10800] CHIP:DL: writing settings to file (/tmp/chip_config.ini-x6zM3m)
    [1689139858.957638][10800:10800] CHIP:DL: renamed tmp file to file (/tmp/chip_config.ini)
    [1689139858.957759][10800:10800] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
    [1689139858.957943][10800:10800] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-GP6GH8)
    [1689139858.958132][10800:10800] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1689139858.958451][10800:10800] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-PMgKOz)
    [1689139858.959067][10800:10800] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
    [1689139858.959134][10800:10800] CHIP:DL: NVS set: chip-factory/unique-id = "4009E09BD06345CA"
    [1689139858.959306][10800:10800] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-9J7xFU)
    [1689139858.959928][10800:10800] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
    [1689139858.959997][10800:10800] CHIP:DL: NVS set: chip-factory/vendor-id = 65521 (0xFFF1)
    [1689139858.960166][10800:10800] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-QJSHLl)
    [1689139858.960761][10800:10800] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
    [1689139858.960829][10800:10800] CHIP:DL: NVS set: chip-factory/product-id = 32769 (0x8001)
    [1689139858.960997][10800:10800] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-OVIjDJ)
    [1689139858.961488][10800:10800] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1689139858.961552][10800:10800] CHIP:DL: NVS set: chip-counters/reboot-count = 1 (0x1)
    [1689139858.961712][10800:10800] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-9Pe51e)
    [1689139858.962484][10800:10800] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1689139858.962550][10800:10800] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1689139858.962782][10800:10800] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-A2M8aw)
    [1689139858.963339][10800:10800] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1689139858.963404][10800:10800] CHIP:DL: NVS set: chip-counters/boot-reason = 0 (0x0)
    [1689139858.963565][10800:10800] CHIP:DL: writing settings to file (/tmp/chip_config.ini-q2oc2F)
    [1689139858.964107][10800:10800] CHIP:DL: renamed tmp file to file (/tmp/chip_config.ini)
    [1689139858.964168][10800:10800] CHIP:DL: NVS set: chip-config/regulatory-location = 0 (0x0)
    [1689139858.964329][10800:10800] CHIP:DL: writing settings to file (/tmp/chip_config.ini-kW4x99)
    [1689139858.964939][10800:10800] CHIP:DL: renamed tmp file to file (/tmp/chip_config.ini)
    [1689139858.965007][10800:10800] CHIP:DL: NVS set: chip-config/location-capability = 2 (0x2)
    [1689139858.965809][10800:10800] CHIP:DL: Got Ethernet interface: eth0
    [1689139858.966389][10800:10800] CHIP:DL: Found the primary Ethernet interface:eth0
    [1689139858.967012][10800:10800] CHIP:DL: Got WiFi interface: wlan0
    [1689139858.967087][10800:10800] CHIP:DL: Failed to reset WiFi statistic counts
    [1689139858.967204][10800:10800] CHIP:IN: UDP::Init bind&listen port=0
    [1689139858.967318][10800:10800] CHIP:IN: UDP::Init bound to port=55610
    [1689139858.967342][10800:10800] CHIP:IN: UDP::Init bind&listen port=0
    [1689139858.967436][10800:10800] CHIP:IN: UDP::Init bound to port=43630
    [1689139858.967459][10800:10800] CHIP:IN: BLEBase::Init - setting/overriding transport
    [1689139858.967478][10800:10800] CHIP:IN: TransportMgr initialized
    [1689139858.967508][10800:10800] CHIP:FP: Initializing FabricTable from persistent storage
    [1689139858.967553][10800:10800] CHIP:TS: Last Known Good Time: [unknown]
    [1689139858.967581][10800:10800] CHIP:TS: Setting Last Known Good Time to firmware build time 2023-07-12T09:42:48
    [1689139858.971126][10800:10800] CHIP:ZCL: Using ZAP configuration...
    [1689139858.973966][10800:10800] CHIP:DL: MDNS failed to join multicast group on wpan0 for address type IPv4: ../examples/chip-tool/third_party/connectedhomeip/src/inet/UDPEndPointImplSockets.cpp:764: Inet Error 0x00000110: Address not found
    [1689139858.974288][10800:10800] CHIP:CTL: System State Initialized...
    [1689139858.974343][10800:10800] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1689139858.974422][10800:10800] CHIP:CTL: Setting attestation nonce to random value
    [1689139858.974475][10800:10800] CHIP:CTL: Setting CSR nonce to random value
    [1689139858.974537][10800:10800] CHIP:IN: UDP::Init bind&listen port=5550
    [1689139858.974629][10800:10800] CHIP:IN: UDP::Init bound to port=5550
    [1689139858.974654][10800:10800] CHIP:IN: UDP::Init bind&listen port=5550
    [1689139858.974741][10800:10800] CHIP:IN: UDP::Init bound to port=5550
    [1689139858.974764][10800:10800] CHIP:IN: TransportMgr initialized
    [1689139858.975047][10800:10802] CHIP:DL: CHIP task running
    [1689139858.975684][10800:10802] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1689139858.975733][10800:10802] CHIP:CTL: Setting attestation nonce to random value
    [1689139858.975913][10800:10802] CHIP:CTL: Setting CSR nonce to random value
    [1689139858.976121][10800:10802] CHIP:CTL: Couldn't get ExampleOpCredsCAKey from storage: ../examples/chip-tool/third_party/connectedhomeip/src/controller/ExamplePersistentStorage.cpp:93: CHIP Error 0x000000A0: Value not found in the persisted storage
    [1689139858.980427][10800:10802] CHIP:CTL: Couldn't get ExampleOpCredsICAKey from storage: ../examples/chip-tool/third_party/connectedhomeip/src/controller/ExamplePersistentStorage.cpp:93: CHIP Error 0x000000A0: Value not found in the persisted storage
    [1689139858.981810][10800:10802] CHIP:CTL: Generating RCAC
    [1689139859.001274][10800:10802] CHIP:CTL: Generating ICAC
    [1689139859.003065][10800:10802] CHIP:CTL: Generating NOC
    [1689139859.004434][10800:10802] CHIP:FP: Validating NOC chain
    [1689139859.009869][10800:10802] CHIP:FP: NOC chain validation successful
    [1689139859.010179][10800:10802] CHIP:FP: Added new fabric at index: 0x1
    [1689139859.010284][10800:10802] CHIP:FP: Assigned compressed fabric ID: 0xB85C55CBB67A0454, node ID: 0x000000000001B669
    [1689139859.010316][10800:10802] CHIP:TS: Last Known Good Time: 2023-07-12T09:42:48
    [1689139859.010339][10800:10802] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
    [1689139859.010360][10800:10802] CHIP:TS: Retaining current Last Known Good Time
    [1689139859.012020][10800:10802] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
    [1689139859.014309][10800:10802] CHIP:TS: Committing Last Known Good Time to storage: 2023-07-12T09:42:48
    [1689139859.020911][10800:10802] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: B85C55CBB67A0454)
    [1689139859.020975][10800:10802] CHIP:IN: UDP::Init bind&listen port=5550
    [1689139859.021119][10800:10802] CHIP:IN: UDP::Init bound to port=5550
    [1689139859.021152][10800:10802] CHIP:IN: UDP::Init bind&listen port=5550
    [1689139859.021280][10800:10802] CHIP:IN: UDP::Init bound to port=5550
    [1689139859.021310][10800:10802] CHIP:IN: TransportMgr initialized
    [1689139859.053533][10800:10802] CHIP:CTL: Setting thread operational dataset from parameters
    [1689139859.053586][10800:10802] CHIP:CTL: Setting attempt thread scan from parameters
    [1689139859.053613][10800:10802] CHIP:CTL: Setting attestation nonce to random value
    [1689139859.053676][10800:10802] CHIP:CTL: Setting CSR nonce to random value
    [1689139859.053717][10800:10802] CHIP:CTL: Setting PASE-only commissioning from parameters
    [1689139859.053745][10800:10802] CHIP:CTL: Commission called for node ID 0x0000000000000001
    [1689139859.059434][10800:10801] CHIP:DL: TRACE: Bus acquired for name C-2a30
    [1689139859.069151][10800:10802] CHIP:DL: PlatformBlueZInit init success
    [1689139859.075467][10800:10801] CHIP:BLE: BLE removing known devices.
    [1689139859.077241][10800:10801] CHIP:BLE: BLE initiating scan.
    [1689139859.085590][10800:10801] CHIP:BLE: Device 03:03:92:77:C5:A7 does not look like a CHIP device.
    [1689139859.111142][10800:10801] CHIP:BLE: Device F2:49:1C:4E:E1:44 does not look like a CHIP device.
    [1689139859.113510][10800:10801] CHIP:BLE: Device 3F:DF:A9:A4:0C:D8 does not look like a CHIP device.
    [1689139859.115651][10800:10801] CHIP:BLE: Device 19:EB:64:8F:CB:B3 does not look like a CHIP device.
    [1689139859.120362][10800:10801] CHIP:BLE: Device 18:E6:CC:61:60:DD does not look like a CHIP device.
    [1689139859.134365][10800:10801] CHIP:BLE: Device 69:7F:AF:12:A3:5A does not look like a CHIP device.
    [1689139859.153198][10800:10801] CHIP:BLE: Device 2C:C1:EB:EF:93:13 does not look like a CHIP device.
    [1689139859.163091][10800:10801] CHIP:BLE: Device 24:A7:D0:E2:35:28 does not look like a CHIP device.
    [1689139859.185214][10800:10801] CHIP:BLE: Device 0D:56:32:DC:D1:73 does not look like a CHIP device.
    [1689139859.205468][10800:10801] CHIP:BLE: Device 53:10:59:59:18:0C does not look like a CHIP device.
    [1689139859.210914][10800:10801] CHIP:BLE: Device 50:EC:82:A0:FF:B2 does not look like a CHIP device.
    [1689139859.238535][10800:10801] CHIP:BLE: New device scanned: 75:19:7E:C1:BD:91
    [1689139859.238614][10800:10801] CHIP:BLE: Device discriminator match. Attempting to connect.
    [1689139859.243421][10800:10801] CHIP:BLE: Scan complete notification without an active scan.
    [1689139859.768354][10800:10801] CHIP:DL: ConnectDevice complete
    [1689139861.012149][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012198][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012225][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012245][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012272][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012292][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012319][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012339][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012362][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012382][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012404][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012423][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012448][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012468][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012490][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012510][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012532][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012552][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012577][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012597][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012644][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012664][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012692][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012712][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012735][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012754][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012776][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012796][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012820][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012840][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012862][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012882][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012904][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012923][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012947][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.012967][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.012989][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.013009][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.013031][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.013050][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.013079][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.013098][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.013120][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.013140][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.013162][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.013182][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.013208][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.013228][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.013250][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.013269][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.013291][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service000d
    [1689139861.013311][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.013336][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.013356][10800:10801] CHIP:DL: Char1 /org/bluez/hci0/dev_75_19_7E_C1_BD_91/service0020
    [1689139861.013383][10800:10801] CHIP:DL: New BLE connection 0xffffb405e080, device 75:19:7E:C1:BD:91, path /org/bluez/hci0/dev_75_19_7E_C1_BD_91
    [1689139861.013527][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16385
    [1689139861.013562][10800:10802] CHIP:DIS: Closing all BLE connections
    [1689139861.013614][10800:10802] CHIP:IN: BleConnectionComplete: endPoint 0xaaaac174c038
    [1689139861.013760][10800:10802] CHIP:IN: SecureSession[0xffffac014f10]: Allocated Type:1 LSID:56629
    [1689139861.013793][10800:10802] CHIP:SC: Assigned local session key ID 56629
    [1689139861.013889][10800:10802] CHIP:EM: <<< [E:60471i M:199606471] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
    [1689139861.013938][10800:10802] CHIP:IN: (U) Sending msg 199606471 to IP address 'BLE'
    [1689139861.013968][10800:10802] CHIP:IN: Message appended to BLE send queue
    [1689139861.013991][10800:10802] CHIP:SC: Sent PBKDF param request
    [1689139861.375578][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139861.473877][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
    [1689139861.473955][10800:10802] CHIP:BLE: subscribe complete, ep = 0xaaaac174c038
    [1689139861.476785][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139861.477079][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139861.477150][10800:10802] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
    [1689139861.477203][10800:10802] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
    [1689139861.477251][10800:10802] CHIP:BLE: local and remote recv window size = 6
    [1689139861.477439][10800:10802] CHIP:IN: BLE EndPoint 0xaaaac174c038 Connection Complete
    [1689139861.570488][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139861.574061][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139861.574341][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139861.574549][10800:10802] CHIP:EM: >>> [E:60471i M:20804041] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
    [1689139861.574624][10800:10802] CHIP:EM: Found matching exchange: 60471i, Delegate: 0xffffac034aa0
    [1689139861.574704][10800:10802] CHIP:SC: Received PBKDF param response
    [1689139861.574789][10800:10802] CHIP:SC: Peer assigned session ID 8216
    [1689139861.586902][10800:10802] CHIP:EM: <<< [E:60471i M:199606472] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
    [1689139861.586967][10800:10802] CHIP:IN: (U) Sending msg 199606472 to IP address 'BLE'
    [1689139861.587074][10800:10802] CHIP:SC: Sent spake2p msg1
    [1689139861.667840][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139866.838965][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139866.839284][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139866.839525][10800:10802] CHIP:EM: >>> [E:60471i M:20804042] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
    [1689139866.839601][10800:10802] CHIP:EM: Found matching exchange: 60471i, Delegate: 0xffffac034aa0
    [1689139866.839689][10800:10802] CHIP:SC: Received spake2p msg2
    [1689139866.843013][10800:10802] CHIP:EM: <<< [E:60471i M:199606473] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
    [1689139866.843120][10800:10802] CHIP:IN: (U) Sending msg 199606473 to IP address 'BLE'
    [1689139866.843293][10800:10802] CHIP:SC: Sent spake2p msg3
    [1689139866.932721][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139866.985069][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139866.985367][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139866.985601][10800:10802] CHIP:EM: >>> [E:60471i M:20804043] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    [1689139866.985676][10800:10802] CHIP:EM: Found matching exchange: 60471i, Delegate: 0xffffac034aa0
    [1689139866.986080][10800:10802] CHIP:SC: SecureSession[0xffffac014f10]: Moving from state 'kEstablishing' --> 'kActive'
    [1689139866.986143][10800:10802] CHIP:IN: SecureSession[0xffffac014f10]: Activated - Type:1 LSID:56629
    [1689139866.986193][10800:10802] CHIP:IN: New secure session activated for device <FFFFFFFB00000000, 0>, LSID:56629 PSID:8216!
    [1689139866.986254][10800:10802] CHIP:CTL: Remote device completed SPAKE2+ handshake
    [1689139866.986304][10800:10802] CHIP:TOO: Pairing Success
    [1689139866.986349][10800:10802] CHIP:TOO: PASE establishment successful
    [1689139866.986400][10800:10802] CHIP:CTL: Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
    [1689139866.986456][10800:10802] CHIP:CTL: Performing next commissioning step 'ReadCommissioningInfo'
    [1689139866.986526][10800:10802] CHIP:CTL: Sending request for commissioning information
    [1689139866.986604][10800:10802] CHIP:DMG: SendReadRequest ReadClient[0xffffac03e000]: Sending Read Request
    [1689139866.986925][10800:10802] CHIP:EM: <<< [E:60472i M:147197894] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    [1689139866.987013][10800:10802] CHIP:IN: (S) Sending msg 147197894 on secure session with LSID: 56629
    [1689139866.987193][10800:10802] CHIP:DMG: MoveToState ReadClient[0xffffac03e000]: Moving to [AwaitingIn]
    [1689139867.079051][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139867.082846][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139867.083129][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139867.179984][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139867.180281][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139867.180579][10800:10802] CHIP:EM: >>> [E:60472i M:256335160] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
    [1689139867.180707][10800:10802] CHIP:EM: Found matching exchange: 60472i, Delegate: 0xffffac03e010
    [1689139867.180935][10800:10802] CHIP:DMG: ReportDataMessage =
    [1689139867.180995][10800:10802] CHIP:DMG: {
    [1689139867.181068][10800:10802] CHIP:DMG: 	AttributeReportIBs =
    [1689139867.181144][10800:10802] CHIP:DMG: 	[
    [1689139867.181201][10800:10802] CHIP:DMG: 		AttributeReportIB =
    [1689139867.181277][10800:10802] CHIP:DMG: 		{
    [1689139867.181361][10800:10802] CHIP:DMG: 			AttributeDataIB =
    [1689139867.181438][10800:10802] CHIP:DMG: 			{
    [1689139867.181534][10800:10802] CHIP:DMG: 				DataVersion = 0x287c0f6,
    [1689139867.181609][10800:10802] CHIP:DMG: 				AttributePathIB =
    [1689139867.181684][10800:10802] CHIP:DMG: 				{
    [1689139867.181782][10800:10802] CHIP:DMG: 					Endpoint = 0x0,
    [1689139867.181864][10800:10802] CHIP:DMG: 					Cluster = 0x31,
    [1689139867.181961][10800:10802] CHIP:DMG: 					Attribute = 0x0000_0003,
    [1689139867.182037][10800:10802] CHIP:DMG: 				}
    [1689139867.182135][10800:10802] CHIP:DMG:
    [1689139867.182215][10800:10802] CHIP:DMG: 				Data = 20,
    [1689139867.182307][10800:10802] CHIP:DMG: 			},
    [1689139867.182381][10800:10802] CHIP:DMG:
    [1689139867.182441][10800:10802] CHIP:DMG: 		},
    [1689139867.182548][10800:10802] CHIP:DMG:
    [1689139867.182605][10800:10802] CHIP:DMG: 		AttributeReportIB =
    [1689139867.182700][10800:10802] CHIP:DMG: 		{
    [1689139867.182762][10800:10802] CHIP:DMG: 			AttributeDataIB =
    [1689139867.182856][10800:10802] CHIP:DMG: 			{
    [1689139867.182932][10800:10802] CHIP:DMG: 				DataVersion = 0xd3bb39b0,
    [1689139867.183024][10800:10802] CHIP:DMG: 				AttributePathIB =
    [1689139867.183100][10800:10802] CHIP:DMG: 				{
    [1689139867.183171][10800:10802] CHIP:DMG: 					Endpoint = 0x0,
    [1689139867.183271][10800:10802] CHIP:DMG: 					Cluster = 0x28,
    [1689139867.183350][10800:10802] CHIP:DMG: 					Attribute = 0x0000_0004,
    [1689139867.183452][10800:10802] CHIP:DMG: 				}
    [1689139867.183530][10800:10802] CHIP:DMG:
    [1689139867.183629][10800:10802] CHIP:DMG: 				Data = 32774,
    [1689139867.183701][10800:10802] CHIP:DMG: 			},
    [1689139867.183795][10800:10802] CHIP:DMG:
    [1689139867.183856][10800:10802] CHIP:DMG: 		},
    [1689139867.183941][10800:10802] CHIP:DMG:
    [1689139867.184016][10800:10802] CHIP:DMG: 		AttributeReportIB =
    [1689139867.184092][10800:10802] CHIP:DMG: 		{
    [1689139867.184172][10800:10802] CHIP:DMG: 			AttributeDataIB =
    [1689139867.184242][10800:10802] CHIP:DMG: 			{
    [1689139867.184290][10800:10802] CHIP:DMG: 				DataVersion = 0xd3bb39b0,
    [1689139867.184365][10800:10802] CHIP:DMG: 				AttributePathIB =
    [1689139867.184417][10800:10802] CHIP:DMG: 				{
    [1689139867.184482][10800:10802] CHIP:DMG: 					Endpoint = 0x0,
    [1689139867.184535][10800:10802] CHIP:DMG: 					Cluster = 0x28,
    [1689139867.184620][10800:10802] CHIP:DMG: 					Attribute = 0x0000_0002,
    [1689139867.184674][10800:10802] CHIP:DMG: 				}
    [1689139867.184740][10800:10802] CHIP:DMG:
    [1689139867.184793][10800:10802] CHIP:DMG: 				Data = 65521,
    [1689139867.184854][10800:10802] CHIP:DMG: 			},
    [1689139867.184905][10800:10802] CHIP:DMG:
    [1689139867.184945][10800:10802] CHIP:DMG: 		},
    [1689139867.185014][10800:10802] CHIP:DMG:
    [1689139867.185053][10800:10802] CHIP:DMG: 		AttributeReportIB =
    [1689139867.185118][10800:10802] CHIP:DMG: 		{
    [1689139867.185159][10800:10802] CHIP:DMG: 			AttributeDataIB =
    [1689139867.185203][10800:10802] CHIP:DMG: 			{
    [1689139867.185263][10800:10802] CHIP:DMG: 				DataVersion = 0xf328d5ef,
    [1689139867.185308][10800:10802] CHIP:DMG: 				AttributePathIB =
    [1689139867.185369][10800:10802] CHIP:DMG: 				{
    [1689139867.185419][10800:10802] CHIP:DMG: 					Endpoint = 0x0,
    [1689139867.185486][10800:10802] CHIP:DMG: 					Cluster = 0x30,
    [1689139867.185540][10800:10802] CHIP:DMG: 					Attribute = 0x0000_0003,
    [1689139867.185605][10800:10802] CHIP:DMG: 				}
    [1689139867.185657][10800:10802] CHIP:DMG:
    [1689139867.185709][10800:10802] CHIP:DMG: 				Data = 0,
    [1689139867.185768][10800:10802] CHIP:DMG: 			},
    [1689139867.185818][10800:10802] CHIP:DMG:
    [1689139867.185877][10800:10802] CHIP:DMG: 		},
    [1689139867.185934][10800:10802] CHIP:DMG:
    [1689139867.185987][10800:10802] CHIP:DMG: 		AttributeReportIB =
    [1689139867.186037][10800:10802] CHIP:DMG: 		{
    [1689139867.186080][10800:10802] CHIP:DMG: 			AttributeDataIB =
    [1689139867.186140][10800:10802] CHIP:DMG: 			{
    [1689139867.186186][10800:10802] CHIP:DMG: 				DataVersion = 0xf328d5ef,
    [1689139867.186247][10800:10802] CHIP:DMG: 				AttributePathIB =
    [1689139867.186297][10800:10802] CHIP:DMG: 				{
    [1689139867.186361][10800:10802] CHIP:DMG: 					Endpoint = 0x0,
    [1689139867.186415][10800:10802] CHIP:DMG: 					Cluster = 0x30,
    [1689139867.186482][10800:10802] CHIP:DMG: 					Attribute = 0x0000_0002,
    [1689139867.186530][10800:10802] CHIP:DMG: 				}
    [1689139867.186584][10800:10802] CHIP:DMG:
    [1689139867.186650][10800:10802] CHIP:DMG: 				Data = 0,
    [1689139867.186696][10800:10802] CHIP:DMG: 			},
    [1689139867.186758][10800:10802] CHIP:DMG:
    [1689139867.186799][10800:10802] CHIP:DMG: 		},
    [1689139867.186871][10800:10802] CHIP:DMG:
    [1689139867.186910][10800:10802] CHIP:DMG: 		AttributeReportIB =
    [1689139867.186961][10800:10802] CHIP:DMG: 		{
    [1689139867.187016][10800:10802] CHIP:DMG: 			AttributeDataIB =
    [1689139867.187062][10800:10802] CHIP:DMG: 			{
    [1689139867.187123][10800:10802] CHIP:DMG: 				DataVersion = 0xf328d5ef,
    [1689139867.187171][10800:10802] CHIP:DMG: 				AttributePathIB =
    [1689139867.187234][10800:10802] CHIP:DMG: 				{
    [1689139867.187285][10800:10802] CHIP:DMG: 					Endpoint = 0x0,
    [1689139867.187337][10800:10802] CHIP:DMG: 					Cluster = 0x30,
    [1689139867.187404][10800:10802] CHIP:DMG: 					Attribute = 0x0000_0001,
    [1689139867.187454][10800:10802] CHIP:DMG: 				}
    [1689139867.187518][10800:10802] CHIP:DMG:
    [1689139867.187567][10800:10802] CHIP:DMG: 				Data =
    [1689139867.187628][10800:10802] CHIP:DMG: 				{
    [1689139867.187718][10800:10802] CHIP:DMG: 					0x0 = 60,
    [1689139867.187787][10800:10802] CHIP:DMG: 					0x1 = 900,
    [1689139867.187840][10800:10802] CHIP:DMG: 				},
    [1689139867.187900][10800:10802] CHIP:DMG: 			},
    [1689139867.187952][10800:10802] CHIP:DMG:
    [1689139867.188005][10800:10802] CHIP:DMG: 		},
    [1689139867.188062][10800:10802] CHIP:DMG:
    [1689139867.188117][10800:10802] CHIP:DMG: 		AttributeReportIB =
    [1689139867.188168][10800:10802] CHIP:DMG: 		{
    [1689139867.188208][10800:10802] CHIP:DMG: 			AttributeDataIB =
    [1689139867.188268][10800:10802] CHIP:DMG: 			{
    [1689139867.188314][10800:10802] CHIP:DMG: 				DataVersion = 0xf328d5ef,
    [1689139867.188374][10800:10802] CHIP:DMG: 				AttributePathIB =
    [1689139867.188424][10800:10802] CHIP:DMG: 				{
    [1689139867.188487][10800:10802] CHIP:DMG: 					Endpoint = 0x0,
    [1689139867.188541][10800:10802] CHIP:DMG: 					Cluster = 0x30,
    [1689139867.188667][10800:10802] CHIP:DMG: 					Attribute = 0x0000_0000,
    [1689139867.188723][10800:10802] CHIP:DMG: 				}
    [1689139867.188795][10800:10802] CHIP:DMG:
    [1689139867.188847][10800:10802] CHIP:DMG: 				Data = 0,
    [1689139867.188905][10800:10802] CHIP:DMG: 			},
    [1689139867.188954][10800:10802] CHIP:DMG:
    [1689139867.189008][10800:10802] CHIP:DMG: 		},
    [1689139867.189065][10800:10802] CHIP:DMG:
    [1689139867.189106][10800:10802] CHIP:DMG: 		AttributeReportIB =
    [1689139867.189171][10800:10802] CHIP:DMG: 		{
    [1689139867.189211][10800:10802] CHIP:DMG: 			AttributeDataIB =
    [1689139867.189275][10800:10802] CHIP:DMG: 			{
    [1689139867.189323][10800:10802] CHIP:DMG: 				DataVersion = 0x287c0f6,
    [1689139867.189385][10800:10802] CHIP:DMG: 				AttributePathIB =
    [1689139867.189436][10800:10802] CHIP:DMG: 				{
    [1689139867.189499][10800:10802] CHIP:DMG: 					Endpoint = 0x0,
    [1689139867.189553][10800:10802] CHIP:DMG: 					Cluster = 0x31,
    [1689139867.189606][10800:10802] CHIP:DMG: 					Attribute = 0x0000_FFFC,
    [1689139867.189671][10800:10802] CHIP:DMG: 				}
    [1689139867.189720][10800:10802] CHIP:DMG:
    [1689139867.189785][10800:10802] CHIP:DMG: 				Data = 2,
    [1689139867.189837][10800:10802] CHIP:DMG: 			},
    [1689139867.189900][10800:10802] CHIP:DMG:
    [1689139867.189941][10800:10802] CHIP:DMG: 		},
    [1689139867.189988][10800:10802] CHIP:DMG:
    [1689139867.190039][10800:10802] CHIP:DMG: 	],
    [1689139867.190145][10800:10802] CHIP:DMG:
    [1689139867.190185][10800:10802] CHIP:DMG: 	SuppressResponse = true,
    [1689139867.190240][10800:10802] CHIP:DMG: 	InteractionModelRevision = 1
    [1689139867.190278][10800:10802] CHIP:DMG: }
    [1689139867.191465][10800:10802] CHIP:CTL: ----- NetworkCommissioning Features: has Thread. endpointid = 0
    [1689139867.191558][10800:10802] CHIP:CTL: Successfully finished commissioning step 'ReadCommissioningInfo'
    [1689139867.191605][10800:10802] CHIP:CTL: Commissioning stage next step: 'ReadCommissioningInfo' -> 'ArmFailSafe'
    [1689139867.191648][10800:10802] CHIP:CTL: Performing next commissioning step 'ArmFailSafe'
    [1689139867.191682][10800:10802] CHIP:CTL: Arming failsafe (60 seconds)
    [1689139867.191781][10800:10802] CHIP:DMG: ICR moving to [AddingComm]
    [1689139867.191826][10800:10802] CHIP:DMG: ICR moving to [AddedComma]
    [1689139867.192003][10800:10802] CHIP:EM: <<< [E:60473i M:147197895] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1689139867.192062][10800:10802] CHIP:IN: (S) Sending msg 147197895 on secure session with LSID: 56629
    [1689139867.192207][10800:10802] CHIP:DMG: ICR moving to [CommandSen]
    [1689139867.276786][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139867.280516][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139867.280796][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139867.281077][10800:10802] CHIP:EM: >>> [E:60473i M:256335161] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1689139867.281145][10800:10802] CHIP:EM: Found matching exchange: 60473i, Delegate: 0xffffb4060ec8
    [1689139867.281240][10800:10802] CHIP:DMG: ICR moving to [ResponseRe]
    [1689139867.281328][10800:10802] CHIP:DMG: InvokeResponseMessage =
    [1689139867.281374][10800:10802] CHIP:DMG: {
    [1689139867.281420][10800:10802] CHIP:DMG: 	suppressResponse = false,
    [1689139867.281469][10800:10802] CHIP:DMG: 	InvokeResponseIBs =
    [1689139867.281552][10800:10802] CHIP:DMG: 	[
    [1689139867.281602][10800:10802] CHIP:DMG: 		InvokeResponseIB =
    [1689139867.281668][10800:10802] CHIP:DMG: 		{
    [1689139867.281738][10800:10802] CHIP:DMG: 			CommandDataIB =
    [1689139867.281804][10800:10802] CHIP:DMG: 			{
    [1689139867.281878][10800:10802] CHIP:DMG: 				CommandPathIB =
    [1689139867.281943][10800:10802] CHIP:DMG: 				{
    [1689139867.282026][10800:10802] CHIP:DMG: 					EndpointId = 0x0,
    [1689139867.282095][10800:10802] CHIP:DMG: 					ClusterId = 0x30,
    [1689139867.282184][10800:10802] CHIP:DMG: 					CommandId = 0x1,
    [1689139867.282249][10800:10802] CHIP:DMG: 				},
    [1689139867.282316][10800:10802] CHIP:DMG:
    [1689139867.282393][10800:10802] CHIP:DMG: 				CommandFields =
    [1689139867.282456][10800:10802] CHIP:DMG: 				{
    [1689139867.282540][10800:10802] CHIP:DMG: 					0x0 = 0,
    [1689139867.282616][10800:10802] CHIP:DMG: 					0x1 = "" (0 chars),
    [1689139867.282707][10800:10802] CHIP:DMG: 				},
    [1689139867.282767][10800:10802] CHIP:DMG: 			},
    [1689139867.282850][10800:10802] CHIP:DMG:
    [1689139867.282902][10800:10802] CHIP:DMG: 		},
    [1689139867.282981][10800:10802] CHIP:DMG:
    [1689139867.283030][10800:10802] CHIP:DMG: 	],
    [1689139867.283091][10800:10802] CHIP:DMG:
    [1689139867.283157][10800:10802] CHIP:DMG: 	InteractionModelRevision = 1
    [1689139867.283205][10800:10802] CHIP:DMG: },
    [1689139867.283342][10800:10802] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1689139867.283409][10800:10802] CHIP:CTL: Received ArmFailSafe response errorCode=0
    [1689139867.283482][10800:10802] CHIP:CTL: Successfully finished commissioning step 'ArmFailSafe'
    [1689139867.283526][10800:10802] CHIP:CTL: Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
    [1689139867.283578][10800:10802] CHIP:CTL: Performing next commissioning step 'ConfigRegulatory'
    [1689139867.283640][10800:10802] CHIP:CTL: Setting Regulatory Config
    [1689139867.283679][10800:10802] CHIP:CTL: Device does not support configurable regulatory location
    [1689139867.283798][10800:10802] CHIP:DMG: ICR moving to [AddingComm]
    [1689139867.283857][10800:10802] CHIP:DMG: ICR moving to [AddedComma]
    [1689139867.284032][10800:10802] CHIP:EM: <<< [E:60474i M:147197896] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1689139867.284130][10800:10802] CHIP:IN: (S) Sending msg 147197896 on secure session with LSID: 56629
    [1689139867.284298][10800:10802] CHIP:DMG: ICR moving to [CommandSen]
    [1689139867.284418][10800:10802] CHIP:DMG: ICR moving to [AwaitingDe]
    [1689139867.374134][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139867.377947][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139867.378237][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139867.378548][10800:10802] CHIP:EM: >>> [E:60474i M:256335162] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1689139867.378627][10800:10802] CHIP:EM: Found matching exchange: 60474i, Delegate: 0xffffb4061248
    [1689139867.378708][10800:10802] CHIP:DMG: ICR moving to [ResponseRe]
    [1689139867.378803][10800:10802] CHIP:DMG: InvokeResponseMessage =
    [1689139867.378886][10800:10802] CHIP:DMG: {
    [1689139867.378940][10800:10802] CHIP:DMG: 	suppressResponse = false,
    [1689139867.378997][10800:10802] CHIP:DMG: 	InvokeResponseIBs =
    [1689139867.379091][10800:10802] CHIP:DMG: 	[
    [1689139867.379148][10800:10802] CHIP:DMG: 		InvokeResponseIB =
    [1689139867.379245][10800:10802] CHIP:DMG: 		{
    [1689139867.379307][10800:10802] CHIP:DMG: 			CommandDataIB =
    [1689139867.379378][10800:10802] CHIP:DMG: 			{
    [1689139867.379462][10800:10802] CHIP:DMG: 				CommandPathIB =
    [1689139867.379535][10800:10802] CHIP:DMG: 				{
    [1689139867.379635][10800:10802] CHIP:DMG: 					EndpointId = 0x0,
    [1689139867.379716][10800:10802] CHIP:DMG: 					ClusterId = 0x30,
    [1689139867.379815][10800:10802] CHIP:DMG: 					CommandId = 0x3,
    [1689139867.379892][10800:10802] CHIP:DMG: 				},
    [1689139867.379969][10800:10802] CHIP:DMG:
    [1689139867.380056][10800:10802] CHIP:DMG: 				CommandFields =
    [1689139867.380130][10800:10802] CHIP:DMG: 				{
    [1689139867.380231][10800:10802] CHIP:DMG: 					0x0 = 0,
    [1689139867.380315][10800:10802] CHIP:DMG: 					0x1 = "" (0 chars),
    [1689139867.380421][10800:10802] CHIP:DMG: 				},
    [1689139867.380494][10800:10802] CHIP:DMG: 			},
    [1689139867.380598][10800:10802] CHIP:DMG:
    [1689139867.380709][10800:10802] CHIP:DMG: 		},
    [1689139867.380802][10800:10802] CHIP:DMG:
    [1689139867.380859][10800:10802] CHIP:DMG: 	],
    [1689139867.380931][10800:10802] CHIP:DMG:
    [1689139867.381008][10800:10802] CHIP:DMG: 	InteractionModelRevision = 1
    [1689139867.381063][10800:10802] CHIP:DMG: },
    [1689139867.381219][10800:10802] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
    [1689139867.381298][10800:10802] CHIP:CTL: Received SetRegulatoryConfig response errorCode=0
    [1689139867.381382][10800:10802] CHIP:CTL: Successfully finished commissioning step 'ConfigRegulatory'
    [1689139867.381434][10800:10802] CHIP:CTL: Commissioning stage next step: 'ConfigRegulatory' -> 'SendPAICertificateRequest'
    [1689139867.381493][10800:10802] CHIP:CTL: Performing next commissioning step 'SendPAICertificateRequest'
    [1689139867.381562][10800:10802] CHIP:CTL: Sending request for PAI certificate
    [1689139867.381608][10800:10802] CHIP:CTL: Sending Certificate Chain request to 0xffffac034a50 device
    [1689139867.381719][10800:10802] CHIP:DMG: ICR moving to [AddingComm]
    [1689139867.381894][10800:10802] CHIP:DMG: ICR moving to [AddedComma]
    [1689139867.382096][10800:10802] CHIP:EM: <<< [E:60475i M:147197897] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1689139867.382214][10800:10802] CHIP:IN: (S) Sending msg 147197897 on secure session with LSID: 56629
    [1689139867.382413][10800:10802] CHIP:DMG: ICR moving to [CommandSen]
    [1689139867.382555][10800:10802] CHIP:DMG: ICR moving to [AwaitingDe]
    [1689139867.471686][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139867.475382][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139867.475661][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139867.572535][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139867.572881][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139867.669962][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139867.670251][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139867.670576][10800:10802] CHIP:EM: >>> [E:60475i M:256335163] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1689139867.670654][10800:10802] CHIP:EM: Found matching exchange: 60475i, Delegate: 0xffffb4060ec8
    [1689139867.670764][10800:10802] CHIP:DMG: ICR moving to [ResponseRe]
    [1689139867.670863][10800:10802] CHIP:DMG: InvokeResponseMessage =
    [1689139867.670917][10800:10802] CHIP:DMG: {
    [1689139867.670971][10800:10802] CHIP:DMG: 	suppressResponse = false,
    [1689139867.671028][10800:10802] CHIP:DMG: 	InvokeResponseIBs =
    [1689139867.671125][10800:10802] CHIP:DMG: 	[
    [1689139867.671183][10800:10802] CHIP:DMG: 		InvokeResponseIB =
    [1689139867.671283][10800:10802] CHIP:DMG: 		{
    [1689139867.671345][10800:10802] CHIP:DMG: 			CommandDataIB =
    [1689139867.671437][10800:10802] CHIP:DMG: 			{
    [1689139867.671506][10800:10802] CHIP:DMG: 				CommandPathIB =
    [1689139867.671580][10800:10802] CHIP:DMG: 				{
    [1689139867.671680][10800:10802] CHIP:DMG: 					EndpointId = 0x0,
    [1689139867.671760][10800:10802] CHIP:DMG: 					ClusterId = 0x3e,
    [1689139867.671854][10800:10802] CHIP:DMG: 					CommandId = 0x3,
    [1689139867.671926][10800:10802] CHIP:DMG: 				},
    [1689139867.672003][10800:10802] CHIP:DMG:
    [1689139867.672091][10800:10802] CHIP:DMG: 				CommandFields =
    [1689139867.672166][10800:10802] CHIP:DMG: 				{
    [1689139867.672262][10800:10802] CHIP:DMG: 					0x0 = [
    [1689139867.672678][10800:10802] CHIP:DMG: 							0x30, 0x82, 0x01, 0xdc, 0x30, 0x82, 0x01, 0x81, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x7f, 0x7e, 0xf3, 0xdb, 0x08, 0xa3, 0x8f, 0x68, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x30, 0x31, 0x18, 0x30, 0x16, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x0f, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x54, 0x65, 0x73, 0x74, 0x20, 0x50, 0x41, 0x41, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x31, 0x30, 0x36, 0x32, 0x38, 0x31, 0x34, 0x32, 0x33, 0x34, 0x33, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x4d, 0x31, 0x1f, 0x30, 0x1d, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x16, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x65, 0x6c, 0x6f, 0x70, 0x6d, 0x65, 0x6e, 0x74, 0x20, 0x50, 0x41, 0x49, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x38, 0x30, 0x30, 0x36, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x42, 0x93, 0x55, 0x77, 0x35, 0x35, 0x15, 0xce, 0xfa, 0x8f, 0x0e, 0x30, 0xe2, 0x34, 0x7e, 0x90, 0xee, 0xd6, 0xfd, 0x51, 0x5b, 0xe8, 0x82, 0xd1, 0xbc, 0xba, 0x74, 0x83, 0xd7, 0xff, 0x6e, 0xf4, 0xde, 0xdf, 0x98, 0xf7, 0xf7, 0x4f, 0x17, 0x42, 0x1d, 0xe5, 0x45, 0x0c, 0xff, 0xfb, 0x3e, 0x7f, 0x6d, 0x4f, 0x62, 0x28, 0x53, 0x41, 0x14, 0xfb, 0xb8, 0x5c, 0x
    [1689139867.672856][10800:10802] CHIP:DMG: 					] (480 bytes)
    [1689139867.672937][10800:10802] CHIP:DMG: 				},
    [1689139867.673008][10800:10802] CHIP:DMG: 			},
    [1689139867.673086][10800:10802] CHIP:DMG:
    [1689139867.673146][10800:10802] CHIP:DMG: 		},
    [1689139867.673217][10800:10802] CHIP:DMG:
    [1689139867.673301][10800:10802] CHIP:DMG: 	],
    [1689139867.673375][10800:10802] CHIP:DMG:
    [1689139867.673431][10800:10802] CHIP:DMG: 	InteractionModelRevision = 1
    [1689139867.673508][10800:10802] CHIP:DMG: },
    [1689139867.673669][10800:10802] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
    [1689139867.673744][10800:10802] CHIP:CTL: Received certificate chain from the device
    [1689139867.673807][10800:10802] CHIP:CTL: Successfully finished commissioning step 'SendPAICertificateRequest'
    [1689139867.673867][10800:10802] CHIP:CTL: Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
    [1689139867.673950][10800:10802] CHIP:CTL: Performing next commissioning step 'SendDACCertificateRequest'
    [1689139867.674001][10800:10802] CHIP:CTL: Sending request for DAC certificate
    [1689139867.674047][10800:10802] CHIP:CTL: Sending Certificate Chain request to 0xffffac034a50 device
    [1689139867.674183][10800:10802] CHIP:DMG: ICR moving to [AddingComm]
    [1689139867.674249][10800:10802] CHIP:DMG: ICR moving to [AddedComma]
    [1689139867.674459][10800:10802] CHIP:EM: <<< [E:60476i M:147197898] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1689139867.674569][10800:10802] CHIP:IN: (S) Sending msg 147197898 on secure session with LSID: 56629
    [1689139867.674770][10800:10802] CHIP:DMG: ICR moving to [CommandSen]
    [1689139867.674912][10800:10802] CHIP:DMG: ICR moving to [AwaitingDe]
    [1689139867.763751][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139867.767889][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139867.768167][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139867.865038][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139867.865326][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139867.962507][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139867.962807][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139867.963145][10800:10802] CHIP:EM: >>> [E:60476i M:256335164] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1689139867.963222][10800:10802] CHIP:EM: Found matching exchange: 60476i, Delegate: 0xffffb4061248
    [1689139867.963332][10800:10802] CHIP:DMG: ICR moving to [ResponseRe]
    [1689139867.963434][10800:10802] CHIP:DMG: InvokeResponseMessage =
    [1689139867.963490][10800:10802] CHIP:DMG: {
    [1689139867.963545][10800:10802] CHIP:DMG: 	suppressResponse = false,
    [1689139867.963602][10800:10802] CHIP:DMG: 	InvokeResponseIBs =
    [1689139867.963701][10800:10802] CHIP:DMG: 	[
    [1689139867.963761][10800:10802] CHIP:DMG: 		InvokeResponseIB =
    [1689139867.963860][10800:10802] CHIP:DMG: 		{
    [1689139867.963923][10800:10802] CHIP:DMG: 			CommandDataIB =
    [1689139867.963994][10800:10802] CHIP:DMG: 			{
    [1689139867.964080][10800:10802] CHIP:DMG: 				CommandPathIB =
    [1689139867.964156][10800:10802] CHIP:DMG: 				{
    [1689139867.964252][10800:10802] CHIP:DMG: 					EndpointId = 0x0,
    [1689139867.964333][10800:10802] CHIP:DMG: 					ClusterId = 0x3e,
    [1689139867.964432][10800:10802] CHIP:DMG: 					CommandId = 0x3,
    [1689139867.964508][10800:10802] CHIP:DMG: 				},
    [1689139867.964711][10800:10802] CHIP:DMG:
    [1689139867.964785][10800:10802] CHIP:DMG: 				CommandFields =
    [1689139867.964881][10800:10802] CHIP:DMG: 				{
    [1689139867.964959][10800:10802] CHIP:DMG: 					0x0 = [
    [1689139867.965357][10800:10802] CHIP:DMG: 							0x30, 0x82, 0x01, 0xf7, 0x30, 0x82, 0x01, 0x9d, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x46, 0x88, 0xeb, 0x94, 0xad, 0x32, 0xb2, 0xe4, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x4d, 0x31, 0x1f, 0x30, 0x1d, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x16, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x65, 0x6c, 0x6f, 0x70, 0x6d, 0x65, 0x6e, 0x74, 0x20, 0x50, 0x41, 0x49, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x38, 0x30, 0x30, 0x36, 0x30, 0x20, 0x17, 0x0d, 0x32, 0x31, 0x30, 0x36, 0x32, 0x38, 0x31, 0x34, 0x32, 0x33, 0x34, 0x33, 0x5a, 0x18, 0x0f, 0x39, 0x39, 0x39, 0x39, 0x31, 0x32, 0x33, 0x31, 0x32, 0x33, 0x35, 0x39, 0x35, 0x39, 0x5a, 0x30, 0x52, 0x31, 0x24, 0x30, 0x22, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x1b, 0x4d, 0x61, 0x74, 0x74, 0x65, 0x72, 0x20, 0x44, 0x65, 0x76, 0x65, 0x6c, 0x6f, 0x70, 0x6d, 0x65, 0x6e, 0x74, 0x20, 0x44, 0x41, 0x43, 0x20, 0x30, 0x30, 0x30, 0x30, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x46, 0x46, 0x46, 0x31, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x38, 0x30, 0x30, 0x36, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0xc5, 0x65, 0xfd, 0xad, 0xfd, 0x16, 0xdd, 0x62, 0xe4, 0x3f, 0x19, 0x60, 0xb9, 0x93, 0xbb, 0x57, 0x2c, 0xfd, 0xd8, 0x1f, 0x6d, 0x71, 0x67, 0x67, 0x
    [1689139867.965534][10800:10802] CHIP:DMG: 					] (507 bytes)
    [1689139867.965613][10800:10802] CHIP:DMG: 				},
    [1689139867.965683][10800:10802] CHIP:DMG: 			},
    [1689139867.965762][10800:10802] CHIP:DMG:
    [1689139867.965842][10800:10802] CHIP:DMG: 		},
    [1689139867.965916][10800:10802] CHIP:DMG:
    [1689139867.965972][10800:10802] CHIP:DMG: 	],
    [1689139867.966044][10800:10802] CHIP:DMG:
    [1689139867.966128][10800:10802] CHIP:DMG: 	InteractionModelRevision = 1
    [1689139867.966183][10800:10802] CHIP:DMG: },
    [1689139867.966340][10800:10802] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
    [1689139867.966415][10800:10802] CHIP:CTL: Received certificate chain from the device
    [1689139867.966498][10800:10802] CHIP:CTL: Successfully finished commissioning step 'SendDACCertificateRequest'
    [1689139867.966559][10800:10802] CHIP:CTL: Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
    [1689139867.966622][10800:10802] CHIP:CTL: Performing next commissioning step 'SendAttestationRequest'
    [1689139867.966693][10800:10802] CHIP:CTL: Sending Attestation Request to the device.
    [1689139867.966741][10800:10802] CHIP:CTL: Sending Attestation request to 0xffffac034a50 device
    [1689139867.966879][10800:10802] CHIP:DMG: ICR moving to [AddingComm]
    [1689139867.966948][10800:10802] CHIP:DMG: ICR moving to [AddedComma]
    [1689139867.967163][10800:10802] CHIP:EM: <<< [E:60477i M:147197899] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1689139867.967279][10800:10802] CHIP:IN: (S) Sending msg 147197899 on secure session with LSID: 56629
    [1689139867.967480][10800:10802] CHIP:DMG: ICR moving to [CommandSen]
    [1689139867.967551][10800:10802] CHIP:CTL: Sent Attestation request, waiting for the Attestation Information
    [1689139867.967669][10800:10802] CHIP:DMG: ICR moving to [AwaitingDe]
    [1689139868.056690][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139868.206321][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139868.206619][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139868.303822][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139868.304110][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139868.401367][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139868.401653][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139868.402008][10800:10802] CHIP:EM: >>> [E:60477i M:256335165] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1689139868.402086][10800:10802] CHIP:EM: Found matching exchange: 60477i, Delegate: 0xffffb4060ec8
    [1689139868.402203][10800:10802] CHIP:DMG: ICR moving to [ResponseRe]
    [1689139868.402305][10800:10802] CHIP:DMG: InvokeResponseMessage =
    [1689139868.402359][10800:10802] CHIP:DMG: {
    [1689139868.402413][10800:10802] CHIP:DMG: 	suppressResponse = false,
    [1689139868.402495][10800:10802] CHIP:DMG: 	InvokeResponseIBs =
    [1689139868.402572][10800:10802] CHIP:DMG: 	[
    [1689139868.402629][10800:10802] CHIP:DMG: 		InvokeResponseIB =
    [1689139868.402730][10800:10802] CHIP:DMG: 		{
    [1689139868.402791][10800:10802] CHIP:DMG: 			CommandDataIB =
    [1689139868.402881][10800:10802] CHIP:DMG: 			{
    [1689139868.402949][10800:10802] CHIP:DMG: 				CommandPathIB =
    [1689139868.403043][10800:10802] CHIP:DMG: 				{
    [1689139868.403122][10800:10802] CHIP:DMG: 					EndpointId = 0x0,
    [1689139868.403202][10800:10802] CHIP:DMG: 					ClusterId = 0x3e,
    [1689139868.403303][10800:10802] CHIP:DMG: 					CommandId = 0x1,
    [1689139868.403376][10800:10802] CHIP:DMG: 				},
    [1689139868.403475][10800:10802] CHIP:DMG:
    [1689139868.403544][10800:10802] CHIP:DMG: 				CommandFields =
    [1689139868.403637][10800:10802] CHIP:DMG: 				{
    [1689139868.403714][10800:10802] CHIP:DMG: 					0x0 = [
    [1689139868.404103][10800:10802] CHIP:DMG: 							0x15, 0x31, 0x01, 0x1d, 0x02, 0x30, 0x82, 0x02, 0x19, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, 0xa0, 0x82, 0x02, 0x0a, 0x30, 0x82, 0x02, 0x06, 0x02, 0x01, 0x03, 0x31, 0x0d, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x82, 0x01, 0x71, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x01, 0xa0, 0x82, 0x01, 0x62, 0x04, 0x82, 0x01, 0x5e, 0x15, 0x24, 0x00, 0x01, 0x25, 0x01, 0xf1, 0xff, 0x36, 0x02, 0x05, 0x00, 0x80, 0x05, 0x01, 0x80, 0x05, 0x02, 0x80, 0x05, 0x03, 0x80, 0x05, 0x04, 0x80, 0x05, 0x05, 0x80, 0x05, 0x06, 0x80, 0x05, 0x07, 0x80, 0x05, 0x08, 0x80, 0x05, 0x09, 0x80, 0x05, 0x0a, 0x80, 0x05, 0x0b, 0x80, 0x05, 0x0c, 0x80, 0x05, 0x0d, 0x80, 0x05, 0x0e, 0x80, 0x05, 0x0f, 0x80, 0x05, 0x10, 0x80, 0x05, 0x11, 0x80, 0x05, 0x12, 0x80, 0x05, 0x13, 0x80, 0x05, 0x14, 0x80, 0x05, 0x15, 0x80, 0x05, 0x16, 0x80, 0x05, 0x17, 0x80, 0x05, 0x18, 0x80, 0x05, 0x19, 0x80, 0x05, 0x1a, 0x80, 0x05, 0x1b, 0x80, 0x05, 0x1c, 0x80, 0x05, 0x1d, 0x80, 0x05, 0x1e, 0x80, 0x05, 0x1f, 0x80, 0x05, 0x20, 0x80, 0x05, 0x21, 0x80, 0x05, 0x22, 0x80, 0x05, 0x23, 0x80, 0x05, 0x24, 0x80, 0x05, 0x25, 0x80, 0x05, 0x26, 0x80, 0x05, 0x27, 0x80, 0x05, 0x28, 0x80, 0x05, 0x29, 0x80, 0x05, 0x2a, 0x80, 0x05, 0x2b, 0x80, 0x05, 0x2c, 0x80, 0x05, 0x2d, 0x80, 0x05, 0x2e, 0x80, 0x05, 0x2f, 0x80, 0x05, 0x30, 0x80, 0x05, 0x31, 0x80, 0x05, 0x32, 0x80, 0x05, 0x33, 0x80, 0x05, 0x34, 0x80, 0x05, 0x35, 0x80, 0x05, 0x36, 0x80, 0x05, 0x37, 0x80, 0x05, 0x38, 0x80, 0x05, 0x39, 0x80, 0x05, 0x3a, 0x80, 0x05, 0x3b, 0x80, 0x05, 0x3c, 0x80, 0x05, 0x3d, 0x80, 0x05, 0x3e, 0x80, 0x05, 0x3f, 0x80, 0x05, 0x40, 0x80, 0x05, 0x41, 0x80, 0x05, 0x42, 0x80, 0x05, 0x43, 0x80, 0x
    [1689139868.404302][10800:10802] CHIP:DMG: 					] (585 bytes)
    [1689139868.404382][10800:10802] CHIP:DMG: 					0x1 = [
    [1689139868.404514][10800:10802] CHIP:DMG: 							0xb9, 0x3a, 0x86, 0x97, 0xff, 0x10, 0xff, 0x43, 0x0c, 0x49, 0x6a, 0x04, 0xee, 0xe4, 0x63, 0xc4, 0x83, 0x80, 0x06, 0x04, 0x82, 0x4c, 0xc5, 0x12, 0x0a, 0x1d, 0xb9, 0xdd, 0x59, 0x44, 0x0a, 0x5e, 0x3a, 0x82, 0x5e, 0x7f, 0x01, 0xb1, 0x8f, 0xf7, 0x5a, 0x86, 0x54, 0xa5, 0x3e, 0xc4, 0xd9, 0xe7, 0x59, 0xd8, 0x6d, 0xae, 0x74, 0x70, 0xb4, 0x66, 0x3e, 0xd1, 0xd0, 0x38, 0xf1, 0xfe, 0xde, 0x77,
    [1689139868.404671][10800:10802] CHIP:DMG: 					] (64 bytes)
    [1689139868.404752][10800:10802] CHIP:DMG: 				},
    [1689139868.404821][10800:10802] CHIP:DMG: 			},
    [1689139868.404927][10800:10802] CHIP:DMG:
    [1689139868.404988][10800:10802] CHIP:DMG: 		},
    [1689139868.405060][10800:10802] CHIP:DMG:
    [1689139868.405138][10800:10802] CHIP:DMG: 	],
    [1689139868.405211][10800:10802] CHIP:DMG:
    [1689139868.405286][10800:10802] CHIP:DMG: 	InteractionModelRevision = 1
    [1689139868.405343][10800:10802] CHIP:DMG: },
    [1689139868.405503][10800:10802] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
    [1689139868.405580][10800:10802] CHIP:CTL: Received Attestation Information from the device
    [1689139868.405665][10800:10802] CHIP:CTL: Successfully finished commissioning step 'SendAttestationRequest'
    [1689139868.405723][10800:10802] CHIP:CTL: AutoCommissioner setting attestationElements buffer size 585/585
    [1689139868.405850][10800:10802] CHIP:CTL: Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
    [1689139868.405916][10800:10802] CHIP:CTL: Performing next commissioning step 'AttestationVerification'
    [1689139868.405965][10800:10802] CHIP:CTL: Verifying attestation
    [1689139868.443997][10800:10802] CHIP:CTL: Successfully validated 'Attestation Information' command received from the device.
    [1689139868.444080][10800:10802] CHIP:CTL: Successfully finished commissioning step 'AttestationVerification'
    [1689139868.444101][10800:10802] CHIP:CTL: Commissioning stage next step: 'AttestationVerification' -> 'SendOpCertSigningRequest'
    [1689139868.444132][10800:10802] CHIP:CTL: Performing next commissioning step 'SendOpCertSigningRequest'
    [1689139868.444154][10800:10802] CHIP:CTL: Sending CSR request to 0xffffac034a50 device
    [1689139868.444227][10800:10802] CHIP:DMG: ICR moving to [AddingComm]
    [1689139868.444259][10800:10802] CHIP:DMG: ICR moving to [AddedComma]
    [1689139868.444404][10800:10802] CHIP:EM: <<< [E:60478i M:147197900] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1689139868.444456][10800:10802] CHIP:IN: (S) Sending msg 147197900 on secure session with LSID: 56629
    [1689139868.444568][10800:10802] CHIP:DMG: ICR moving to [CommandSen]
    [1689139868.444645][10800:10802] CHIP:CTL: Sent CSR request, waiting for the CSR
    [1689139868.444734][10800:10802] CHIP:DMG: ICR moving to [AwaitingDe]
    [1689139868.544347][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139869.815289][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139869.815594][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139869.912680][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139869.912979][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139869.913253][10800:10802] CHIP:EM: >>> [E:60478i M:256335166] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1689139869.913333][10800:10802] CHIP:EM: Found matching exchange: 60478i, Delegate: 0xffffb4061248
    [1689139869.913420][10800:10802] CHIP:DMG: ICR moving to [ResponseRe]
    [1689139869.913522][10800:10802] CHIP:DMG: InvokeResponseMessage =
    [1689139869.913579][10800:10802] CHIP:DMG: {
    [1689139869.913633][10800:10802] CHIP:DMG: 	suppressResponse = false,
    [1689139869.913690][10800:10802] CHIP:DMG: 	InvokeResponseIBs =
    [1689139869.913766][10800:10802] CHIP:DMG: 	[
    [1689139869.913822][10800:10802] CHIP:DMG: 		InvokeResponseIB =
    [1689139869.913901][10800:10802] CHIP:DMG: 		{
    [1689139869.913961][10800:10802] CHIP:DMG: 			CommandDataIB =
    [1689139869.914032][10800:10802] CHIP:DMG: 			{
    [1689139869.914097][10800:10802] CHIP:DMG: 				CommandPathIB =
    [1689139869.914172][10800:10802] CHIP:DMG: 				{
    [1689139869.914247][10800:10802] CHIP:DMG: 					EndpointId = 0x0,
    [1689139869.914327][10800:10802] CHIP:DMG: 					ClusterId = 0x3e,
    [1689139869.914405][10800:10802] CHIP:DMG: 					CommandId = 0x5,
    [1689139869.914480][10800:10802] CHIP:DMG: 				},
    [1689139869.914559][10800:10802] CHIP:DMG:
    [1689139869.914627][10800:10802] CHIP:DMG: 				CommandFields =
    [1689139869.914701][10800:10802] CHIP:DMG: 				{
    [1689139869.914776][10800:10802] CHIP:DMG: 					0x0 = [
    [1689139869.915062][10800:10802] CHIP:DMG: 							0x15, 0x30, 0x01, 0xcd, 0x30, 0x81, 0xca, 0x30, 0x70, 0x02, 0x01, 0x00, 0x30, 0x0e, 0x31, 0x0c, 0x30, 0x0a, 0x06, 0x03, 0x55, 0x04, 0x0a, 0x0c, 0x03, 0x43, 0x53, 0x52, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0xc2, 0x48, 0xa3, 0xfb, 0x15, 0xfd, 0xb3, 0x94, 0xf2, 0x3c, 0x80, 0x01, 0xad, 0x4d, 0x23, 0xd3, 0x12, 0xe4, 0x02, 0x58, 0x45, 0x3f, 0xd0, 0xfe, 0x98, 0xe4, 0xec, 0x37, 0x58, 0xbf, 0x09, 0x66, 0x0d, 0x99, 0xde, 0x34, 0xa7, 0xd2, 0x8f, 0x40, 0xc4, 0xb1, 0xf1, 0xad, 0xae, 0xde, 0x9a, 0xff, 0x8e, 0x6c, 0x18, 0xb7, 0x66, 0x2a, 0xe9, 0xe4, 0x68, 0xc6, 0xc2, 0x90, 0x21, 0xc0, 0x91, 0x30, 0xa0, 0x00, 0x30, 0x0c, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x05, 0x00, 0x03, 0x48, 0x00, 0x30, 0x45, 0x02, 0x21, 0x00, 0x9f, 0x86, 0xe7, 0x6a, 0x48, 0x3b, 0xa1, 0xaa, 0x1c, 0x05, 0xcc, 0x3f, 0xab, 0xf3, 0x92, 0x13, 0x3a, 0x4f, 0x95, 0xda, 0xab, 0xed, 0x45, 0xbc, 0x28, 0x13, 0xe8, 0x7f, 0x78, 0x5e, 0x20, 0xb2, 0x02, 0x20, 0x02, 0x9a, 0xd4, 0xee, 0xd8, 0xfd, 0x78, 0xa9, 0xe8, 0xa6, 0x21, 0x02, 0xbc, 0xe7, 0xc5, 0x56, 0x57, 0x2f, 0x5d, 0x36, 0xa6, 0x30, 0x83, 0x36, 0x40, 0xbe, 0xc8, 0x29, 0x05, 0xe6, 0xc9, 0xc4, 0x30, 0x02, 0x20, 0x5f, 0x73, 0x91, 0x64, 0x79, 0xeb, 0xb6, 0x39, 0xd8, 0x28, 0x8e, 0x64, 0x68, 0xc8, 0xf5, 0x96, 0xa9, 0x09, 0xf1, 0x38, 0x11, 0x36, 0xcb, 0x51, 0x70, 0xd4, 0x18, 0x9d, 0x51, 0x77, 0x1f, 0xdd, 0x18,
    [1689139869.915228][10800:10802] CHIP:DMG: 					] (245 bytes)
    [1689139869.915309][10800:10802] CHIP:DMG: 					0x1 = [
    [1689139869.915440][10800:10802] CHIP:DMG: 							0x59, 0xbd, 0x98, 0x38, 0xe3, 0xb4, 0xdc, 0xfc, 0x93, 0x1f, 0x71, 0x46, 0xa9, 0xe3, 0x4e, 0x43, 0x12, 0xac, 0xdc, 0x4b, 0xd1, 0x27, 0x1a, 0x17, 0x5d, 0x10, 0xfb, 0xe4, 0xb2, 0x3a, 0x4d, 0xcb, 0x61, 0xf3, 0x28, 0x70, 0x12, 0x2e, 0x70, 0x3f, 0xf0, 0x43, 0x15, 0x80, 0x74, 0x92, 0x75, 0x30, 0x6a, 0x28, 0x0a, 0xb5, 0xfb, 0x97, 0xb5, 0x09, 0x9e, 0x2b, 0x83, 0x71, 0x99, 0x4e, 0x97, 0x9f,
    [1689139869.915538][10800:10802] CHIP:DMG: 					] (64 bytes)
    [1689139869.915617][10800:10802] CHIP:DMG: 				},
    [1689139869.915687][10800:10802] CHIP:DMG: 			},
    [1689139869.915765][10800:10802] CHIP:DMG:
    [1689139869.915824][10800:10802] CHIP:DMG: 		},
    [1689139869.915897][10800:10802] CHIP:DMG:
    [1689139869.915953][10800:10802] CHIP:DMG: 	],
    [1689139869.916025][10800:10802] CHIP:DMG:
    [1689139869.916080][10800:10802] CHIP:DMG: 	InteractionModelRevision = 1
    [1689139869.916134][10800:10802] CHIP:DMG: },
    [1689139869.916274][10800:10802] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0005
    [1689139869.916350][10800:10802] CHIP:CTL: Received certificate signing request from the device
    [1689139869.916414][10800:10802] CHIP:CTL: Successfully finished commissioning step 'SendOpCertSigningRequest'
    [1689139869.916466][10800:10802] CHIP:CTL: Commissioning stage next step: 'SendOpCertSigningRequest' -> 'ValidateCSR'
    [1689139869.916527][10800:10802] CHIP:CTL: Performing next commissioning step 'ValidateCSR'
    [1689139869.925228][10800:10802] CHIP:CTL: Successfully finished commissioning step 'ValidateCSR'
    [1689139869.925292][10800:10802] CHIP:CTL: Commissioning stage next step: 'ValidateCSR' -> 'GenerateNOCChain'
    [1689139869.925328][10800:10802] CHIP:CTL: Performing next commissioning step 'GenerateNOCChain'
    [1689139869.925355][10800:10802] CHIP:CTL: Getting certificate chain for the device from the issuer
    [1689139869.930035][10800:10802] CHIP:CTL: Verifying Certificate Signing Request
    [1689139869.932973][10800:10802] CHIP:CTL: Generating NOC
    [1689139869.933358][10800:10802] CHIP:CTL: Providing certificate chain to the commissioner
    [1689139869.933395][10800:10802] CHIP:CTL: Received callback from the CA for NOC Chain generation. Status ../examples/chip-tool/third_party/connectedhomeip/src/controller/ExampleOperationalCredentialsIssuer.cpp:396: Success
    [1689139869.933432][10800:10802] CHIP:CTL: Successfully finished commissioning step 'GenerateNOCChain'
    [1689139869.933622][10800:10802] CHIP:CTL: Performing next commissioning step 'SendTrustedRootCert'
    [1689139869.933652][10800:10802] CHIP:CTL: Sending root certificate to the device
    [1689139869.933731][10800:10802] CHIP:DMG: ICR moving to [AddingComm]
    [1689139869.933764][10800:10802] CHIP:DMG: ICR moving to [AddedComma]
    [1689139869.933896][10800:10802] CHIP:EM: <<< [E:60479i M:147197901] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1689139869.933943][10800:10802] CHIP:IN: (S) Sending msg 147197901 on secure session with LSID: 56629
    [1689139869.934059][10800:10802] CHIP:DMG: ICR moving to [CommandSen]
    [1689139869.934091][10800:10802] CHIP:CTL: Sent root certificate to the device
    [1689139869.934602][10800:10802] CHIP:DMG: ICR moving to [AwaitingDe]
    [1689139870.007009][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139870.104087][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139870.351076][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139870.351322][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139870.351595][10800:10802] CHIP:EM: >>> [E:60479i M:256335167] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1689139870.351656][10800:10802] CHIP:EM: Found matching exchange: 60479i, Delegate: 0xffffb4060ec8
    [1689139870.351737][10800:10802] CHIP:DMG: ICR moving to [ResponseRe]
    [1689139870.351815][10800:10802] CHIP:DMG: InvokeResponseMessage =
    [1689139870.351856][10800:10802] CHIP:DMG: {
    [1689139870.351898][10800:10802] CHIP:DMG: 	suppressResponse = false,
    [1689139870.351940][10800:10802] CHIP:DMG: 	InvokeResponseIBs =
    [1689139870.352015][10800:10802] CHIP:DMG: 	[
    [1689139870.352059][10800:10802] CHIP:DMG: 		InvokeResponseIB =
    [1689139870.352133][10800:10802] CHIP:DMG: 		{
    [1689139870.352180][10800:10802] CHIP:DMG: 			CommandStatusIB =
    [1689139870.352231][10800:10802] CHIP:DMG: 			{
    [1689139870.352301][10800:10802] CHIP:DMG: 				CommandPathIB =
    [1689139870.352359][10800:10802] CHIP:DMG: 				{
    [1689139870.352432][10800:10802] CHIP:DMG: 					EndpointId = 0x0,
    [1689139870.352493][10800:10802] CHIP:DMG: 					ClusterId = 0x3e,
    [1689139870.352565][10800:10802] CHIP:DMG: 					CommandId = 0xb,
    [1689139870.352655][10800:10802] CHIP:DMG: 				},
    [1689139870.352719][10800:10802] CHIP:DMG:
    [1689139870.352785][10800:10802] CHIP:DMG: 				StatusIB =
    [1689139870.352842][10800:10802] CHIP:DMG: 				{
    [1689139870.352915][10800:10802] CHIP:DMG: 					status = 0x00 (SUCCESS),
    [1689139870.352972][10800:10802] CHIP:DMG: 				},
    [1689139870.353044][10800:10802] CHIP:DMG:
    [1689139870.353095][10800:10802] CHIP:DMG: 			},
    [1689139870.353151][10800:10802] CHIP:DMG:
    [1689139870.353213][10800:10802] CHIP:DMG: 		},
    [1689139870.353264][10800:10802] CHIP:DMG:
    [1689139870.353305][10800:10802] CHIP:DMG: 	],
    [1689139870.353374][10800:10802] CHIP:DMG:
    [1689139870.353415][10800:10802] CHIP:DMG: 	InteractionModelRevision = 1
    [1689139870.353472][10800:10802] CHIP:DMG: },
    [1689139870.353573][10800:10802] CHIP:DMG: Received Command Response Status for Endpoint=0 Cluster=0x0000_003E Command=0x0000_000B Status=0x0
    [1689139870.353636][10800:10802] CHIP:CTL: Device confirmed that it has received the root certificate
    [1689139870.353683][10800:10802] CHIP:CTL: Successfully finished commissioning step 'SendTrustedRootCert'
    [1689139870.353722][10800:10802] CHIP:CTL: Commissioning stage next step: 'SendTrustedRootCert' -> 'SendNOC'
    [1689139870.353784][10800:10802] CHIP:CTL: Performing next commissioning step 'SendNOC'
    [1689139870.353889][10800:10802] CHIP:DMG: ICR moving to [AddingComm]
    [1689139870.353967][10800:10802] CHIP:DMG: ICR moving to [AddedComma]
    [1689139870.354175][10800:10802] CHIP:EM: <<< [E:60480i M:147197902] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1689139870.354256][10800:10802] CHIP:IN: (S) Sending msg 147197902 on secure session with LSID: 56629
    [1689139870.354407][10800:10802] CHIP:DMG: ICR moving to [CommandSen]
    [1689139870.354475][10800:10802] CHIP:CTL: Sent operational certificate to the device
    [1689139870.354551][10800:10802] CHIP:DMG: ICR moving to [AwaitingDe]
    [1689139870.445735][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139870.543064][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139870.640587][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139871.375258][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139871.375576][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139871.375872][10800:10802] CHIP:EM: >>> [E:60480i M:256335168] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1689139871.375952][10800:10802] CHIP:EM: Found matching exchange: 60480i, Delegate: 0xffffb4061248
    [1689139871.376035][10800:10802] CHIP:DMG: ICR moving to [ResponseRe]
    [1689139871.376133][10800:10802] CHIP:DMG: InvokeResponseMessage =
    [1689139871.376191][10800:10802] CHIP:DMG: {
    [1689139871.376244][10800:10802] CHIP:DMG: 	suppressResponse = false,
    [1689139871.376301][10800:10802] CHIP:DMG: 	InvokeResponseIBs =
    [1689139871.376374][10800:10802] CHIP:DMG: 	[
    [1689139871.376431][10800:10802] CHIP:DMG: 		InvokeResponseIB =
    [1689139871.376509][10800:10802] CHIP:DMG: 		{
    [1689139871.376570][10800:10802] CHIP:DMG: 			CommandDataIB =
    [1689139871.376696][10800:10802] CHIP:DMG: 			{
    [1689139871.376769][10800:10802] CHIP:DMG: 				CommandPathIB =
    [1689139871.376844][10800:10802] CHIP:DMG: 				{
    [1689139871.376921][10800:10802] CHIP:DMG: 					EndpointId = 0x0,
    [1689139871.377000][10800:10802] CHIP:DMG: 					ClusterId = 0x3e,
    [1689139871.377085][10800:10802] CHIP:DMG: 					CommandId = 0x8,
    [1689139871.377156][10800:10802] CHIP:DMG: 				},
    [1689139871.377234][10800:10802] CHIP:DMG:
    [1689139871.377300][10800:10802] CHIP:DMG: 				CommandFields =
    [1689139871.377374][10800:10802] CHIP:DMG: 				{
    [1689139871.377451][10800:10802] CHIP:DMG: 					0x0 = 0,
    [1689139871.377531][10800:10802] CHIP:DMG: 					0x1 = 1,
    [1689139871.377609][10800:10802] CHIP:DMG: 				},
    [1689139871.377678][10800:10802] CHIP:DMG: 			},
    [1689139871.377752][10800:10802] CHIP:DMG:
    [1689139871.377811][10800:10802] CHIP:DMG: 		},
    [1689139871.377883][10800:10802] CHIP:DMG:
    [1689139871.377938][10800:10802] CHIP:DMG: 	],
    [1689139871.378008][10800:10802] CHIP:DMG:
    [1689139871.378063][10800:10802] CHIP:DMG: 	InteractionModelRevision = 1
    [1689139871.378117][10800:10802] CHIP:DMG: },
    [1689139871.378251][10800:10802] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0008
    [1689139871.378327][10800:10802] CHIP:CTL: Device returned status 0 on receiving the NOC
    [1689139871.378379][10800:10802] CHIP:CTL: Operational credentials provisioned on device 0xffffac034a50
    [1689139871.378428][10800:10802] CHIP:TOO: Secure Pairing Success
    [1689139871.378472][10800:10802] CHIP:TOO: CASE establishment successful
    [1689139871.378527][10800:10802] CHIP:CTL: Successfully finished commissioning step 'SendNOC'
    [1689139871.378579][10800:10802] CHIP:CTL: No NetworkScan enabled or WiFi/Thread endpoint not specified, skipping ScanNetworks
    [1689139871.378629][10800:10802] CHIP:CTL: Commissioning stage next step: 'SendNOC' -> 'ThreadNetworkSetup'
    [1689139871.378687][10800:10802] CHIP:CTL: Performing next commissioning step 'ThreadNetworkSetup'
    [1689139871.378804][10800:10802] CHIP:DMG: ICR moving to [AddingComm]
    [1689139871.378961][10800:10802] CHIP:DMG: ICR moving to [AddedComma]
    [1689139871.379172][10800:10802] CHIP:EM: <<< [E:60481i M:147197903] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1689139871.379259][10800:10802] CHIP:IN: (S) Sending msg 147197903 on secure session with LSID: 56629
    [1689139871.379452][10800:10802] CHIP:DMG: ICR moving to [CommandSen]
    [1689139871.379577][10800:10802] CHIP:DMG: ICR moving to [AwaitingDe]
    [1689139871.469499][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139871.566706][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1689139871.570271][10800:10801] CHIP:DL: Indication received, conn = 0xffffb405e080
    [1689139871.570506][10800:10802] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1689139871.570768][10800:10802] CHIP:EM: >>> [E:60481i M:256335169] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1689139871.570839][10800:10802] CHIP:EM: Found matching exchange: 60481i, Delegate: 0xffffb4060ec8
    [1689139871.570908][10800:10802] CHIP:DMG: ICR moving to [ResponseRe]
    [1689139871.570990][10800:10802] CHIP:DMG: InvokeResponseMessage =
    [1689139871.571032][10800:10802] CHIP:DMG: {
    [1689139871.571177][10800:10802] CHIP:DMG: 	suppressResponse = false,
    [1689139871.571220][10800:10802] CHIP:DMG: 	InvokeResponseIBs =
    [1689139871.571275][10800:10802] CHIP:DMG: 	[
    [1689139871.571317][10800:10802] CHIP:DMG: 		InvokeResponseIB =
    [1689139871.571375][10800:10802] CHIP:DMG: 		{
    [1689139871.571420][10800:10802] CHIP:DMG: 			CommandDataIB =
    [1689139871.571471][10800:10802] CHIP:DMG: 			{
    [1689139871.571524][10800:10802] CHIP:DMG: 				CommandPathIB =
    [1689139871.571581][10800:10802] CHIP:DMG: 				{
    [1689139871.571638][10800:10802] CHIP:DMG: 					EndpointId = 0x0,
    [1689139871.571698][10800:10802] CHIP:DMG: 					ClusterId = 0x31,
    [1689139871.571757][10800:10802] CHIP:DMG: 					CommandId = 0x5,
    [1689139871.571813][10800:10802] CHIP:DMG: 				},
    [1689139871.571871][10800:10802] CHIP:DMG:
    [1689139871.571921][10800:10802] CHIP:DMG: 				CommandFields =
    [1689139871.571977][10800:10802] CHIP:DMG: 				{
    [1689139871.572043][10800:10802] CHIP:DMG: 					0x0 = 1,
    [1689139871.572099][10800:10802] CHIP:DMG: 				},
    [1689139871.572155][10800:10802] CHIP:DMG: 			},
    [1689139871.572212][10800:10802] CHIP:DMG:
    [1689139871.572256][10800:10802] CHIP:DMG: 		},
    [1689139871.572309][10800:10802] CHIP:DMG:
    [1689139871.572350][10800:10802] CHIP:DMG: 	],
    [1689139871.572401][10800:10802] CHIP:DMG:
    [1689139871.572442][10800:10802] CHIP:DMG: 	InteractionModelRevision = 1
    [1689139871.572483][10800:10802] CHIP:DMG: },
    [1689139871.572581][10800:10802] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0005
    [1689139871.572742][10800:10802] CHIP:CTL: Received NetworkConfig response, networkingStatus=1
    [1689139871.572808][10800:10802] CHIP:CTL: Error on commissioning step 'ThreadNetworkSetup': '../examples/chip-tool/third_party/connectedhomeip/src/controller/CHIPDeviceController.cpp:2050: CHIP Error 0x000000AC: Internal error'
    [1689139871.572850][10800:10802] CHIP:CTL: Failed to perform commissioning step 15
    [1689139871.572897][10800:10802] CHIP:CTL: Going from commissioning step 'ThreadNetworkSetup' with lastErr = '../examples/chip-tool/third_party/connectedhomeip/src/controller/CHIPDeviceController.cpp:2050: CHIP Error 0x000000AC: Internal error' -> 'Cleanup'
    [1689139871.572956][10800:10802] CHIP:CTL: Performing next commissioning step 'Cleanup' with completion status = '../examples/chip-tool/third_party/connectedhomeip/src/controller/CHIPDeviceController.cpp:2050: CHIP Error 0x000000AC: Internal error'
    [1689139871.573000][10800:10802] CHIP:CTL: Successfully finished commissioning step 'Cleanup'
    [1689139871.573054][10800:10802] CHIP:TOO: Device commissioning Failure: ../examples/chip-tool/third_party/connectedhomeip/src/controller/CHIPDeviceController.cpp:2050: CHIP Error 0x000000AC: Internal error
    [1689139871.573148][10800:10802] CHIP:DMG: ICR moving to [AwaitingDe]
    [1689139871.573511][10800:10800] CHIP:CTL: Shutting down the commissioner
    [1689139871.573565][10800:10800] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1689139871.573760][10800:10800] CHIP:DIS: Closing all BLE connections
    [1689139871.573804][10800:10800] CHIP:IN: Clearing BLE pending packets.
    [1689139871.573910][10800:10800] CHIP:BLE: Auto-closing end point's BLE connection.
    [1689139871.573952][10800:10800] CHIP:DL: Closing BLE GATT connection (con 0xffffb405e080)
    [1689139871.574032][10800:10800] CHIP:IN: SecureSession[0xffffac014f10]: MarkForEviction Type:1 LSID:56629
    [1689139871.574074][10800:10800] CHIP:SC: SecureSession[0xffffac014f10]: Moving from state 'kActive' --> 'kPendingEviction'
    [1689139871.574154][10800:10800] CHIP:IN: SecureSession[0xffffac014f10]: Released - Type:1 LSID:56629
    [1689139871.574204][10800:10800] CHIP:CTL: Shutting down the controller
    [1689139871.574246][10800:10800] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1689139871.574284][10800:10800] CHIP:FP: Forgetting fabric 0x1
    [1689139871.574344][10800:10800] CHIP:TS: Pending Last Known Good Time: 2023-07-12T09:42:48
    [1689139871.574391][10800:10801] CHIP:DL: BluezDisconnect peer=75:19:7E:C1:BD:91
    [1689139871.574581][10800:10800] CHIP:TS: Previous Last Known Good Time: 2023-07-12T09:42:48
    [1689139871.574632][10800:10800] CHIP:TS: Reverted Last Known Good Time to previous value
    [1689139871.574701][10800:10800] CHIP:CTL: Shutting down the commissioner
    [1689139871.574738][10800:10800] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1689139871.574933][10800:10800] CHIP:CTL: Shutting down the controller
    [1689139871.574975][10800:10800] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1689139871.575722][10800:10800] CHIP:DMG: IM WH moving to [Uninitialized]
    [1689139871.575777][10800:10800] CHIP:DMG: IM WH moving to [Uninitialized]
    [1689139871.575823][10800:10800] CHIP:DMG: IM WH moving to [Uninitialized]
    [1689139871.575865][10800:10800] CHIP:DMG: IM WH moving to [Uninitialized]
    [1689139871.575903][10800:10800] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1689139871.576068][10800:10800] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1689139871.576126][10800:10800] CHIP:FP: Shutting down FabricTable
    [1689139871.576174][10800:10800] CHIP:TS: Pending Last Known Good Time: 2023-07-12T09:42:48
    [1689139871.576341][10800:10800] CHIP:TS: Previous Last Known Good Time: 2023-07-12T09:42:48
    [1689139871.576389][10800:10800] CHIP:TS: Reverted Last Known Good Time to previous value
    [1689139871.576832][10800:10800] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-whpZh2)
    [1689139871.581286][10800:10800] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1689139871.581397][10800:10800] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1689139871.581442][10800:10800] CHIP:DL: Inet Layer shutdown
    [1689139871.581482][10800:10800] CHIP:DL: BLE shutdown
    [1689139871.583467][10800:10800] CHIP:DL: System Layer shutdown
    [1689139873.616336][10800:10800] CHIP:TOO: Run command failure: ../examples/chip-tool/third_party/connectedhomeip/src/controller/CHIPDeviceController.cpp:2050: CHIP Error 0x000000AC: Internal error
    ubuntu@raspberrypi:~/matter/out$
    Matter 设备打印的 UART 日志:
    Xshell 7 (Build 0099)
    Copyright (c) 2020 NetSarang Computer, Inc. All rights reserved.
    Type `help' to learn how to use Xshell prompt.
    [C:\~]$
    Connecting to COM4...
    Connected.
    ÿOpenThread started: OK
    Setting OpenThread device type to MINIMAL END DEVICE
    Initialize Server
    Server initializing...
    Last Known Good Time: 2023-07-03T16:02:44
    AccessControl: initializing
    Examples::AccessControlDelegate::Init
    AccessControl: setting
    DefaultAclStorage: initializing
    DefaultAclStorage: 0 entries loaded
    Using ZAP configuration...
    AccessControlCluster: initializing
    Initiating Admin Commissioning cluster.
    Door Lock server initialized
    Cluster callback: 0x0000_0030
    Cluster callback: 0x0000_002B
    Updating services using commissioning mode 0
    Advertise commission parameter vendorID=65521 productID=32774 discriminator=3840/15 cm=0
    Failed to advertise extended commissionable node: 3
    Failed to finalize service update: 1c
    Delaying proxy of operational discovery: missing delegate
    CASE Server enabling CASE session setups
    Joining Multicast groups
    Server Listening...
    Initialize LEDs
    Initialize buttons
    Lock completed
    Device Configuration:
      Serial Number: TEST_SN
      Vendor Id: 65521 (0xFFF1)
      Product Id: 32774 (0x8006)
      Hardware Version: 0
      Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
      Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
      Manufacturing Date: (not set)
      Device Type: 65535 (0xFFFF)
    Stopping the watchdog timer
    Starting the periodic query timer, timeout: 86400 seconds
    SetupQRCode: [MT:8IXS142C00KA0648G00]
    Copy/paste the below URL in a browser to see the QR Code:
    project-chip.github.io/.../qrcode.html
    Manual pairing code: [34970112332]
    Unlock initiated
    Cluster callback: 0x0000_0101
    Door lock cluster: 0x0000_0101
    Unlock completed
    Updating services using commissioning mode 1
    Advertise commission parameter vendorID=65521 productID=32774 discriminator=3840/15 cm=1
    Failed to advertise commissionable node: 3
    Enabled BLE Advertisements
    local and remote recv window sizes = 6
    selected BTP version 4
    >>> [E:60471r M:199606471] (U) Msg RX from 0:3DE92DF1A0FC06D4 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
    <<< [E:60471r M:20804041] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
    (U) Sending msg 20804041 to IP address 'BLE'
    >>> [E:60471r M:199606472] (U) Msg RX from 0:3DE92DF1A0FC06D4 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
    <<< [E:60471r M:20804042] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
    (U) Sending msg 20804042 to IP address 'BLE'
    Long dispatch time: 5152 ms, for event type 7
    >>> [E:60471r M:199606473] (U) Msg RX from 0:3DE92DF1A0FC06D4 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
    <<< [E:60471r M:20804043] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    (U) Sending msg 20804043 to IP address 'BLE'
    SecureSession[0x200121b8]: Moving from state 'kEstablishing' --> 'kActive'
    Commissioning completed session establishment step
    Device completed Rendezvous process
    >>> [E:60472r M:147197894] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    <<< [E:60472r M:256335160] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
    (S) Sending msg 256335160 on secure session with LSID: 8216
    >>> [E:60473r M:147197895] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    GeneralCommissioning: Received ArmFailSafe (60s)
    <<< [E:60473r M:256335161] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    (S) Sending msg 256335161 on secure session with LSID: 8216
    >>> [E:60474r M:147197896] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    <<< [E:60474r M:256335162] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    (S) Sending msg 256335162 on secure session with LSID: 8216
    >>> [E:60475r M:147197897] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    OpCreds: Certificate Chain request received for PAI
    <<< [E:60475r M:256335163] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    (S) Sending msg 256335163 on secure session with LSID: 8216
    >>> [E:60476r M:147197898] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    OpCreds: Certificate Chain request received for DAC
    <<< [E:60476r M:256335164] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    (S) Sending msg 256335164 on secure session with LSID: 8216
    >>> [E:60477r M:147197899] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    OpCreds: Received an AttestationRequest command
    OpCreds: AttestationRequest successful.
    <<< [E:60477r M:256335165] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    (S) Sending msg 256335165 on secure session with LSID: 8216
    Long dispatch time: 159 ms, for event type 7
    >>> [E:60478r M:147197900] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    OpCreds: Received a CSRRequest command
    OpCreds: AllocatePendingOperationalKey succeeded
    OpCreds: CSRRequest successful.
    <<< [E:60478r M:256335166] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    (S) Sending msg 256335166 on secure session with LSID: 8216
    Long dispatch time: 1290 ms, for event type 7
    >>> [E:60479r M:147197901] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    OpCreds: Received an AddTrustedRootCertificate command
    OpCreds: AddTrustedRootCertificate successful.
    <<< [E:60479r M:256335167] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    (S) Sending msg 256335167 on secure session with LSID: 8216
    Long dispatch time: 278 ms, for event type 7
    >>> [E:60480r M:147197902] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    OpCreds: Received an AddNOC command
    Validating NOC chain
    NOC chain validation successful
    Added new fabric at index: 0x1
    Assigned compressed fabric ID: 0xB85C55CBB67A0454, node ID: 0x0000000000000001
    New proposed Last Known Good Time: 2021-01-01T00:00:00
    Retaining current Last Known Good Time
    OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0x000000000001B669
    Advertise operational node B85C55CBB67A0454-0000000000000001
    OpCreds: successfully created fabric index 0x1 via AddNOC
    <<< [E:60480r M:256335168] (S) Msg TX to 1:FFFFFFFB00000000 [0454] --- Type 0001:09 (IM:InvokeCommandResponse)
    (S) Sending msg 256335168 on secure session with LSID: 8216
    Long dispatch time: 718 ms, for event type 7
    >>> [E:60481r M:147197903] (S) Msg RX from 1:FFFFFFFB00000000 [0454] --- Type 0001:08 (IM:InvokeCommandRequest)
    <<< [E:60481r M:256335169] (S) Msg TX to 1:FFFFFFFB00000000 [0454] --- Type 0001:09 (IM:InvokeCommandResponse)
    (S) Sending msg 256335169 on secure session with LSID: 8216
    Releasing end point's BLE connection back to application.
    Fail-safe timer expired
    Failsafe timer expired
    SecureSession[0x200121b8]: Moving from state 'kActive' --> 'kPendingEviction'
    Commissioning failed (attempt 1): 32
    Failed to advertise operational node: 3
    OpCreds: Got FailSafeTimerExpired
    OpCreds: Proceeding to FailSafeCleanup on fail-safe expiry!
    Reverting pending fabric data for fabric 0x1
    Warning: metadata not found during delete of fabric 0x1
    Fabric (0x1) deleted.
    UserLabel: Last Fabric index 0x1 was removed
    OpCreds: Fabric index 0x1 was removed
    [OnFabricRemoved] Handling a fabric removal from the door lock server [endpointId=1,fabricIndex=1]
    Door Lock App: LockManager::GetUser [endpoint=1,userIndex=0]
    Door Lock App: LockManager::GetUser [endpoint=1,userIndex=1]
    Door Lock App: LockManager::GetUser [endpoint=1,userIndex=2]
    Door Lock App: LockManager::GetUser [endpoint=1,userIndex=3]
    Door Lock App: LockManager::GetUser [endpoint=1,userIndex=4]
    Door Lock App: LockManager::GetUser [endpoint=1,userIndex=5]
    Door Lock App: LockManager::GetUser [endpoint=1,userIndex=6]
    Door Lock App: LockManager::GetUser [endpoint=1,userIndex=7]
    Door Lock App: LockManager::GetUser [endpoint=1,userIndex=8]
    Door Lock App: LockManager::GetUser [endpoint=1,userIndex=9]
    Lock App: LockManager::GetCredential [credentialType=2], credentialIndex=0
    Lock App: LockManager::GetCredential [credentialType=2], credentialIndex=1
    Lock App: LockManager::GetCredential [credentialType=2], credentialIndex=2
    Lock App: LockManager::GetCredential [credentialType=2], credentialIndex=3
    Lock App: LockManager::GetCredential [credentialType=2], credentialIndex=4
    Lock App: LockManager::GetCredential [credentialType=2], credentialIndex=5
    Lock App: LockManager::GetCredential [credentialType=2], credentialIndex=6
    Lock App: LockManager::GetCredential [credentialType=2], credentialIndex=7
    Lock App: LockManager::GetCredential [credentialType=2], credentialIndex=8
    Lock App: LockManager::GetCredential [credentialType=2], credentialIndex=9
    Lock App: LockManager::GetCredential [credentialType=1], credentialIndex=0
    Lock App: LockManager::GetCredential [credentialType=1], credentialIndex=1
    Lock App: LockManager::GetCredential [credentialType=1], credentialIndex=2
    Lock App: LockManager::GetCredential [credentialType=1], credentialIndex=3
    Lock App: LockManager::GetCredential [credentialType=1], credentialIndex=4
    Lock App: LockManager::GetCredential [credentialType=1], credentialIndex=5
    Lock App: LockManager::GetCredential [credentialType=1], credentialIndex=6
    Lock App: LockManager::GetCredential [credentialType=1], credentialIndex=7
    Lock App: LockManager::GetCredential [credentialType=1], credentialIndex=8
    Lock App: LockManager::GetCredential [credentialType=1], credentialIndex=9
    Lock App: LockManager::GetCredential [credentialType=0], credentialIndex=0
    Pending Last Known Good Time: 2023-07-03T16:02:44
    Previous Last Known Good Time: 2023-07-03T16:02:44
    OpCreds: failed to delete fabric at index 1: d8
    Long dispatch time: 504 ms, for event type 32782
    Fail-safe cleanly disarmed
    谢谢。此致、
    尼克
    感谢您提供日志。  直接的问题是 Matter 芯片工具主机无法访问 OTBR 线程网络。   请参阅运行 CHIPLE-TOOL 的终端日志中的"CHIP ERROR 0x000000AC:内部错误"
    如果他们使用的是最新的 TI Matter 存储库、则 CHIPDeviceController.cpp 会失败、  OnNetworkConfigResponse 内会显示 CHIP_ERROR_INTERNAL。
    void DeviceCommissioner::OnNetworkConfigResponse(void * context,
                                                     const NetworkCommissioning::Commands::NetworkConfigResponse::DecodableType & data)
        CommissioningDelegate::CommissioningReport report;
        CHIP_ERROR err = CHIP_NO_ERROR;
        ChipLogProgress(Controller, "Received NetworkConfig response, networkingStatus=%u", to_underlying(data.networkingStatus));
        if (data.networkingStatus != NetworkCommissioning::NetworkCommissioningStatus::kSuccess)
            err = CHIP_ERROR_INTERNAL;
            report.Set<NetworkCommissioningStatusInfo>(data.networkingStatus);
        DeviceCommissioner * commissioner = static_cast<DeviceCommissioner *>(context);
        commissioner->CommissioningStageComplete(err, report);
    他们正在测试的 RPi 4上有多少 RAM 可用?  同一个器件是否在运行 OTBR?  chip-tool 和 OTBR 是否已连接到同一台路由器?
    瑞安
    您好,Ryan M ü,
    感谢你的帮助。 以下是客户提供的进一步更新:
    他使用的是最新的  TI Matter 存储库 那么、应使用哪个版本可以消除该误差呢?
    Raspberry Pi 是4GB 版本 、且 正在运行 OTBR。 他也在 Raspberry Pi 上运行 chip-tool 命令。
    谢谢。此致、
    尼克
    我没有看到此设置有任何问题、因为我之前使用的硬件和软件解决方案完全相同。  他们是否使用了我提供的 RCP、或者他们是否构建了自己的 RCP?  他们是否能够启动 OTBR 并加入 Thread 设备?  他们可以使用 Thread 边界路由器设置 SimpleLink Academy 实验 (任务3至5)和 Thread 示例进行评估。  RPi 是通过 WiFi 还是以太网连接到路由器?  互联网访问不应该是一个问题。
    重要说明 :最新的 chip-tool 已经稍微更新了 命令模式 ,所以必须将"hex :"放在 Thread 操作数据集之前。  实际上、我之前遇到过与此完全相同的错误、因为 Chip-tool 日志不指示错误、但调试步骤15 (查找 Thread 网络)失败。  您的命令应如下所示:
    ./chip-tool pairing ble-thread 1 hex:000300000f35060004001fffe00208dead00beef00cafe0708fde2f55f8122e830051000112233445566778899aabbccddeeff030f4f70656e5468726561642d37386237010212340410104810e2315100afd6bc9215a6bfac530c0402a0f7f80e080000000000010000 20202021 3840
    瑞安
    您好,Ryan M ü,
    客户 仍然无法解决。
    CHIPool 可以调试 Matter 器件的必要条件是什么?  他目前根据官方文件开展业务。
    这是 Matter 设备打印的日志:
    ÿOpenThread ifconfig up and thread start
    Initialize Server
    Fabric index 0x1 was retrieved from storage. Compressed FabricId 0xB07ED91A051673C2, FabricId 0x0000000000000001, NodeId 0x0000000000000001, VendorId 0xFFF1
    DefaultAclStorage: 1 entries loaded
    Fabric already commissioned. Disabling BLE advertisement
    Advertise operational node B07ED91A051673C2-0000000000000001
    Server Listening...
    Initialize LEDs
    Initialize buttons
    Unlock completed
      Hardware Version: 0
    SRP Client was started, detected server: fde2:f55f:8122:e830:6366:0c88IXS142C00KA0Cluster callback: 0x0000_002A
    Setting operational delegate post init
    advertising srp service: B07ED91A051673C2-0000000000000001._matter._tcp
    advertising srp service: 3812229523780283._matterc._udp
     运行芯片工具时、他是否必须将 Raspberry PIE 连接到 WiFi? 如下图所示:
    谢谢。此致、
    尼克
    芯片工具调试 Matter 设备需要哪些条件?
    我不明白你这么说是什么意思。  Matter 设备日志中没有明显的问题。  您可以通过 Matter\examples\lock-app\cc13x2x7_26x2x7\args.ni 启用其他日志记录
    chip_progress_logging = true
    chip_detail_logging = true
    chip_automation_logging = true
    除非通过 WiFi 运行 Matter (Thread 并非如此)、否则不要求 WiFi、但即使没有互联网连接、您的设备也应连接到路由器。
    瑞安
    您好、Ryan、
    感谢您的持续跟进。
    客户 使用上述方法、并出现一些警告和错误。
    这些问题吗?
    这是否意味着成功?
    应在此命令的后两个参数中写入什么:  ./chip-tool Doorlock lock-door destination-id endent-id-ignored-for-group-commands ?
    谢谢。此致、
    尼克
    前三张图片表明了与 OTBR 建立连接的问题、就像在之前的芯片工具日志中一样。
    下一个图像(从第二个到最后一个)显示了 成功的 Matter 设备调试。
    自述文件中提供了芯片工具与 lock-app 示例交互的示例。  您还可以参考 芯片工具指南。  如果节点是端点1,则可以将这两个参数设置为1以测试您的环境。
    瑞安
    您好、Ryan、
    什么是 属性值 出现什么情况? 文档中未提及。
    ./chip-tool doorlock   <attribute-name> <attribute-values> <destination-id> <endpoint-id-ignored-for-group-commands>
    谢谢。此致、
    尼克
    这取决于所引用的属性名称。  在芯片工具指南的步骤8中有一节介绍了如何读取 Matter 器件信息、lock-app README 提供了写入属性(锁门和解锁门)的示例。  他们还可以参考 Matter 设备规范、了解有关可能的设备类型、属性和命令的更多信息。
    瑞安
    您好、Ryan、
    感谢你的帮助。
    这是什么意思? 是否有必要添加此命令?
    ./chip-tool doorlock set-user 0 1 TST 6452 1 0 0 1 1  --timedInteractionTimeoutMs 1000
    谢谢。此致、
    尼克
    这是 Matter 结构上的命令交互将超时的时间(以毫秒为单位),它应该是可选的,以便您可以测试删除它或增加值。
    瑞安
