[参考译文] CC1352P7:无法创建线程
Guru**** 3031630 points
https://e2e.ti.com/support/wireless-connectivity/zigbee-thread-group/zigbee-and-thread/f/zigbee-thread-forum/1283628/cc1352p7-unable-to-create-thread
器件型号:CC1352P7
您好
我使用的是 LP-CC1352P7-1。
我正在尝试在代码中创建几个线程。 将创建除一个线程之外的所有线程。
在下面的代码中创建的线程:
void B_taskCreate(void)
    pthread_t thread;
    pthread_attr_t attrs;
    struct sched_param priParam;
    int retc;
    /* Initialize the attributes structure with default values */
    pthread_attr_init(&attrs);
    /* Set priority, detach state, and stack size attributes */
    priParam.sched_priority = 5;
    retc  = pthread_attr_setschedparam(&attrs, &priParam);
    retc |= pthread_attr_setdetachstate(&attrs, PTHREAD_CREATE_DETACHED);
    retc |= pthread_attr_setstacksize(&attrs, 1024);
    if (retc != 0)
        /* failed to set attributes */
        while (1) {}
    retc = pthread_create(&thread, &attrs, b_task, NULL);
    if (retc != 0)
        /* pthread_create() failed */
        while (1) {}
    retc = pthread_attr_destroy(&attrs);
未创建的代码是具有不同优先级和例程的相同代码:
void a_taskCreate(void)
    pthread_t thread;
    int retc;
    priParam.sched_priority = A_TASK_PRIORITY;  //priority 3
    if (retc != 0)
        while (1) {}
    retc = pthread_create(&thread, &attrs, a_task, NULL);
    if (retc != 0)
        while (1) {}
在上面的代码中(不创建线程的代码)、下面一行的返回值为22:
这可能是什么原因、如何纠正?
