controlsuilt F28M35 V201 以上的版本 CCS5.5 编译错误
Other Parts Discussed in Thread: CONTROLSUITE
TI employees :
HI ,
下载了controlsuite setup 3.3.7 ,发现F28M35 的例程 V201 以上的版本编译有错误。console 如下所示 :
error: file
"E:/chenna/controlSUITE/device_support/f28m35x_v5/v206/MWare/driverlib/ccs/D
ebug/driverlib.lib<ethernet.obj>" has a Tag_PCS_config attribute value of
"1" that is different than one previously seen ("0"); combining incompatible
files
error: file
ebug/driverlib.lib<flash.obj>" has a Tag_PCS_config attribute value of "1"
files
error: file
ebug/driverlib.lib<gpio.obj>" has a Tag_PCS_config attribute value of "1"
files
error: file
ebug/driverlib.lib<interrupt.obj>" has a Tag_PCS_config attribute value of
files
error: file
ebug/driverlib.lib<sysctl.obj>" has a Tag_PCS_config attribute value of "1"
files
error: file
ebug/driverlib.lib<systick.obj>" has a Tag_PCS_config attribute value of "1"
files
error: file
ebug/driverlib.lib<uart.obj>" has a Tag_PCS_config attribute value of "1"
files
error: file
ebug/driverlib.lib<watchdog.obj>" has a Tag_PCS_config attribute value of
files
error: file
ebug/driverlib.lib<cpu.obj>" has a Tag_PCS_config attribute value of "1"
files
error: errors encountered during linking; "enet_lwip_m3.out" not built
据我分析,可能是 M3 的driver.lib 的版本不对。
请教一下,如何解决这个问题?
  • 没有将controlSUITIE下的工程拷贝到其他地方吧
    相关链接:
    http://www.deyisupport.com/question_answer/microcontrollers/c2000/f/56/t/9470.aspx?keyMatch=driverlib.lib&tisearch=Search-CN-Everything
