老师:
您好!菜鸟最近在学习无刷直流BLDC电机BLDC3-1文档与例程.其中电机驱动库中有hall3_drv模块,此模块目的是根据检测到hall信号决定电机换相信号,其中有一个变量为Stallcount 不知道怎么回事?而且计数那么多次,恳请不吝赐教,感谢您百忙之中的回复!下面附上程序:
void F281X_EV1_HALL3_Debounce(HALL3 *p)
if (p->HallGpio == p->HallGpioAccepted) // GPIO_UNCHANGED: 没变Current GPIO reading == debounced GPIO reading?
if (p->Revolutions <= 0) // Only create hall map during initial Revolutions
F281X_EV1_HALL3_Create_Map(p);
p->StallCount -= 1; // Decrement stall counter
if (p->StallCount == 0)
p->EdgeDebounced = 0x7FFF; // If motor has stalled, then user trigger to commutate
p->StallCount = 0xFFFF; // Reset counter to starting value
else // GPIO_CHANGED: If not zero, then the motor has moved to a new position.
if (p->HallGpio == p->HallGpioBuffer) // Current GPIO reading == previous GPIO reading?
if (p->DebounceCount >= p->DebounceAmount) // If equal, is current GPIO reading debounced?
p->HallGpioAccepted = p->HallGpioBuffer; // Current GPIO reading is now debounced,当前位置已经去抖
p->EdgeDebounced = 0x7FFF; // Edge/position debounced, trigger commutation
p->DebounceCount = 0; // Reset debounce counter
if (p->HallMapPointer==0)
p->Revolutions += 1; // Increment on every rev (HallMapPointer = 0)
else // DEBOUNCE_MORE
p->DebounceCount += 1; // Increment debounce counter
else // NEW_READING
p->HallGpioBuffer = p->HallGpio; // Save new reading and reset debounce counter
