TMS320F28379D: 我在调试CLB与epwm的TZ模块时,出现问题,单独调试的时候,CLB跟TZ都是没问题的,他俩放在一起工作出现TZ覆盖CLB的问题
Part Number: TMS320F28379D
 Copyright (c) 2020 Texas Instruments Incorporated - http://www.ti.com
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 * *  Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 *    its contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "board.h"
// Board Configurations
// Initializes the rest of the modules.
// Call this function in your application if you wish to do all module
// initialization.
// If you wish to not use some of the initializations, instead of the
// Board_init use the individual Module_inits
void Board_init()
    EALLOW;
    PinMux_init();
    INPUTXBAR_init();
    SYNC_init();
    CLB_init();
    CLBXBAR_init();
    EPWM_init();
    EPWMXBAR_init();
    GPIO_init();
    EDIS;
// PINMUX Configurations
void PinMux_init()
    // PinMux for modules assigned to CPU1
    // EPWM1 -> myEPWM1 Pinmux
    GPIO_setPinConfig(myEPWM1_EPWMA_PIN_CONFIG);
    GPIO_setPadConfig(myEPWM1_EPWMA_GPIO, GPIO_PIN_TYPE_STD);
    GPIO_setQualificationMode(myEPWM1_EPWMA_GPIO, GPIO_QUAL_SYNC);
    GPIO_setPinConfig(myEPWM1_EPWMB_PIN_CONFIG);
    GPIO_setPadConfig(myEPWM1_EPWMB_GPIO, GPIO_PIN_TYPE_STD);
    GPIO_setQualificationMode(myEPWM1_EPWMB_GPIO, GPIO_QUAL_SYNC);
    // EPWM3 -> myEPWM3 Pinmux
    GPIO_setPinConfig(myEPWM3_EPWMA_PIN_CONFIG);
    GPIO_setPadConfig(myEPWM3_EPWMA_GPIO, GPIO_PIN_TYPE_STD);
    GPIO_setQualificationMode(myEPWM3_EPWMA_GPIO, GPIO_QUAL_SYNC);
    GPIO_setPinConfig(myEPWM3_EPWMB_PIN_CONFIG);
    GPIO_setPadConfig(myEPWM3_EPWMB_GPIO, GPIO_PIN_TYPE_STD);
    GPIO_setQualificationMode(myEPWM3_EPWMB_GPIO, GPIO_QUAL_SYNC);
    // EPWM2 -> myEPWM2 Pinmux
    GPIO_setPinConfig(myEPWM2_EPWMA_PIN_CONFIG);
    GPIO_setPadConfig(myEPWM2_EPWMA_GPIO, GPIO_PIN_TYPE_STD);
    GPIO_setQualificationMode(myEPWM2_EPWMA_GPIO, GPIO_QUAL_SYNC);
    GPIO_setPinConfig(myEPWM2_EPWMB_PIN_CONFIG);
    GPIO_setPadConfig(myEPWM2_EPWMB_GPIO, GPIO_PIN_TYPE_STD);
    GPIO_setQualificationMode(myEPWM2_EPWMB_GPIO, GPIO_QUAL_SYNC);
    // GPIO29 -> myGPIO29 Pinmux
    GPIO_setPinConfig(GPIO_29_GPIO29);
// CLB Configurations
void CLB_init(){
    myCLB1_init();
    myCLB2_init();
void myCLB1_init(){
    CLB_setOutputMask(myCLB1_BASE,
                (0UL << 0UL) |
                (1UL << 2UL), true);
    // myCLB1 CLB_IN0 initialization
    // The following functions configure the CLB input mux and whether the inputs
    // have synchronization or pipeline enabled; check the device manual for more
    // information on when a signal needs to be synchronized or go through a
    // pipeline filter
    CLB_configLocalInputMux(myCLB1_BASE, CLB_IN0, CLB_LOCAL_IN_MUX_GLOBAL_IN);
    CLB_configGlobalInputMux(myCLB1_BASE, CLB_IN0, CLB_GLOBAL_IN_MUX_CLB_AUXSIG0);
    CLB_configGPInputMux(myCLB1_BASE, CLB_IN0, CLB_GP_IN_MUX_EXTERNAL);
    CLB_enableSynchronization(myCLB1_BASE, CLB_IN0);
    CLB_selectInputFilter(myCLB1_BASE, CLB_IN0, CLB_FILTER_NONE);
    // myCLB1 CLB_IN1 initialization
    // pipeline filter
    CLB_configLocalInputMux(myCLB1_BASE, CLB_IN1, CLB_LOCAL_IN_MUX_GLOBAL_IN);
    CLB_configGlobalInputMux(myCLB1_BASE, CLB_IN1, CLB_GLOBAL_IN_MUX_CLB_AUXSIG0);
    CLB_configGPInputMux(myCLB1_BASE, CLB_IN1, CLB_GP_IN_MUX_EXTERNAL);
    CLB_enableSynchronization(myCLB1_BASE, CLB_IN1);
    CLB_selectInputFilter(myCLB1_BASE, CLB_IN1, CLB_FILTER_RISING_EDGE);
    // myCLB1 CLB_IN2 initialization
    // pipeline filter
    CLB_configLocalInputMux(myCLB1_BASE, CLB_IN2, CLB_LOCAL_IN_MUX_GLOBAL_IN);
    CLB_configGlobalInputMux(myCLB1_BASE, CLB_IN2, CLB_GLOBAL_IN_MUX_EPWM1B);
    CLB_configGPInputMux(myCLB1_BASE, CLB_IN2, CLB_GP_IN_MUX_EXTERNAL);
    CLB_enableSynchronization(myCLB1_BASE, CLB_IN2);
    CLB_selectInputFilter(myCLB1_BASE, CLB_IN2, CLB_FILTER_NONE);
    CLB_setGPREG(myCLB1_BASE,0);
    initTILE1(myCLB1_BASE);
    CLB_enableCLB(myCLB1_BASE);
void myCLB2_init(){
    CLB_setOutputMask(myCLB2_BASE,
                (0UL << 0UL) |
    // myCLB2 CLB_IN0 initialization
    // pipeline filter
    CLB_configLocalInputMux(myCLB2_BASE, CLB_IN0, CLB_LOCAL_IN_MUX_GLOBAL_IN);
    CLB_configGlobalInputMux(myCLB2_BASE, CLB_IN0, CLB_GLOBAL_IN_MUX_CLB_AUXSIG0);
    CLB_configGPInputMux(myCLB2_BASE, CLB_IN0, CLB_GP_IN_MUX_EXTERNAL);
    CLB_enableSynchronization(myCLB2_BASE, CLB_IN0);
    CLB_selectInputFilter(myCLB2_BASE, CLB_IN0, CLB_FILTER_NONE);
    // myCLB2 CLB_IN1 initialization
    // pipeline filter
    CLB_configLocalInputMux(myCLB2_BASE, CLB_IN1, CLB_LOCAL_IN_MUX_GLOBAL_IN);
    CLB_configGlobalInputMux(myCLB2_BASE, CLB_IN1, CLB_GLOBAL_IN_MUX_CLB_AUXSIG0);
    CLB_configGPInputMux(myCLB2_BASE, CLB_IN1, CLB_GP_IN_MUX_EXTERNAL);
    CLB_enableSynchronization(myCLB2_BASE, CLB_IN1);
    CLB_selectInputFilter(myCLB2_BASE, CLB_IN1, CLB_FILTER_RISING_EDGE);
    // myCLB2 CLB_IN2 initialization
    // pipeline filter
    CLB_configLocalInputMux(myCLB2_BASE, CLB_IN2, CLB_LOCAL_IN_MUX_GLOBAL_IN);
    CLB_configGlobalInputMux(myCLB2_BASE, CLB_IN2, CLB_GLOBAL_IN_MUX_EPWM2B);
    CLB_configGPInputMux(myCLB2_BASE, CLB_IN2, CLB_GP_IN_MUX_EXTERNAL);
    CLB_enableSynchronization(myCLB2_BASE, CLB_IN2);
    CLB_selectInputFilter(myCLB2_BASE, CLB_IN2, CLB_FILTER_NONE);
    CLB_setGPREG(myCLB2_BASE,0);
    initTILE2(myCLB2_BASE);
    CLB_enableCLB(myCLB2_BASE);
// CLBXBAR Configurations
void CLBXBAR_init(){
    myCLBXBAR0_init();
void myCLBXBAR0_init(){
    XBAR_setCLBMuxConfig(myCLBXBAR0, XBAR_CLB_MUX01_INPUTXBAR1);
    XBAR_enableCLBMux(myCLBXBAR0, myCLBXBAR0_ENABLED_MUXES);
// EPWM Configurations
void EPWM_init(){
    EPWM_setClockPrescaler(myEPWM1_BASE, EPWM_CLOCK_DIVIDER_1, EPWM_HSCLOCK_DIVIDER_1);
    EPWM_setTimeBasePeriod(myEPWM1_BASE, 1250);
    EPWM_setTimeBaseCounter(myEPWM1_BASE, 0);
    EPWM_setTimeBaseCounterMode(myEPWM1_BASE, EPWM_COUNTER_MODE_UP_DOWN);
    EPWM_disablePhaseShiftLoad(myEPWM1_BASE);
    EPWM_setPhaseShift(myEPWM1_BASE, 0);
    EPWM_setCounterCompareValue(myEPWM1_BASE, EPWM_COUNTER_COMPARE_A, 625);
    EPWM_setCounterCompareShadowLoadMode(myEPWM1_BASE, EPWM_COUNTER_COMPARE_A, EPWM_COMP_LOAD_ON_CNTR_ZERO);
    EPWM_setCounterCompareValue(myEPWM1_BASE, EPWM_COUNTER_COMPARE_B, 0);
    EPWM_setCounterCompareShadowLoadMode(myEPWM1_BASE, EPWM_COUNTER_COMPARE_B, EPWM_COMP_LOAD_ON_CNTR_ZERO);
    EPWM_setActionQualifierShadowLoadMode(myEPWM1_BASE, EPWM_ACTION_QUALIFIER_A, EPWM_AQ_LOAD_ON_CNTR_PERIOD);
    EPWM_setActionQualifierContSWForceAction(myEPWM1_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_SW_OUTPUT_LOW);
    EPWM_setActionQualifierAction(myEPWM1_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
    EPWM_setActionQualifierAction(myEPWM1_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
    EPWM_setActionQualifierAction(myEPWM1_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
    EPWM_setActionQualifierAction(myEPWM1_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
    EPWM_setActionQualifierAction(myEPWM1_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPB);
    EPWM_setActionQualifierAction(myEPWM1_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPB);
    EPWM_setActionQualifierShadowLoadMode(myEPWM1_BASE, EPWM_ACTION_QUALIFIER_B, EPWM_AQ_LOAD_ON_CNTR_PERIOD);
    EPWM_setActionQualifierContSWForceAction(myEPWM1_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_SW_OUTPUT_HIGH);
    EPWM_setActionQualifierAction(myEPWM1_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
    EPWM_setActionQualifierAction(myEPWM1_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
    EPWM_setActionQualifierAction(myEPWM1_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
    EPWM_setActionQualifierAction(myEPWM1_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
    EPWM_setActionQualifierAction(myEPWM1_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPB);
    EPWM_setActionQualifierAction(myEPWM1_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPB);
    EPWM_setDeadBandDelayPolarity(myEPWM1_BASE, EPWM_DB_FED, EPWM_DB_POLARITY_ACTIVE_LOW);
    EPWM_setDeadBandDelayMode(myEPWM1_BASE, EPWM_DB_RED, true);
    EPWM_setRisingEdgeDelayCountShadowLoadMode(myEPWM1_BASE, EPWM_RED_LOAD_ON_CNTR_ZERO);
    EPWM_setRisingEdgeDelayCount(myEPWM1_BASE, 50);
    EPWM_setDeadBandDelayMode(myEPWM1_BASE, EPWM_DB_FED, true);
    EPWM_setFallingEdgeDelayCountShadowLoadMode(myEPWM1_BASE, EPWM_FED_LOAD_ON_CNTR_ZERO);
    EPWM_setFallingEdgeDelayCount(myEPWM1_BASE, 50);
    EPWM_setTripZoneAction(myEPWM1_BASE, EPWM_TZ_ACTION_EVENT_TZA, EPWM_TZ_ACTION_LOW);
    EPWM_setTripZoneAction(myEPWM1_BASE, EPWM_TZ_ACTION_EVENT_TZB, EPWM_TZ_ACTION_LOW);
    EPWM_enableTripZoneSignals(myEPWM1_BASE, EPWM_TZ_SIGNAL_DCAEVT2);
    EPWM_enableTripZoneInterrupt(myEPWM1_BASE, EPWM_TZ_INTERRUPT_CBC);
    EPWM_selectDigitalCompareTripInput(myEPWM1_BASE, EPWM_DC_TRIP_TRIPIN4, EPWM_DC_TYPE_DCAH);
    EPWM_setTripZoneDigitalCompareEventCondition(myEPWM1_BASE, EPWM_TZ_DC_OUTPUT_A2, EPWM_TZ_EVENT_DCXH_LOW);
    EPWM_setTripZoneDigitalCompareEventCondition(myEPWM1_BASE, EPWM_TZ_DC_OUTPUT_B2, EPWM_TZ_EVENT_DCXL_LOW);
    EPWM_setClockPrescaler(myEPWM3_BASE, EPWM_CLOCK_DIVIDER_1, EPWM_HSCLOCK_DIVIDER_1);
    EPWM_setTimeBasePeriod(myEPWM3_BASE, 10000);
    EPWM_setTimeBaseCounter(myEPWM3_BASE, 0);
    EPWM_setTimeBaseCounterMode(myEPWM3_BASE, EPWM_COUNTER_MODE_UP_DOWN);
    EPWM_disablePhaseShiftLoad(myEPWM3_BASE);
    EPWM_setPhaseShift(myEPWM3_BASE, 0);
    EPWM_setCounterCompareValue(myEPWM3_BASE, EPWM_COUNTER_COMPARE_A, 1200);
    EPWM_setCounterCompareShadowLoadMode(myEPWM3_BASE, EPWM_COUNTER_COMPARE_A, EPWM_COMP_LOAD_ON_CNTR_ZERO);
    EPWM_setCounterCompareValue(myEPWM3_BASE, EPWM_COUNTER_COMPARE_B, 0);
    EPWM_setCounterCompareShadowLoadMode(myEPWM3_BASE, EPWM_COUNTER_COMPARE_B, EPWM_COMP_LOAD_ON_CNTR_ZERO);
    EPWM_setActionQualifierShadowLoadMode(myEPWM3_BASE, EPWM_ACTION_QUALIFIER_A, EPWM_AQ_LOAD_ON_CNTR_PERIOD);
    EPWM_setActionQualifierContSWForceAction(myEPWM3_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_SW_OUTPUT_LOW);
    EPWM_setActionQualifierAction(myEPWM3_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
    EPWM_setActionQualifierAction(myEPWM3_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
    EPWM_setActionQualifierAction(myEPWM3_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
    EPWM_setActionQualifierAction(myEPWM3_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
    EPWM_setActionQualifierAction(myEPWM3_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPB);
    EPWM_setActionQualifierAction(myEPWM3_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPB);
    EPWM_setActionQualifierShadowLoadMode(myEPWM3_BASE, EPWM_ACTION_QUALIFIER_B, EPWM_AQ_LOAD_ON_CNTR_PERIOD);
    EPWM_setActionQualifierContSWForceAction(myEPWM3_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_SW_OUTPUT_HIGH);
    EPWM_setActionQualifierAction(myEPWM3_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
    EPWM_setActionQualifierAction(myEPWM3_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
    EPWM_setActionQualifierAction(myEPWM3_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
    EPWM_setActionQualifierAction(myEPWM3_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
    EPWM_setActionQualifierAction(myEPWM3_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPB);
    EPWM_setActionQualifierAction(myEPWM3_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPB);
    EPWM_setDeadBandDelayPolarity(myEPWM3_BASE, EPWM_DB_FED, EPWM_DB_POLARITY_ACTIVE_LOW);
    EPWM_setDeadBandDelayMode(myEPWM3_BASE, EPWM_DB_RED, true);
    EPWM_setRisingEdgeDelayCountShadowLoadMode(myEPWM3_BASE, EPWM_RED_LOAD_ON_CNTR_ZERO);
    EPWM_setRisingEdgeDelayCount(myEPWM3_BASE, 10);
    EPWM_setDeadBandDelayMode(myEPWM3_BASE, EPWM_DB_FED, true);
    EPWM_setFallingEdgeDelayCountShadowLoadMode(myEPWM3_BASE, EPWM_FED_LOAD_ON_CNTR_ZERO);
    EPWM_setFallingEdgeDelayCount(myEPWM3_BASE, 10);
    EPWM_setClockPrescaler(myEPWM2_BASE, EPWM_CLOCK_DIVIDER_1, EPWM_HSCLOCK_DIVIDER_1);
    EPWM_setTimeBasePeriod(myEPWM2_BASE, 1250);
    EPWM_setTimeBaseCounter(myEPWM2_BASE, 0);
    EPWM_setTimeBaseCounterMode(myEPWM2_BASE, EPWM_COUNTER_MODE_UP_DOWN);
    EPWM_disablePhaseShiftLoad(myEPWM2_BASE);
    EPWM_setPhaseShift(myEPWM2_BASE, 0);
    EPWM_setCounterCompareValue(myEPWM2_BASE, EPWM_COUNTER_COMPARE_A, 625);
    EPWM_setCounterCompareShadowLoadMode(myEPWM2_BASE, EPWM_COUNTER_COMPARE_A, EPWM_COMP_LOAD_ON_CNTR_ZERO);
    EPWM_setCounterCompareValue(myEPWM2_BASE, EPWM_COUNTER_COMPARE_B, 0);
    EPWM_setCounterCompareShadowLoadMode(myEPWM2_BASE, EPWM_COUNTER_COMPARE_B, EPWM_COMP_LOAD_ON_CNTR_ZERO);
    EPWM_setActionQualifierShadowLoadMode(myEPWM2_BASE, EPWM_ACTION_QUALIFIER_A, EPWM_AQ_LOAD_ON_CNTR_PERIOD);
    EPWM_setActionQualifierContSWForceAction(myEPWM2_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_SW_OUTPUT_LOW);
    EPWM_setActionQualifierAction(myEPWM2_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
    EPWM_setActionQualifierAction(myEPWM2_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
    EPWM_setActionQualifierAction(myEPWM2_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
    EPWM_setActionQualifierAction(myEPWM2_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
    EPWM_setActionQualifierAction(myEPWM2_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPB);
    EPWM_setActionQualifierAction(myEPWM2_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPB);
    EPWM_setActionQualifierShadowLoadMode(myEPWM2_BASE, EPWM_ACTION_QUALIFIER_B, EPWM_AQ_LOAD_ON_CNTR_PERIOD);
    EPWM_setActionQualifierContSWForceAction(myEPWM2_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_SW_OUTPUT_HIGH);
    EPWM_setActionQualifierAction(myEPWM2_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
    EPWM_setActionQualifierAction(myEPWM2_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
    EPWM_setActionQualifierAction(myEPWM2_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
    EPWM_setActionQualifierAction(myEPWM2_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
    EPWM_setActionQualifierAction(myEPWM2_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPB);
    EPWM_setActionQualifierAction(myEPWM2_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPB);
    EPWM_setDeadBandDelayPolarity(myEPWM2_BASE, EPWM_DB_FED, EPWM_DB_POLARITY_ACTIVE_LOW);
    EPWM_setDeadBandDelayMode(myEPWM2_BASE, EPWM_DB_RED, true);
    EPWM_setRisingEdgeDelayCountShadowLoadMode(myEPWM2_BASE, EPWM_RED_LOAD_ON_CNTR_ZERO);
    EPWM_setRisingEdgeDelayCount(myEPWM2_BASE, 50);
    EPWM_setDeadBandDelayMode(myEPWM2_BASE, EPWM_DB_FED, true);
    EPWM_setFallingEdgeDelayCountShadowLoadMode(myEPWM2_BASE, EPWM_FED_LOAD_ON_CNTR_ZERO);
    EPWM_setFallingEdgeDelayCount(myEPWM2_BASE, 50);
    EPWM_setTripZoneAction(myEPWM2_BASE, EPWM_TZ_ACTION_EVENT_TZA, EPWM_TZ_ACTION_LOW);
    EPWM_setTripZoneAction(myEPWM2_BASE, EPWM_TZ_ACTION_EVENT_TZB, EPWM_TZ_ACTION_LOW);
    EPWM_enableTripZoneSignals(myEPWM2_BASE, EPWM_TZ_SIGNAL_DCBEVT2);
    EPWM_enableTripZoneInterrupt(myEPWM2_BASE, EPWM_TZ_INTERRUPT_CBC);
    EPWM_selectDigitalCompareTripInput(myEPWM2_BASE, EPWM_DC_TRIP_TRIPIN4, EPWM_DC_TYPE_DCAH);
    EPWM_setTripZoneDigitalCompareEventCondition(myEPWM2_BASE, EPWM_TZ_DC_OUTPUT_A2, EPWM_TZ_EVENT_DCXH_LOW);
    EPWM_setTripZoneDigitalCompareEventCondition(myEPWM2_BASE, EPWM_TZ_DC_OUTPUT_B2, EPWM_TZ_EVENT_DCXL_LOW);
// EPWMXBAR Configurations
void EPWMXBAR_init(){
    myEPWMXBAR0_init();
void myEPWMXBAR0_init(){
    XBAR_setEPWMMuxConfig(myEPWMXBAR0, XBAR_EPWM_MUX01_INPUTXBAR1);
    XBAR_enableEPWMMux(myEPWMXBAR0, XBAR_MUX01);
// GPIO Configurations
void GPIO_init(){
    myGPIO29_init();
void myGPIO29_init(){
    GPIO_setPadConfig(myGPIO29, GPIO_PIN_TYPE_STD);
    GPIO_setQualificationMode(myGPIO29, GPIO_QUAL_SYNC);
    GPIO_setDirectionMode(myGPIO29, GPIO_DIR_MODE_IN);
    GPIO_setControllerCore(myGPIO29, GPIO_CORE_CPU1);
// INPUTXBAR Configurations
void INPUTXBAR_init(){
    myINPUTXBARINPUT1_init();
void myINPUTXBARINPUT1_init(){
    XBAR_setInputPin(myINPUTXBARINPUT1_INPUT, myINPUTXBARINPUT1_SOURCE);
// SYNC Scheme Configurations
void SYNC_init(){
    SysCtl_setSyncOutputConfig(SYSCTL_SYNC_OUT_SRC_EPWM1SYNCOUT);
    // For EPWM1, the sync input is: SYSCTL_SYNC_IN_SRC_EXTSYNCIN1
    SysCtl_setSyncInputConfig(SYSCTL_SYNC_IN_EPWM4, SYSCTL_SYNC_IN_SRC_EPWM1SYNCOUT);
    SysCtl_setSyncInputConfig(SYSCTL_SYNC_IN_EPWM7, SYSCTL_SYNC_IN_SRC_EPWM1SYNCOUT);
    SysCtl_setSyncInputConfig(SYSCTL_SYNC_IN_EPWM10, SYSCTL_SYNC_IN_SRC_EPWM1SYNCOUT);
    SysCtl_setSyncInputConfig(SYSCTL_SYNC_IN_ECAP1, SYSCTL_SYNC_IN_SRC_EPWM1SYNCOUT);
    SysCtl_setSyncInputConfig(SYSCTL_SYNC_IN_ECAP4, SYSCTL_SYNC_IN_SRC_EPWM1SYNCOUT);
    // SOCA
    SysCtl_enableExtADCSOCSource(0);
    // SOCB
