I have purchased the TMS320F28P55. Are there additional resources about its NPU capabilities, and how to deploy models on this development board? Are there any relevant documents or videos available?
I can tell how to use it for Arc fault solution. U need to train the model using Edge AI studio dev.ti.com/.../ After training, you can also compile the the trained model using the same platform. Once you have the compiled model, you integrate the compiled files in the CCS project. The CCS project is is available in the latest DPSDK as TIDA010955. For more details, please refer to the attached user guide for arc fault solution.
Amir Hussaintida_010955_sw.pdf
