按照TI推荐的电路,设计了F28069和AFE031芯片的SPI接口使用了F28069的SPI-B信号,其中SPISIMO信号选择了使用Pin77(80Pin的F28069,77脚为GPIO24).
SPI-B的管脚定义如下:
GpioCtrlRegs.GPAPUD.bit.GPIO24 = 0; // Enable pullup on GPIO24 (SPISIMOB)
GpioCtrlRegs.GPAPUD.bit.GPIO13 = 0; // Enable pullup on GPIO13 (SPISOMIB)
GpioCtrlRegs.GPAPUD.bit.GPIO14 = 0; // Enable pullup on GPIO14 (***)
GpioCtrlRegs.GPAPUD.bit.GPIO15 = 0; // Enable pullup on GPIO15 (SPISTEB)
GpioCtrlRegs.GPAQSEL2.bit.GPIO24 = 3; // asynch input
GpioCtrlRegs.GPAQSEL1.bit.GPIO13 = 3; // asynch input
GpioCtrlRegs.GPAQSEL1.bit.GPIO14 = 3; // asynch input
GpioCtrlRegs.GPAQSEL1.bit.GPIO15 = 3; // asynch input
GpioCtrlRegs.GPAMUX2.bit.GPIO24 = 3; // GPIO24 = SPISIMOB
GpioCtrlRegs.GPAMUX1.bit.GPIO13 = 3; // GPIO13 = SPISOMIB
GpioCtrlRegs.GPAMUX1.bit.GPIO14 = 3; // GPIO14 = ***
GpioCtrlRegs.GPAMUX1.bit.GPIO15 = 3; // GPIO15 = SPISTEB
SPI-B的寄存器配置如下:
SpibRegs.***.bit.SPISWRESET = 0; // reset SPISTS to clear flags
SpibRegs.***.bit.CLKPOLARITY = 0; // data is output on rising edge and input on falling edge.
SpibRegs.***.bit.SPILBK = 0; // disables SPI loopback
SpibRegs.***.bit.*** = 0xF; // character length is 16, adapt to the input bit length of AFE031.
SpibRegs.SPIBRR = 0x007F; // SYSCLKOUT: 80MHz, LSPCLK: 20MHz, SPI Baud Rate: ??Mbps
SpibRegs.***.bit.MASTER_SLAVE = 1; // master mode
SpibRegs.***.bit.TALK = 1; // enables sent data ???
SpibRegs.***.bit.CLK_PHASE = 1; // half-cycle delay
SpibRegs.***.bit.SPIINTENA = 0; // disables interrupt
SpibRegs.***.bit.OVERRUNINTENA = 0; // disables receiver overrun flag
SpibRegs.SPIFFTX.all = 0x0000; // disable SPI FIFO enhancements
SpibRegs.SPIFFRX.all = 0x0000;
SpibRegs.SPIPRI.bit.FREE = 1; // Free run
SpibRegs.***.bit.SPISWRESET = 1; // ready to transmit or receive
编译通过顺利加载,可以看到系统时钟部分的配置完成(锁相环已经锁定),上述的配置已经写入寄存器,发送数据也写入到SPITXBUF和SPIDAT,但管脚上就是没有信号。请问这是什么问题?谢谢!
