I have installed the MCU-MOTOR-CONTROL-GUI, but I am unable to open it on my laptop. The system is Windows 11.When I double-click or run it as administrator, the screen goes black for a moment and then nothing happens.
Hi Vivian
Gao I've checked out this post, but unfortunately, I still can't find a solution to this problem. Thanks anyway.
Hi Vivian Gao I've checked out this post, but unfortunately, I still can't find a solution to this problem. Thanks anyway.
The above link attempts different versions of GUI. If your issue still persists, please try using a PC with a different system.
The installation packages for GUI are all the same, so we need a PC that is more compatible
