CCS5.5运行的工程文件出现的问题
Description Resource Path Location Type
cannot find file DCMotor_TI C/C++ Problem
no valid memory range(NULL) available for placement of ".text" DCMotor_TI C/C++ Problem
program will not fit into available memory. run placement with DCMotor_TI C/C++ Problem
program will not fit into available memory. placement with DCMotor_TI C/C++ Problem
errors encountered during linking; "DCMotor.out" not built DCMotor_TI C/C++ Problem
