TMX320F28377S可支持加密功能吗
请问TMX320F28377S可支持加密功能吗?
  • 可以,你可以参考userguide的DCSM模块
    The dual code security module (DCSM) is a security feature incorporated in this device. It prevents access
    and visibility to on-chip secure memories (and other secure resources) to unauthorized persons. It also
    prevents duplication and reverse engineering of proprietary code. The term “secure” implies access to on-
    chip secure memories and resources are blocked. The term “unsecure” implies access is allowed (the
    contents of the memory could be read by any means); for example, through a debugging tool such as
    Code Composer Studio™.
    The CPU subsystem's CSM has dual-zone security, zone1 and zone2.
