Part Number: TMS320F280025
Can the value of the PHSDIR register be modified in real time within an interrupt? I have attempted this and found that the corresponding ePWM module directly outputs a high level instead of a PWM signal with a specific duty cycle. If the value of PHSDIR is not modified in the interrupt service routine, a normal PWM signal can be generated properly.
