用的芯片是F2812.编译没有报错,但是无.out文件生成,CDT Build Console显示临时文件有错,求指导!CDT Build Console详细信息如下:
| **** Build of configuration Debug for project SRMC **** "C:\\ti\\ccsv6\\utils\\bin\\gmake" -k all 'Building file: ../main.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="main.pp" "../main.c" "C:\Users\CAIHAI~1\AppData\Local\Temp\0762010", ERROR! at line 343: [E0003] Syntax error - Operand 1 OUT 1, 000ch "C:\Users\CAIHAI~1\AppData\Local\Temp\0762010", ERROR! at line 349: [E0003] Syntax error - Operand 1 OUT 0, 000ch 2 Assembly Errors, No Assembly Warnings Errors in Source - Assembler Aborted >> Compilation failure gmake: *** [main.obj] Error 1 'Building file: ../srm.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="srm.pp" "../srm.c" 'Finished building: ../srm.c' ' ' 'Building file: ../source/DSP28_Adc.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_Adc.pp" --obj_directory="source" "../source/DSP28_Adc.c" 'Finished building: ../source/DSP28_Adc.c' ' ' 'Building file: ../source/DSP28_DefaultIsr.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_DefaultIsr.pp" --obj_directory="source" "../source/DSP28_DefaultIsr.c" 'Finished building: ../source/DSP28_DefaultIsr.c' ' ' 'Building file: ../source/DSP28_Ev.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_Ev.pp" --obj_directory="source" "../source/DSP28_Ev.c" 'Finished building: ../source/DSP28_Ev.c' ' ' 'Building file: ../source/DSP28_GlobalVariableDefs.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_GlobalVariableDefs.pp" --obj_directory="source" "../source/DSP28_GlobalVariableDefs.c" 'Finished building: ../source/DSP28_GlobalVariableDefs.c' ' ' 'Building file: ../source/DSP28_Gpio.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_Gpio.pp" --obj_directory="source" "../source/DSP28_Gpio.c" 'Finished building: ../source/DSP28_Gpio.c' ' ' 'Building file: ../source/DSP28_InitPeripherals.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_InitPeripherals.pp" --obj_directory="source" "../source/DSP28_InitPeripherals.c" 'Finished building: ../source/DSP28_InitPeripherals.c' ' ' 'Building file: ../source/DSP28_PieCtrl.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_PieCtrl.pp" --obj_directory="source" "../source/DSP28_PieCtrl.c" 'Finished building: ../source/DSP28_PieCtrl.c' ' ' 'Building file: ../source/DSP28_PieVect.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_PieVect.pp" --obj_directory="source" "../source/DSP28_PieVect.c" 'Finished building: ../source/DSP28_PieVect.c' ' ' 'Building file: ../source/DSP28_SysCtrl.c' 'Invoking: C2000 Compiler' "C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/bin/cl2000" -v28 -ml -mt --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_6.4.6/include" --include_path="D:/SRMC" --include_path="D:/SRMC/include" --advice:performance=all -g --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="source/DSP28_SysCtrl.pp" --obj_directory="source" "../source/DSP28_SysCtrl.c" 'Finished building: ../source/DSP28_SysCtrl.c' ' ' gmake: Target `all' not remade because of errors. **** Build Finished **** |
