TMS320F280049: tidm_hv_1ph_dcac
Part Number: TMS320F280049
Other Parts Discussed in Thread: C2000WARE, SFRA, SYSCONFIG, POWERSUITE
Hello,
when I imported the project voltageSourceInverterLCFltr_F28004x from the tidm_hv_1ph_dcac project, an error occurred. I would like to ask how to solve this issue.
However, when I import voltageSourceInverterLCFltr_nonpowerSUITE_F28004x, it compiles successfully.
**** Clean-only build of configuration RELEASE for project voltageSourceInverterLCFltr_F28004x ****
"D:\\software\\CCS\\ccs\\utils\\bin\\gmake" -k -j 12 clean -O
DEL /F  "syscfg\board.h" "syscfg\board.cmd.genlibs" "syscfg\board.json" "syscfg\pinmux.csv" "syscfg\c2000ware_libraries.cmd.genlibs" "syscfg\c2000ware_libraries.h" "syscfg\clocktree.h" "D:\software\CCS_workspace_v12\voltageSourceInverterLCFltr_F28004x\Kit.json"  "syscfg\board.c" "syscfg\board.opt" "syscfg\c2000ware_libraries.opt" "syscfg\c2000ware_libraries.c"  "voltageSourceInverterLCFltr_F28004x.out"
DEL /F "hv1phdcac_board.obj" "syscfg\board.obj" "syscfg\c2000ware_libraries.obj" "voltagesourceinvlcfltr.obj" "device\device.obj" "device\f28004x_codestartbranch.obj" "libraries\DCL\source\DCL_DF22_C1.obj" "libraries\DCL\source\DCL_PI_C4.obj" "libraries\sfra\sfra_gui_scicomms_driverlib.obj"
DEL /F "hv1phdcac_board.d" "syscfg\board.d" "syscfg\c2000ware_libraries.d" "voltagesourceinvlcfltr.d" "device\device.d" "libraries\sfra\sfra_gui_scicomms_driverlib.d"
DEL /F "device\f28004x_codestartbranch.d" "libraries\DCL\source\DCL_DF22_C1.d" "libraries\DCL\source\DCL_PI_C4.d"
RMDIR /S/Q  "syscfg"
找不到 D:\software\CCS_workspace_v12\voltageSourceInverterLCFltr_F28004x\RELEASE\device\f28004x_codestartbranch.d
找不到 D:\software\CCS_workspace_v12\voltageSourceInverterLCFltr_F28004x\RELEASE\libraries\DCL\source\DCL_DF22_C1.d
Finished clean
**** Build Finished ****
**** Build of configuration RELEASE for project voltageSourceInverterLCFltr_F28004x ****
"D:\\software\\CCS\\ccs\\utils\\bin\\gmake" -k -j 12 all -O
Building file: "../main.syscfg"
Invoking: SysConfig
"D:/software/CCS/ccs/utils/sysconfig_1.21.0/sysconfig_cli.bat" --script "D:/software/CCS_workspace_v12/voltageSourceInverterLCFltr_F28004x/main.syscfg" -o "syscfg" -s "C:/ti/c2000/C2000Ware_DigitalPower_SDK_5_06_00_00/powerSUITE/.metadata/product.json" -d "F28004x" --compiler ccs
Running script...
subdir_rules.mk:16: recipe for target 'build-1096267823' failed
Ignoring the following missing components: /transfer/transferCommon.js
Error: Exception occurred calling scripting.addModule()
    at Object.addModule (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\src\pinmux\services\scripting\scriptingGuard.ts:46:10)
    at scriptFunc (D:\software\CCS_workspace_v12\voltageSourceInverterLCFltr_F28004x\main.syscfg:12:31)
    at cb (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\src\pinmux\services\scripting\runScript.ts:113:7)
    at withDeprecatedAccess (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\src\pinmux\services\deprecatedAccessGuard.ts:14:10)
    at runAsUserScript (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\src\pinmux\services\scripting\scriptingGuard.ts:61:3)
    at iteratee (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\src\pinmux\services\scripting\runScript.ts:111:5)
    at baseEach (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\node_modules\lodash\lodash.js:530:11)
    at Function.each (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\node_modules\lodash\lodash.js:9409:52)
    at iteratee (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\src\pinmux\services\scripting\runScript.ts:109:6)
    at Pt (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\node_modules\lodash\lodash.js:530:11)
Caused by: Error: No such resource: /Kit.json
Paths searched:
C:\ti\c2000\C2000Ware_DigitalPower_SDK_5_06_00_00\powerSUITE\source\Kit.json
C:\ti\c2000\C2000Ware_DigitalPower_SDK_5_06_00_00\powerSUITE\source\.meta\Kit.json
C:\ti\c2000\C2000Ware_DigitalPower_SDK_5_06_00_00\powerSUITE\.metadata\Kit.json
C:\ti\c2000\C2000Ware_DigitalPower_SDK_5_06_00_00\powerSUITE\.metadata\.meta\Kit.json
C:\ti\c2000\C2000Ware_DigitalPower_SDK_5_06_00_00\c2000ware\Kit.json
C:\ti\c2000\C2000Ware_DigitalPower_SDK_5_06_00_00\c2000ware\.meta\Kit.json
D:\software\CCS_workspace_v12\voltageSourceInverterLCFltr_F28004x\.meta\Kit.json
    at t.ResourceLoader.findPathAndLoader (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\src\pinmux\services\resources\metaContentLoaders\resourceLoader.ts:287:11)
    at t.ResourceLoader.loadResource (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\src\pinmux\services\resources\metaContentLoaders\resourceLoader.ts:230:43)
    at t.ResourceLoader.getResource (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\src\pinmux\services\resources\metaContentLoaders\resourceLoader.ts:338:15)
    at Object.getScript (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\src\pinmux\services\resources\runtime.ts:103:25)
    at loaderFunc (C:\ti\c2000\C2000Ware_DigitalPower_SDK_5_06_00_00\powerSUITE\source\devkits\.meta\HV_1PH_DCAC\HV_1PH_DCAC.syscfg.js:55:25)
    at func (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\src\pinmux\services\resources\metaContentLoaders\resourceLoader.ts:238:45)
    at internalBoundary (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\src\pinmux\services\niceExceptions.ts:53:10)
    at t.ResourceLoader.loadResource (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\src\pinmux\services\resources\metaContentLoaders\resourceLoader.ts:238:22)
    at K.loadModule (D:\software\CCS\ccs\utils\sysconfig_1.21.0\dist\webpack:\sysconfig\src\pinmux\services\resources\runtime.ts:564:27)
gmake: *** [build-1096267823] Error 1
gmake: Target 'all' not remade because of errors.
