咨询一下F28335中断时FPU寄存器的情况
datasheet里面没有提到FPU寄存器会自动保存,但是有一个地方这么写的
All of the floating-point registers except the repeat block register are shadowed. This shadowing can be used in high priority interrupts for fast context save and restore of the floating-point registers.
是不是说,fpu的寄存器其实还是要手工保存的,汇编里面也有一个save 和 restore的命令,是不是这样就可以了呢?
