在调试ADC模块,子程序和主程序 都有 Uint16 Voltage1[3] 变量,在ram里运行 正常,但把CMD文件 改成28062.cmd 后 就报错了。
报错位置: .econst : > FLASHA, PAGE = 0
报错内容:
Description Resource Path Location Type
<a href="processors.wiki.ti.com/.../10099"> program will not fit into available memory. placement with alignment/blocking fails for section ".econst" size 0x292 page 0. Available memory ranges: F28062.cmd /05SCI_Int_Timer161210B line 153 C/C++ Problem
