错误提示:
C28xx: Flash Programmer: Warning: The configured device (TMS320F28062), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx: Failed CPU Reset: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.407.3)
C28xx: Trouble Reading Register PC: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.407.3)
C28xx: Trouble Reading Register ST1: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.407.3)
C28xx: GEL: Error while executing OnReset(1): Target failed to read register ST1
at (ST1&~(0x0100)) [f28062.gel:299]
at C28x_Mode() [f28062.gel:32]
at OnReset(1)
C28xx: Trouble Writing Memory Block at 0x0 on Page 0 of Length 0x2: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.407.3)
C28xx: File Loader: Verification failed: Target failed to write 0x00000@Program
C28xx: GEL: File: E:\TI\workspace\SAI_INV\Debug\SAI_INV.out: Load failed.
一开始我以为是芯片自锁了 换了一片 一样有这个问题,.cmd文件和.gel文件都是从CONTROLSIUT上COPY下来的,
另外发现XRS复位脚一直是低电平,电路没用问题 XRS上有上拉电阻
我看到网上很多人碰到这个问题 但没有说怎么解决的。。请大神帮帮忙
