IE60730 文件
28035关于IEC60730的codestart中POST一直失败,为什么啊 28035_IEC60730_FLASH.cmd文件已经添加,IEC60730.lib和头文件已经添加
DSP2803x_CodeStartBranch_IEC60730.asm中POST(Power On Self-Test
;// FILE:  DSP2803x_CodeStartBranch.asm
;// TITLE: Branch for redirecting code execution after boot.
* Function: codestart section
* Description: Branch to code starting point
     .include "psa.inc"
     .cdecls  C,LIST,"IEC60730_Tests.h"
     .def _FLASH_test
     .ref _c_int00, __stack
     .global code_start
WD_DISABLE   .set 1  ;set to 1 to disable WD, else set to 0
vars_util   .usect "IEC60730_PASS_FAIL",3,1 ;vars on same data page
_PASS    .set vars_util+0
_FAIL    .set vars_util+1
_PART    .set vars_util+2
     .sect "EXPECTED_CRCs"
expectedCRC_M0M1RamTest  .long 0xD0329384 ;Common RAM CRC
expectedCRC_PIERamTest  .long 0x877078AB ;Common RAM CRC
expectedCRC_RomTest   .long 0xBC9BF741 ;Common ROM CRC
expectedCRC_OTPCalTest1  .long 0xCE722B22 ;Common OTPCal CRC
expectedCRC_OTPCalTest2  .long 0x241263EA ;Common OTPCal CRC
expectedCRC_OTPCalTest3  .long 0x788A932C ;Common OTPCal CRC
expectedCRC_RegsTest  .long 0x72D05672 ;Common CPU_REG CRC
expectedCRC_8k_L0RamTest_LOW .long 0x89E210D4 ;28035_28034_28033_28032 RAM CRC
expectedCRC_8k_L0RamTest_HIGH .long 0x2ED5F855 ;28035_28034_28033_28032 RAM CRC
expectedCRC_6k_L0RamTest_LOW .long 0xBC4A8AC0 ;28035_28034_28033_28032 RAM CRC
expectedCRC_6k_L0RamTest_HIGH .long 0x2ED5F855 ;28035_28034_28033_28032 RAM CRC
expectedCRC_4k_L0RamTest_LOW .long 0xB795DDDC ;28035_28034_28033_28032 RAM CRC
expectedCRC_4k_L0RamTest_HIGH .long 0x2ED5F855 ;28035_28034_28033_28032 RAM CRC
expectedCRC_64k_FlashTest .long 0xDF09FFDE ;28035_28034 FLASH CRC
expectedCRC_32k_FlashTest .long 0xB2AD181F ;28033_28032_28031 FLASH CRC
expectedCRC_16k_FlashTest .long 0xEB1C544B ;28030 FLASH CRC
    .sect "codestart"
code_start:
    .if WD_DISABLE == 1
        LB wd_disable       ;Branch to watchdog disable code
    .else
        LB _c_int00         ;Branch to start of boot.asm in RTS library
    .endif
;end codestart section
* Function: wd_disable
* Description: Disables the watchdog timer
    .if WD_DISABLE == 1
    .text
wd_disable:
    SETC OBJMODE        ;Set OBJMODE for 28x object code
    EALLOW              ;Enable EALLOW protected register access
    MOVZ DP, #7029h>>6  ;Set data page for WDCR register
    MOV @7029h, #0068h  ;Set WDDIS bit in WDCR to disable WD
    EDIS                ;Disable EALLOW protected register access
RAM_Common_Testing:
    MOVZ  DP, #_PASS  ;Set data page
 MOV  @_PASS, #1
 MOV  @_FAIL, #0
 MOV  @SP, #__stack
 ;32-bit CRC returned in ACC, On passed test PASS=0 and FAIL!=0
 TEST_RAM  M0M1_START_ADDR, M0M1_END_ADDR, expectedCRC_M0M1RamTest
 TEST_RAM  PIE_START_ADDR, PIE_END_ADDR, expectedCRC_PIERamTest
Part_Identification:
; check the PART ID register location
 MOVL  XAR7, #0x3D7FFF
 MOVL ACC, *XAR7
    MOVZ  DP, #_PART  ;Set data page
 MOV  @_PART, AH
 ;TRUE for both 0xBF and 0xBE, PARTNO_28035PN and PARTNO_28035PAG
 ;TRUE for both 0xBB and 0xBA, PARTNO_28034PN and PARTNO_28034PAG
 CMP  @_PART, #PARTNO_28034PAG
 B  Test_28035_28034,GEQ
 ;TRUE for both 0xB6 and 0xB7, PARTNO_28033PAG and PARTNO_28033PN
 ;TRUE for both 0xB2 and 0xB3, PARTNO_28032PAG and PARTNO_28032PN
 CMP  @_PART, #PARTNO_28032PAG
 B  Test_28032_28033,GEQ
 ;TRUE for both 0xAE and 0xAF, PARTNO_28031PAG and PARTNO_28031PN
 CMP  @_PART, #PARTNO_28031PAG
 B  Test_28031,GEQ
 ;TRUE for both 0xAA and 0xAB, PARTNO_28030PAG and PARTNO_28030PN
 CMP  @_PART, #PARTNO_28030PAG
 B  Test_28030,GEQ
Test_28035_28034:
 TEST_RAM L0RAM_8k_START_ADDR_LOW, L0RAM_8k_END_ADDR_LOW,  expectedCRC_8k_L0RamTest_LOW ;8k_L0RamTest address map 1
 TEST_RAM L0RAM_8k_START_ADDR_HIGH, L0RAM_8k_END_ADDR_HIGH,  expectedCRC_8k_L0RamTest_HIGH ;8k_L0RamTest address map 2
 CRC_CALC FLASH_START_ADDR_64k, FLASH_END_ADDR_64k,    expectedCRC_64k_FlashTest  ;32k_FlashTest
 LB NonRAM_Common_TESTS
Test_28032_28033:
 CRC_CALC FLASH_START_ADDR_32k_3x, FLASH_END_ADDR_32k_3x,  expectedCRC_32k_FlashTest  ;32k_FlashTest
Test_28031:
 TEST_RAM L0RAM_6k_START_ADDR_LOW, L0RAM_6k_END_ADDR_LOW,  expectedCRC_6k_L0RamTest_LOW ;6k_L0RamTest address map 1
 TEST_RAM L0RAM_6k_START_ADDR_HIGH, L0RAM_6k_END_ADDR_HIGH, expectedCRC_6k_L0RamTest_HIGH ;6k_L0RamTest address map 2
Test_28030:
 TEST_RAM L0RAM_4k_START_ADDR_LOW, L0RAM_4k_END_ADDR_LOW,  expectedCRC_4k_L0RamTest_LOW ;4k_L0RamTest address map 1
 TEST_RAM L0RAM_4k_START_ADDR_HIGH, L0RAM_4k_END_ADDR_HIGH_3x,expectedCRC_4k_L0RamTest_HIGH ;4k_L0RamTest address map 2
 CRC_CALC FLASH_START_ADDR_16k, FLASH_END_ADDR_16k,    expectedCRC_16k_FlashTest  ;16k_FlashTest
NonRAM_Common_TESTS:
 CRC_CALC  ROM_START_ADDR_2803x, ROM_END_ADDR_2803x, expectedCRC_RomTest
 CRC_CALC  OTP_CAL_START_ADDR1, OTP_CAL_END_ADDR1,  expectedCRC_OTPCalTest1
 CRC_CALC  OTP_CAL_START_ADDR2, OTP_CAL_END_ADDR2,  expectedCRC_OTPCalTest2
 CRC_CALC  OTP_CAL_START_ADDR3, OTP_CAL_END_ADDR3,  expectedCRC_OTPCalTest3
 TEST_CPU_REGS            expectedCRC_RegsTest
PASS_TESTS:
   .endif
;C Run-time CRC Calculation, allow choice of address range to give user
;control over lenght test time and resulting time that interrupts are disabled.
_FLASH_test:
  PUSH DP:ST1 ; preserve original SPA bit in ST1
  ASP    ; Align stack just in case.
  ; push Save on Entry registers as specified by C conventions
  PUSH XAR1
  PUSH XAR2
  PUSH XAR3
  MOVL XAR3, ACC  ;  save start address passed parameter
  MOVL XAR2, *-SP[12] ;  save length passed parameter
  PSA_INIT_DRDB  ; claim PSA and initialize to 0
loop:
  ; preserve resources used in memory test
  PUSH XAR0
  PUSH XAR1
  ; preserve contents of status registers (mainly INTM and SPA)
   PUSH ST1
  PUSH ST0
  ; set status registers to a known state
  MOV *SP++,#0x024B ; ST1: ARP=0, XF=0, CNF=0, OBJMODE=1, AMODE=0,
       ; EALLOW=1, VMAP=1, PAGE0=0, DBGM=1, INTM=1
  MOV *SP++,#0x0080 ; ST0: OVC=0, PM = 1, V=0, N=0, Z=0, C=0, TC=0, OVM=0, SXM=0
  POP ST0   ; configure ST0
  POP ST1   ; configure ST1 (interrupts disabled, debug disabled, EALLOW enabled)
  ; ------------- start uninterruptible code --------------
     PSA_ON_DRDB   ; monitor DRDB
;  Read memory range, values on bus will be in CRC by PSA
  RPT  AR2
  || ADDL ACC, *XAR3++
  PSA_OFF_RELEASE
  POP ST0
  POP ST1     ; INTM is restored
  ; -------------- end uninterruptible code ---------------
  ; ------------- (interrupts serviced here) --------------
  POP  XAR1   ; restore resources
  POP  XAR0
  ; store CRC result in ACC
  EALLOW
  MOVL ACC, *+XAR4[2]
  EDIS
  ; pop Save on Entry registers as specified by C conventions
  POP  XAR3
  POP  XAR2
  POP  XAR1
  NASP     ; un-align stack just in case
  POP  DP:ST1   ; restore original SPA bit in ST1
  LRETR
 .end
 .end
;// End of file.
