save memory 文件头
请教下,通过CCS保存数据时,得到的.dat文件的第一行格式是怎样定义的?我想在自己的文件中加入这个文件头,从而将数据load memory.
  • 文件头为
    1651             1           80000000         0           10
    固定标识  数据格式     基地址           页类型       长度
    数据格式:1-十六进制  2-十进制  3-十进制长整型  4-十进制浮点型
    页类型:  0-数据   1-程序   ?
    长度:  装入数据的长度
  • 看这里,通过ccs->help content->Data File Formats
    The header information for data files uses this syntax:
    MagicNumber  Format StartingAddress PageNum Length [NewFormat]
    • MagicNumber—fixed at 1651.
    • Format—a number from 1 to 4, indicating the format of the samples in the file.
      This number represents a data format: (1) hexadecimal, (2) integer, (3) long, (4) float, or (9) Use new scheme
    • StartingAddress—starting address of the block that was saved.
    • PageNum—page number the block was taken from.
    • Length—number of samples in the block.
    • NewFormatFormat (9); the new scheme. This is optional when usign the legacy formats 1 - 4
