28035 HRPWM 汇编
求大神解释 解释:
_Epwm1_Isr:
; entry into Zero event Isr 进入零中断事件
;automatic context save :
;ST0,T,AL,AH,PL,PH,AR0,AR1,ST1,DP,IER,DBGSTAT,return address
;context save
ASP
MOVL *SP++,XAR7
SPM 0
NOP *,ARP7
CLRC PAGE0,OVM
SETC SXM
MOVW DP,#_IsrVars + _CPU_DP
MOVL XAR7,#_g_st_RunFlag ;g_st_RunFlag.bit0 = bModelONCtl=1:enable run; 0=disable run
TBIT *,#00
BF CHECKEND,NTC
TBIT *,#07 ;Check if ModelRunState>=3
BF DCPWMON,TC ; >=4(0x100)
TBIT *,#06 ; <4 (0x100)
BF CHECKEND,NTC ; <2 (0x010)
TBIT *,#05 ; >=2 (0x010)
BF CHECKEND,NTC ; =2
DCPWMON: ; >=3 softstart or normal
MOV AL,@_u16FlagFsFinal ;
CMP AL,#6
BF PWMUPDT,NEQ
MOVL XAR7,#_EPwm1Regs + _AQCSFRC
MOV *XAR7,#0x05 ; 0x0101 fprce low
MOVL XAR7,#_EPwm2Regs + _AQCSFRC
MOV *XAR7,#0x05
MOVL XAR7,#_EPwm3Regs + _AQCSFRC
MOV *XAR7,#0x05
MOVL XAR7,#_EPwm4Regs + _AQCSFRC
MOV *XAR7,#0x05
BF CHECKEND,UNC
PWMUPDT:
; MOVW DP,#_IsrVars + _CPU_DP
; MOV AL,@_u16FlagFsOld
; CMP AL,#6
; BF PWMUPDT1,NEQ
MOVL XAR7,#_EPwm1Regs + _AQCSFRC ; 0x0000:no effect
AND *,#0x00
AND *,#0x00
AND *,#0x00
AND *,#0x00
//频率
PWMUPDT1:
MOVL ACC,@_lDcdcPWMTs
MOVL XAR7,#_EPwm1Regs + _TBPRD
MOV *++,AH
MOV *,AL
MOVL XAR7,#_EPwm2Regs + _TBPRD
MOV *++,AH
MOV *,AL
MOVL XAR7,#_EPwm3Regs + _TBPRD
MOV *++,AH
MOV *,AL
MOVL XAR7,#_EPwm4Regs + _TBPRD
MOV *++,AH
MOV *,AL
//占空比
MOVL ACC,@_lManuDuty
MOVL XAR7,#_EPwm1Regs + _CMPA
MOV *--,AH
MOV *,AL
SUBL ACC,@_lManuDuty
MOVL XAR7,#_EPwm2Regs + _CMPA
MOV *--,AH
MOV *,AL
MOVL ACC,@_lDcdcDuty
MOVL XAR7,#_EPwm3Regs + _CMPA
MOV *--,AH
MOV *,AL
SUBL ACC,@_lDcdcDuty
MOVL XAR7,#_EPwm4Regs + _CMPA
MOV *--,AH
MOV *,AL
CHECKEND:
;MOVW DP,#_IsrVars + _CPU_DP
;MOV AL,@_u16FlagFsFinal
;MOV @_u16FlagFsOld,AL
MOVL XAR7,#_EPwm1Regs+_ETCLR
OR *,#0x0001 ; clear the event trigger flag
MOVL XAR7,#_EPwm1Regs+_ETSEL
AND *,#0xFFF7 ; bit3=0, disable the PWM1.INT
MOVL XAR7,#_EPwm1Regs+_ETPS
AND *,#0xFFFE ; INTPRD=0x10, Generate interrupt on second event
MOVL XAR7,#_PieCtrlRegs + _PIEACK
MOV *,#4
MOVL XAR7,*--SP
NASP
IRET
; _Epwm1_Isr end
.def _epwm1_tzint_isr
.sect "IsrRamfuncs"
.global _epwm1_tzint_isr
_epwm1_tzint_isr:
;context save
ASP
MOVL *SP++,XAR7
SPM 0
MOVL *SP++,XT
MOVL XAR7,#_EPwm1Regs+_AQCSFRC
MOV *XAR7,#0x05
MOVL XAR7,#_EPwm2Regs+_AQCSFRC
MOV *XAR7,#0x05
MOVL XAR7,#_EPwm5Regs+_AQCSFRC
MOV *XAR7,#0x05
MOVL XAR7,#_EPwm6Regs+_AQCSFRC
MOV *XAR7,#0x05
MOVW DP,#_PieCtrlRegs + _PIEIER2
AND @_PieCtrlRegs + _PIEIER2,#0xFFFE
MOVW DP,#_PieCtrlRegs + _PIEACK
MOV @_PieCtrlRegs + _PIEACK,#2
MOVL XT,*--SP
MOVL XAR7,*--SP
NASP
IRET
