RAMM0 和 RAMM1整合以后还是不够用怎么解决,
Other Parts Discussed in Thread: CONTROLSUITE
·          你好 ,我已经将RAMM0 和 RAMM1整合到一起,组成一个RAMM0M1的空间。
起始地址就是RAMM0的首地址,长度为RAMM0+RAMM1的总长度。
RAMM0M1     : origin = 0x000050, length = 0x0007B0
.stack            : > RAMM0M1,       PAGE = 1
.ebss             : > RAMM0M1,       PAGE = 1
不过由于程序中有个16*8的二维数组查表程序,RAMM0M1还是不够用,编译还是过不了,请问如何处理,谢谢!
试了 把.ebss 的地址设置为FLASHB ,但是程序不运行.
FLASHB      : origin = 0x3F4000, length = 0x001000     /* on-chip FLASH */
"../28035_FLASH_HVPM_Sensorless_CLA_lnk.cmd", line 129: error #10099-D: program
   will not fit into available memory.  run placement with alignment/blocking
   fails for section ".stack" size 0x300 page 1.  Available memory ranges:
   RAMM0M1      size: 0x7b0        unused: 0x2ce        max hole: 0x2ce
  • 优化一下吧。
    -o4, -mo
  • 之前已经优化到 -o4了还是这样的,能把.ebss 的地址设置为FLASHB或者其他大点的地址空间吗?
  • .ebss放到RAM中
  • 鸵鸟蝈蝈  你好
    能否详细点告诉 .ebss放到哪个RAM中?
    下面是我现在的 CMD.
     _Cla1Prog_Start = _Cla1funcsRunStart;
    --undef_sym=__cla_scratchpad_end
    --undef_sym=__cla_scratchpad_start
    MEMORY
    /*Program Space*/
    PAGE 0:
          RAML0     : origin = 0x008000, length = 0x000C00         /* on-chip RAM (L0+CLARAM0), previous RAML0     : origin = 0x008000, length = 0x000800  */
          RAML3     : origin = 0x009000, length = 0x001000     /* data RAM (L3) */
          OTP         : origin = 0x3D7800, length = 0x000400     /* on-chip OTP */
          FLASHH      : origin = 0x3E8000, length = 0x002000     /* on-chip FLASH */
          FLASHG      : origin = 0x3EA000, length = 0x002000     /* on-chip FLASH */
          FLASHF      : origin = 0x3EC000, length = 0x002000     /* on-chip FLASH */
          FLASHE      : origin = 0x3EE000, length = 0x002000     /* on-chip FLASH */
          FLASHD      : origin = 0x3F0000, length = 0x002000     /* on-chip FLASH */
          FLASHC      : origin = 0x3F2000, length = 0x002000     /* on-chip FLASH */
          FLASHA      : origin = 0x3F5000, length = 0x002F80     /* on-chip FLASH ,previous FLASHA      : origin = 0x3F6000, length = 0x001F80 */
          CSM_RSVD    : origin = 0x3F7F80, length = 0x000076     /* Part of FLASHA.  Program with all 0x0000 when CSM is in use. */
          BEGIN       : origin = 0x3F7FF6, length = 0x000002     /* Part of FLASHA.  Used for "boot to Flash" bootloader mode. */
          CSM_PWL     : origin = 0x3F7FF8, length = 0x000008     /* Part of FLASHA.  CSM password locations in FLASHA */
          IQTABLES    : origin = 0x3FE000, length = 0x000B50     /* IQ Math Tables in Boot ROM */
          IQTABLES2   : origin = 0x3FEB50, length = 0x00008C     /* IQ Math Tables in Boot ROM */
          IQTABLES3   : origin = 0x3FEBDC, length = 0x0000AA     /* IQ Math Tables in Boot ROM */
          BOOTROM     : origin = 0x3FF27C, length = 0x000D44     /* Boot ROM */
          RESET       : origin = 0x3FFFC0, length = 0x000002     /* part of boot ROM  */
          VECTORS     : origin = 0x3FFFC2, length = 0x00003E     /* part of boot ROM  */
    /*Data Space*/
    PAGE 1 :
          BOOT_RSVD   : origin = 0x000000, length = 0x000050     /* Part of M0, BOOT rom will use this for stack */
          //RAMM0       : origin = 0x000050, length = 0x0003B0     /* on-chip RAM block M0 */
          //RAMM1       : origin = 0x000400, length = 0x000400     /* on-chip RAM block M1 */
          RAMM0M1     : origin = 0x000050, length = 0x0007B0// length = 0x0007B0     /* on-chip RAM block M0 and M1 */
     /*   CLARAM0           : origin = 0x008800, length = 0x000400    */   /* on-chip RAM block L1, previous origin = 0x008800, length = 0x000400origin = 0x008C00, length = 0x000200*/
          CLARAM1           : origin = 0x008C00, length = 0x000400       /* on-chip RAM block L2,prevous  origin = 0x008E00, length = 0x000200 */
          CLA_CPU_MSGRAM  : origin = 0x001480, length = 0x000080 /* CLA-R/W, CPU-R message RAM */
          CPU_CLA_MSGRAM  : origin = 0x001500, length = 0x000080 /* CPU-R/W, CLA-R message RAM */
    SECTIONS
       /* Allocate program areas: */
       .cinit            : > FLASHA,     PAGE = 0
       .pinit            : > FLASHA,     PAGE = 0
       .text             : > FLASHA,     PAGE = 0
       codestart         : > BEGIN       PAGE = 0
       ramfuncs          : LOAD = FLASHD,
                           RUN = RAML0,
                           LOAD_START(_RamfuncsLoadStart),
                           LOAD_END(_RamfuncsLoadEnd),
                           RUN_START(_RamfuncsRunStart),
                           PAGE = 0
          Cla1Prog         : LOAD = FLASHC, /* Note for running from RAM the load and RUN can be the same */
                          RUN = RAML3,
                          LOAD_START(_Cla1funcsLoadStart),
                          LOAD_END(_Cla1funcsLoadEnd),
                          RUN_START(_Cla1funcsRunStart),
                          PAGE = 0
       csmpasswds        : > CSM_PWL     PAGE = 0
       csm_rsvd          : > CSM_RSVD    PAGE = 0
       /* Allocate uninitalized data sections: */
     //  .stack            : > RAMM0,      PAGE = 1
     //  .ebss             : > RAMM1,          PAGE = 1
        .stack            : > RAMM0M1,       PAGE = 1  //Steven 2012.9.26 combine RAMM0 and RAMM1
     //  .esysmem          : > RAMM1,      PAGE = 1
          .esysmem          : > RAMM0M1,      PAGE = 1 //Steven 2012.9.26 combine RAMM0 and RAMM1
       /* Initalized sections go in Flash */
       /* For SDFlash to program these, they must be allocated to page 0 */
       .econst           : > FLASHA      PAGE = 0
       .switch           : > FLASHA      PAGE = 0
       /* Allocate IQ math areas: */
       IQmath            : > FLASHD      PAGE = 0                  /* Math Code */
       IQmathTables      : > IQTABLES     PAGE = 0, TYPE = NOLOAD   /* Math Tables In ROM */
       Cla1ToCpuMsgRAM   : > CLA_CPU_MSGRAM PAGE = 1
       CpuToCla1MsgRAM   : > CPU_CLA_MSGRAM PAGE = 1
     /*ClaDataRam0          : > CLARAM0,              PAGE = 1 */
       ClaDataRam1          : > CLARAM1,              PAGE = 1
       CLAmathTables  : > CLARAM1,              PAGE = 1
       CLA1mathTables : > CLARAM1,              PAGE = 1
       // Must be allocated to memory the CLA has write access to
       CLAscratch       :
                            { *.obj(CLAscratch)
                            . += CLA_SCRATCHPAD_SIZE;
                            *.obj(CLAscratch_end) } > CLARAM1,  PAGE = 1  /*Previous CLARAM0*/
       .reset            : > RESET,      PAGE = 0, TYPE = DSECT
       vectors           : > VECTORS     PAGE = 0, TYPE = DSECT
     /* Uncomment the section below if calling the IQNexp() or IQexp()
          functions from the IQMath.lib library in order to utilize the
          relevant IQ Math table in Boot ROM (This saves space and Boot ROM
          is 1 wait-state). If this section is not uncommented, IQmathTables2
          will be loaded into other memory (SARAM, Flash, etc.) and will take
          up space, but 0 wait-state is possible.
       IQmathTables2    : > IQTABLES2, PAGE = 0, TYPE = NOLOAD
                  IQmath.lib<IQNexpTable.obj> (IQmathTablesRam)
       /* Uncomment the section below if calling the IQNasin() or IQasin()
       IQmathTables3    : > IQTABLES3, PAGE = 0, TYPE = NOLOAD
                  IQmath.lib<IQNasinTable.obj> (IQmathTablesRam)
  • 楼主
    你好!
    请注意.ebss为全局变量,变量只能放在RAM区。
    你有用CLA吗?如果没有用的话,可以将.ebss分配到RAML3段.
    原则上只要是RAM都可以用为.ebss。
    楼主可以看一下那个RAM段剩余空间多,就可以将.ebss分配给它。
    或者把.MAP文件贴上来,我帮你看一下将.ebss分配给哪个段合适。
  • Johnson Chen, 你好,谢谢你的回复,我们的程序是PMSM控制加PFC的,所以RAML3段已经用给CLA Prog RAM.
    我贴上来了.MAP文件,麻烦你帮我看一下如何分配新的扩大空间给.ebss,谢谢。
    我们在程序中有个16*8或者 16*16的二维常数数组查表用的,所以会导致 整合后的RAMM0M1 的空间也不够用,二维数组只能改成16*6时候才刚刚好,还是需要16*16的二维表的。
    _iq   array[16][16]或者 Const _iq
             name                      origin    length          used            unused   attr    fill
     RAMM0M1               00000050   000007b0  000007a2  0000000e  RWIX
       array[16][16]
                 TMS320C2000 Linker PC v6.1.0
    >> Linked Fri Sep 28 09:01:14 2012
    OUTPUT FILE NAME:   <Piccolo_CLA_TemplateProject.out>
    ENTRY POINT SYMBOL: "_c_int00"  address: 003f6aea
    MEMORY CONFIGURATION
    PAGE 0:
      RAML0                 00008000   00000c00  000008e0  00000320  RWIX
      RAML3                 00009000   00001000  00000448  00000bb8  RWIX
      OTP                   003d7800   00000400  00000000  00000400  RWIX
      FLASHH                003e8000   00002000  00000000  00002000  RWIX
      FLASHG                003ea000   00002000  00000000  00002000  RWIX
      FLASHF                003ec000   00002000  00000000  00002000  RWIX
      FLASHE                003ee000   00002000  00000000  00002000  RWIX
      FLASHD                003f0000   00002000  00000a46  000015ba  RWIX
      FLASHC                003f2000   00002000  00000448  00001bb8  RWIX
      FLASHA                003f5000   00002f80  000022c3  00000cbd  RWIX
      CSM_RSVD              003f7f80   00000076  00000000  00000076  RWIX
      BEGIN                 003f7ff6   00000002  00000002  00000000  RWIX
      CSM_PWL               003f7ff8   00000008  00000000  00000008  RWIX
      IQTABLES              003fe000   00000b50  00000b50  00000000  RWIX
      IQTABLES2             003feb50   0000008c  00000000  0000008c  RWIX
      IQTABLES3             003febdc   000000aa  00000000  000000aa  RWIX
      BOOTROM               003ff27c   00000d44  00000000  00000d44  RWIX
      RESET                 003fffc0   00000002  00000000  00000002  RWIX
      VECTORS               003fffc2   0000003e  00000000  0000003e  RWIX
    PAGE 1:
      BOOT_RSVD             00000000   00000050  00000000  00000050  RWIX
      DEV_EMU               00000880   00000105  00000004  00000101  RWIX
      SYS_PWR_CTL           00000985   00000003  00000003  00000000  RWIX
      FLASH_REGS            00000a80   00000060  00000008  00000058  RWIX
      CSM                   00000ae0   00000010  00000010  00000000  RWIX
      ADC_RESULT            00000b00   00000020  00000020  00000000  RWIX
      CPU_TIMER0            00000c00   00000008  00000008  00000000  RWIX
      CPU_TIMER1            00000c08   00000008  00000008  00000000  RWIX
      CPU_TIMER2            00000c10   00000008  00000008  00000000  RWIX
      PIE_CTRL              00000ce0   00000020  0000001a  00000006  RWIX
      PIE_VECT              00000d00   00000100  00000100  00000000  RWIX
      CLA1                  00001400   00000080  00000040  00000040  RWIX
      CLA_CPU_MSGRAM        00001480   00000080  00000006  0000007a  RWIX
      CPU_CLA_MSGRAM        00001500   00000080  00000005  0000007b  RWIX
      ECANA                 00006000   00000040  00000034  0000000c  RWIX
      ECANA_LAM             00006040   00000040  00000040  00000000  RWIX
      ECANA_MOTS            00006080   00000040  00000040  00000000  RWIX
      ECANA_MOTO            000060c0   00000040  00000040  00000000  RWIX
      ECANA_MBOX            00006100   00000100  00000100  00000000  RWIX
      COMP1                 00006400   00000020  00000014  0000000c  RWIX
      COMP2                 00006420   00000020  00000014  0000000c  RWIX
      COMP3                 00006440   00000020  00000014  0000000c  RWIX
      EPWM1                 00006800   00000040  00000040  00000000  RWIX
      EPWM2                 00006840   00000040  00000040  00000000  RWIX
      EPWM3                 00006880   00000040  00000040  00000000  RWIX
      EPWM4                 000068c0   00000040  00000040  00000000  RWIX
      EPWM5                 00006900   00000040  00000040  00000000  RWIX
      EPWM6                 00006940   00000040  00000040  00000000  RWIX
      EPWM7                 00006980   00000040  00000040  00000000  RWIX
      ECAP1                 00006a00   00000020  00000020  00000000  RWIX
      HRCAP1                00006ac0   00000020  00000000  00000020  RWIX
      HRCAP2                00006ae0   00000020  00000000  00000020  RWIX
      EQEP1                 00006b00   00000040  00000040  00000000  RWIX
      LINA                  00006c00   00000080  0000004a  00000036  RWIX
      GPIOCTRL              00006f80   00000040  00000040  00000000  RWIX
      GPIODAT               00006fc0   00000020  00000020  00000000  RWIX
      GPIOINT               00006fe0   00000020  0000000c  00000014  RWIX
      SYSTEM                00007010   00000020  00000020  00000000  RWIX
      SPIA                  00007040   00000010  00000010  00000000  RWIX
      SCIA                  00007050   00000010  00000010  00000000  RWIX
      NMIINTRUPT            00007060   00000010  00000010  00000000  RWIX
      XINTRUPT              00007070   00000010  00000010  00000000  RWIX
      ADC                   00007100   00000080  00000050  00000030  RWIX
      SPIB                  00007740   00000010  00000010  00000000  RWIX
      I2CA                  00007900   00000040  00000022  0000001e  RWIX
      CLARAM1               00008c00   00000400  0000014a  000002b6  RWIX
      PARTID                003d7e80   00000001  00000001  00000000  RWIX
      FLASHB                003f4000   00001000  00000000  00001000  RWIX
      CSM_PWL               003f7ff8   00000008  00000008  00000000  RWIX
    SECTION ALLOCATION MAP
     output                                  attributes/
    section   page    origin      length       input sections
    .pinit     0    003f5000    00000000     UNINITIALIZED
    ramfuncs   0    003f0000    000008e0     RUN ADDR = 00008000
                      003f0000    000008bf     HVPM_Sensorless_CLA-Main.obj (ramfuncs:retain)
                      003f08bf    0000001d     HVPM_Sensorless_CLA-DevInit_F2803x.obj (ramfuncs)
                      003f08dc    00000004     DSP2803x_usDelay.obj (ramfuncs)
    IQmath     0    003f08e0    00000166
                      003f08e0    00000088     IQmath.lib : IQ24atan2PU.obj (IQmath)
                      003f0968    00000047                : IQ15div.obj (IQmath)
                      003f09af    00000047                : IQ24div.obj (IQmath)
                      003f09f6    00000029                : IQ24sinPU.obj (IQmath)
                      003f0a1f    00000027                : IQ24cosPU.obj (IQmath)
    Cla1Prog   0    003f2000    00000448     RUN ADDR = 00009000
                      003f2000    00000448     HVPM_Sensorless_CLA-Tasks_C.obj (Cla1Prog:retain)
    .text      0    003f5000    00001d08
                      003f5000    00000bea     HVPM_Sensorless_CLA-Main.obj (.text)
                      003f5bea    000003fa     Drv_UART.obj (.text)
                      003f5fe4    0000023d     HVPM_Sensorless_CLA-DevInit_F2803x.obj (.text)
                      003f6221    00000203     FieldWeakening.obj (.text)
                      003f6424    000001bd     ADC_SOC_Cnf.obj (.text)
                      003f65e1    00000192     Drv_UART.obj (.text:retain)
                      003f6773    000000ad     HVPM_Sensorless_CLA-Main.obj (.text:retain)
                      003f6820    0000009e     rts2800_ml.lib : exp.obj (.text)
                      003f68be    00000083                    : fd_mpy.obj (.text)
                      003f6941    00000083                    : fs_div.obj (.text)
                      003f69c4    00000078                    : fs_add.obj (.text)
                      003f6a3c    0000005a                    : fs_mpy.obj (.text)
                      003f6a96    00000054     PWM_1ch_Cnf.obj (.text)
                      003f6aea    00000044     rts2800_ml.lib : boot.obj (.text)
                      003f6b2e    00000041                    : ldexp.obj (.text)
                      003f6b6f    0000003a     DSP2803x_CpuTimers.obj (.text)
                      003f6ba9    00000029     rts2800_ml.lib : fs_tol.obj (.text)
                      003f6bd2    00000025                    : fs_toi.obj (.text)
                      003f6bf7    0000001f                    : fd_tol.obj (.text)
                      003f6c16    0000001d                    : fs_tou.obj (.text)
                      003f6c33    0000001c                    : fs_tofd.obj (.text)
                      003f6c4f    0000001a                    : i_tofs.obj (.text)
                      003f6c69    00000019                    : args_main.obj (.text)
                      003f6c82    00000019                    : exit.obj (.text)
                      003f6c9b    00000019                    : prolog.obj (.text)
                      003f6cb4    00000017                    : fs_cmp.obj (.text)
                      003f6ccb    00000013                    : ul_tofs.obj (.text)
                      003f6cde    00000010                    : u_tofs.obj (.text)
                      003f6cee    0000000c                    : epilog.obj (.text)
                      003f6cfa    00000008     DSP2803x_CodeStartBranch.obj (.text)
                      003f6d02    00000005     HVPM_Sensorless_CLA-DevInit_F2803x.obj (.text:retain)
                      003f6d07    00000001     rts2800_ml.lib : _lock.obj (.text)
    .cinit     0    003f6d08    0000037f
                      003f6d08    0000035d     HVPM_Sensorless_CLA-Main.obj (.cinit)
                      003f7065    00000016     <whole-program> (.cinit)
                      003f707b    0000000a     rts2800_ml.lib : exit.obj (.cinit)
                      003f7085    00000002     --HOLE-- [fill = 0]
    .econst    0    003f7088    0000020c
                      003f7088    00000100     Drv_UART.obj (.econst:_auchCRCHi)
                      003f7188    00000100     Drv_UART.obj (.econst:_auchCRCLo)
                      003f7288    0000000c     HVPM_Sensorless_CLA-Main.obj (.econst)
    .switch    0    003f7294    00000030
                      003f7294    00000030     Drv_UART.obj (.switch:_GetRegisterVal)
    codestart
    *          0    003f7ff6    00000002
                      003f7ff6    00000002     DSP2803x_CodeStartBranch.obj (codestart)
    IQmathTables
    *          0    003fe000    00000b50     NOLOAD SECTION
                      003fe000    00000b50     IQmath.lib : IQmathTables.obj (IQmathTables)
    .reset     0    003fffc0    00000002     DSECT
                      003fffc0    00000002     rts2800_ml.lib : boot.obj (.reset)
    vectors    0    003fffc2    00000000     DSECT
    .ebss      1    00000050    000004a2     UNINITIALIZED
                      00000050    00000008     DSP2803x_CpuTimers.obj (.ebss)
                      00000058    00000004     rts2800_ml.lib : _lock.obj (.ebss)
                      0000005c    00000004                    : exit.obj (.ebss)
                      00000060    00000001                    : errno.obj (.ebss)
                      00000061    0000001f     --HOLE--
                      00000080    000002a2     HVPM_Sensorless_CLA-Main.obj (.ebss)
                      00000322    0000001e     --HOLE--
                      00000340    00000132     FieldWeakening.obj (.ebss)
                      00000472    0000000e     --HOLE--
                      00000480    00000072     Drv_UART.obj (.ebss)
    .stack     1    000004f2    00000300     UNINITIALIZED
                      000004f2    00000300     --HOLE--
    DevEmuRegsFile
    *          1    00000880    00000004     UNINITIALIZED
                      00000880    00000004     DSP2803x_GlobalVariableDefs.obj (DevEmuRegsFile)
    SysPwrCtrlRegsFile
    *          1    00000985    00000003     UNINITIALIZED
                      00000985    00000003     DSP2803x_GlobalVariableDefs.obj (SysPwrCtrlRegsFile)
    FlashRegsFile
    *          1    00000a80    00000008     UNINITIALIZED
                      00000a80    00000008     DSP2803x_GlobalVariableDefs.obj (FlashRegsFile)
    CsmRegsFile
    *          1    00000ae0    00000010     UNINITIALIZED
                      00000ae0    00000010     DSP2803x_GlobalVariableDefs.obj (CsmRegsFile)
    AdcResultFile
    *          1    00000b00    00000020     UNINITIALIZED
                      00000b00    00000020     DSP2803x_GlobalVariableDefs.obj (AdcResultFile)
    CpuTimer0RegsFile
    *          1    00000c00    00000008     UNINITIALIZED
                      00000c00    00000008     DSP2803x_GlobalVariableDefs.obj (CpuTimer0RegsFile)
    CpuTimer1RegsFile
    *          1    00000c08    00000008     UNINITIALIZED
                      00000c08    00000008     DSP2803x_GlobalVariableDefs.obj (CpuTimer1RegsFile)
    CpuTimer2RegsFile
    *          1    00000c10    00000008     UNINITIALIZED
                      00000c10    00000008     DSP2803x_GlobalVariableDefs.obj (CpuTimer2RegsFile)
    PieCtrlRegsFile
    *          1    00000ce0    0000001a     UNINITIALIZED
                      00000ce0    0000001a     DSP2803x_GlobalVariableDefs.obj (PieCtrlRegsFile)
    PieVectTableFile
    *          1    00000d00    00000100     UNINITIALIZED
                      00000d00    00000100     DSP2803x_GlobalVariableDefs.obj (PieVectTableFile)
    EmuKeyVar
    *          1    00000d00    00000001     UNINITIALIZED
                      00000d00    00000001     DSP2803x_GlobalVariableDefs.obj (EmuKeyVar)
    EmuBModeVar
    *          1    00000d01    00000001     UNINITIALIZED
                      00000d01    00000001     DSP2803x_GlobalVariableDefs.obj (EmuBModeVar)
    FlashCallbackVar
    *          1    00000d02    00000002     UNINITIALIZED
                      00000d02    00000002     DSP2803x_GlobalVariableDefs.obj (FlashCallbackVar)
    FlashScalingVar
    *          1    00000d04    00000002     UNINITIALIZED
                      00000d04    00000002     DSP2803x_GlobalVariableDefs.obj (FlashScalingVar)
    Cla1RegsFile
    *          1    00001400    00000040     UNINITIALIZED
                      00001400    00000040     DSP2803x_GlobalVariableDefs.obj (Cla1RegsFile)
    Cla1ToCpuMsgRAM
    *          1    00001480    00000006     UNINITIALIZED
                      00001480    00000006     HVPM_Sensorless_CLA-Tasks_C.obj (Cla1ToCpuMsgRAM)
    CpuToCla1MsgRAM
    *          1    00001500    00000005     UNINITIALIZED
                      00001500    00000005     HVPM_Sensorless_CLA-Tasks_C.obj (CpuToCla1MsgRAM)
    ECanaRegsFile
    *          1    00006000    00000034     UNINITIALIZED
                      00006000    00000034     DSP2803x_GlobalVariableDefs.obj (ECanaRegsFile)
    ECanaLAMRegsFile
    *          1    00006040    00000040     UNINITIALIZED
                      00006040    00000040     DSP2803x_GlobalVariableDefs.obj (ECanaLAMRegsFile)
    ECanaMOTSRegsFile
    *          1    00006080    00000040     UNINITIALIZED
                      00006080    00000040     DSP2803x_GlobalVariableDefs.obj (ECanaMOTSRegsFile)
    ECanaMOTORegsFile
    *          1    000060c0    00000040     UNINITIALIZED
                      000060c0    00000040     DSP2803x_GlobalVariableDefs.obj (ECanaMOTORegsFile)
    ECanaMboxesFile
    *          1    00006100    00000100     UNINITIALIZED
                      00006100    00000100     DSP2803x_GlobalVariableDefs.obj (ECanaMboxesFile)
    Comp1RegsFile
    *          1    00006400    00000014     UNINITIALIZED
                      00006400    00000014     DSP2803x_GlobalVariableDefs.obj (Comp1RegsFile)
    Comp2RegsFile
    *          1    00006420    00000014     UNINITIALIZED
                      00006420    00000014     DSP2803x_GlobalVariableDefs.obj (Comp2RegsFile)
    Comp3RegsFile
    *          1    00006440    00000014     UNINITIALIZED
                      00006440    00000014     DSP2803x_GlobalVariableDefs.obj (Comp3RegsFile)
    EPwm1RegsFile
    *          1    00006800    00000040     UNINITIALIZED
                      00006800    00000040     DSP2803x_GlobalVariableDefs.obj (EPwm1RegsFile)
    EPwm2RegsFile
    *          1    00006840    00000040     UNINITIALIZED
                      00006840    00000040     DSP2803x_GlobalVariableDefs.obj (EPwm2RegsFile)
    EPwm3RegsFile
    *          1    00006880    00000040     UNINITIALIZED
                      00006880    00000040     DSP2803x_GlobalVariableDefs.obj (EPwm3RegsFile)
    EPwm4RegsFile
    *          1    000068c0    00000040     UNINITIALIZED
                      000068c0    00000040     DSP2803x_GlobalVariableDefs.obj (EPwm4RegsFile)
    EPwm5RegsFile
    *          1    00006900    00000040     UNINITIALIZED
                      00006900    00000040     DSP2803x_GlobalVariableDefs.obj (EPwm5RegsFile)
    EPwm6RegsFile
    *          1    00006940    00000040     UNINITIALIZED
                      00006940    00000040     DSP2803x_GlobalVariableDefs.obj (EPwm6RegsFile)
    EPwm7RegsFile
    *          1    00006980    00000040     UNINITIALIZED
                      00006980    00000040     DSP2803x_GlobalVariableDefs.obj (EPwm7RegsFile)
    ECap1RegsFile
    *          1    00006a00    00000020     UNINITIALIZED
                      00006a00    00000020     DSP2803x_GlobalVariableDefs.obj (ECap1RegsFile)
    EQep1RegsFile
    *          1    00006b00    00000040     UNINITIALIZED
                      00006b00    00000040     DSP2803x_GlobalVariableDefs.obj (EQep1RegsFile)
    LinaRegsFile
    *          1    00006c00    0000004a     UNINITIALIZED
                      00006c00    0000004a     DSP2803x_GlobalVariableDefs.obj (LinaRegsFile)
    GpioCtrlRegsFile
    *          1    00006f80    00000040     UNINITIALIZED
                      00006f80    00000040     DSP2803x_GlobalVariableDefs.obj (GpioCtrlRegsFile)
    GpioDataRegsFile
    *          1    00006fc0    00000020     UNINITIALIZED
                      00006fc0    00000020     DSP2803x_GlobalVariableDefs.obj (GpioDataRegsFile)
    GpioIntRegsFile
    *          1    00006fe0    0000000c     UNINITIALIZED
                      00006fe0    0000000c     DSP2803x_GlobalVariableDefs.obj (GpioIntRegsFile)
    SysCtrlRegsFile
    *          1    00007010    00000020     UNINITIALIZED
                      00007010    00000020     DSP2803x_GlobalVariableDefs.obj (SysCtrlRegsFile)
    SpiaRegsFile
    *          1    00007040    00000010     UNINITIALIZED
                      00007040    00000010     DSP2803x_GlobalVariableDefs.obj (SpiaRegsFile)
    SciaRegsFile
    *          1    00007050    00000010     UNINITIALIZED
                      00007050    00000010     DSP2803x_GlobalVariableDefs.obj (SciaRegsFile)
    NmiIntruptRegsFile
    *          1    00007060    00000010     UNINITIALIZED
                      00007060    00000010     DSP2803x_GlobalVariableDefs.obj (NmiIntruptRegsFile)
    XIntruptRegsFile
    *          1    00007070    00000010     UNINITIALIZED
                      00007070    00000010     DSP2803x_GlobalVariableDefs.obj (XIntruptRegsFile)
    AdcRegsFile
    *          1    00007100    00000050     UNINITIALIZED
                      00007100    00000050     DSP2803x_GlobalVariableDefs.obj (AdcRegsFile)
    SpibRegsFile
    *          1    00007740    00000010     UNINITIALIZED
                      00007740    00000010     DSP2803x_GlobalVariableDefs.obj (SpibRegsFile)
    I2caRegsFile
    *          1    00007900    00000022     UNINITIALIZED
                      00007900    00000022     DSP2803x_GlobalVariableDefs.obj (I2caRegsFile)
    CLAscratch
    *          1    00008c00    00000100     UNINITIALIZED
                      00008c00    00000100     --HOLE--
    ClaDataRam1
    *          1    00008d00    0000004a     UNINITIALIZED
                      00008d00    0000004a     HVPM_Sensorless_CLA-Tasks_C.obj (ClaDataRam1)
    PartIdRegsFile
    *          1    003d7e80    00000001     UNINITIALIZED
                      003d7e80    00000001     DSP2803x_GlobalVariableDefs.obj (PartIdRegsFile)
    CsmPwlFile
    *          1    003f7ff8    00000008     UNINITIALIZED
                      003f7ff8    00000008     DSP2803x_GlobalVariableDefs.obj (CsmPwlFile)
    GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
    address    name
    003f5000   .text
    003f6c82   C$$EXIT
    003f68be   FD$$MPY
    003f6bf7   FD$$TOL
    003f69c9   FS$$ADD
    003f6cb4   FS$$CMP
    003f6941   FS$$DIV
    003f6a3c   FS$$MPY
    003f69c4   FS$$SUB
    003f6c33   FS$$TOFD
    003f6bd2   FS$$TOI
    003f6ba9   FS$$TOL
    003f6c16   FS$$TOU
    003f6c4f   I$$TOFS
    003f6cde   U$$TOFS
    003f6ccb   UL$$TOFS
    000001ea   _ACQPS
    003f6424   _ADC_SOC_CNF
    00007100   _AdcRegs
    00000b00   _AdcResult
    000000d6   _Advance_Angle
    0000008e   _Angle_Choice
    000000d8   _Angle_Comp
    000000ec   _Angle_Test
    000000b0   _BackTicker
    003f61c7   _CLA_C_Init
    00000210   _ChSel
    00009000   _Cla1Prog_Start
    00001400   _Cla1Regs
    000090f2   _Cla1Task1
    000090ea   _Cla1Task2
    000090e2   _Cla1Task3
    000090da   _Cla1Task4
    000090d2   _Cla1Task5
    000090ca   _Cla1Task6
    000090c2   _Cla1Task7
    00009000   _Cla1Task8
    003f2448   _Cla1funcsLoadEnd
    003f2000   _Cla1funcsLoadStart
    00009000   _Cla1funcsRunStart
    00000152   _Comp
    00006400   _Comp1Regs
    00006420   _Comp2Regs
    00006440   _Comp3Regs
    003f6b84   _ConfigCpuTimer
    00000050   _CpuTimer0
    00000c00   _CpuTimer0Regs
    00000c08   _CpuTimer1Regs
    00000c10   _CpuTimer2Regs
    003f5c9f   _Crc16
    003f7ff8   _CsmPwl
    00000ae0   _CsmRegs
    00008d32   _CurrentLoopCount
    00000138   _Current_OffsetA
    0000013a   _Current_OffsetB
    00000106   _Current_Speed
    00000085   _Current_U
    000000ee   _DC_BUS_Temp
    003f5be2   _DLOG_BuffInit
    000088dc   _DSP28x_usDelay
    00000081   _DeltaTheta
    00000880   _DevEmuRegs
    003f616c   _DeviceInit
    000000d2   _E0
    00006040   _ECanaLAMRegs
    000060c0   _ECanaMOTORegs
    00006080   _ECanaMOTSRegs
    00006100   _ECanaMboxes
    00006000   _ECanaRegs
    00006a00   _ECap1Regs
    00006800   _EPwm1Regs
    00006840   _EPwm2Regs
    00006880   _EPwm3Regs
    000068c0   _EPwm4Regs
    00006900   _EPwm5Regs
    00006940   _EPwm6Regs
    00006980   _EPwm7Regs
    00006b00   _EQep1Regs
    00000087   _ElecTheta
    00000d01   _EmuBMode
    00000d00   _EmuKey
    000000a2   _EnableFlag
    0000012c   _Estimat_Theta
    000000f2   _Estspeed_Temp
    003f62a5   _FWInit
    000000ca   _FW_idRef
    00000104   _FW_idRef_permillage
    00000341   _FWi
    00000340   _FWj
    00000380   _FdWeakParm
    00008d46   _FeedForward
    00001500   _Feedforward_ratio
    003f6221   _FieldWeakening
    000000e6   _FilterA
    00000144   _FilterATemp
    000000dc   _FilterB
    000000e2   _FilterBTemp
    000000da   _FilterC
    000000e0   _FilterCTemp
    00000a80   _FlashRegs
    00000d04   _Flash_CPUScaleFactor
    00000d02   _Flash_CallbackPtr
    000000c4   _For_Test_Count
    003f5ed1   _GetCoilVal
    003f5d36   _GetRegisterVal
    00006f80   _GpioCtrlRegs
    00006fc0   _GpioDataRegs
    00006fe0   _GpioIntRegs
    0000009d   _Gui_IpfcAvg
    000000ae   _Gui_VacLineAvg
    00000094   _Gui_VpfcOut
    00000098   _Gui_VpfcSet
    00001504   _Gui_Vref
    003f5307   _HVDMC_Protection
    000000ac   _HWTripFlagPFC
    00007900   _I2caRegs
    003fead8   _IQ10mpyRndSatTable
    003feacc   _IQ11mpyRndSatTable
    003feac0   _IQ12mpyRndSatTable
    003feab4   _IQ13mpyRndSatTable
    003feaa8   _IQ14mpyRndSatTable
    003fea9c   _IQ15mpyRndSatTable
    003fea90   _IQ16mpyRndSatTable
    003fea84   _IQ17mpyRndSatTable
    003fea78   _IQ18mpyRndSatTable
    003fea6c   _IQ19mpyRndSatTable
    003feb44   _IQ1mpyRndSatTable
    003fea60   _IQ20mpyRndSatTable
    003fea54   _IQ21mpyRndSatTable
    003fea48   _IQ22mpyRndSatTable
    003fea3c   _IQ23mpyRndSatTable
    003fea30   _IQ24mpyRndSatTable
    003fea24   _IQ25mpyRndSatTable
    003fea18   _IQ26mpyRndSatTable
    003fea0c   _IQ27mpyRndSatTable
    003fea00   _IQ28mpyRndSatTable
    003fe9f4   _IQ29mpyRndSatTable
    003feb38   _IQ2mpyRndSatTable
    003fe9e8   _IQ30mpyRndSatTable
    003feb2c   _IQ3mpyRndSatTable
    003feb20   _IQ4mpyRndSatTable
    003feb14   _IQ5mpyRndSatTable
    003feb08   _IQ6mpyRndSatTable
    003feafc   _IQ7mpyRndSatTable
    003feaf0   _IQ8mpyRndSatTable
    003feae4   _IQ9mpyRndSatTable
    003fe824   _IQatan2HalfPITable
    003fe862   _IQatan2Table
    003fe9e8   _IQatan2TableEnd
    003fe100   _IQcosTable
    003fe502   _IQcosTableEnd
    003fe502   _IQdivRoundSatTable
    003fe510   _IQdivTable
    003fe712   _IQdivTableEnd
    003fe712   _IQisqrtRoundSatTable
    003fe722   _IQisqrtTable
    003fe824   _IQisqrtTableEnd
    003fe9e8   _IQmpyRndSatTable
    003feb50   _IQmpyRndSatTableEnd
    003fe000   _IQsinTable
    003fe400   _IQsinTableEnd
    003fe712   _IQsqrtRoundSatTable
    003fe722   _IQsqrtTable
    003fe824   _IQsqrtTableEnd
    00008d40   _IRef
    003f6d02   _ISR_ILLEGAL
    0000010c   _IdRef
    00000095   _Index_Test_Data
    003f6b6f   _InitCpuTimers
    000088bf   _InitFlash
    003f608c   _InitGpio
    000000aa   _Init_IFlag
    003f607c   _IntOsc1Sel
    00008d42   _InvAvg
    00008d44   _InvAvgSqr
    00008d34   _Ipfc
    00001484   _IpfcAvg
    00008d38   _IpfcAvg_old
    00008d36   _Ipfc_filter
    00000112   _IqRef
    00000102   _IqRef_RampMax
    00000114   _IsrTicker
    00000086   _LED_counter
    00006c00   _LinaRegs
    0000008a   _Load_Start
    000000a5   _LockRotorFlag
    000000b9   _MPeriod
    00008000   _MainISR
    000000a9   _Major_Faults_Flag
    0000013e   _Max_Parking_Current
    000000f6   _Max_Theta_error_Swith
    003f606c   _MemCopy
    000000fa   _Min_Speed
    003f5cb6   _ModbusExcep
    00000097   _ModbusModule_Start_receive
    00000482   _ModbusModule_Status
    0000009a   _ModbusModule_TimeoutReg
    003f5f72   _ModbusRTUSlaveRun
    000000ab   _Motor_ON
    000000b6   _Motor_ON_Previous
    003f52cc   _Motor_PWM_OFF
    00007060   _NmiIntruptRegs
    0000008b   _OpenLoop_Ok
    00001503   _Output_Voltage_AD
    003f5bcc   _PFC_HW_Protection
    003f52b7   _PFC_OFF
    00001502   _PFC_ON
    000000b5   _PFC_ON_Previous
    000000be   _PFC_Over_Voltage_time
    003f5297   _PFC_Reset
    003f59c1   _PFC_voltage_ramp
    003f5273   _PIM_Reset
    000000bc   _PIM_Reset_ON
    003f603a   _PLLset
    003f6a96   _PWM_1ch_CNF
    0000011c   _Park_IdRef
    0000011e   _Park_IqRef
    00000148   _Park_VdRef
    00000140   _Park_VqRef
    00000130   _Parking_Delay
    0000008c   _Parking_Step
    0000008d   _Parking_Test_Count
    003d7e80   _PartIdRegs
    003f601b   _PieCntlInit
    00000ce0   _PieCtrlRegs
    00000d00   _PieVectTable
    003f600a   _PieVectTableInit
    003f5ccf   _PresetMultipleRegisters
    003f5d11   _PresetSingleRegister
    000000b7   _PwmDacCh1
    000000b2   _PwmDacCh2
    000000b1   _PwmDacCh3
    000000b4   _PwmDacCh4
    003f08e0   _RamfuncsLoadEnd
    003f0000   _RamfuncsLoadStart
    00008000   _RamfuncsRunStart
    0000048e   _RdataA
    00000483   _RdataA_Num
    003f5ee3   _ReadCoil
    003f5e6f   _ReadHoldRegisters
    0000009b   _Regerne_Over_Voltage_time
    003f5f3c   _ResolveModbus
    00000080   _RgOut
    00000082   _SMOTheta
    00007050   _SciaRegs
    003f5c82   _SciaTx_Response
    000004c0   _SdataA
    00000480   _SdataA_Num
    000000b8   _Sector
    00000088   _Sensorless_Ok
    003f6000   _ServiceDog
    003f5c26   _SetRegisterVal
    003f5b90   _Slide_Disshakes_Average_Filter
    0000009e   _SpeedLoopCount
    0000009f   _SpeedLoopPrescaler
    00000108   _SpeedRef
    000000f4   _SpeedRefRPM
    0000012a   _SpeedRpm
    00000128   _SpeedRpm_Qep
    00000089   _Speed_Choice
    000000ad   _Speed_Reg
    003f5b78   _Speed_Regulate
    00007040   _SpiaRegs
    00007740   _SpibRegs
    000000fc   _Startup_Lock_Cnt
    003f5ac1   _Switchover_CloseLoop
    003f59f3   _Switchover_CloseLoop_for_New_Drive
    00007010   _SysCtrlRegs
    00000985   _SysPwrCtrlRegs
    00000116   _T
    00000126   _Temp1
    000000a3   _TempCalibratedAngle
    00000099   _Test_Flag
    0000013c   _Test_Parking_Angle
    00000100   _Theta_error
    0000011a   _Tmp
    00000118   _TmpD
    00000124   _Tmp_fr
    00000230   _TrigSel
    00000481   _TxFifo_Time
    000000a1   _V_dc
    000000a0   _V_dc_time
    000000a8   _V_dc_total
    000000c6   _Va
    00001482   _VacLineAvg
    00008d3e   _VacLineAvg_old
    00008d3a   _VacLineRect
    00008d3c   _VacLineRect_filter
    000000c0   _Vb
    000000c8   _Vc
    000000d0   _VdTesting
    00008d30   _VoltageLoopCount
    00001480   _VpfcOut
    000000ce   _VqTesting
    00008d48   _Vref
    003f5ff8   _WDogDisable
    00007070   _XIntruptRegs
    003f5fe4   _XtalOscSel
    003f0968   __IQ15div
    003f08e0   __IQ24atan2PU
    003f0a1f   __IQ24cosPU
    003f09af   __IQ24div
    003f09f6   __IQ24sinPU
    000007f2   __STACK_END
    00000300   __STACK_SIZE
    00000001   __TI_args_main
    ffffffff   ___binit__
    ffffffff   ___c_args__
    003f6d08   ___cinit__
    003f6d08   ___etext__
    ffffffff   ___pinit__
    003f5000   ___text__
    003f6c69   __args_main
    00008d00   __cla_scratchpad_end
    00008c00   __cla_scratchpad_start
    0000005c   __cleanup_ptr
    0000005e   __dtors_ptr
    0000005a   __lock
    003f6d07   __nop
    000004f2   __stack
    00000058   __unlock
    003f6c82   _abort
    0000010a   _accele_slope
    003f7088   _auchCRCHi
    003f7188   _auchCRCLo
    003f6aea   _c_int00
    003f59a9   _checkzero
    0000015a   _clarke1
    003f6773   _cpu_timer0_isr
    00000110   _decele_slope
    00000220   _ePWM
    003f6cee   _epilog_c28x_1
    003f6cf2   _epilog_c28x_2
    00000060   _errno
    003f6c84   _exit
    003f6820   _exp
    00000134   _fcc
    000000e4   _fcc_DC
    0000010e   _fcc_Estspeed
    000000d4   _invE0
    000001dc   _ipark1
    00000136   _kc1
    000000de   _kc1_DC
    000000ea   _kc1_Estspeed
    00000132   _kc2
    000000f0   _kc2_DC
    000000e8   _kc2_Estspeed
    003f6b2e   _ldexp
    000000af   _lsw
    003f5353   _main
    003f503a   _motor_initial
    00000484   _nData4Test
    000001c0   _park1
    000000a4   _pfc_counter
    00008d00   _pi_i
    00008d18   _pi_v
    000002c0   _pid1_id
    00000280   _pid1_iq
    000002a0   _pid1_spd
    003f6c9b   _prolog_c28x_1
    003f6c9f   _prolog_c28x_2
    003f6ca7   _prolog_c28x_3
    00000162   _pwm1
    0000016a   _pwmdac1
    00000240   _qep1
    000000cc   _qep_Advance_Angle
    000000f8   _qep_Advance_Angle_Percent_Degree
    0000012e   _qep_Estimat_Theta
    000001ce   _rc1
    0000018c   _rc2
    0000019a   _rc3
    00000120   _rc_tmp
    00000091   _relay_off
    00000092   _relay_off_timedelay
    0000009c   _relay_on
    00000090   _relay_on_flag
    0000008f   _relay_on_timedelay
    003f5000   _relaycontrol
    00000180   _rg1
    003f6729   _sciaRxFifoIsr
    003f65e1   _sciaTxFifoIsr
    003f5bea   _scia_fifo_init
    00000300   _smo1
    000001a8   _smo1_const
    000000fe   _spd_Out_Current_Is
    00000252   _speed1
    00000200   _speed3
    00000174   _svgen_dq1
    000000c2   _t1
    00000146   _t2
    00000142   _temp_sv1
    00000122   _temp_sv2
    000000ba   _timebase_100ms
    000000bb   _timebase_10ms
    000000bd   _timebase_5ms
    00000083   _transmit_end_TimeoutReg
    00000084   _transmit_end_flag
    00000093   _vaczero_flag
    00000096   _vaczero_time
    00000264   _volt1
    000000a7   _voltage_ad
    ffffffff   binit
    003f6d08   cinit
    003f7ff6   code_start
    003f6d08   etext
    ffffffff   pinit
    GLOBAL SYMBOLS: SORTED BY Symbol Address
    address    name
    00000050   _CpuTimer0
    00000058   __unlock
    0000005a   __lock
    00000060   _errno
    00000080   _RgOut
    00000082   _SMOTheta
    00000085   _Current_U
    00000087   _ElecTheta
    00000091   _relay_off
    00000099   _Test_Flag
    0000009c   _relay_on
    000000a0   _V_dc_time
    000000a1   _V_dc
    000000ab   _Motor_ON
    000000ad   _Speed_Reg
    000000af   _lsw
    000000b1   _PwmDacCh3
    000000b2   _PwmDacCh2
    000000b4   _PwmDacCh4
    000000b7   _PwmDacCh1
    000000b8   _Sector
    000000b9   _MPeriod
    000000c0   _Vb
    000000c2   _t1
    000000c6   _Va
    000000c8   _Vc
    000000ca   _FW_idRef
    000000ce   _VqTesting
    000000d0   _VdTesting
    000000d2   _E0
    000000d4   _invE0
    000000da   _FilterC
    000000dc   _FilterB
    000000de   _kc1_DC
    000000e4   _fcc_DC
    000000e6   _FilterA
    000000f0   _kc2_DC
    000000fa   _Min_Speed
    00000108   _SpeedRef
    0000010c   _IdRef
    00000112   _IqRef
    00000114   _IsrTicker
    00000116   _T
    00000118   _TmpD
    0000011a   _Tmp
    00000120   _rc_tmp
    00000122   _temp_sv2
    00000124   _Tmp_fr
    00000126   _Temp1
    0000012a   _SpeedRpm
    00000132   _kc2
    00000134   _fcc
    00000136   _kc1
    00000142   _temp_sv1
    00000146   _t2
    00000152   _Comp
    0000015a   _clarke1
    00000162   _pwm1
    0000016a   _pwmdac1
    00000174   _svgen_dq1
    00000180   _rg1
    0000018c   _rc2
    0000019a   _rc3
    000001c0   _park1
    000001ce   _rc1
    000001dc   _ipark1
    000001ea   _ACQPS
    00000200   _speed3
    00000210   _ChSel
    00000220   _ePWM
    00000230   _TrigSel
    00000240   _qep1
    00000252   _speed1
    00000264   _volt1
    00000280   _pid1_iq
    000002a0   _pid1_spd
    000002c0   _pid1_id
    00000300   _smo1
    00000340   _FWj
    00000341   _FWi
    0000048e   _RdataA
    000004c0   _SdataA
    000004f2   __stack
    00000a80   _FlashRegs
    00000ae0   _CsmRegs
    00000b00   _AdcResult
    00000d00   _EmuKey
    00000d01   _EmuBMode
    00001400   _Cla1Regs
    00001480   _VpfcOut
    00001484   _IpfcAvg
    00001502   _PFC_ON
    00001504   _Gui_Vref
    00006000   _ECanaRegs
    00006400   _Comp1Regs
    00006420   _Comp2Regs
    00006440   _Comp3Regs
    00006800   _EPwm1Regs
    00006840   _EPwm2Regs
    00006880   _EPwm3Regs
    000068c0   _EPwm4Regs
    00006900   _EPwm5Regs
    00006940   _EPwm6Regs
    00006980   _EPwm7Regs
    00006a00   _ECap1Regs
    00006b00   _EQep1Regs
    00006c00   _LinaRegs
    00007040   _SpiaRegs
    00007050   _SciaRegs
    00007100   _AdcRegs
    00007740   _SpibRegs
    00007900   _I2caRegs
    00008000   _MainISR
    000088bf   _InitFlash
    00008d00   _pi_i
    00008d18   _pi_v
    00008d34   _Ipfc
    00008d40   _IRef
    00008d42   _InvAvg
    00008d44   _InvAvgSqr
    00008d48   _Vref
    00009000   _Cla1Task8
    000090c2   _Cla1Task7
    000090ca   _Cla1Task6
    000090d2   _Cla1Task5
    000090da   _Cla1Task4
    000090e2   _Cla1Task3
    000090ea   _Cla1Task2
    000090f2   _Cla1Task1
    003f0968   __IQ15div
    003f09af   __IQ24div
    003f5000   .text
    003f5000   ___text__
    003f5273   _PIM_Reset
    003f5297   _PFC_Reset
    003f52b7   _PFC_OFF
    003f5353   _main
    003f59a9   _checkzero
    003f5c9f   _Crc16
    003f5ee3   _ReadCoil
    003f603a   _PLLset
    003f606c   _MemCopy
    003f608c   _InitGpio
    003f62a5   _FWInit
    003f6820   _exp
    003f68be   FD$$MPY
    003f6941   FS$$DIV
    003f69c4   FS$$SUB
    003f69c9   FS$$ADD
    003f6a3c   FS$$MPY
    003f6aea   _c_int00
    003f6b2e   _ldexp
    003f6ba9   FS$$TOL
    003f6bd2   FS$$TOI
    003f6bf7   FD$$TOL
    003f6c16   FS$$TOU
    003f6c33   FS$$TOFD
    003f6c4f   I$$TOFS
    003f6c82   C$$EXIT
    003f6c82   _abort
    003f6c84   _exit
    003f6cb4   FS$$CMP
    003f6ccb   UL$$TOFS
    003f6cde   U$$TOFS
    003f6d07   __nop
    003f6d08   ___cinit__
    003f6d08   ___etext__
    003f6d08   cinit
    003f6d08   etext
    003f7088   _auchCRCHi
    003f7188   _auchCRCLo
    003f7ff6   code_start
    003f7ff8   _CsmPwl
    ffffffff   ___binit__
    ffffffff   ___pinit__
    ffffffff   binit
    ffffffff   pinit
    [406 symbols]
  • 楼主你好!
    可以将你的数组变量放到RAML0段去,方法可参考如下:
    #pragma DATA_SECTION(array,"mysect")
    _iq   array[16][16];
    然后在CMD文件中的section部分添加以下段:
    mysect           : > RAML0,          PAGE = 0
  • 使用-mo指令,可以将不使用的函数去掉
  • 您好,我想请教下你 CMD文件的配置,
    我直接用例程的CLA.CMD文件,会报错,说  _Cla1Prog_Start = _Cla1funcsRunStart; 未定义
    请问这是什么原因啊
  • 楼主你好!
    如果.CMD文件中包含 _Cla1Prog_Start = _Cla1funcsRunStart,那么请确保你的.CMD文件中包含下面这个段定义,楼主可以更新controlSUITE,里面有最新的CLA的C例程,楼主可以直接使用里面的CMD文件。楼主也可以将.CMD文件贴上来看一下!
       Cla1Prog            : LOAD = FLASHD,
                             RUN = RAML3,
                             LOAD_SIZE(_Cla1funcsLoadSize)
                             LOAD_SIZE(_Cla1funcsLoadSize),
                             PAGE = 0
  • 您好:
           我有下面这一段的,这个问题暂时解决了。现在出现这样的问题:
    undefined first referenced
    symbol in file
    下面是我的.CMD文件:
    MEMORY
    /*Program Space*/
    PAGE 0:
    RAML0 : origin = 0x008000, length = 0x000800 /* on-chip RAM (L0)*/
    // FLASHC : origin = 0x3F2000, length = 0x002000 /* on-chip FLASH */
    FLASHA : origin = 0x3F2000, length = 0x005F80 /* on-chip FLASH */
    /*Data Space*/
    PAGE 1 :
    RAMEBSS : origin = 0x3F8000, length = 0x3F8800
    CLARAM0 : origin = 0x008800, length = 0x000400 /* on-chip RAM block L1 */
    CLARAM1 : origin = 0x008C00, length = 0x000400 /* on-chip RAM block L2 */
    // FLASHB : origin = 0x3F4000, length = 0x002000 /* on-chip FLASH */
    SECTIONS
    RUN = RAML0,
    PAGE = 0
    Cla1Prog : LOAD = FLASHA, /* Note for running from RAM the load and RUN can be the same */
    RUN = RAML3,
    PAGE = 0
    .ebss : > RAMEBSS, PAGE = 1
    CLAscratch :
    { *.obj(CLAscratch)
    *.obj(CLAscratch_end) } > CLARAM0, PAGE = 1
  • 我直接用里面的CMD也出现:
    symbol in file
  • 外部RAM接口,可以扩展RAM!
  • mysect           : > RAML0,          PAGE = 0
    请问一下,把数组array分配到段mysect里面,mysect应该是在PAGE 1吧,不是PAGE 0,也就是DATA。
x 出现错误。请重试或与管理员联系。
